path: root/arch/arm/cpu/armv7/am33xx/sys_info.c
2013-09-20am335x_evm: am33xx_spl_board_init function and scale core frequencyTom Rini
Add a am33xx_spl_board_init (and enable the PMICs) that we may see, depending on the board we are running on. In all cases, we see if we can rely on the efuse_sma register to tell us the maximum speed. In the case of Beaglebone White, we need to make sure we are on AC power, and are on later than rev A1, and then we can ramp up to the PG1.0 maximum of 720Mhz. In the case of Beaglebone Black, we are either on PG2.0 that supports 1GHz or PG2.1. As PG2.0 may or may not have efuse_sma set, we cannot rely on this probe. In the case of the GP EVM, EVM SK and IDK we need to rely on the efuse_sma if we are on PG2.1, and the defaults for PG1.0/2.0. Signed-off-by: Tom Rini <trini@ti.com>
2013-05-10am33xx: Fix warning with CONFIG_DISPLAY_CPUINFOTom Rini
The arm_freq and ddr_freq variables are unused, so remove. Fixup whitespace slightly while in here. Reviewed-by: Peter Korsgaard <jacmet@sunsite.dk> Signed-off-by: Tom Rini <trini@ti.com>
2013-03-24am33xx: add ti814x specific register definitionsMatt Porter
Support the ti814x specific register definitions within arch-am33xx. Signed-off-by: Matt Porter <mporter@ti.com> Reviewed-by: Tom Rini <trini@ti.com>
2013-03-24ARM: AM33XX: Fix typo that causes an AM duplication in CPU name.Enric Balletbo i Serra
Just fix a typo displaying the CPU info. With CONFIG_DISPLAY_INFO we see something like AMAM335X-GP rev 0 instead of AM335X-GP rev 0. Signed-off-by: Enric Balletbo i Serra <eballetbo@iseebcn.com> Reviewed-by: Javier Martinez Canillas <javier@dowhile0.org>
2011-10-27ARM:AM33XX: Added support for AM33xxChandan Nath
This patch adds basic support for AM33xx which is based on ARMV7 Cortex A8 CPU. Signed-off-by: Chandan Nath <chandan.nath@ti.com> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
