path: root/arch/arm/cpu/arm926ejs/versatile/timer.c
2011-02-02arm926ejs: timer: Replace bss variable by gdrHeiko Schocher
Reuse the gd->tbl value for timestamp and add gd->lastinc for lastinc bss values in the arm926ejs timers implementation. The usage of bss values in drivers before initialisation of bss is forbidden. In that special case some data in .rel.dyn gets corrupted. This patch is similiar to the patch Dirk Behme posted for the armv7/omap-common/timer.c and added suggestions from Reinhard Meyer. Tested on the arm926ejs mx27 based magnesium board Tested on the arm926ejs kirkwood based suen3 board Signed-off-by: Heiko Schocher <hs@denx.de> cc: Albert ARIBAUD <albert.aribaud@free.fr> cc: Prafulla Wadaskar <prafulla@marvell.com> cc: Stefano Babic <sbabic@denx.de> cc: Reinhard Meyer <u-boot@emk-elektronik.de>
2010-05-21ARM: */timer.c: fix spelling and vertical alignmentWolfgang Denk
2010-04-13arm: Move cpu/$CPU to arch/arm/cpu/$CPUPeter Tyser
