path: root/arch/arm/cpu/armv7/mx5/clock.c
2014-01-03arm: mx5: Add fuse supply enable in fsl_iimSergey Alyoshin
Enable fuse supply before fuse programming and disable after. Signed-off-by: Sergey Alyoshin <alyoshin.s@gmail.com> Reviewed-by: Benoît Thébaudeau <benoit.thebaudeau@advansee.com>
2013-10-17i2c: mxc: move to new subsystemtrem
Signed-off-by: Philippe Reynes <tremyfr@yahoo.fr>
2013-08-26usb: ehci-mx5: Use 'bool' instead of 'unsigned char'Fabio Estevam
The 'enable' argument can be better expressed as boolean. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com> Reviewed-by: Otavio Salvador <otavio@ossystems.com.br>
2013-05-05arm: mx5: Add NAND clock handlingMarek Vasut
Augment the MX5 clock code with function to enable and configure NFC clock. This is necessary to get NFC working on MX5. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Albert ARIBAUD <albert.u.boot@aribaud.net> Cc: Benoît Thébaudeau <benoit.thebaudeau@advansee.com> Cc: Fabio Estevam <fabio.estevam@freescale.com> Cc: Scott Wood <scottwood@freescale.com> Cc: Stefano Babic <sbabic@denx.de> Cc: Tom Rini <trini@ti.com>
2012-11-19mx5: Print CSPI clock in 'clock' commandFabio Estevam
Print CSPI clock in 'clock' command. Signed-off-by: Fabio Estevam <festevam@gmail.com>
2012-10-26MX5: fix warning in clock.cStefano Babic
Patch fix warnings compiling with ELDK-4.2: clock.c: In function 'get_standard_pll_sel_clk': clock.c:341: warning: 'freq' may be used uninitialized in this function Reported-by : Marek Vasut <marex@denx.de> Signed-off-by: Stefano Babic <sbabic@denx.de>
2012-10-15mx5/6 clocks: Fix SDHC clocksBenoît Thébaudeau
The i.MX5 eSDHC clocks were considered as coming from the IPG clock although they have dedicated clock paths. Also, on i.MX5/6, each SDHC instance has a dedicated clock, so gd->sdhc_clk must be set accordingly. This is good for the case only a single SDHC instance is used (initialization made with fsl_esdhc_mmc_init()). A future patch will fix the multi-instance use case (initialization made directly with fsl_esdhc_initialize()). Signed-off-by: Benoît Thébaudeau <benoit.thebaudeau@advansee.com> Cc: Stefano Babic <sbabic@denx.de> Cc: Eric Bénard <eric@eukrea.com> Cc: Otavio Salvador <otavio@ossystems.com.br>
2012-10-15mx51: Fix I2C clock ID checkBenoît Thébaudeau
There are only 2 I²C instances on i.MX51, but 3 on i.MX53. Signed-off-by: Benoît Thébaudeau <benoit.thebaudeau@advansee.com> Cc: Stefano Babic <sbabic@denx.de>
2012-10-15mx5 clocks: Fix MXC_FEC_CLKBenoît Thébaudeau
The FEC clock does not come from PLL1, but from the IPG clock. The previous code was even inconsistent with itself, returning the IPG clock as expected for imx_get_fecclk(), but the PLL1 clock for mxc_get_clock(MXC_FEC_CLK). Signed-off-by: Benoît Thébaudeau <benoit.thebaudeau@advansee.com> Cc: Stefano Babic <sbabic@denx.de>
2012-10-15mx5 clocks: Simplify imx_get_cspiclk()Benoît Thébaudeau
The code handling the dividers was duplicated for each possible input clock, and this function can benefit from the newly introduced get_standard_pll_sel_clk() function instead of duplicating this mux handling code. Signed-off-by: Benoît Thébaudeau <benoit.thebaudeau@advansee.com> Cc: Stefano Babic <sbabic@denx.de>
2012-10-15mx5 clocks: Fix get_uart_clk()Benoît Thébaudeau
This function returned 66500000 instead of the correct lp_apm clock frequency if the CCM.CSCMR1.uart_clk_sel mux is set to 3. This patch fixes this issue by introducing the get_standard_pll_sel_clk() function that will be used by future patches to handle identical muxes used by many other clocks. Signed-off-by: Benoît Thébaudeau <benoit.thebaudeau@advansee.com> Cc: Stefano Babic <sbabic@denx.de>
2012-10-15mx5 clocks: Fix get_ipg_per_clk()Benoît Thébaudeau
This fixes the "IPG PERCLK" frequency printed by the clocks command. The issue was that get_ipg_per_clk() used periph_clk instead of lp_apm in the case CCM.CBCMR.perclk_lp_apm_sel is set. It also fixes I²C support. Signed-off-by: Benoît Thébaudeau <benoit.thebaudeau@advansee.com> Cc: Stefano Babic <sbabic@denx.de>
