path: root/arch/arm/cpu/armv7/at91/sama5d4_devices.c
2015-02-21ARM: at91: collect SoC sources into mach-at91Masahiro Yamada
This commit moves source files as follows: arch/arm/cpu/arm920t/at91/* -> arch/arm/mach-at91/arm920t/* arch/arm/cpu/arm926ejs/at91/* -> arch/arm/mach-at91/arm926ejs/* arch/arm/cpu/armv7/at91/* -> arch/arm/mach-at91/armv7/* arch/arm/cpu/at91-common/* -> arch/arm/mach-at91/* Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Acked-by: Andreas Bießmann <andreas.devel@googlemail.co>
2015-02-07ARM: atmel: sama5d4: add interrupt redirect functionBo Shen
Signed-off-by: Bo Shen <voice.shen@atmel.com> [fix subject] Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com>
2015-02-07ARM: atmel: sama5d4: add bus matrix init functionBo Shen
2015-01-19ARM: atmel: sama5d4: add usb device initial codeBo Shen
2014-11-17ARM: atmel: add sama5d4ek board supportBo Shen
The code for this board supports following features: - Boot media support: NAND flash/SD card/SPI flash - Support LCD display - Support ethernet - Support USB mass storage Signed-off-by: Bo Shen <voice.shen@atmel.com> Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com>
