path: root/arch/arm/Makefile
2020-05-15rename symbol: CONFIG_STM32 -> CONFIG_ARCH_STM32Trevor Woerner
Have this symbol follow the pattern of all other such symbols. Signed-off-by: Trevor Woerner <twoerner@gmail.com>
2020-05-15rename symbol: CONFIG_TEGRA -> CONFIG_ARCH_TEGRATrevor Woerner
2020-05-15rename symbol: CONFIG_KIRKWOOD -> CONFIG_ARCH_KIRKWOODTrevor Woerner
Have this symbol follow the pattern of all other such symbols. This patch also removes a TODO from the code. Reviewed-by: Chris Packham <judge.packham@gmail.com> Signed-off-by: Trevor Woerner <twoerner@gmail.com>
2020-05-15rename symbol: CONFIG_ORION5X -> CONFIG_ARCH_ORION5XTrevor Woerner
Have this symbol follow the pattern of all other such symbols. This patch removes a TODO from the code. Signed-off-by: Trevor Woerner <twoerner@gmail.com>
2020-05-15arch/arm/Makefile: sort machine namesTrevor Woerner
The comment immediately above the block of machine directory names implored users to keep the macro names sorted, but, alas, this is no longer the case. Put the list of machine directory names back in alphanumerical order by CONFIG_* macro name, as the comment asks. Sort all the symbols as though they all followed the convention of having the string "ARCH_" in the middle of their definitions. Signed-off-by: Trevor Woerner <twoerner@gmail.com>
2020-05-15arm: lpc32xx: move SoC to mach-lpc32xxTrevor Woerner
Following the example of most other SoCs in arch/$(ARCH)/cpu/$(CPU)/$(SOC) move the lpc32xx code from arch/arm/cpu/arm926ejs/lpc32xx to arch/arm/mach-lpc32xx. Following the checklist from commit 01f14456306c ("ARM: prepare for moving SoC sources into mach-*"): [1] move files from arch/arm/cpu/arm926ejs/lpc32xx to arch/arm/mach-lpx32xx [2] add machine entry to arch/arm/Makefile [3] remove "obj-y += ..." from arch/arm/cpu/arm926ejs/Makefile [4] fix the Kconfig file path in arch/arm/Kconfig [5] (no MAINTAINERS update) Reviewed-by: Simon Glass <sjg@chromium.org> Signed-off-by: Trevor Woerner <twoerner@gmail.com>
2020-01-22arm: Add support for ST-Ericsson U8500 SoCStephan Gerhold
The NovaThor U8500 SoC was released by ST-Ericsson in 2011. It was used for some development boards like the CALAO Systems Snowball SBC, but mass production was primarily for Android smartphones like the Samsung Galaxy S III mini. Previous support for U8500 was removed in commit 68282f55b846 ("arm: Remove unused ST-Ericsson u8500 arch") since none of the boards were converted to generic boards before the deadline. The new code does not have much in common with the previous code. I have completely rewritten everything, embracing the Driver Model and device trees wherever possible. The U8500 support is a bit more minimal for now - my primary use case is to use U-Boot as alternative bootloader for some of the U8500 Samsung smartphones. At the moment U-Boot is chain-loaded from the original Samsung bootloader. A side effect of this is that we can (temporarily) get away without implementing some functionality - e.g. all clocks are already enabled by the original bootloader. More functionality will be added in future patches. Cc: Mathieu Poirier <mathieu.poirier@linaro.org> Cc: John Rigby <john.rigby@linaro.org> Signed-off-by: Stephan Gerhold <stephan@gerhold.net> Reviewed-by: Linus Walleij <linus.walleij@linaro.org>
2020-01-14imx: Add basic support for the NXP IMXRT10xx SoC familyGiulio Benetti
Add i.IMXRT family basic support. Signed-off-by: Giulio Benetti <giulio.benetti@benettiengineering.com>
2019-12-09arm: -march=armv5t for ARM11Heinrich Schuchardt
