path: root/arch/arm/cpu/armv7/zynq/Makefile
2015-01-26ARM: zynq: Enable the Neon instructionsMichal Simek
Added the lowlevel_init to enable the Neon instructions. Initially the u-boot was causing undefined instruction exception if loaded through tcl, and working fine if loaded through FSBL. The exception was causing in convertion formula of given time to ticks. It was because, the Neon instructions were disabled and hence causing the undefined exception. In FSBL case, the FSBL was enabling the Neon instructions. Hence, added the lowlevel_init to enable the Neon instructions. Also enable neon instructions for non-xilinx toolchain. Signed-off-by: Siva Durga Prasad Paladugu <sivadur@xilinx.com> Acked-by: Radhey Shyam Pandey <radheys@xilinx.com> Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2014-02-19zynq: Add support for U-BOOT SPLMichal Simek
SPL is using ps7_init.c/h files which are generated from design tools which have to be copied to boards/xilinx/zynq folder before compilation. BSS section is moved to SDRAM because fat support requires more space than SRAM size. Added: - MMC and QSPI support - Boot OS directly from SPL - Enable SPL command Signed-off-by: Michal Simek <michal.simek@xilinx.com> Reviewed-by: Tom Rini <trini@ti.com>
2014-02-19zynq: Provide a framework to read clock frequenciesSoren Brinkmann
Signed-off-by: Soren Brinkmann <soren.brinkmann@xilinx.com> Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2013-10-31armv7: convert makefiles to Kbuild styleMasahiro Yamada
2013-08-12zynq: Add new ddrc driver for ECC supportMichal Simek
The first 1MB is not initialized by first stage bootloader. Check if memory is setup to 16bit mode and ECC is enabled. If it is, clear the first 1MB. Also u-boot should report only the half size of memory. Acked-by: Jagannadha Sutradharudu Teki <jaganna@xilinx.com> Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2013-02-07arm: zynq: Add SLCR support with system resetMichal Simek
The patch provides slcr base address initialization support and a support to reset the cpu through slcr driver, hence removed the reset_cpu() from board.c. Signed-off-by: Jagannadha Sutradharudu Teki <jaganna@xilinx.com> Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2012-10-04arm: Support new Xilinx Zynq platformMichal Simek
Add timer driver. Signed-off-by: Michal Simek <monstr@monstr.eu> CC: Joe Hershberger <joe.hershberger@gmail.com> CC: Marek Vasut <marex@denx.de> Acked-by: Marek Vasut <marex@denx.de>
