path: root/arch/arm/cpu/pxa/start.S
2016-03-27pxa: start.S: enable SRAM clockVasily Khoruzhick
SRAM is used for early stack, but kernel disables its clock on suspend. Re-enable SRAM clock on startup, otherwise u-boot crashes on resume from suspend. Signed-off-by: Vasily Khoruzhick <anarsoul@gmail.com>
2016-02-29ARM: start.S: fix typoYuichiro Goto
Fix typo in comment about position of 'A' bit in several start.S. Signed-off-by: Yuichiro Goto <goto.yuichiro@espark.co.jp>
2015-03-24remove unnecessary version.h includesRob Herring
Various files are needlessly rebuilt every time due to the version and build time changing. As version.h is not actually needed, remove the include. Signed-off-by: Rob Herring <robh@kernel.org> Cc: Albert Aribaud <albert.u.boot@aribaud.net> Cc: Stefano Babic <sbabic@denx.de> Cc: Minkyu Kang <mk7.kang@samsung.com> Cc: Marek Vasut <marex@denx.de> Cc: Tom Warren <twarren@nvidia.com> Cc: Michal Simek <monstr@monstr.eu> Cc: Macpaul Lin <macpaul@andestech.com> Cc: Wolfgang Denk <wd@denx.de> Cc: York Sun <yorksun@freescale.com> Cc: Stefan Roese <sr@denx.de> Cc: Nobuhiro Iwamatsu <iwamatsu@nigauri.org> Cc: Simon Glass <sjg@chromium.org> Cc: Philippe Reynes <tremyfr@yahoo.fr> Cc: Eric Jarrige <eric.jarrige@armadeus.org> Cc: "David Müller" <d.mueller@elsoft.ch> Cc: Phil Edworthy <phil.edworthy@renesas.com> Cc: Robert Baldyga <r.baldyga@samsung.com> Cc: Torsten Koschorrek <koschorrek@synertronixx.de> Cc: Anatolij Gustschin <agust@denx.de> Reviewed-by: Linus Walleij <linus.walleij@linaro.org> Reviewed-by: Łukasz Majewski <l.majewski@samsung.com>
2014-05-15arm: move exception handling out of start.S filesAlbert ARIBAUD
Exception handling is basically identical for all ARM targets. Factorize it out of the various start.S files and into a single vectors.S file, and adjust linker scripts accordingly. Signed-off-by: Albert ARIBAUD <albert.u.boot@aribaud.net>
2014-05-15arm: remove unused _end_vect and _vectors_end symbolsAlbert ARIBAUD
2014-05-15arm: pxa: move SP check from start.S to cpuinfo.cAlbert ARIBAUD
PXA start.S has a PXA (variant) specific check in start.S. Move it to cpuinfo.c. Signed-off-by: Albert ARIBAUD <albert.u.boot@aribaud.net> Acked-by: Marek Vasut <marex@denx.de>
2014-02-26arm: remove unneeded symbol offsets and _TEXT_BASEAlbert ARIBAUD
Remove the last uses of symbol offsets in ARM U-Boot. Remove some needless uses of _TEXT_BASE. Remove all _TEXT_BASE definitions. Signed-off-by: Albert ARIBAUD <albert.u.boot@aribaud.net>
2013-06-22pxa: turn icache off in cpu_init_crit()Mike Dunn
The comment in the low-level initialization function cpu_init_crit() says that the caches are being disabled, but (oddly) the icache is actually turned on. This is probably not a good idea prior to relocating code, so this patch turns it off. Tested on the pxa270. Signed-off-by: Mike Dunn <mikedunn@newsguy.com>
2013-05-30arm: factorize relocate_code routineAlbert ARIBAUD
Replace all relocate_code routines from ARM start.S files with a single instance in file arch/arm/lib/relocate.S. For PXA, this requires moving the dcache unlocking code from within relocate_code into c_runtime_cpu_setup. Signed-off-by: Albert ARIBAUD <albert.u.boot@aribaud.net> Reviewed-by: Benoît Thébaudeau <benoit.thebaudeau@advansee.com> Tested-by: Simon Glass <sjg@chromium.org>
2013-05-30arm: do not compile relocate_code() for SPL buildsAlbert ARIBAUD
2013-04-13BUGFIX: arm: data abort in get_bad_stack_swiTetsuyuki Kobayashi
When swi instruction is executed, it is expected to get message "software interrupt" in console and dump registers and reboot, as do_software_interrupt() in arch/arm/lib/interrupts.c. But, actually it causes data abort accessing wrong address in get_bad_stack_swi macro in arch/arm/cpu/v7/start.S. This patch fixes this problem. The same mistake in arch/arm/cpu/{arm1136,arm1176,pxa}/start.S. Signed-off-by: Tetsuyuki Kobayashi <koba@kmckk.co.jp>