In GCC 9 support for the Armv5 and Armv5E architectures (which have no known implementations) has been removed, cf. https://gcc.gnu.org/gcc-9/changes.html Commit 16540d07fd62 ("arm: fix -march for ARM11") changed the value of the compiler flag from -march=armv5 and -march=armv5t into -march=armv6 for ARM11. The values prior to this patch were: arch-$(CONFIG_CPU_ARM1136) =-march=armv5 arch-$(CONFIG_CPU_ARM1176) =-march=armv5t The change lead to a regression with the Raspberry Pi Zero W not booting anymore. Use -march=armv5t both for ARM1136 and ARM1176. Fixes: 16540d07fd62 ("arm: fix -march for ARM11") Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de> Tested-by: Joris Offouga <offougajoris@gmail.com>
2019-11-23arm: fix -march for ARM11Heinrich Schuchardt
In GCC 9 support for the Armv5 and Armv5E architectures (which have no known implementations) has been removed, cf. https://gcc.gnu.org/gcc-9/changes.html ARM11 is an armv6 implementation. So change the architecture flag for the compiler to armv6 for ARM11. Suggested-by: Fabio Estevam <festevam@gmail.com> Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de> Reviewed-by: Fabio Estevam <festevam@gmail.com>
2019-01-28arm: imx: build mach-imx for i.MX8Peng Fan
To enable SPL for i.MX8, we could reuse code in arch/arm/mach-imx. Signed-off-by: Peng Fan <peng.fan@nxp.com>
2019-01-24arm64: zynqmp: Move SoC sources to mach-zynqmpMichal Simek
Similar changes was done for Zynq in past and this patch just follow this pattern to separate cpu code from SoC code. Move arch/arm/cpu/armv8/zynqmp/* -> arch/arm/mach-zynqmp/* And also fix references to these files. Based on "ARM: zynq: move SoC sources to mach-zynq" (sha1: 0107f2403669f764ab726d0d404e35bb9447bbcc) Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2019-01-01imx: rename mx8m,MX8M to imx8m,IMX8MPeng Fan
Rename mx8m,MX8M to imx8m,IMX8M Signed-off-by: Peng Fan <peng.fan@nxp.com> Signed-off-by: Jon Nettleton <jon@solid-run.com>
2018-11-28arm: MediaTek: add basic support for MT7629 boardsRyder Lee
This adds a general board file based on MT7629 SoCs from MediaTek. Apart from the generic parts (cpu) we add some low level init codes and initialize the early clocks. Signed-off-by: Ryder Lee <ryder.lee@mediatek.com> Signed-off-by: Weijie Gao <weijie.gao@mediatek.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2018-10-25Merge tag 'u-boot-imx-20181025' of git://git.denx.de/u-boot-imxTom Rini
Merged imx8 architecture, fix build for imx8 + warnings
2018-10-22arm: build mach-imx for i.MX8Peng Fan
Build mach-imx for i.MX8 Signed-off-by: Peng Fan <peng.fan@nxp.com> Reviewed-by: Anatolij Gustschin <agust@denx.de> Cc: Stefano Babic <sbabic@denx.de>
2018-10-16arm64: versal: Add support for new Xilinx Versal ACAPsMichal Simek
Xilinx is introducing Versal, an adaptive compute acceleration platform (ACAP), built on 7nm FinFET process technology. Versal ACAPs combine Scalar Processing Engines, Adaptable Hardware Engines, and Intelligent Engines with leading-edge memory and interfacing technologies to deliver powerful heterogeneous acceleration for any application. The Versal AI Core series has five devices, offering 128 to 400 AI Engines. The series includes dual-core Arm Cortex™-A72 application processors, dual-core Arm Cortex-R5 real-time processors, 256KB of on-chip memory with ECC, more than 1,900 DSP engines optimized for high-precision floating point with low latency. The patch is adding necessary infrastructure in place without enabling platform which is done in separate patch. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2018-09-11arm: K3: Add initial support for TI's K3 generation of SoCsLokesh Vutla
