path: root/arch/arm/Kconfig
2018-06-11LS1012AFRWY: Add Secure Boot supportVinitha V Pillai
Added the following: 1. defconfig for LS1012AFRWY Secure boot 2. PfE Validation support Signed-off-by: Vinitha V Pillai <vinitha.pillai@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
2018-06-11board: ls1012a: FRWY-LS1012A board supportBhaskar Upadhaya
FRWY-LS1012A belongs to LS1012A family with features 2 1G SGMII PFE MAC, Micro SD, USB 3.0, DDR, QuadSPI, Audio, UART. Signed-off-by: Bhaskar Upadhaya <Bhaskar.Upadhaya@nxp.com> [yorks: rebase and fix SPDX tag] [yorks: fix board/freescale/ls1012afrdm/Kconfig] Reviewed-by: York Sun <york.sun@nxp.com>
2018-05-30fastboot: Move fastboot to drivers/fastbootAlex Kiernan
Separate CMD_FASTBOOT from FASTBOOT and move code and configuration to drivers/fastboot. Switch dependencies on FASTBOOT to USB_FUNCTION_FASTBOOT as anyone who wants FASTBOOT before this series wants USB_FUNCTION_FASTBOOT. Split USB_FUNCTION_FASTBOOT from FASTBOOT so they retain their existing behaviour. Signed-off-by: Alex Kiernan <alex.kiernan@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org> Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2018-05-26stm32mp1: add FUSE command supportPatrick Delaunay
Add support of fuse command (read/write/program/sense) on bank 0 to access to BSEC SAFMEM (4096 OTP bits). Signed-off-by: Patrick Delaunay <patrick.delaunay@st.com> Signed-off-by: Patrice Chotard <patrice.chotard@st.com>
2018-05-23arm: armv7m: Clean up some thumb / compiler flag optionsTom Rini
- The correct way to build with thumb mode is to select SYS_THUMB_BUILD - We should be setting -march=armv7-m in arch/arm/Makefile not the sub-config.mk file. Signed-off-by: Tom Rini <trini@konsulko.com>
2018-05-22at91: Minor tweaks to SPL logic for space savings on smartwebTom Rini
- spl_board_init is empty on smartweb so drop that function - When CONFIG_AT91SAM9_WATCHDOG is set we do not disable the watchdog in SPL and instead let full U-Boot handle it. Instead of an empty function just do not call a function. Signed-off-by: Tom Rini <trini@konsulko.com>
2018-05-20Merge branch 'master' of git://git.denx.de/u-boot-socfpgaTom Rini
2018-05-18ARM: socfpga: Convert to DM serialMarek Vasut
Pull the serial port configuration from DT and use DM serial instead of having the serial configuration in two places, DT and board config. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Chin Liang See <chin.liang.see@intel.com> Cc: Dinh Nguyen <dinguyen@kernel.org>
2018-05-18ARM: socfpga: Clean up Kconfig entriesMarek Vasut
Shuffle the default Kconfig entries around so it is not such a mess. No functional change. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Chin Liang See <chin.liang.see@intel.com> Cc: Dinh Nguyen <dinguyen@kernel.org>
2018-05-17mx31pdk: Convert CONFIG_MX31 flag to use Kconfig.Magnus Lilja
Move CONFIG_MX31 from mx31pdk.h to mx31pdk_defconfig and introduce necessary Kconfig changes as well. Signed-off-by: Magnus Lilja <lilja.magnus@gmail.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2018-05-11arm: zynqmp: Add ZynqMP minimal R5 supportMichal Simek
Xilinx ZynqMP also contains dual Cortex R5 which can run U-Boot. This patch is adding minimal support to get U-Boot boot. U-Boot on R5 runs out of DDR with default configuration that's why DDR needs to be partitioned if there is something else running on arm64. Console is done via Cadence uart driver and the first Cadence Triple Timer Counter is used for time. This configuration with uart1 was tested on zcu100-revC. U-Boot 2018.05-rc2-00021-gd058a08d907d (Apr 18 2018 - 14:11:27 +0200) Model: Xilinx ZynqMP R5 DRAM: 512 MiB WARNING: Caches not enabled MMC: In: serial@ff010000 Out: serial@ff010000 Err: serial@ff010000 Net: Net Initialization Skipped No ethernet found. ZynqMP r5> There are two ways how to run this on ZynqMP. 1. Run from ZynqMP arm64 tftpb 20000000 u-boot-r5.elf setenv autostart no && bootelf -p 20000000 cpu 4 disable && cpu 4 release 10000000 lockstep or cpu 4 disable && cpu 4 release 10000000 split 2. Load via jtag when directly to R5 Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2018-05-11arm: zynq: Rework FPGA initializationMichal Simek