2013-04-12arm: Remove unused relocate_code() parametersBenoît Thébaudeau
Commit e05e5de7fae5bec79617e113916dac6631251156 made the 2 1st parameters of ARM's relocate_code() useless since it moved the code handling them to crt0.S. So, drop these parameters. Signed-off-by: Benoît Thébaudeau <benoit.thebaudeau@advansee.com>
2013-04-12arm: relocate_code(): Use __image_copy_end for end of relocationBenoît Thébaudeau
Use __image_copy_end instead of __bss_start for the end of the image to relocate. This is the same as commit 033ca72, but applied to all ARM start.S. This is a more appropriate symbol naming for an image copy & relocate feature, and this also saves a useless copy of data put between __image_copy_end and __bss_start in linker scripts (e.g. relocation information, or MMU initialization tables used only before jumping to the relocated image). Signed-off-by: Benoît Thébaudeau <benoit.thebaudeau@advansee.com>
2013-04-12arm: relocate_code(): Remove useless relocation offset computationBenoît Thébaudeau
2013-04-12arm: relocate_code() is no longer noreturnBenoît Thébaudeau
Commit e05e5de7fae5bec79617e113916dac6631251156 made ARM's relocate_code() return to its caller, but it did not update its declaration accordingly. Fixing this function declaration fixes dropped C code following calls to relocate_code(). Signed-off-by: Benoît Thébaudeau <benoit.thebaudeau@advansee.com>
2013-04-12arm: start.S: Fix _TEXT_BASE for SPLBenoît Thébaudeau
_TEXT_BASE must be set to CONFIG_SPL_TEXT_BASE for generic SPL, and to CONFIG_SYS_TEXT_BASE for non-SPL builds. Signed-off-by: Benoît Thébaudeau <benoit.thebaudeau@advansee.com> Reviewed-by: Tom Rini <trini@ti.com>
2013-03-15Replace __bss_end__ with __bss_endSimon Glass
Note this is a tree-wide change affecting multiple architectures. At present we use __bss_start, but mostly __bss_end__. This seems inconsistent and in a number of places __bss_end is used instead. Change to use __bss_end for the BSS end symbol throughout U-Boot. This makes it possible to use the asm-generic/sections.h file on all archs. Signed-off-by: Simon Glass <sjg@chromium.org>
2013-01-14pxa: Save lr register in relocate_code functionŁukasz Dałek
When u-boot is compiled for PXA25x processor, pxa/start.S is calling cpu_init_crit by BL instruction. BL is overwriting lr register so relocate_code is going into infinite loop. This patch preservs lr register in r12 before calling cpu_init_crit and after function returns restores it. Signed-off-by: Lukasz Dalek <luk0104@gmail.com> Acked-by: Marek Vasut <marex@denx.de>
2013-01-08arm: move C runtime setup code in crt0.SAlbert ARIBAUD
Move all the C runtime setup code from every start.S in arch/arm into arch/arm/lib/crt0.S. This covers the code sequence from setting up the initial stack to calling into board_init_r(). Also, rewrite the C runtime setup and make functions board_init_*() and relocate_code() behave according to normal C semantics (no jumping across the C stack any more, etc). Some SPL targets had to be touched because they use start.S explicitly or for some reason; the relevant maintainers and custodians are cc:ed. Signed-off-by: Albert ARIBAUD <albert.u.boot@aribaud.net>
2012-10-04arm: Fixed the offset for the no relocation.Zhong Hongbo
When the u-boot address of destination equal to __start, no relocation. relocation offset(r9) = 0. Signed-off-by: Zhong Hongbo <bocui107@gmail.com> Tested-by: Stefano Babic <sbabic@denx.de>
2012-07-20arm: Fix to mistake clean the memory spaceZhong Hongbo
In currently, when __bss_start is equal to __bss_end__, The bss loop will clear all the things in memory space. But just only when __bss_end__ greater than __bss_start__, we do the clear bss section operation. Signed-off-by: Zhong Hongbo <bocui107@gmail.com> Acked-by: Andreas Bießmann <andreas.devel@googlemail.com>
