path: root/arch/arm/cpu/armv7/mx5
2011-05-23MX53: Handle silicon revision 2.1 caseFabio Estevam
2011-04-27MX5: factor out boot cause funciton to common codeJason Liu
factor out boot cause function to common code to avoid the duplicate code in each board support package Signed-off-by: Jason Liu <jason.hui@linaro.org>
2011-02-02MX5: Reuse the gd->tbl value for timestamp and add gd->lastinc for lastinc bssStefano Babic
The usage of bss values in drivers before initialisation of bss is forbidden. In that special case some data in .rel.dyn gets corrupted. This patch is the same as recently applied for arm926js architecture. Signed-off-by: Stefano Babic <sbabic@denx.de> CC: Heiko Schocher <hs@denx.de>
2011-02-02MX5: Add initial support for MX53 processorLiu Hui-R64343
Add initial support for Freescale MX53 processor, - Add the iomux support and the pin definition, - Add the regs definition, clean up some unused def from mx51, - Add the low level init support, make use the freq input of setup_pll macro Signed-off-by: Jason Liu <r64343@freescale.com>
2010-12-21Move DECLARE_GLOBAL_DATA_PTR to file scopeJohn Rigby
It can be optimised out by the compiler otherwise resulting in obscure errors like a board not booting. This has been documented in README since 2006 when these were first fixed up for GCC 4.x. Signed-off-by: John Rigby <john.rigby@linaro.org> Fix some additional places. Signed-off-by: Wolfgang Denk <wd@denx.de> Acked-By: Albert ARIBAUD <albert.aribaud@free.fr>
2010-12-09Merge branch 'master' of git://git.denx.de/u-boot-imxWolfgang Denk
2010-11-21imx: Get fec mac address from fuseLiu Hui-R64343
The patch is to support getting FEC MAC address from fuse bank. Signed-off-by: Jason Liu <r64343@freescale.com> Tested-by: Stefano Babic <sbabic@denx.de>
2010-10-28MX51: remove warning in clock.cStefano Babic
The patch removes the warning: clock.c:291: warning: initialization from incompatible pointer type after constification of args[] Signed-off-by: Stefano Babic <sbabic@denx.de>
2010-10-28MX5:use common u-boot.lds of cpu layerJason Liu
Remove u-boot.lds from mx5 and use the common u-boot.lds of cpu layer. This patch also fix the building errors: arch/arm/cpu/armv7/start.o: In function `_rel_dyn_start_ofs': arch/arm/cpu/armv7/start.S:283: undefined reference to `__rel_dyn_start' arch/arm/cpu/armv7/start.o: In function `_rel_dyn_end_ofs': arch/arm/cpu/armv7/start.S:283: undefined reference to `__rel_dyn_end' arch/arm/cpu/armv7/start.o: In function `_dynsym_start_ofs': arch/arm/cpu/armv7/start.S:283: undefined reference to `__dynsym_start' Signed-off-by: Jason Liu <r64343@freescale.com>
2010-10-19MX5: Remove dead code with ENABLE_IMPRECISE_ABORTJason Liu
This code section is dead due to we never define ENABLE_IMPRECISE_ABORT for MX5 Signed-off-by: Jason Liu <r64343@freescale.com>
2010-10-18MX5: rename mx51 to mx5Jason Liu
Rename mx51 to mx5 in order to support more mx51 like-style SOCs such as MX53 and the followings. Signed-off-by: Jason Liu <r64343@freescale.com>