This commit moves the FPGA descriptor definition to mach-zynq, where it makes more sense. Based on patches from Ariel D'Alessandro <ariel@vanguardiasur.com.ar> and Ezequiel Garcia <ezequiel@vanguardiasur.com.ar> Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2018-05-07arm: v7R: Add support for MPULokesh Vutla
The Memory Protection Unit(MPU) allows to partition memory into regions and set individual protection attributes for each region. In absence of MPU a default map[1] will take effect. Add support for configuring MPU on Cortex-R, by reusing the existing support for Cortex-M processor. [1] http://infocenter.arm.com/help/index.jsp?topic=/com.arm.doc.ddi0460d/I1002400.html Tested-by: Michal Simek <michal.simek@xilinx.com> Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2018-05-07arm: v7R: Add initial supportMichal Simek
The Cortex-R* processors are a mid-range CPUs for use in deeply-embedded, real-time systems. It implements the ARMv7-R architecture, and includes Thumb-2 technology for optimum code density and processing throughput. Except for MPU(Memory Protection Unit) and few CP15 registers, most of the features are compatible with v7 architecture. So,reuse the same armv7 folder and introduce a new config CPU_V7R in order to differentiate from v7 based platforms. Tested-by: Michal Simek <michal.simek@xilinx.com> Reviewed-by: Tom Rini <trini@konsulko.com> Signed-off-by: Michal Simek <michal.simek@xilinx.com> Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com>
2018-05-07arm: v7: Kconfig: Introduce SYS_ARM_CACHE_CP15Lokesh Vutla
Certain ARM architectures like ARMv7-A, ARMv7-R has support for enabling caches using CP15 registers. To have a common support for all these architectures, introduce a Kconfig symbol SYS_ARM_CACHE_CP15 that selects cache-cp15.c Tested-by: Michal Simek <michal.simek@xilinx.com> Reviewed-by: Tom Rini <trini@konsulko.com> Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com>
2018-05-07arm: v7: Kconfig: Add entry for MMULokesh Vutla
Add a Kconfig entry for MMU and imply for all platforms using cache-cp15.c containing MMU setup. Using imply instead of select so that MMU can be disabled by defconfigs when not needed. Tested-by: Michal Simek <michal.simek@xilinx.com> Reviewed-by: Tom Rini <trini@konsulko.com> Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com>
2018-05-07arm: v7: Kconfig: Rename CPU_V7 as CPU_V7ALokesh Vutla
Currently CPU_V7 kconfig symbol supports only ARMv7A architectures under armv7 folder. This led to a misconception of creating separate folders for armv7m and armv7r. There is no reason to create separate folder for other armv7 based architectures when it can co-exist with few Kconfig symbols. As a first step towards a common folder, rename CPU_V7 as CPUV7A. Later separate Kconfig symbols can be added for CPU_V7R and CPU_V7M and can co exist in the same folder. Reviewed-by: Tom Rini <trini@konsulko.com> Tested-by: Michal Simek <michal.simek@xilinx.com> Suggested-by: Alexander Graf <agraf@suse.de> Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com>
2018-04-30Merge git://git.denx.de/u-boot-imxTom Rini
