This arch does not seem to be supported / used at all in the current
U-Boot mainline source tree any more. So lets remove the core u8500 code
and code that was only referenced by this platform.
Please note that this patch also removes these config options:
- CONFIG_PL011_SERIAL_RLCR
- CONFIG_PL011_SERIAL_FLUSH_ON_INIT
As they only seem to be referenced by u8500 based boards. Without any
such board in the current code, these config option don't make sense
any more. Lets remove them as well.
If someone still wants to use this platform, then please send patches
to re-enable support by adding at least one board that references this
code.
Cc: Mathieu Poirier <mathieu.poirier@linaro.org>
Cc: John Rigby <john.rigby@linaro.org>
Cc: Albert Aribaud <albert.u.boot@aribaud.net>
Reviewed-by: Masahiro Yamada <yamada.masahiro@socionext.com>
[trini: Fixup common/cmd_io.c]
Following ARM's reference manuel for initializing the cache - the
kernel won't boot otherwise.
Signed-off-by: Mathieu Poirier <mathieu.poirier@linaro.org>
Signed-off-by: John Rigby <john.rigby@linaro.org>
Register mapping has changed on power control chip between
the first and second revision.
Functions such as providing power to the MMC device and reading
the processor version register should be in the cpu area for
access by multiple u8500-based boards.
Enabling timers and clocks in PRCMU and cleaning up mailbox.