2011-12-06PXA: Rename CONFIG_PXA2[57]X to CONFIG_CPU_PXA2[57]XMarek Vasut
2011-12-06PXA: Re-add the Dcache locking as RAM for pxa250Marek Vasut
Signed-off-by: Marek Vasut <marek.vasut@gmail.com> Cc: Stefan Herbrechtsmeier <sherbrec@cit-ec.uni-bielefeld.de> Cc: Albert ARIBAUD <albert.u.boot@aribaud.net>
2011-12-06PXA: Rework start.S to be closer to other ARMsMarek Vasut
The start.S on PXA was very obscure. This reworks it back to be close to arm1136 start.S and others. Signed-off-by: Marek Vasut <marek.vasut@gmail.com> Cc: Albert ARIBAUD <albert.u.boot@aribaud.net> V2: Don't compile in relocation support if building SPL
2011-07-26replace CONFIG_PRELOADER with CONFIG_SPL_BUILDAneesh V
replace all occurences of CONFIG_PRELOADER with CONFIG_SPL_BUILD Signed-off-by: Aneesh V <aneesh@ti.com>
2011-03-27arm: fix incorrect monitor protection region in FLASHPo-Yu Chuang
Monitor protection region in FLASH did not cover .rel.dyn and .dynsym sections, because it uses __bss_start to compute monitor_flash_len. Use _end instead. Add _end to linker scripts for end of u-boot image Add _end_ofs to all the start.S. Signed-off-by: Po-Yu Chuang <ratbert@faraday-tech.com>
2011-03-27rename _end to __bss_end__Po-Yu Chuang
Currently, _end is used for end of BSS section. We want _end to mean end of u-boot image, so we rename _end to __bss_end__ first. Signed-off-by: Po-Yu Chuang <ratbert@faraday-tech.com>
2011-02-02ARM: */start.S: code cleanupLiu Hui-R64343
Remove the useless code from start.S Signed-off-by: Jason Liu <r64343@freescale.com> Tested-by: Andreas Bießmann <andreas.devel@googlemail.com>
2010-12-13ARM: */start.S: use canonical asm syntaxWolfgang Denk
Make code build with older tool chains. Signed-off-by: Wolfgang Denk <wd@denx.de>
2010-12-09arm: fixloop(): do not use r8 for relocationAndreas Bießmann
r8 is used for global_data and should therefore be left alone! For C code the compiler flag --fixed-r8 does the job, but in assembler we need to be aware of that fact. Signed-off-by: Andreas Biemann <andreas.devel@googlemail.com>
2010-12-09arm: relocate_code(): do not set register uselessAndreas Bießmann
In case we are still at relocation target address before relocation we do not need to load the registers needed for relocation. We should instead skip the whole relocation part and jump over to clear_bss immediately. Signed-off-by: Andreas Biemann <andreas.devel@googlemail.com>
2010-12-09arm: copy_loop(): use scratch registerAndreas Bießmann
This patch uses r1 as scratch register for copy_loop(). Therefore we do not longer need r7 for the storage of relocate_code()'s 'addr_moni' (the destination address of relocation). Therefore r7 can be used later on for other purposes. Signed-off-by: Andreas Biemann <andreas.devel@googlemail.com>
2010-12-08arm: add 8-byte alignment for ABI compliance before board_init_fHeiko Schocher
suggested from Daniel Hobi<daniel.hobi@schmid-telecom.ch> Tested on following boards: arm1136: qong armv7: omap3_beagle arm926ejs: magnesium, tx25 Signed-off-by: Heiko Schocher <hs@denx.de> cc: Daniel Hobi <daniel.hobi@schmid-telecom.ch> cc: Albert ARIBAUD <albert.aribaud@free.fr>
2010-10-29Merge branch 'for-wd-master' of git://git.denx.de/u-boot-pxaWolfgang Denk
2010-10-29Drop support for CONFIG_SKIP_RELOCATE_UBOOTWolfgang Denk
For ARM systems, before ELF relocation was introduced, CONFIG_SKIP_RELOCATE_UBOOT coul be used to prevent *COPYING* the U-Boot image from whereever it was loaded to it's link address (CONFIG_SYS_TEXT_BASE). The name was badly chosen, as no relocation was performed at all, it was just a memcpy(). With ELF relocation, this does not work like that any more, and related boards need to be fixed anyway. So don't keep this relict any longer. Signed-off-by: Wolfgang Denk <wd@denx.de> Tested-by: Heiko Schocher <hs@denx.de> Tested-by: Reinhard Meyer <u-boot@emk-elektronik.de>