2012-10-15mx5 clocks: Fix get_periph_clk()Benoît Thébaudeau
In the case periph_clk comes from periph_apm_clk, the latter is selected by the CCM.CBCMR.periph_apm_sel mux, which can source the lp_apm clock from its input ♯2. get_periph_clk() returned 0 instead of the lp_apm clock frequency in this case. Signed-off-by: Benoît Thébaudeau <benoit.thebaudeau@advansee.com> Cc: Stefano Babic <sbabic@denx.de>
2012-10-15mx5 clocks: Fix get_lp_apm()Benoît Thébaudeau
If CCM.CCSR.lp_apm is set, the lp_apm clock is not necessarily 32768 Hz x 1024. In that case: - on i.MX51, this clock comes from the output of the FPM, - on i.MX53, this clock comes from the output of PLL4. This patch fixes the code accordingly. Signed-off-by: Benoît Thébaudeau <benoit.thebaudeau@advansee.com> Cc: Stefano Babic <sbabic@denx.de>
2012-10-15mx5 clocks: Add and use CCSR definitionsBenoît Thébaudeau
This fixes config_pll_clk(), which used 0x20 instead of 0x200 for PLL4_CLOCK. Signed-off-by: Benoît Thébaudeau <benoit.thebaudeau@advansee.com> Cc: Stefano Babic <sbabic@denx.de>
2012-10-15mx51: Fix USB PHY clocksBenoît Thébaudeau
The i.MX51 has a single USB PHY clock, while the i.MX53 has two. These 3 clocks have different clock gate control bit-fields. The existing code was correct only for i.MX53, so this patch fixes the i.MX51 use case. Signed-off-by: Benoît Thébaudeau <benoit.thebaudeau@advansee.com> Cc: Stefano Babic <sbabic@denx.de> Cc: Marek Vasut <marex@denx.de> Cc: Jana Rapava <fermata7@gmail.com> Cc: Wolfgang Grandegger <wg@denx.de> Cc: Igor Grinberg <grinberg@compulab.co.il>
2012-10-15mx5: Fix clock gate valuesBenoît Thébaudeau
The clock gate values are 2-bit bit-fields. Hence, setting or clearing only one of these bits like what was done is wrong and can lead to unpredictable behavior depending on the original value of these bit-fields. Signed-off-by: Benoît Thébaudeau <benoit.thebaudeau@advansee.com> Cc: Stefano Babic <sbabic@denx.de>
2012-10-15mx5: Use explicit clock gate namesBenoît Thébaudeau
Use clock gate definitions having names showing clearly the gated clock instead of names giving only a register field index. Signed-off-by: Benoît Thébaudeau <benoit.thebaudeau@advansee.com> Cc: Stefano Babic <sbabic@denx.de>
2012-10-15mx5 clocks: CleanupBenoît Thébaudeau
Clean up the i.MX5 clock driver: - Use readl() and writel() instead of their __raw_ counterparts. - Use the clr/setbits_le32() family of macros rather than expanding code. - Use accessor macros for bit-fields instead of _MASK and _OFFSET. Signed-off-by: Benoît Thébaudeau <benoit.thebaudeau@advansee.com> Cc: Stefano Babic <sbabic@denx.de>
2012-10-15mx5/6: Define default SoC input clock frequenciesBenoît Thébaudeau
Define default SoC input clock frequencies for i.MX5/6 in order to get rid of duplicated definitions. Signed-off-by: Benoît Thébaudeau <benoit.thebaudeau@advansee.com> Cc: Stefano Babic <sbabic@denx.de> Cc: Jason Liu <r64343@freescale.com> Cc: Matt Sealey <matt@genesi-usa.com> Cc: Fabio Estevam <fabio.estevam@freescale.com>
2012-10-15imx: Use MXC_I2C_CLK in imx i2c driverMatthias Weisser
i2c didn't work on imx25 due to missing MXC_IPG_PERCLK. Now using MXC_I2C_CLK on all imx systems using i2c. Signed-off-by: Matthias Weisser <weisserm@arcor.de> Acked-by: Stefano Babic <sbabic@denx.de>
2012-07-31imx-common: add i2c.c for bus recovery supportTroy Kisky
Signed-off-by: Troy Kisky <troy.kisky@boundarydevices.com>
2012-07-07mx53: Fix mask for SATA reference clockFabio Estevam
SATA_ALT_REF_CLK field corresponds to bits 1 and 2 of offset 0x180c. Fix the mask for these bits. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com>
2012-05-15mx5: Add clock config interfaceFabio Estevam