Add support for Texas Instruments' K3 Generation Processor families. Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2018-09-10arm: armv7-a: Compile and tune for armv7-a instead of armv5Adam Ford
arch/arm/Makefile references armv5 for backwards compatibility with older compilers. This patch removes those references to armv5, since by now newer compilers are required which should have armv7 support enabled. The Makefile also also has a list of options for mtune, but the entry for CONFIG_CPU_V7A is empty, so this patch tunes the CPU_V7A architecture to generic-armv7-a. The following size changed apply to omap3_logic using GCC. Stock text data bss dec hex filename 50910 429 67580 118919 1d087 spl/u-boot-spl 540713 22700 327072 890485 d9675 u-boot Without Armv5 text data bss dec hex filename 50916 429 67580 118925 1d08d spl/u-boot-spl 540719 22700 327064 890483 d9673 u-boot mtune=generic-armv7-a text data bss dec hex filename 50932 429 67580 118941 1d09d spl/u-boot-spl 540519 22700 327080 890299 d95bb u-boot Signed-off-by: Adam Ford <aford173@gmail.com>
2018-07-10board: arm: Add support for Broadcom BCM7445Thomas Fitzsimmons
Add support for loading U-Boot on the Broadcom 7445 SoC. This port assumes Broadcom's BOLT bootloader is acting as the second stage bootloader, and U-Boot is acting as the third stage bootloader, loaded as an ELF program by BOLT. Signed-off-by: Thomas Fitzsimmons <fitzsim@fitzsim.org> Cc: Stefan Roese <sr@denx.de> Cc: Tom Rini <trini@konsulko.com> Cc: Florian Fainelli <f.fainelli@gmail.com>
2018-07-09arm: Add support for Actions Semi OWL SoC familyManivannan Sadhasivam
This commit adds Actions Semi OWL SoC family support with S900 as the first target SoC. Signed-off-by: Manivannan Sadhasivam <manivannan.sadhasivam@linaro.org>
2018-05-23arm: armv7m: Clean up some thumb / compiler flag optionsTom Rini
- The correct way to build with thumb mode is to select SYS_THUMB_BUILD - We should be setting -march=armv7-m in arch/arm/Makefile not the sub-config.mk file. Signed-off-by: Tom Rini <trini@konsulko.com>
2018-05-11arm: zynqmp: Add ZynqMP minimal R5 supportMichal Simek
Xilinx ZynqMP also contains dual Cortex R5 which can run U-Boot. This patch is adding minimal support to get U-Boot boot. U-Boot on R5 runs out of DDR with default configuration that's why DDR needs to be partitioned if there is something else running on arm64. Console is done via Cadence uart driver and the first Cadence Triple Timer Counter is used for time. This configuration with uart1 was tested on zcu100-revC. U-Boot 2018.05-rc2-00021-gd058a08d907d (Apr 18 2018 - 14:11:27 +0200) Model: Xilinx ZynqMP R5 DRAM: 512 MiB WARNING: Caches not enabled MMC: In: serial@ff010000 Out: serial@ff010000 Err: serial@ff010000 Net: Net Initialization Skipped No ethernet found. ZynqMP r5> There are two ways how to run this on ZynqMP. 1. Run from ZynqMP arm64 tftpb 20000000 u-boot-r5.elf setenv autostart no && bootelf -p 20000000 cpu 4 disable && cpu 4 release 10000000 lockstep or cpu 4 disable && cpu 4 release 10000000 split 2. Load via jtag when directly to R5 Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2018-05-07arm: v7R: Add initial supportMichal Simek