2010-10-29Drop support for CONFIG_SYS_ARM_WITHOUT_RELOCWolfgang Denk
When this define was introduced, the idea was to provide a soft migration path for ARM boards to get adapted to the new relocation support. However, other recent changes led to a different implementation (ELF relocation), where this no longer works. By now CONFIG_SYS_ARM_WITHOUT_RELOC does not only not help any more, but it actually hurts because it obfuscates the actual code by sprinkling it with lots of dead and non-working debris. So let's make a clean cut and drop CONFIG_SYS_ARM_WITHOUT_RELOC. Signed-off-by: Wolfgang Denk <wd@denx.de> Tested-by: Heiko Schocher <hs@denx.de> Tested-by: Reinhard Meyer <u-boot@emk-elektronik.de>
2010-10-27arm/pxa: remove unused arch-pxa/macro.hMikhail Kshevetskiy
Signed-off-by: Mikhail Kshevetskiy <mikhail.kshevetskiy@gmail.com>
2010-10-26ARM: fix address setup in start.SDarius Augulis
Fix address setup bug for ARM. This bug stops u-boot booting if CONFIG_SKIP_RELOCATE_UBOOT is defined. Signed-off-by: Darius Augulis <augulis.darius@gmail.com>
2010-10-22PXA: Use pxa-regs.h register definitions in start.SMarek Vasut
2010-10-22PXA: Implement ELF relocationMarek Vasut
Based on patch by: Albert Aribaud <albert.aribaud@free.fr> Signed-off-by: Marek Vasut <marek.vasut@gmail.com>
2010-10-19PXA: Fix reloc, Push lowlevel init into C codeMarek Vasut
Firstly, this fixes relocation issues. I had to use part of Dcache as RAM for a while. I also moved around the lowlevel init code. It turned out so most of the lowlevel init code ended in cpu.c (and eventually was rewritten into C). This will also allow easier operation with FDT, multi-CPU-model support etc. in later releases. NOTE: This breaks most of the PXA boards (actually, the reloc stuff did already, this only finishes the doom). Signed-off-by: Marek Vasut <marek.vasut@gmail.com>
2010-10-11arm: bugfix: replace ble with blo in start.S filesAlbert Aribaud
Generalized misuse of ble within relocation and bss initialization loops caused one iteration too many. Instead of ble ('branch if lower or equal'), use blo ('branch if lower'). While we're at it, fix all 'addreee' typos. Signed-off-by: Albert Aribaud <albert.aribaud@free.fr>
2010-09-19ARM: implement relocation for pxaHeiko Schocher
Change the implementation for pxa to relocate the code to an arbitrary address in RAM. Portions of this work were supported by funding from the CE Linux Forum. Signed-off-by: Heiko Schocher <hs@denx.de>
2010-07-14PXA: Add OneNAND booting support to start.SMarek Vasut
2010-06-22ARM: Align stack to 8 bytesVitaly Kuzmichev
The ARM ABI requires that the stack be aligned to 8 bytes as it is noted in Procedure Call Standard for the ARM Architecture: http://infocenter.arm.com/help/topic/com.arm.doc.ihi0042d/index.html Unaligned SP also causes the problem with variable-length arrays allocation when VLA address becomes less than stack pointer during aligning of this address, so the next 'push' in the stack overwrites first 4 bytes of VLA. Signed-off-by: Vitaly Kuzmichev <vkuzmichev@mvista.com>
2010-06-13PXA: Align stack to 8 bytesMarek Vasut
Part of this patch is by: Mikhail Kshevetskiy. Stack must be aligned to 8 bytes on PXA (possibly all armv5te) for LDRD/STRD instructions. In case LDRD/STRD is issued on an unaligned address, the behaviour is undefined. The issue was observed when working with the NAND code, which was rendered disfunctional. Also, the vsprintf() function had serious problems with printing 64bit wide long longs. After aligning the stack, this wrong behaviour is no longer present. Tested on: Marvell Littleton PXA310 board Toradex Colibri PXA320 board Aeronix Zipit Z2 PXA270 handheld Voipac PXA270 board Signed-off-by: Marek Vasut <marek.vasut@gmail.com>
