path: root/arch/arm/cpu/armv7/sunxi/cpu_info.c
2014-11-05sunxi: Use CONFIG_MACH_SUN?I from Kconfig instead of CONFIG_SUN?IIan Campbell
Mostly automatic with: sed -i -e 's/CONFIG_\(SUN[45678]I\)/CONFIG_MACH_\1/g' $(git grep -l CONFIG_SUN[45678]I) followed by removing the relevant #defines from include/configs/sun?i.h by hand. Signed-off-by: Ian Campbell <ijc@hellion.org.uk> Reviewed-by: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Hans de Goede <hdegoede@redhat.com>
2014-10-24ARM: sunxi: Add basic A23 supportChen-Yu Tsai
The basic blocks of the A23 are similar to the A31 (sun6i). Re-use sun6i code for initial clock, gpio, and uart setup. There is no SPL support for A23, as we do not have any documentation or sample code for DRAM initialization. Signed-off-by: Chen-Yu Tsai <wens@csie.org> Acked-by: Ian Campbell <ijc@hellion.org.uk>
2014-10-24ARM: sunxi: Add basic A31 supportMaxime Ripard
Add a new sun6i machine that supports UART and MMC. Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com> Signed-off-by: Hans de Goede <hdegoede@redhat.com> [wens@csie.org: use SPDX labels, adapt to Kconfig system, drop ifdef around mmc and smp code, drop MACH_TYPE] Signed-off-by: Chen-Yu Tsai <wens@csie.org> Acked-by: Ian Campbell <ijc@hellion.org.uk>
2014-07-06sunxi: Add sun5i supportHans de Goede
Add support for the Allwinner A13 and A10s SoCs also know as the Allwinner sun5i family, and the A13-OLinuXinoM A13 based and r7-tv-dongle A10s based boards. The only differences compared to the already supported sun4i and sun7i families are all in the DRAM controller initialization: -Different hcpr values -Different MBUS settings -Some other small initialization changes Signed-off-by: Henrik Nordstrom <henrik@henriknordstrom.net> Signed-off-by: Stefan Roese <sr@denx.de> Signed-off-by: Oliver Schinagl <oliver@schinagl.nl> Signed-off-by: Hans de Goede <hdegoede@redhat.com> Acked-by: Ian Campbell <ijc@hellion.org.uk>
2014-07-06sunxi: Add sun4i supportHans de Goede
Add support for the Allwinner A10 SoC also known as the Allwinner sun4i family, and add the Cubieboard board which uses the A10 SoC. Compared to sun7 only the DRAM controller is a bit different: -Controller reset bits are inverted, but only for Rev. A -Different hpcr values -No MBUS on sun4i -Various other initialization changes Signed-off-by: Henrik Nordstrom <henrik@henriknordstrom.net> Signed-off-by: Stefan Roese <sr@denx.de> Signed-off-by: Oliver Schinagl <oliver@schinagl.nl> Signed-off-by: Hans de Goede <hdegoede@redhat.com> Acked-by: Ian Campbell <ijc@hellion.org.uk>
2014-05-25sunxi: add sun7i cpu, board and start of day supportIan Campbell
This patch adds generic board, start of day and basic build system support for the Allwinner A20 (sun7i) processor. This code will not been compiled until the build is hooked up in a later patch. It has been split out to keep the patches manageable. Signed-off-by: Adam Sampson <ats@offog.org> Signed-off-by: Aleksei Mamlin <mamlinav@gmail.com> Signed-off-by: Alexandru Gagniuc <mr.nuke.me@gmail.com> Signed-off-by: Chen-Yu Tsai <wens@csie.org> Signed-off-by: Emilio López <emilio@elopez.com.ar> Signed-off-by: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Henrik Nordstrom <henrik@henriknordstrom.net> Signed-off-by: Jens Kuske <jenskuske@gmail.com> Signed-off-by: Luc Verhaegen <libv@skynet.be> Signed-off-by: Luke Leighton <lkcl@lkcl.net> Signed-off-by: Oliver Schinagl <oliver@schinagl.nl> Signed-off-by: Patrick Wood <patrickhwood@gmail.com> Signed-off-by: Stefan Roese <sr@denx.de> Signed-off-by: Wills Wang <wills.wang.open@gmail.com> Signed-off-by: Ian Campbell <ijc@hellion.org.uk> Reviewed-by: Marek Vasut <marex@denx.de> Cc: Tom Cubie <Mr.hipboi@gmail.com> Reviewed-by: Tom Rini <trini@ti.com>
