path: root/arch/arm/cpu/ixp
2010-12-13ARM: */start.S: use canonical asm syntaxWolfgang Denk
Make code build with older tool chains. Signed-off-by: Wolfgang Denk <wd@denx.de>
2010-12-09arm: fixloop(): do not use r8 for relocationAndreas Bießmann
r8 is used for global_data and should therefore be left alone! For C code the compiler flag --fixed-r8 does the job, but in assembler we need to be aware of that fact. Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com>
2010-12-09arm: relocate_code(): do not set register uselessAndreas Bießmann
In case we are still at relocation target address before relocation we do not need to load the registers needed for relocation. We should instead skip the whole relocation part and jump over to clear_bss immediately. Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com>
2010-12-09arm: copy_loop(): use scratch registerAndreas Bießmann
This patch uses r1 as scratch register for copy_loop(). Therefore we do not longer need r7 for the storage of relocate_code()'s 'addr_moni' (the destination address of relocation). Therefore r7 can be used later on for other purposes. Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com>
2010-12-08arm: add 8-byte alignment for ABI compliance before board_init_fHeiko Schocher
suggested from Daniel Hobi<daniel.hobi@schmid-telecom.ch> Tested on following boards: arm1136: qong armv7: omap3_beagle arm926ejs: magnesium, tx25 Signed-off-by: Heiko Schocher <hs@denx.de> cc: Daniel Hobi <daniel.hobi@schmid-telecom.ch> cc: Albert ARIBAUD <albert.aribaud@free.fr>
2010-11-26arm: add ELF relocation support to rest of cpusAlbert Aribaud
bulk addition of ELF relocation support to ARM cpus arm946es, arm720t,arm920t, arm925t, arm_intcm, ixp, lh7a40x, s3c44b0, and sa1100. Signed-off-by: Albert Aribaud <albert.aribaud@free.fr>
2010-10-29Drop support for CONFIG_SKIP_RELOCATE_UBOOTWolfgang Denk
For ARM systems, before ELF relocation was introduced, CONFIG_SKIP_RELOCATE_UBOOT coul be used to prevent *COPYING* the U-Boot image from whereever it was loaded to it's link address (CONFIG_SYS_TEXT_BASE). The name was badly chosen, as no relocation was performed at all, it was just a memcpy(). With ELF relocation, this does not work like that any more, and related boards need to be fixed anyway. So don't keep this relict any longer. Signed-off-by: Wolfgang Denk <wd@denx.de> Tested-by: Heiko Schocher <hs@denx.de> Tested-by: Reinhard Meyer <u-boot@emk-elektronik.de>
2010-10-29Drop support for CONFIG_SYS_ARM_WITHOUT_RELOCWolfgang Denk
When this define was introduced, the idea was to provide a soft migration path for ARM boards to get adapted to the new relocation support. However, other recent changes led to a different implementation (ELF relocation), where this no longer works. By now CONFIG_SYS_ARM_WITHOUT_RELOC does not only not help any more, but it actually hurts because it obfuscates the actual code by sprinkling it with lots of dead and non-working debris. So let's make a clean cut and drop CONFIG_SYS_ARM_WITHOUT_RELOC. Signed-off-by: Wolfgang Denk <wd@denx.de> Tested-by: Heiko Schocher <hs@denx.de> Tested-by: Reinhard Meyer <u-boot@emk-elektronik.de>
2010-10-26ARM: use the same branch insn on all architecturesWolfgang Denk
For the "fixloop" implementation in start.S a number of different instructions was used. Unify code so all architectures use "blo" here because it is more robust in case of incorrect alignments. Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Albert ARIBAUD <albert.aribaud@free.fr> Cc: Minkyu Kang <mk7.kang@samsung.com> Cc: Sandeep Paulraj <s-paulraj@ti.com> Cc: Prafulla Wadaskar <prafulla@marvell.com> Cc: Stefano Babic <sbabic@denx.de> Cc: Marek Vasut <marek.vasut@gmail.com> Acked-by: Heiko Schocher <hs@denx.de>
2010-10-11arm: bugfix: replace ble with blo in start.S filesAlbert Aribaud
Generalized misuse of ble within relocation and bss initialization loops caused one iteration too many. Instead of ble ('branch if lower or equal'), use blo ('branch if lower'). While we're at it, fix all 'addreee' typos. Signed-off-by: Albert Aribaud <albert.aribaud@free.fr>
2010-09-28Merge branch 'next' of /home/wd/git/u-boot/nextWolfgang Denk
Conflicts: include/ppc4xx.h Signed-off-by: Wolfgang Denk <wd@denx.de>
2010-09-28ixp/npe: Remove duplicated commentThomas Weber
Signed-off-by: Thomas Weber <weber@corscience.de>
2010-09-19ARM: implement relocation for ixpHeiko Schocher
Change the implementation for ixp to relocate the code to an arbitrary address in RAM. Portions of this work were supported by funding from the CE Linux Forum. Signed-off-by: Heiko Schocher <hs@denx.de>
2010-08-09miiphy: constify device nameMike Frysinger
The driver name does not need to be writable, so constify it. Signed-off-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2010-06-22ARM: Align stack to 8 bytesVitaly Kuzmichev
The ARM ABI requires that the stack be aligned to 8 bytes as it is noted in Procedure Call Standard for the ARM Architecture: http://infocenter.arm.com/help/topic/com.arm.doc.ihi0042d/index.html Unaligned SP also causes the problem with variable-length arrays allocation when VLA address becomes less than stack pointer during aligning of this address, so the next 'push' in the stack overwrites first 4 bytes of VLA. Signed-off-by: Vitaly Kuzmichev <vkuzmichev@mvista.com>
2010-04-13arm: Move cpu/$CPU to arch/arm/cpu/$CPUPeter Tyser
