path: root/arch/arm/cpu/arm926ejs/mxs/iomux.c
2012-09-01mxs: prefix register acessor macros with 'mxs' prefixOtavio Salvador
As the register accessing mode is the same for all i.MXS SoCs we ought to use 'mxs' prefix intead of 'mx28'. Signed-off-by: Otavio Salvador <otavio@ossystems.com.br>
2012-09-01mxs: reorganize source directory for easy sharing of code in i.MXS SoCsOtavio Salvador
Most code can be shared between i.MX23 and i.MX28 as both are from i.MXS family; this source directory structure makes easy to share code among them. Signed-off-by: Otavio Salvador <otavio@ossystems.com.br> Acked-by: Stefano Babic <sbabic@denx.de>