2018-04-28arm: move SYS_ARCH_TIMER to KConfigAndre Przywara
SYS_ARCH_TIMER guards the usage of the ARM Generic Timer (aka arch timer) in U-Boot. At the moment it is mandatory for ARMv8 and used by a few ARMv7 boards. Add a proper Kconfig symbol to express this dependency properly, allowing certain board configuration to later disable arch timer in case there are any problems with it. Signed-off-by: Andre Przywara <andre.przywara@arm.com> [tuomas: rebase + fix conflicts and resync with moveconfig & use select] Signed-off-by: Tuomas Tynkkynen <tuomas.tynkkynen@iki.fi>
2018-04-28distro: use imply to enable DISTRO_DEFAULTS as SoC defaultMasahiro Yamada
The default of DISTRO_DEFAULTS is messy. Using the 'imply' keyword is equivalent and cleaner. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2018-04-27ARM: mxs: support full SPL frameworkMans Rullgard
This allows using the full SPL framework on mxs devices. In this mode, the u-boot.sb image loaded by the boot ROM contains only the SPL which then loads U-Boot proper or a kernel in falcon mode. Signed-off-by: Mans Rullgard <mans@mansr.com>
2018-04-25rockchip: enable SYS_NS16550 for all SoCs by defaultKever Yang
All rockchip SoCs can use ns16550 driver, enable it for all and set SYS_NS16550_MEM32 for all SoCs. Version-changes: 2 - use imply instead of select Signed-off-by: Kever Yang <kever.yang@rock-chips.com> Acked-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com> Reviewed-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
2018-04-15Merge git://git.denx.de/u-boot-imxTom Rini
2018-04-15mx31ads: DeleteTom Rini
This platform has been marked as orphaned since September 2013, remove. Signed-off-by: Tom Rini <trini@konsulko.com>
2018-04-15imx31_phycore: DeleteTom Rini
2018-04-06stm32mp: handle SYSRESETPatrick Delaunay
Add support of sysreset with generic driver "syscon-reboot" provided by RCC, for U-boot and for SPL. Signed-off-by: Patrick Delaunay <patrick.delaunay@st.com>
2018-04-06stm32mp1: get boot mode from BootRomPatrick Delaunay
SPL copy BootRom boot mode information in TAMP register 21. This TAMP register information is used after relocation to set 2 env variables - boot_device - boot_instance Signed-off-by: Patrick Delaunay <patrick.delaunay@st.com>
2018-03-23arm64: zynqmp: Add support for verifying secure imagesSiva Durga Prasad Paladugu
This patch adds new command "zynqmp" to handle zynqmp specific commands like "zynqmp secure". This secure command is used for verifying zynqmp specific secure images. The secure image can either be authenticated or encrypted or both encrypted and authenticated. The secure image is prepared using bootgen and will be in xilinx specific BOOT.BIN format. The optional key can be used for decryption of encrypted image if user key was specified while creation BOOT.BIN. Signed-off-by: Siva Durga Prasad Paladugu <sivadur@xilinx.com> Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2018-03-23arm: zynq: Wire watchdog internalsMichal Simek
Watchdog is only enabled in full u-boot. Adoption for SPL should be also done because that's the right place where watchdog should be enabled. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2018-03-19arm: stm32: add new architecture for STM32MP familyPatrick Delaunay
- add new arch stm32mp for STM32 MPU/Soc based on Cortex A - support for stm32mp157 SOC - SPL is used as first boot stage loader - using driver model for all the drivers, even in SPL - all security feature are deactivated (ETZC and TZC) - reused STM32 MCU drivers when it is possible Signed-off-by: Patrick Delaunay <patrick.delaunay@st.com>
2018-03-16Convert all of CONFIG_CONS_INDEX to KconfigTom Rini
