path: root/arch/arm/cpu/arm926ejs/mx28/mx28.c
2012-09-01mxs: reorganize source directory for easy sharing of code in i.MXS SoCsOtavio Salvador
Most code can be shared between i.MX23 and i.MX28 as both are from i.MXS family; this source directory structure makes easy to share code among them. Signed-off-by: Otavio Salvador <otavio@ossystems.com.br> Acked-by: Stefano Babic <sbabic@denx.de>
2012-09-01MX28: extend print_cpuinfo() to use chip informationOtavio Salvador
The information now is gathered from HW_DIGCTL_CHIPID register and includes the chip modem and revision on the output. Signed-off-by: Otavio Salvador <otavio@ossystems.com.br>
2012-07-07ARM: mx28: Remove CONFIG_ARCH_CPU_INITFabio Estevam
No need to define CONFIG_ARCH_CPU_INIT. All mx28 based boards should use arch_cpu_init(). Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com> Acked-by: Marek Vasut <marex@denx.de>
2012-05-15i.MX28: Shut down the LCD controller before resetMarek Vasut
If the LCD controller is on before the CPU goes into reset, the traffic on LCDIF data pins interferes with the BootROM's boot mode sampling. So shut the controller down. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Detlev Zundel <dzu@denx.de> Cc: Fabio Estevam <festevam@gmail.com> Cc: Stefano Babic <sbabic@denx.de> Cc: Wolfgang Denk <wd@denx.de>
2012-05-15i.MX28: Implement boot pads sampling and reportingMarek Vasut
This patch implements code that samples i.MX28 boot pads and reports boot mode accordingly. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Detlev Zundel <dzu@denx.de> Cc: Fabio Estevam <fabio.estevam@freescale.com> Cc: Stefano Babic <sbabic@denx.de> Cc: Wolfgang Denk <wd@denx.de>
2012-05-15i.MX28: Improve passing of data from SPL to U-BootMarek Vasut
Pass memory size from SPL via structure located in SRAM instead of SCRATCH registers. This allows passing more data about boot from SPL to U-Boot, like the boot mode pads configuration. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Detlev Zundel <dzu@denx.de> Cc: Fabio Estevam <fabio.estevam@freescale.com> Cc: Stefano Babic <sbabic@denx.de> Cc: Wolfgang Denk <wd@denx.de>
2012-04-16DMA: Split the APBH DMA init into block and channel initMarek Vasut
This fixes the issue where mxs_dma_init() was called either twice or never, without introducing any new init hooks. The idea is to allow each and every device using the APBH DMA block to configure and request only the channels it uses, instead of making it call init for all the channels as is now. The common DMA block init part, which only configures the block, is then called from CPUs arch_cpu_init() call. NOTE: This patch depends on: http://patchwork.ozlabs.org/patch/150957/ Signed-off-by: Marek Vasut <marex@denx.de> Cc: Stefano Babic <sbabic@denx.de> Cc: Wolfgang Denk <wd@denx.de> Cc: Detlev Zundel <dzu@denx.de> Cc: Fabio Estevam <fabio.estevam@freescale.com> Tested-by: Fabio Estevam <fabio.estevam@freescale.com>
2012-03-29i.MX28: Enable caches by defaultMarek Vasut
2012-03-26Renamed mx28_register to mx28_register_32 to prepare for mx28_register_8Robert Delien
This patch renames mx28_register to mx28_register_32 in order to prepare for the introduction of an 8-bit register, mx28_register_8. Signed-off-by: Robert Delien <robert@delien.nl> Acked-by: Marek Vasut <marex@denx.de> Tested-by: Marek Vasut <marex@denx.de>
2012-03-26i.mx28: Replaced magic numbers for scratch register addresses with register ↵Robert Delien
definitions This patch replaces the use of magice numbers for scratch register addresses with earlier defined register definitions. Signed-off-by: Robert Delien <robert@delien.nl>
2012-02-12mx28: Show CPU frequencyFabio Estevam
Showing CPU frequency during boot is useful information. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com> Acked-by: Marek Vasut <marek.vasut@gmail.com> Acked-by: Stefano Babic <sbabic@denx.de>
2012-01-16mx28: Let dram_init be common for mx28Fabio Estevam
Let dram_init function be a common function, so that other mx28 boards can reuse it. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com> Acked-by: Marek Vasut <marek.vasut@gmail.com>
2012-01-16mx28: Let imx_get_mac_from_fuse be common for mx28Fabio Estevam
Let imx_get_mac_from_fuse function be a common function, so that other mx28 boards can reuse it. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com> Acked-by: Marek Vasut <marek.vasut@gmail.com> Acked-by: Stefano Babic <sbabic@denx.de>
2011-11-11iMX28: Fix ARM vector handlingMarek Vasut
This patch introduces proper ARM vector handling for i.MX28 CPU. This issue wasn't addressed because the interrupts weren't enabled on any ARMv5 core, therefore the issue wasn't noticed earlier. In previous implementation, the vectoring code used by i.MX28 CPU when an exception happened was that of the SPL. With this change, the branch target when an exception happens can be reconfigured by U-Boot. Signed-off-by: Marek Vasut <marek.vasut@gmail.com> Cc: Stefano Babic <sbabic@denx.de> Cc: Wolfgang Denk <wd@denx.de> Cc: Detlev Zundel <dzu@denx.de>
2011-11-11iMX28: Add GPIO controlMarek Vasut
2011-11-11iMX28: Initial support for iMX28 CPUMarek Vasut
This patch supports: - Timers - Debug UART - Clock Signed-off-by: Marek Vasut <marek.vasut@gmail.com> Cc: Stefano Babic <sbabic@denx.de> Cc: Wolfgang Denk <wd@denx.de> Cc: Detlev Zundel <dzu@denx.de>