The Cortex-R* processors are a mid-range CPUs for use in deeply-embedded, real-time systems. It implements the ARMv7-R architecture, and includes Thumb-2 technology for optimum code density and processing throughput. Except for MPU(Memory Protection Unit) and few CP15 registers, most of the features are compatible with v7 architecture. So,reuse the same armv7 folder and introduce a new config CPU_V7R in order to differentiate from v7 based platforms. Tested-by: Michal Simek <michal.simek@xilinx.com> Reviewed-by: Tom Rini <trini@konsulko.com> Signed-off-by: Michal Simek <michal.simek@xilinx.com> Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com>
2018-05-07arm: v7: Kconfig: Rename CPU_V7 as CPU_V7ALokesh Vutla
Currently CPU_V7 kconfig symbol supports only ARMv7A architectures under armv7 folder. This led to a misconception of creating separate folders for armv7m and armv7r. There is no reason to create separate folder for other armv7 based architectures when it can co-exist with few Kconfig symbols. As a first step towards a common folder, rename CPU_V7 as CPUV7A. Later separate Kconfig symbols can be added for CPU_V7R and CPU_V7M and can co exist in the same folder. Reviewed-by: Tom Rini <trini@konsulko.com> Tested-by: Michal Simek <michal.simek@xilinx.com> Suggested-by: Alexander Graf <agraf@suse.de> Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com>
2018-03-19arm: stm32: add new architecture for STM32MP familyPatrick Delaunay
- add new arch stm32mp for STM32 MPU/Soc based on Cortex A - support for stm32mp157 SOC - SPL is used as first boot stage loader - using driver model for all the drivers, even in SPL - all security feature are deactivated (ETZC and TZC) - reused STM32 MCU drivers when it is possible Signed-off-by: Patrick Delaunay <patrick.delaunay@st.com>
2018-02-04imx: add i.MX8M into KconfigPeng Fan
Add i.MX8M into Kconfig, create a new folder mx8m dedicated for i.MX8M. Signed-off-by: Peng Fan <peng.fan@nxp.com> Reviewed-by: Fabio Estevam <fabio.estevam@nxp.com> Cc: Stefano Babic <sbabic@denx.de> Reviewed-by: Stefano Babic <sbabic@denx.de>
Change is consistent with other SOCs and it is in preparation for adding SOMs. SOC's related files are moved from cpu/ to mach-imx/<SOC>. This change is also coherent with the structure in kernel. Signed-off-by: Stefano Babic <sbabic@denx.de> CC: Fabio Estevam <fabio.estevam@nxp.com> CC: Akshay Bhat <akshaybhat@timesys.com> CC: Ken Lin <Ken.Lin@advantech.com.tw> CC: Marek Vasut <marek.vasut@gmail.com> CC: Heiko Schocher <hs@denx.de> CC: "Sébastien Szymanski" <sebastien.szymanski@armadeus.com> CC: Christian Gmeiner <christian.gmeiner@gmail.com> CC: Stefan Roese <sr@denx.de> CC: Patrick Bruenn <p.bruenn@beckhoff.com> CC: Troy Kisky <troy.kisky@boundarydevices.com> CC: Nikita Kiryanov <nikita@compulab.co.il> CC: Otavio Salvador <otavio@ossystems.com.br> CC: "Eric Bénard" <eric@eukrea.com> CC: Jagan Teki <jagan@amarulasolutions.com> CC: Ye Li <ye.li@nxp.com> CC: Peng Fan <peng.fan@nxp.com> CC: Adrian Alonso <adrian.alonso@nxp.com> CC: Alison Wang <b18965@freescale.com> CC: Tim Harvey <tharvey@gateworks.com> CC: Martin Donnelly <martin.donnelly@ge.com> CC: Marcin Niestroj <m.niestroj@grinn-global.com> CC: Lukasz Majewski <lukma@denx.de> CC: Adam Ford <aford173@gmail.com> CC: "Albert ARIBAUD (3ADEV)" <albert.aribaud@3adev.fr> CC: Boris Brezillon <boris.brezillon@free-electrons.com> CC: Soeren Moch <smoch@web.de> CC: Richard Hu <richard.hu@technexion.com> CC: Wig Cheng <wig.cheng@technexion.com> CC: Vanessa Maegima <vanessa.maegima@nxp.com> CC: Max Krummenacher <max.krummenacher@toradex.com> CC: Stefan Agner <stefan.agner@toradex.com> CC: Markus Niebel <Markus.Niebel@tq-group.com> CC: Breno Lima <breno.lima@nxp.com> CC: Francesco Montefoschi <francesco.montefoschi@udoo.org> CC: