path: root/arch/arm/cpu/armv7/s5p-common
2012-07-07Exynos: fix cpuinfo and cpu detectingMinkyu Kang
Since Exynos architecture have new SoCs, need to fix cpuinfo correctly. Signed-off-by: Minkyu Kang <mk7.kang@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Tested-by: Jaehoon Chung <jh80.chung@samsung.com> Cc: Chander Kashyap <chander.kashyap@linaro.org>
2012-02-12S5P: support generic watchdog timerMinkyu Kang
This patch adds support the generic watchdog timer for s5pc1xx and exynos4 Signed-off-by: Minkyu Kang <mk7.kang@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Cc: HeungJun, Kim <riverful.kim@samsung.com>
2011-11-16arch/arm/cpu/armv7/s5p-common/pwm.c: fix GCC 4.6 warningAnatolij Gustschin
Fix: pwm.c: In function 'pwm_config': pwm.c:85:16: warning: variable 'timer_rate_hz' set but not used [-Wunused-but-set-variable] Signed-off-by: Anatolij Gustschin <agust@denx.de>
2011-07-26Timer: Remove reset_timer() for non-Nios2 archesGraeme Russ
2011-07-26Timer: Remove set_timer completelyGraeme Russ
2011-05-26S5PC2XX: Support the cpu revisionMinkyu Kang
S5PC210 SoC have two cpu revisions, and have some difference. So, support the cpu revision for each revision. Signed-off-by: Minkyu Kang <mk7.kang@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com>
2011-05-26S5P:SROM config code moved to s5p-common directoryChander Kashyap
SROM config code is made common for S5P series of boards. smdkc100.c now refers to s5p-common/sromc.c for SROM related subroutines. Signed-off-by: Chander Kashyap <chander.kashyap@linaro.org> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2011-03-27S5P: timer: replace bss variable by gdMinkyu Kang
Use the global data instead of bss variable, replace as follow. count_value -> removed timestamp -> tbl lastdec -> lastinc Signed-off-by: Minkyu Kang <mk7.kang@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Acked-by: Albert ARIBAUD <albert.aribaud@free.fr>
2011-03-27S5P: timer: Use pwm functionsMinkyu Kang
Use pwm functions for timer that is PWM timer 4. Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2011-03-27ARM: S5P: pwm driver supportDonghwa Lee
This is common pwm driver of S5P. Signed-off-by: Donghwa Lee <dh09.lee@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2011-02-02armv7: s5pc1xx: don't use function pointer for clock functionsMinkyu Kang
Because of the bss area is cleared after relocation, we've lost pointers. This patch fixed it. Signed-off-by: Minkyu Kang <mk7.kang@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com>
2010-11-30Merge branch 'master' of git://git.denx.de/u-boot-samsungWolfgang Denk
2010-11-30ARMV7: S5P: timer: get the count_value from register when call udelayMinkyu Kang
Because of count_value is set to tcnb4 register, should be get from this register when call udelay function. Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2010-08-30ARMV7: S5P: separate the peripheral clocksMinkyu Kang
Because of peripheral devices can select clock sources, separate the peripheral clocks. (pwm, uart and so on) It just return the pclk at s5pc1xx SoC, but s5pc210 SoC must be calculated by own clock register setting. Signed-off-by: Minkyu Kang <mk7.kang@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com>
2010-08-23ARMV7: S5P: rename from s5pc1xx to s5pMinkyu Kang
Because of these are common files around s5p Socs, rename from s5pc1xx to s5p. And getting cpu_id is SoC specific, so move to SoC's header file. Signed-off-by: Minkyu Kang <mk7.kang@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com>
2010-08-23ARMV7: S5P: make s5p-common for sharing the code between s5pc1xx and s5pc2xxMinkyu Kang
This patch adds basic support for s5pc210. s5p-common will be used by all of s5p SoCs. Signed-off-by: Minkyu Kang <mk7.kang@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com>
