path: root/arch/arm/cpu/tegra124-common
2014-04-17ARM: tegra: Tegra124 pinmux cleanupStephen Warren
This renames all the pinmux pins, drive groups, and functions so they have a prefix which matches the type name. These lists are also auto- generated using scripts that were also used to generate the kernel pinctrl drivers. This ensures that the lists are consistent between the two. The entries in tegra124_pingroups[] are all updated to remove the columns which are no longer used. All affected code is updated to match. There are differences in the set of drive groups. I have validated this against the TRM. There are differences order of pin definitions in pinmux.c; these previously had significant mismatches with the correct order:-( I adjusted a few entries in pinmux-config-venice2.h since the set of legal functions for some pins was updated to match the TRM. Signed-off-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Tom Warren <twarren@nvidia.com>
2014-04-17ARM: tegra: pinmux naming consistency fixesStephen Warren
Clean up the naming of pinmux-related objects: * Refer to drive groups rather than pad groups to match the Linux kernel. * Ensure all pinmux API types are prefixed with pmux_, values (defines) are prefixed with PMUX_, and functions prefixed with pinmux_. * Modify a few type names to make their content clearer. * Minimal changes to SoC-specific .h/.c files are made so the code still compiles. A separate per-SoC change will be made immediately following, in order to keep individual patch size down. Signed-off-by: Stephen Warren <swarren@nvidia.com> Acked-by: Simon Glass <sjg@chromium.org> Signed-off-by: Tom Warren <twarren@nvidia.com>
2014-04-17ARM: tegra: pinctrl: remove duplicationStephen Warren
Much of arch/arm/cpu/tegra*-common/pinmux.c is identical. Remove the duplication by creating pinmux-common.c for all the identical code. This leaves: * arch/arm/include/asm/arch-tegra*/pinmux.h defining only the names of the various pins/pin groups, drive groups, and mux functions. * arch/arm/cpu/tegra*-common/pinmux.c containing only the lookup table stating which pin groups support which mux functions. The code in pinmux-common.c is semantically identical to that in the various original pinmux.c, but had some consistency and cleanup fixes applied during migration. I removed the definition of struct pmux_tri_ctlr, since this is different between SoCs (especially Tegra20 vs all others), and it's much simpler to deal with this via the new REG/MUX_REG/... defines. spl.c, warmboot.c, and warmboot_avp.c needed updates due to this, since they previously hijacked this struct to encode the location of some non-pinmux registers. Now, that code simply calculates these register addresses directly using simple and obvious math. I like this method better irrespective of the pinmux code cleanup anyway. Signed-off-by: Stephen Warren <swarren@nvidia.com> Acked-by: Simon Glass <sjg@chromium.org> Signed-off-by: Tom Warren <twarren@nvidia.com>
2014-04-17ARM: tegra: pinctrl: remove vddioStephen Warren
This field isn't used anywhere, so remove it. Note that PIN() macros are left unchanged for now, to avoid many diffs to them; later commits will completely rewrite them just one time. Signed-off-by: Stephen Warren <swarren@nvidia.com> Acked-by: Simon Glass <sjg@chromium.org> Signed-off-by: Tom Warren <twarren@nvidia.com>
2014-04-17ARM: tegra: pinctrl: remove func_safeStephen Warren
2014-02-03ARM: tegra: Add CPU (armv7) files for Tegra124Tom Warren
These files are for code that runs on the CPU (A15) on Tegra124 boards. At this time, there is no A15-specific code here. The warmboot/LP0 files aren't included as that code hasn't been ported yet. Signed-off-by: Tom Warren <twarren@nvidia.com> Signed-off-by: Stephen Warren <swarren@nvidia.com> Tested-by: Thierry Reding <treding@nvidia.com> Signed-off-by: Tom Warren <twarren@nvidia.com>