Jaehoon Chung <jh80.chung@samsung.com> CC: Scott Wood <oss@buserror.net> CC: Joe Hershberger <joe.hershberger@ni.com> CC: Anatolij Gustschin <agust@denx.de> CC: Simon Glass <sjg@chromium.org> CC: "Andrew F. Davis" <afd@ti.com> CC: "Łukasz Majewski" <l.majewski@samsung.com> CC: Patrice Chotard <patrice.chotard@st.com> CC: Nobuhiro Iwamatsu <iwamatsu@nigauri.org> CC: Hans de Goede <hdegoede@redhat.com> CC: Masahiro Yamada <yamada.masahiro@socionext.com> CC: Stephen Warren <swarren@nvidia.com> CC: Andre Przywara <andre.przywara@arm.com> CC: "Álvaro Fernández Rojas" <noltari@gmail.com> CC: York Sun <york.sun@nxp.com> CC: Xiaoliang Yang <xiaoliang.yang@nxp.com> CC: Chen-Yu Tsai <wens@csie.org> CC: George McCollister <george.mccollister@gmail.com> CC: Sven Ebenfeld <sven.ebenfeld@gmail.com> CC: Filip Brozovic <fbrozovic@gmail.com> CC: Petr Kulhavy <brain@jikos.cz> CC: Eric Nelson <eric@nelint.com> CC: Bai Ping <ping.bai@nxp.com> CC: Anson Huang <Anson.Huang@nxp.com> CC: Sanchayan Maity <maitysanchayan@gmail.com> CC: Lokesh Vutla <lokeshvutla@ti.com> CC: Patrick Delaunay <patrick.delaunay@st.com> CC: Gary Bisson <gary.bisson@boundarydevices.com> CC: Alexander Graf <agraf@suse.de> CC: u-boot@lists.denx.de Reviewed-by: Fabio Estevam <fabio.estevam@nxp.com> Reviewed-by: Christian Gmeiner <christian.gmeiner@gmail.com>
2017-04-27ARM: omap2+: rename config to ARCH_OMAP2PLUS and consolidate KconfigMasahiro Yamada
In Linux, CONFIG_ARCH_OMAP2PLUS is used for OMAP2 or later SoCs. Rename CONFIG_ARCH_OMAP2 to CONFIG_ARCH_OMAP2PLUS to follow this naming. Move the OMAP2+ board/SoC choice down to mach-omap2/Kconfig to slim down the arch/arm/Kconfig level. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2017-03-17imx: mx7ulp: Add soc level initialization codes and functionsPeng Fan
Implement soc level functions to get cpu rev, reset cause, enable cache, etc. We will disable the wdog and init clocks in s_init at very early u-boot phase. Since the we are seeking the way to get chip id for mx7ulp, the get_cpu_rev is hard coded to a fixed value. This may change in future. Reuse some code in imx-common. Signed-off-by: Peng Fan <peng.fan@nxp.com> Signed-off-by: Ye Li <ye.li@nxp.com> Cc: Stefano Babic <sbabic@denx.de>
2017-02-01Merge branch 'master' of git://www.denx.de/git/u-boot-imxTom Rini
2017-01-28aspeed: Add drivers common to all Aspeed SoCsmaxims@google.com
Add support for Watchdog Timer, which is compatible with AST2400 and AST2500 watchdogs. There is no uclass for Watchdog yet, so the driver does not follow the driver model. It also uses fixed clock, so no clock driver is needed. Add support for timer for Aspeed ast2400/ast2500 devices. The driver actually controls several devices, but because all devices share the same Control Register, it is somewhat difficult to completely decouple them. Since only one timer is needed at the moment, this should be OK. The timer uses fixed clock, so does not rely on a clock driver. Add sysreset driver, which uses watchdog timer to do resets and particular watchdog device to use is hardcoded (0) Reviewed-by: Simon Glass <sjg@chromium.org>
2017-01-27ARM: imx6ul: Move liteSOM source to SoC directoryMarcin Niestroj
Moving arch/arm/mach-litesom/ to arch/arm/cpu/armv7/mx6/ was requested in [1] during discussion of chiliSOM support patches. [1] http://lists.denx.de/pipermail/u-boot/2017-January/279137.html Suggested-by: Tom Rini <trini@konsulko.com> Signed-off-by: Marcin Niestroj <m.niestroj@grinn-global.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2017-01-02arm: imx: remove bmode , hdmidet and dek commands from SPLSven Ebenfeld
