path: root/arch/arm/cpu/armv7/omap3
2016-11-21arm: Introduce arch/arm/mach-omap2 for OMAP2 derivative platformsTom Rini
This moves what was in arch/arm/cpu/armv7/omap-common in to arch/arm/mach-omap2 and moves arch/arm/cpu/armv7/{am33xx,omap3,omap4,omap5} in to arch/arm/mach-omap2 as subdirectories. All refernces to the former locations are updated to the current locations. For the logic to decide what our outputs are, consolidate the tests into a single config.mk rather than including 4. Signed-off-by: Tom Rini <trini@konsulko.com>
2016-09-16Convert CONFIG_SPL_POWER_SUPPORT to KconfigSimon Glass
2016-09-16Convert CONFIG_SPL_LIBDISK_SUPPORT to KconfigSimon Glass
2016-09-16Convert CONFIG_SPL_FAT_SUPPORT to KconfigSimon Glass
2016-09-16Convert CONFIG_SPL_EXT_SUPPORT to KconfigSimon Glass
2016-08-05omap3: Drop omap3_evm_quick_* targetsTom Rini
These config targets were added well before the Kconfig migration began as a way to demonstrate how to make these platforms work with cut down features. At this point in time they no longer serve a good purpose so remove them. Signed-off-by: Tom Rini <trini@konsulko.com>
2016-08-05omap3: Move to select SUPPORT_SPL for allTom Rini
In reality all omap3 platforms support SPL so move the select for this up a level. Signed-off-by: Tom Rini <trini@konsulko.com>
2016-07-22armv7: simplify identify_nand_chipLadislav Michl
Use newly introduced function Signed-off-by: Ladislav Michl <ladis@linux-mips.org>
2016-07-22armv7: add reset timeout to identify_nand_chipLadislav Michl
identify_nand_chip hangs forever in loop when NAND is not present. As IGEPv2 comes either with NAND or OneNAND flash, add reset timeout to let function fail gracefully allowing caller to know NAND is not present. On NAND equipped board, reset succeeds on first read, so 1000 loops seems to be safe timeout. Signed-off-by: Ladislav Michl <ladis@linux-mips.org>
2016-06-09mtd: nand: omap: allow to switch to BCH16Heiko Schocher
support in omap_nand_switch_ecc() also an eccstrength from 16. Signed-off-by: Heiko Schocher <hs@denx.de>
2016-04-01sniper: Change vendor name from lge to lg, matching devicetree vendor prefixPaul Kocialkowski
This moves the sniper board from the lge to lg, in order to match the devicetree vendor prefix already defined in the kernel. Signed-off-by: Paul Kocialkowski <contact@paulk.fr>
2016-03-15omap3: Use a define for reboot reason offsetPaul Kocialkowski
This introduces a define for the offset to the reboot reason, rather than hardcoding it. Signed-off-by: Paul Kocialkowski <contact@paulk.fr> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-03-15omap3: String-based reboot mode handlingPaul Kocialkowski
This switches reboot mode handling to a string-based interface, that allows more flexibility to set a common interface with the next generations of OMAP devices. Signed-off-by: Paul Kocialkowski <contact@paulk.fr> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-02-29sniper: Various minor cleanups, missing Kconfig configs and reorganisationPaul Kocialkowski
This introduces some minor cleanups, regarding aspects such as board name, code and headers organization as well as deprecated and missing config options. Signed-off-by: Paul Kocialkowski <contact@paulk.fr> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-02-08OMAP3_LOGIC: Setup defconfig to enable SPL and NAND bootingAdam Ford
The defconfig patch will enable the the SPL and NAND settings. The update to Kconfig will allow the SPL to configured in and built. Signed-off-by: Derald D. Woods <woods.technical@gmail.com> Signed-off-by: Adam Ford <aford173@gmail.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2015-10-22omap-common: Common function to display die id, replacing omap3-specific versionPaul Kocialkowski
This introduces omap_die_id_display to display the full die id. There is no need to store it in an environment variable, that no boot script is using anyway. Signed-off-by: Paul Kocialkowski <contact@paulk.fr> Reviewed-by: Tom Rini <trini@konsulko.com>
2015-10-22omap3: omap_die_id supportPaul Kocialkowski
This replaces the previous get_dieid definition with omap_die_id, that matches the common omap_die_id definition. Signed-off-by: Paul Kocialkowski <contact@paulk.fr> Reviewed-by: Tom Rini <trini@konsulko.com>
2015-09-11arm: Remove omap3_sdp3430 boardSimon Glass