mx5: Add clock config interface Add clock config interface support, so that we can configure CPU or DDR clock in the later init Signed-off-by: Jason Liu <jason.hui@linaro.org> Signed-off-by: Eric Miao <eric.miao@linaro.org> Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com>
2012-05-15imx-common: Factor out get_ahb_clk()Fabio Estevam
get_ahb_clk() is a common function between mx5 and mx6. Place it into imx-common directory. Cc: Dirk Behme <dirk.behme@googlemail.com> Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com>
2012-05-15MX53: add function to set SATA clock to internalStefano Babic
The MX53 SATA interface can use an internal clock (USB PHY1) instead of an external clock. This is an undocumented feature, but used on most Freescale's evaluation boards, such as MX53-loco. As stated by Freescale's support: Fuses (but not pins) may be used to configure SATA clocks. Particularly the i.MX53 Fuse_Map contains the next information about configuring SATA clocks : SATA_ALT_REF_CLK[1:0] (offset 0x180C) '00' - 100MHz (External) '01' - 50MHz (External) '10' - 120MHz, internal (USB PHY) '11' - Reserved Signed-off-by: Stefano Babic <sbabic@denx.de> CC: Fabio Estevam <fabio.estevam@freescale.com>
2012-05-15MX5: Add definitions for SATA controllerStefano Babic
Add base address and MXC_SATA_CLK to return the clock used for the SATA controller. Signed-off-by: Stefano Babic <sbabic@denx.de> CC: Fabio Estevam <fabio.estevam@freescale.com> CC: Dirk Behme <dirk.behme@de.bosch.com>
2011-12-11USB: MX5: add helper functions to enable USB clocksWolfgang Grandegger
Signed-off-by: Wolfgang Grandegger <wg@denx.de> Cc: Stefano Babic <sbabic@denx.de> Cc: Remy Bohmer <linux@bohmer.net> Cc: Wolfgang Grandegger <wg@denx.de> Cc: Jason Liu <r64343@freescale.com> V2: Fix spacing in crm_regs.h
2011-12-06mx5: Correct a warning in clock.cSimon Glass
This corects the warning below, obtained with my gcc 4.6 compiler. arch/arm/cpu/armv7/mx5/libmx5.o: In function `decode_pll': arch/arm/cpu/armv7/mx5/clock.c:94: undefined reference to `__aeabi_uldivmod' I am not able to test this on MX5x hardware, but it does improve the MAKEALL output for me. You may already have a similar patch, but I cannot see it on the list. Signed-off-by: Simon Glass <sjg@chromium.org>
2011-09-30MX5: Clean up the output of "clocks" commandMarek Vasut
The new output looks like this: > clocks PLL1 800 MHz PLL2 665 MHz PLL3 216 MHz AHB 133000 kHz IPG 66500 kHz IPG PERCLK 665000 kHz Signed-off-by: Marek Vasut <marek.vasut@gmail.com> Acked-by: Stefano Babic <sbabic@denx.de> Acked-by: Jason Liu <jason.hui@linaro.org>
2011-09-30MX5: Add AHB clock reporting and fix IPG clock reportingMarek Vasut
Signed-off-by: Marek Vasut <marek.vasut@gmail.com> Cc: Stefano Babic <sbabic@denx.de> Cc: Jason Liu <jason.hui@linaro.org> Acked-by: Jason Liu <jason.hui@linaro.org>
2011-09-30MX5: Modify the PLL decoding algorithmMarek Vasut
The PLL decoding algorithm didn't take into account many configuration bits. Adjust it according to Linux kernel. Also, add PLL4 for MX53. Signed-off-by: Marek Vasut <marek.vasut@gmail.com> Cc: Stefano Babic <sbabic@denx.de> Cc: Jason Hui <jason.hui@linaro.org> Tested-by: Jason Liu <Jason.hui@linaro.org>
2011-09-04MX: MX35 / MX5: uniform clock command with powerpcStefano Babic
There was already a command to show the processor clocks for PowerPC (clocks). For i.MX, the "clockinfo" command was introduce. The patch sets the same command name used on PowerPC. A nasty and not needed newline is also dropped in the help for the command. Signed-off-by: Stefano Babic <sbabic@denx.de>
2010-10-28MX51: remove warning in clock.cStefano Babic
The patch removes the warning: clock.c:291: warning: initialization from incompatible pointer type after constification of args[] Signed-off-by: Stefano Babic <sbabic@denx.de>
2010-10-18MX5: rename mx51 to mx5Jason Liu
Rename mx51 to mx5 in order to support more mx51 like-style SOCs such as MX53 and the followings. Signed-off-by: Jason Liu <r64343@freescale.com>
