CONFIG_SYS_BOOT_GET_CMDLINE
CONFIG_SYS_BOOT_GET_KBD
Signed-off-by: Derald D. Woods <woods.technical@gmail.com>
Support common commands bdinfo and image format,
also modify common generic flow for RISC-V.
Signed-off-by: Rick Chen <rick@andestech.com>
Signed-off-by: Rick Chen <rickchen36@gmail.com>
Signed-off-by: Greentime Hu <green.hu@gmail.com>
This migrates ASIX, ASIX88179, MCS7830, RTL8152 and SMSC95XX to Kconfig.
Update defconfigs.
Signed-off-by: Chris Packham <judge.packham@gmail.com>
CONFIG_USB_HOST_ETHER is the framework that the drivers are dependent on
USB_HOST_ETHER. Use this as a menu and move the existing LAN75XX and
LAN78XX options under new menu. Finally update the defconfigs that need
CONFIG_USB_HOST_ETHER.
Let's imply the 'pci' command to access the de facto interconnect
bus in an x86 system.
CONFIG_CMD_ZBOOT
Reviewed-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
CONFIG_CMD_SF_TEST
After MMC is converted to DM, convert to use DM SCSI as well for all
x86 boards and imply BLK for both MMC and SCSI drivers.
CONFIG_SCSI_DEV_LIST is no longer used. Clean them up.
Convert the pci_mmc driver over to driver model and migrate all x86 boards
that use it.
Tested-by: Bin Meng <bmeng.cn@gmail.com>
[bmeng: remove DM_MMC from edison_defconfig]
Like other peripheral drivers, move USB related drivers to platform
Kconfig as well.
Reviewed-by: Andy Shevchenko <andy.shevchenko@gmail.com>
Now that all x86 boards have been converted to use DM, we can imply
these uclass drivers (DM_ETH, DM_RTC, DM_USB, DM_VIDEO) from the
top level.
Previously DM_GPIO, DM_KEYBOARD, DM_SERIAL, DM_SPI, DM_SPI_FLASH
are selected. Change to use 'imply' to allow them to be removed.
Note with this change, chromebook_link64 build fails:
common/built-in.o:(.data.env_htab+0xc): undefined reference to 'env_flags_validate'
lib/built-in.o: In function `hsearch_r':
lib/hashtable.c:380: undefined reference to 'env_callback_init'
lib/hashtable.c:382: undefined reference to 'env_flags_init'
make[1]: *** [spl/u-boot-spl] Error 1
CONFIG_SPL_ENV_SUPPORT is required for chromebook_link64 to build
again. This is just a workaround as it is not needed at all. See
commit bda40d5 "x86: qemu: Add a config for 64-bit U-Boot" for
the same issue seen on QEMU 64-bit target.
This is a must have for all x86 boards.
PCI is the de facto interconnect bus in an x86 system.
x86 is using the built-in libgcc implementation and this cannot be
turned off.
Without a timer, U-Boot just doesn't boot. This is not something
we can turn off.
Kbuild complains if USB is not selected before any of host driver.
warning: (X86) selects USB_EHCI_HCD which has unmet direct dependencies (USB)
Select it for X86.
Fixes: 64d6ac5bc4a9 ("Kconfig: USB: Migrate CONFIG_USB_EHCI_HCD users to Kconfig")
[bmeng: Update all x86 boards' defconfig files to remove CONFIG_USB]
The above CONFIG options are in Kconfig, and now have correct depends and
inter-dependencies. Migrate these to configs/ from include/configs/. In the
case of CMD_UBIFS also change it to be a default y if CMD_UBI.
CONFIG_CMD_SATA
CONFIG_SCSI
AVR32 is gone. It's already more than two years for no support in Buildroot,
even longer there is no support in GCC (last version is heavily patched 4.2.4).
Linux kernel v4.12 got rid of it (and v4.11 didn't build successfully).
There is no good point to keep this support in U-Boot either.
This reverts commit ddb3ac3c716f56cead695444e65a7ba7b0946555.