This board has not been converted to generic board by the deadline. Remove it. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-09-11arm: Remove omap3_mvblx boardSimon Glass
2015-09-11arm: Remove dig297 boardSimon Glass
2015-09-02Convert omap3_logic to ti_omap3_common.hAdam Ford
Convert to using the common config files. Signed-off-by: Adam Ford <adam.ford@logicpd.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2015-08-12gpio: omap: Drop 'method' parameterTom Rini
The "method" parameter was part of the original port of the driver from the kernel. At some point this may have been added to allow for future differentiation (as omap1 and omap2 have different GPIO IP blocks, so this wasn't an unreasonable thing to do). At this point however it's just extra overhead, so drop. Signed-off-by: Tom Rini <trini@konsulko.com>
2015-08-12LG Optimus Black (P970) codename sniper supportPaul Kocialkowski
The LG Optimus Black (P970) codename sniper is a smartphone that was designed and manufactured by LG Electronics (LGE) and released back in 2011. It is using an OMAP3630 SoC GP version, which allows running U-Boot and the U-Boot SPL from the ground up. This port is aimed at running an Android version such as Replicant, the fully free Android distribution. However, support for upstream Linux with device-tree and common GNU/Linux distros boot commands could be added in the future. For more information about the journey to freeing this device, please read the series of blog posts at: http://code.paulk.fr/article20/a-hacker-s-journey-freeing-a-phone-from-the-ground-up-first-part Signed-off-by: Paul Kocialkowski <contact@paulk.fr> Reviewed-by: Tom Rini <trini@konsulko.com> [trini: Add CONFIG_OF_SUPPORT] Signed-off-by: Tom Rini <trini@konsulko.com>
2015-08-12omap3: Reboot mode supportPaul Kocialkowski
Reboot mode is written in scratchpad memory before reboot in the form of a single char, that is the first letter of the reboot mode string as passed to the reboot function. This mechanism is supported on OMAP3 both my the upstream kernel and by various TI kernels. It is up to each board to make use of this mechanism or not. Signed-off-by: Paul Kocialkowski <contact@paulk.fr> Reviewed-by: Tom Rini <trini@konsulko.com>
2015-07-27omap3: CONFIG_REVISION_TAG ifdef check for get_board_revPaul Kocialkowski
Despite being defined with __weak, this declaration of get_board_rev will conflict with the fallback one when ONFIG_REVISION_TAG is not defined. Signed-off-by: Paul Kocialkowski <contact@paulk.fr> Reviewed-by: Tom Rini <trini@konsulko.com>
2015-07-27omap3: Definitions for SYS_BOOT-based fallback boot device selectionPaul Kocialkowski
This introduces code to read the value of the SYS_BOOT pins on the OMAP3, as well as the memory-preferred scheme for the interpretation of each value. Signed-off-by: Paul Kocialkowski <contact@paulk.fr>
2015-07-27omap-common: Common boot code OMAP3 support and cleanupPaul Kocialkowski
This introduces OMAP3 support for the common omap boot code, as well as a major cleanup of the common omap boot code. First, the omap_boot_parameters structure becomes platform-specific, since its definition differs a bit across omap platforms. The offsets are removed as well since it is U-Boot's coding style to use structures for mapping such kind of data (in the sense that it is similar to registers). It is correct to assume that romcode structure encoding is the same as U-Boot, given the description of these structures in the TRMs. The original address provided by the bootrom is passed to the U-Boot binary instead of a duplicate of the structure stored in global data. This allows to have only the relevant (boot device and mode) information stored in global data. It is also expected that the address where the bootrom stores that information is not overridden by the U-Boot SPL or U-Boot. The save_omap_boot_params is expected to handle all special cases where the data provided by the bootrom cannot be used as-is, so that spl_boot_device and spl_boot_mode only return the data from global data. All of this is only relevant when the U-Boot SPL is used. In cases it is not, save_boot_params should fallback to its weak (or board-specific) definition. save_omap_boot_params should not be called in that context either. Signed-off-by: Paul Kocialkowski <contact@paulk.fr>