These files are blowing up the SPL and should not be required there as the SPL delivers no command console. Because building fails for mx27 and mx31 machines with SPL build, we remove the linker flag for them from the Makefile. Nothing is built for them to be linked in that directory. Cc: sbabic@denx.de v2 Changes: - Remove mx27 and mx31 from Makefile during SPL build as nothing is built for them in that directory. And removing the commands with the libs-y directive lead to linker failures. e.g. "armv5te-ld.bfd: cannot find arch/arm/imx-common/built-in.o: No such file or directory)" Signed-off-by: Sven Ebenfeld <sven.ebenfeld@gmail.com> Reviewed-by: George McCollister <george.mccollister@gmail.com> Tested-by: George McCollister <george.mccollister@gmail.com>
2016-12-16ARM: imx6ul: Add support for liteSOMMarcin Niestroj
liteSOM is a System On Module (http://grinn-global.com/litesom/). It can't exists on its own, but will be used as part of other boards. Hardware specification: * NXP i.MX6UL processor * 256M or 512M DDR3 memory * optional eMMC (uSDHC2) Here we treat SOM similar to SOC, so we place it inside arch/arm/mach-* directory and make it possible to reuse initialization code (i.e. DDR, eMMC init) for all boards that use it. Signed-off-by: Marcin Niestroj <m.niestroj@grinn-global.com>
2016-11-21arm: Introduce arch/arm/mach-omap2 for OMAP2 derivative platformsTom Rini
This moves what was in arch/arm/cpu/armv7/omap-common in to arch/arm/mach-omap2 and moves arch/arm/cpu/armv7/{am33xx,omap3,omap4,omap5} in to arch/arm/mach-omap2 as subdirectories. All refernces to the former locations are updated to the current locations. For the logic to decide what our outputs are, consolidate the tests into a single config.mk rather than including 4. Signed-off-by: Tom Rini <trini@konsulko.com>
2016-08-20Merge branch 'rmobile' of git://git.denx.de/u-boot-shTom Rini
[trini: Drop CMD_BOOTI as it's now on by default on ARM64] Signed-off-by: Tom Rini <trini@konsulko.com>
2016-08-17ARM: Rmobile: Rename CONFIG_RMOBILE to CONFIG_ARCH_RMOBILENobuhiro Iwamatsu
2016-08-17ARM: rmobile: Move SoC sources to mach-rmobileNobuhiro Iwamatsu
Move from arch/arm/cpu/armv7/rmobile/ to arch/arm/mach-rmobile/. Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2016-08-05ARM: Rework and correct barrier definitionsTom Rini
As part of testing booting Linux kernels on Rockchip devices, it was discovered by Ziyuan Xu and Sandy Patterson that we had multiple and for some cases incomplete isb definitions. This was causing a failure to boot of the Linux kernel. In order to solve this problem as well as cover any corner cases that we may also have had a number of changes are made in order to consolidate things. First, <asm/barriers.h> now becomes the source of isb/dsb/dmb definitions. This however introduces another complexity. Due to needing to build SPL for 32bit tegra with -march=armv4 we need to borrow the __LINUX_ARM_ARCH__ logic from the Linux Kernel in a more complete form. Move this from arch/arm/lib/Makefile to arch/arm/Makefile and add a comment about it. Now that we can always know what the target CPU is capable off we can get always do the correct thing for the barrier. The final part of this is that need to be consistent everywhere and call isb()/dsb()/dmb() and NOT call ISB/DSB/DMB in some cases and the function names in others. Reviewed-by: Stephen Warren <swarren@nvidia.com> Tested-by: Stephen Warren <swarren@nvidia.com> Acked-by: Ziyuan Xu <xzy.xu@rock-chips.com> Acked-by: Sandy Patterson <apatterson@sightlogix.com> Reported-by: Ziyuan Xu <xzy.xu@rock-chips.com> Reported-by: Sandy Patterson <apatterson@sightlogix.com> Signed-off-by: Tom Rini <trini@konsulko.com>
