Add multi-FEC support for imx_get_mac_from_fuse by passing dev_id as a parameter.
This feature is important on mx28 SoC for example that has two FEC ports.
Cc: Ben Warren <biggerbadderben@gmail.com>
Fix checkpatch warning and errors in several i.MX related files.
While at it also address a checkpatch warning at arch/arm/cpu/armv7/mx5/soc.c
regarding the usage of extern in a C file.
When building the zmx25 target we get:
Configuring for zmx25 board...
generic.c:108: warning: 'get_reset_cause' defined but not used
Fix this warning by defining get_reset_cause only if CONFIG_DISPLAY_CPUINFO is defined.
Print the source of reset during boot.
Print the silicon revison during boot.
The patch is to support getting FEC MAC address from fuse bank.
Signed-off-by: Jason Liu <r64343@freescale.com>
Tested-by: Stefano Babic <sbabic@denx.de>
Replace call to imx_get_mpllclk with imx_get_armclk
to show frequency of ARM core instead of mpll internal
bus in print_cpuinfo.
Signed-off-by: John Rigby <jcrigby@gmail.com>
CC: Stefano Babic <sbabic@denx.de>