This converts the following to Kconfig: CONFIG_CONS_INDEX We have existing entries for this option in a number of places, with different guards on them. They're also sometimes used for things not directly inside of the serial driver. First, introduce a new symbol to guard the use of CONFIG_CONS_INDEX, so that in the case where we don't need this for the serial driver, but for some other use, we can still do it. Next, consolidate all of these into the single entry in drivers/serial/Kconfig. Finally, introduce CONS_INDEX_[023456] so that we can imply a correct value here to make the defconfig side of this smaller. Signed-off-by: Adam Ford <aford173@gmail.com> [trini: Rework a lot of the logic here, such that I took authorship from Adam, but kept his S-o-B line] Signed-off-by: Tom Rini <trini@konsulko.com>
2018-02-23ARM: Kconfig: Move TI_SECURE_DEVICE to a common areaAndrew F. Davis
TI_SECURE_DEVICE is used by both OMAP2+ and Keystone2 family devices, and so when ARCH_OMAP2PLUS was used to gate off the OMAP2+ Kconfig Keystone2 family devices lost this config option. Move this option out of mach-omap2 Kconfig to a spot accessible by both families. We picked arch/arm/Kconfig over the TI specific board/ti/ location as this option is not specific to our boards but rather our architecture. Plus at some point this option can be changed to just SECURE_DEVICE, as having secure parts is not exclusive to TI and so other vendors can interpret this option as needed by their device configurations. Fixes: a93fbf4a7892 ("ARM: omap2+: rename config to ARCH_OMAP2PLUS and consolidate Kconfig") Signed-off-by: Andrew F. Davis <afd@ti.com> Reviewed-by: Lokesh Vutla <lokeshvutla@ti.com>
2018-02-15arm: socfpga: use imply instead of select where applicableSimon Goldschmidt
Kconfig should only 'select' features that are required for an arch. Standard features that can be disabled without breaking board support should use 'imply' instead, to allow users to disable it. These options are changed for mach-socfpga: - DM_SPI & DM_SPI_FLASH: only required with QSPI support enabled - SYS_MMCSD_RAW_MODE_U_BOOT_USE_PARTITION: the boot rom supports a partitionless mode also, where SPL is located at address 0 - HW_WATCHDOG: while all mainline board defconfigs use it, U-Boot should still work without it. Signed-off-by: Simon Goldschmidt <sgoldschmidt@de.pepperl-fuchs.com>
2018-02-15Convert socfpga: select CONFIG_HW_WATCHDOG support for ARCH_SOCFPGALukasz Majewski
All Socfpga boards from ./include/configs/socfpga_* define CONFIG_HW_WATCHDOG. To ease CONFIG_HW_WATCHDOG conversion to Kconfig select it in config ARCH_SOCFPGA (arch/arm/Kconfig) section. Signed-off-by: Lukasz Majewski <lukma@denx.de> Signed-off-by: Simon Goldschmidt <sgoldschmidt@de.pepperl-fuchs.com>
2018-02-13arm: update Kconfig help for ENABLE_ARM_SOC_BOOT0_HOOKSimon Goldschmidt
When this config is enabled, <asm/arch/boot0.h> is included, but the Kconfig help says this should be a define (ARM_SOC_BOOT0_HOOK). The code for this in arch/arm/lib/vectors.s was changed on 01/02/2017 with commit ce62e57fc571 ("ARM: boot0 hook: remove macro, include whole header file"). Signed-off-by: Simon Goldschmidt <sgoldschmidt@de.pepperl-fuchs.com>
2018-02-08spl: use ARCH_MX23/28 to specify SPL_LDSCRIPTStefan Agner
Simplify SPL_LDSCRIPT config by using the new arch Kconfig configurations ARCH_MX23 and ARCH_MX28. Signed-off-by: Stefan Agner <stefan.agner@toradex.com>
2018-02-08arm: imx: mx28: Move MX28 selection to KconfigStefan Agner
The motivation for moving MX28 selection to Kconfig is to be able to better handle NAND MXS selection through Kconfig. This selection method also aligns with the way other i.MX SoCs are selected in U-Boot. Signed-off-by: Stefan Agner <stefan.agner@toradex.com>