2016-06-02arm: Treat arm946es as v5teMarek Vasut
The arm946es is armv5te , so use -march=armv5te instead of armv4t. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Albert Aribaud <albert.u.boot@aribaud.net> Cc: Tom Rini <trini@konsulko.com>
2016-05-27arm: add initial support for Amlogic Meson and ODROID-C2Beniamino Galvani
This adds platform code for the Amlogic Meson GXBaby (S905) SoC and a board definition for ODROID-C2. This initial submission only supports UART and Ethernet (through the existing Designware driver). DTS files are the ones submitted to Linux arm-soc for 4.7 [1]. [1] https://patchwork.ozlabs.org/patch/603583/ Signed-off-by: Beniamino Galvani <b.galvani@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2016-04-01arm: Add support for Qualcomm Snapdragon familyMateusz Kulikowski
First supported chip is APQ8016 (that is compatible with MSM8916). Drivers in SoC code: - Reset controller (PSHOLD) - Clock controller (very simple clock configuration for MMC and UART) Signed-off-by: Mateusz Kulikowski <mateusz.kulikowski@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org> Tested-by: Simon Glass <sjg@chromium.org>
2016-04-01arm: clang: Update support slightlyTom Rini
- Move most of the flags required into LLVM_RELFLAGS to test at build time instead of requiring them to be passed in. - Update doc/README.clang to reflect this - Switch to rpi_2 as the example as it's closer to working out of the box than rpi is. Cc: Jeroen Hofstee <jeroen@myspectrum.nl> Signed-off-by: Tom Rini <trini@konsulko.com>
2016-04-01sunxi: Move cpu independent code to mach directoryAlexander Graf
Some of the code in arch/arm/cpu/armv7/sunxi is actually armv7 specific, while most of it is just generic code that could as well be used on an AArch64 SoC. Move all files that are not really tied to armv7 into a new mach-sunxi directory. Signed-off-by: Alexander Graf <agraf@suse.de> Acked-by: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Hans de Goede <hdegoede@redhat.com>
2016-02-15arm: the ARM920T is THUMB capable, so select the appropriate ISADavid Müller (ELSOFT AG)
Signed-off-by: David Müller <d.mueller@elsoft.ch>
2016-01-20stm32: move stm32 specific code to mach-stm32Vikas Manocha
This patch moves stm32 sources at one place, with this armv7m now contains only generic stuff. Signed-off-by: Vikas Manocha <vikas.manocha@st.com>
2016-01-14arm: mvebu: Move SoC selection (A38X vs AXP) into KconfigStefan Roese
Until now, the SoC selection for the ARCH_MVEBU platforms has been done in the config header. Using CONFIG_ARMADA_XP in a non-clear way. As it needed to get selected for AXP and A38x based boards. This patch now changes this to move the SoC selection to Kconfig. And also uses CONFIG_ARCH_MVEBU as a common define for both AXP and A38x. This makes things a bit clearer - especially for new board additions. Additionally the defines CONFIG_SYS_MVEBU_DDR_AXP and CONFIG_SYS_MVEBU_DDR_A38X are replaced with the already available CONFIG_ARMADA_38X and CONFIG_ARMADA_XP. And CONFIG_DDR3 is removed, as its not referenced anywhere. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Luka Perkov <luka.perkov@sartura.hr>
2015-11-30arm: s5pc1xx: move SoC to mach-s5pc1xxMinkyu Kang
move arm/arm/cpu/armv7/s5pc1xx to arch/arm/mach-s5pc1xx Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