2015-05-12arch: Make board selection choices optionalJoe Hershberger
By making the board selections optional, every defconfig will include the board selection when running savedefconfig so if a new board is added to the top of the list of choices the former top's defconfig will still be correct. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> Cc: Masahiro Yamada <yamada.masahiro@socionext.com> Acked-by: Stephen Warren <swarren@wwwdotorg.org> Cc: Tom Rini <trini@konsulko.com>
2015-04-18dm: select CONFIG_DM* optionsMasahiro Yamada
As mentioned in the previous commit, adding default values in each Kconfig causes problems because it does not co-exist with the "depends on" syntax. (Please note this is not a bug of Kconfig.) We should not do so unless we have a special reason. Actually, for CONFIG_DM*, we have no good reason to do so. Generally, CONFIG_DM is not a user-configurable option. Once we convert a driver into Driver Model, the board only works with Driver Model, i.e. CONFIG_DM must be always enabled for that board. So, using "select DM" is more suitable rather than allowing users to modify it. Another good thing is, Kconfig warns unmet dependencies for "select" syntax, so we easily notice bugs. Actually, CONFIG_DM and other related options have been added without consistency: some into arch/*/Kconfig, some into board/*/Kconfig, and some into configs/*_defconfig. This commit prefers "select" and cleans up the following issues. [1] Never use "CONFIG_DM=n" in defconfig files It is really rare to add "CONFIG_FOO=n" to disable CONFIG options. It is more common to use "# CONFIG_FOO is not set". But here, we do not even have to do it. Less than half of OMAP3 boards have been converted to Driver Model. Adding the default values to arch/arm/cpu/armv7/omap3/Kconfig is weird. Instead, add "select DM" only to appropriate boards, which eventually eliminates "CONFIG_DM=n", etc. [2] Delete redundant CONFIGs Sandbox sets CONFIG_DM in arch/sandbox/Kconfig and defines it again in configs/sandbox_defconfig. Likewise, OMAP3 sets CONFIG_DM arch/arm/cpu/armv7/omap3/Kconfig and defines it also in omap3_beagle_defconfig and devkit8000_defconfig. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2015-03-28malloc_f: enable SYS_MALLOC_F by default if DM is onMasahiro Yamada
This option has a bool type, not hex. Fix it and enable it if CONFIG_DM is on because Driver Model always requires malloc memory. Devices are scanned twice, before/after relocation. CONFIG_SYS_MALLOC_F should be enabled to use malloc memory before relocation. As it is board-independent, handle it globally. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Acked-by: Stephen Warren <swarren@wwwdotorg.org> Reviewed-by: Simon Glass <sjg@chromium.org> Acked-by: Robert Baldyga <r.baldyga@samsung.com>
2015-03-28malloc_f: remove redundant defalut values of CONFIG_SYS_MALLOC_F_LENMasahiro Yamada
The default value of CONFIG_SYS_MALLOC_F_LEN is defined by ./Kconfig as 0x400. Each defconfig or Kconfig need not repeat the same value. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Acked-by: Stephen Warren <swarren@wwwdotorg.org> Reviewed-by: Simon Glass <sjg@chromium.org> Acked-by: Robert Baldyga <r.baldyga@samsung.com>
2015-03-24remove unnecessary version.h includesRob Herring
Various files are needlessly rebuilt every time due to the version and build time changing. As version.h is not actually needed, remove the include. Signed-off-by: Rob Herring <robh@kernel.org> Cc: Albert Aribaud <albert.u.boot@aribaud.net> Cc: Stefano Babic <sbabic@denx.de> Cc: Minkyu Kang <mk7.kang@samsung.com> Cc: Marek Vasut <marex@denx.de> Cc: Tom Warren <twarren@nvidia.com> Cc: Michal Simek <monstr@monstr.eu> Cc: Macpaul Lin <macpaul@andestech.com> Cc: Wolfgang Denk <wd@denx.de> Cc: York Sun <yorksun@freescale.com> Cc: Stefan Roese <sr@denx.de> Cc: Nobuhiro Iwamatsu <iwamatsu@nigauri.org> Cc: Simon Glass <sjg@chromium.org> Cc: Philippe Reynes <tremyfr@yahoo.fr> Cc: Eric Jarrige <eric.jarrige@armadeus.org> Cc: "David Müller" <d.mueller@elsoft.ch> Cc: Phil Edworthy <phil.edworthy@renesas.com> Cc: Robert Baldyga <r.baldyga@samsung.com> Cc: Torsten Koschorrek <koschorrek@synertronixx.de> Cc: Anatolij Gustschin <agust@denx.de> Reviewed-by: Linus Walleij <linus.walleij@linaro.org> Reviewed-by: Łukasz Majewski <l.majewski@samsung.com>
