path: root/arch/arm/cpu/armv7/s5pc1xx
2011-07-04armv7: adapt s5pc1xx to the new cache maintenance frameworkAneesh V
adapt s5pc1xx to the new layered cache maintenance framework Signed-off-by: Aneesh V <aneesh@ti.com>
2011-05-26S5P: add set_mmc_clk for external clock controlJaehoon Chung
This patch added set_mmc_clk for external clock control. c210 didn't support host clock control. So We need external_clock_control function for c210. Signed-off-by: Jaehoon Chung <jh80.chung@samsung.com> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com>
2011-05-26S5P:SROM config code moved to s5p-common directoryChander Kashyap
SROM config code is made common for S5P series of boards. smdkc100.c now refers to s5p-common/sromc.c for SROM related subroutines. Signed-off-by: Chander Kashyap <chander.kashyap@linaro.org> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2011-02-02armv7: s5pc1xx: don't use function pointer for clock functionsMinkyu Kang
Because of the bss area is cleared after relocation, we've lost pointers. This patch fixed it. Signed-off-by: Minkyu Kang <mk7.kang@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com>
2010-08-30ARMV7: S5P: separate the peripheral clocksMinkyu Kang
Because of peripheral devices can select clock sources, separate the peripheral clocks. (pwm, uart and so on) It just return the pclk at s5pc1xx SoC, but s5pc210 SoC must be calculated by own clock register setting. Signed-off-by: Minkyu Kang <mk7.kang@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com>
2010-08-23ARMV7: S5P: rename from s5pc1xx to s5pMinkyu Kang
Because of these are common files around s5p Socs, rename from s5pc1xx to s5p. And getting cpu_id is SoC specific, so move to SoC's header file. Signed-off-by: Minkyu Kang <mk7.kang@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com>
2010-08-23ARMV7: S5P: make s5p-common for sharing the code between s5pc1xx and s5pc2xxMinkyu Kang
This patch adds basic support for s5pc210. s5p-common will be used by all of s5p SoCs. Signed-off-by: Minkyu Kang <mk7.kang@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com>
2010-08-17S5P: Use accessor functions instead of SoC specific defines to access the ↵Minkyu Kang
base address This patch is intended to prepare the other S5P SoC. (s5pc210) If use SoC specific defines then can't share with other SoC. So, make the accessor functions for access the base address by common way. Signed-off-by: Minkyu Kang <mk7.kang@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com>
2010-07-05ARM: Rename arch/arm/cpu/arm_cortexa8 to armv7Steve Sakoman
The purpose of this patch is to prepare for adding the OMAP4 architecture, which is Cortex A9 Cortex A8 and A9 both belong to the armv7 architecture, hence the name change. The two architectures are similar enough that substantial code can be shared. Signed-off-by: Aneesh V <aneesh@ti.com> Signed-off-by: Steve Sakoman <steve@sakoman.com> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
