path: root/arch/arm/cpu/s3c44b0/timer.c
2013-09-19ARM: s3c44b0: remove remainders of dead boardMasahiro Yamada
Because commit 5dc5f36 removed B2 board support, arch/arm/cpu/s3c44b0/* and arch/arm/include/asm/arch-s3c44b0/* are not necessary anymore. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Wolfgang Denk <wd@denx.de> Cc: Andrea Scian <andrea.scian@dave-tech.it>
2011-07-26Timer: Remove reset_timer_masked()Graeme Russ
In some circumstances, reset_timer_masked() was called be timer_init() in order to perform architecture specific timer initialisation. In such cases, the required code in reset_timer_masked() has been moved into timer_init()
2011-07-26Timer: Remove reset_timer() for non-Nios2 archesGraeme Russ
2011-07-26Timer: Remove set_timer completelyGraeme Russ
2010-04-13arm: Move cpu/$CPU to arch/arm/cpu/$CPUPeter Tyser