2018-02-08arm: imx: mx23: Move MX23 selection to KconfigStefan Agner
The motivation for moving MX23 selection to Kconfig is to be able to better handle NAND MXS selection through Kconfig. This selection method also aligns with the way other i.MX SoCs are selected in U-Boot. Signed-off-by: Stefan Agner <stefan.agner@toradex.com>
2018-02-08Convert CONFIG_MXC_GPIO to KconfigAdam Ford
This converts the following to Kconfig: CONFIG_MXC_GPIO Signed-off-by: Adam Ford <aford173@gmail.com>
2018-02-04imx: add i.MX8M into KconfigPeng Fan
Add i.MX8M into Kconfig, create a new folder mx8m dedicated for i.MX8M. Signed-off-by: Peng Fan <peng.fan@nxp.com> Reviewed-by: Fabio Estevam <fabio.estevam@nxp.com> Cc: Stefano Babic <sbabic@denx.de> Reviewed-by: Stefano Babic <sbabic@denx.de>
2018-01-31Merge tag 'xilinx-for-v2018.03' of git://git.denx.de/u-boot-microblazeTom Rini
Xilinx changes for v2018.03 - Several Kconfig fixes (also moving configs to defconfigs) - Some DTS updates - ZynqMP psu rework based on Zynq concept - Add low level initialization for zc770 and zcu102 - Add support for Zynq zc770 x16 nand configuration - Add mini nand/emmc ZynqMP targets - Some arasan nand changes
2018-01-30arm: zynq: Enable DM_GPIO when neededMichal Simek
There are two reasons for doing this change. There is still !DM driver for xilinx soft gpio IP and especially it is saving some space for memory constrained boards like cse (almost ~400B). Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2018-01-30arm: zynq: Enable DM_ETH and DM_MMC only if subsystem is enabledMichal Simek
Do not enable DM_ETH/MMC if subsystems are not enabled. This saves memory for memory constrained boards like cse. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2018-01-30arm: zynq: Enable BLK when neededMichal Simek
There is no reason to enable BLK by default for all boards which is just increasing memory footprint for memory contrained boards like cse. zc770s are also saving some space. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2018-01-29serial: Make full device search optionalAlexander Graf
Commit 608b0c4ad4e5ec0c ("serial: Use next serial device if probing fails") added code to search for more serial devices if the default one was not probed correctly. Unfortunately, that breaks omap3_evm. So while investigating why that is the case, let's disable the full search for everyone but bcm283x where it is needed. Fixes: 608b0c4ad4e5ec0c ("serial: Use next serial device if probing fails") Reported-by: Derald D. Woods <woods.technical@gmail.com> Signed-off-by: Alexander Graf <agraf@suse.de>
2018-01-28pl01x: Convert CONFIG_PL01X_SERIAL to KconfigAlexander Graf
We want to use Kconfig logic to depend on whether pl01x devices are built in, so let's convert their inclusion selection to Kconfig. This round goes to pl01x. Signed-off-by: Alexander Graf <agraf@suse.de>
2018-01-28pl011: Convert CONFIG_PL011_SERIAL to KconfigAlexander Graf
We want to use Kconfig logic to depend on whether pl01x devices are built in, so let's convert their inclusion selection to Kconfig. This round goes to pl011. Signed-off-by: Alexander Graf <agraf@suse.de>
2018-01-28pl010: Convert CONFIG_PL010_SERIAL to KconfigAlexander Graf
We want to use Kconfig logic to depend on whether pl01x devices are built in, so let's convert their inclusion selection to Kconfig. This round goes to pl010. Signed-off-by: Alexander Graf <agraf@suse.de>
2018-01-28arm: add support for PDU001Felix Brack
This patch adds support for the PDU001 board. Signed-off-by: Felix Brack <fb@ltec.ch> Reviewed-by: Tom Rini <trini@konsulko.com>