2015-03-13ARM: OMAP3: rx51: Enable workaround for ARM errata 454179, 430973, 621766Nishanth Menon
RX51 has a secure logic which uses different parameters compared to traditional implementation. So, make the generic secure acr write over-ride-able by board file and refactor rx51 code to use this. While at it, enable the OMAP3 specific errata code for 454179, 430973, 621766. Signed-off-by: Nishanth Menon <nm@ti.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2015-03-13ARM: OMAP3: Enable workaround for ARM errata 454179, 430973, 621766Nishanth Menon
Enable the OMAP3 specific errata code for 454179, 430973, 621766 and while at it, remove legacy non-revision checked errata logic. Signed-off-by: Nishanth Menon <nm@ti.com> Tested-by: Matt Porter <mporter@konsulko.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2015-03-13ARM: OMAP3: Get rid of omap3_gp_romcode_call and replace with omap_smc1Nishanth Menon
omap_smc1 is now generic enough to remove duplicate omap3_gp_romcode_call logic that omap3 introduced. As part of this change, move to using the generic lowlevel_init.S for omap3 as well. Signed-off-by: Nishanth Menon <nm@ti.com> Tested-by: Matt Porter <mporter@konsulko.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2015-03-05omap: gpmc: 'nandecc sw' can use HAM1 or BCH8Ash Charles
The 'nandecc sw' command selects a software-based error correction algorithm. By default, this is OMAP_ECC_HAM1_CODE_SW but some platforms use OMAP_ECC_BCH8_CODE_HW_DETECTION_SW as their software-based correction algorithm. Allow a user to be specific e.g. # nandecc sw <hamming|bch8> where 'hamming' is still the default. Note: we don't just use CONFIG_NAND_OMAP_ECCSCHEME as it might be set to a hardware-based ECC scheme---a little strange when the user has requested 'sw' ECC. Signed-off-by: Ash Charles <ashcharles@gmail.com>
2015-03-05omap3: add support for QUIPOS Cairo board.Albert ARIBAUD \(3ADEV\)
This patch extends OMAP3 support for AM/DM37xx and introduces the AM3703-based Quipos Cairo board. Signed-off-by: Albert ARIBAUD (3ADEV) <albert.aribaud@3adev.fr> Reviewed-by: Simon Glass <sjg@chromium.org>
2015-03-04ti: armv7: Move SPL SDRAM init to the right place, drop unused CONFIG_SPL_STACKSimon Glass
Currently in some cases SDRAM init requires global_data to be available and soon this will not be available prior to board_init_f(). Adjust the code paths in these cases to be correct. In some cases we had the SPL stack be in DDR as we might have large stacks (due to Falcon Mode + Environment). In these cases switch to CONFIG_SPL_STACK_R. In other cases we had simply been setting CONFIG_SPL_STACK into SRAM. In these cases we no longer need to (CONFIG_SYS_INIT_SP_ADDR is used and is also in SRAM) so drop those lines. Signed-off-by: Simon Glass <sjg@chromium.org> Tested on Beagleboard, Beagleboard xM Tested-by: Matt Porter <mporter@konsulko.com> Tested on Beaglebone Black, AM43xx GP EVM, OMAP5 uEVM, OMAP4 Pandaboard Tested-by: Tom Rini <trini@konsulko.com> Signed-off-by: Tom Rini <trini@konsulko.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2015-02-24kconfig: remove unneeded dependency on !SPL_BUILDMasahiro Yamada
Now CONFIG_SPL_BUILD is not defined in Kconfig, so "!depends on SPL_BUILD" and "if !SPL_BUILD" are redundant. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2015-02-17Merge branch 'master' of http://git.denx.de/u-boot-sunxiTom Rini
2015-02-16arm: Allow lr to be saved by board codeSimon Glass
The link register value can be required on some boards (e.g. FEL mode on sunxi) so use a branch instruction to jump to save_boot_params() instead of a branch link. This requires a branch back to save_boot_params_ret so adjust the users to deal with this. For exynos just drop the function since it doesn't do anything. Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Siarhei Siamashka <siarhei.siamashka@gmail.com> Acked-by: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Hans de Goede <hdegoede@redhat.com>
2015-02-12dm: Kconfig: Move CONFIG_SYS_MALLOC_F_LEN to KconfigSimon Glass
Move this option to Kconfig and update all boards. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-02-12dm: omap3: Move driver model CONFIGs to KconfigSimon Glass
Remove driver model CONFIGs from the board config headers and use Kconfig instead. Signed-off-by: Simon Glass <sjg@chromium.org>