With MMC converted to driver model, SCSI driver is broken due to
zero address access at (ops->read) in block_dread() function.
The fix (SCSI driver converted to DM) is ready in u-boot-dm branch,
but it is too late for this relese to get that in.
Now that these symbols are in Kconfig, migrate all users. Use imply on
a number of platforms that default to having this enabled. As part of
this we must migrate some straglers for CMD_FAT and DOS_PARTITION.
Currently these (board agnostic) commands cannot be selected using
menuconfig and friends. Fix this the obvious way. As part of this,
don't muddle the meaning of CONFIG_HASH_VERIFY to mean both 'hash -v'
and "we have a hashing command" as this makes the Kconfig logic odd.
Signed-off-by: Daniel Thompson <daniel.thompson@linaro.org>
[trini: Re-apply, add imply for a few cases, run moveconfig.py, also
migrate CRC32_VERIFY]
Enable this option by default on sandbox to increase build coverage.
CONFIG_CMD_LZMADEC
CONFIG_LZMA
CONFIG_CMD_IRQ
CONFIG_CMD_IOTRACE
CONFIG_CMD_IO
CONFIG_CMD_HASH
[trini: Rework slightly, enable on some boards again]
CONFIG_CMD_GETTIME
CONFIG_CMD_FPGA_LOADBP
CONFIG_CMD_FPGA_LOADFS
CONFIG_CMD_FPGA_LOADMK
CONFIG_CMD_FPGA_LOADP
Support AG101P serial device tree flow.
Signed-off-by: rick <rick@andestech.com>
that use it.
Migrate the rest of the users of CONFIG_USB_EHCI_HCD over to Kconfig.
For a few SoCs, imply or default y this if USB is enabled. In some
cases we had not already migrated to CONFIG_USB so do that as well.
The OpenRISC architecture is currently unmaintained, remove.
Cc: Stefan Kristiansson <stefan.kristiansson@saunalahti.fi>
The SPARC architecture is currently unmaintained, remove.
Cc: Francois Retief <fgretief@spaceteq.co.za>
The architecture is currently unmaintained, remove.
Cc: Benjamin Matthews <mben12@gmail.com>
Cc: Chong Huang <chuang@ucrobotics.com>
Cc: Dimitar Penev <dpn@switchfin.org>
Cc: Haitao Zhang <hzhang@ucrobotics.com>
Cc: I-SYST Micromodule <support@i-syst.com>
Cc: M.Hasewinkel (MHA) <info@ssv-embedded.de>
Cc: Martin Strubel <strubel@section5.ch>
Cc: Peter Meerwald <devel@bct-electronic.com>
Cc: Sonic Zhang <sonic.adi@gmail.com>
Cc: Valentin Yakovenkov <yakovenkov@niistt.ru>
Cc: Wojtek Skulski <info@skutek.com>
Cc: Wojtek Skulski <skulski@pas.rochester.edu>
This commit replaces legacy timer code with usage of arc timer
driver.
It removes arch/arc/lib/time.c file and selects CONFIG_CLK,
CONFIG_TIMER and CONFIG_ARC_TIMER options for all ARC boards by default.
Therefore we remove CONFIG_CLK option from less common axs101 and
axs103 defconfigs.
Also it removes legacy CONFIG_SYS_TIMER_RATE config symbol from
axs10x.h, tb100.h and nsim.h configs files as it is no longer required.
Signed-off-by: Vlad Zakharov <vzakhar@synopsys.com>
CONFIG_ARCH_MISC_INIT
CONFIG_ARCH_EARLY_INIT_R
This option should not really be user selectable. Note that on PowerPC
we currently only need BOARD_LATE_INIT when CHAIN_OF_TRUST is enabled so be
conditional on that.
Acked-by: Masahiro Yamada <yamada.masahiro@socionext.com> (for UniPhier)
Once we migrate to DM-based drivers, we cannot go back to legacy
ones, i.e. config options like DM_* are not user-configurable.
Make SANDBOX and X86 select DM_KEYBOARD like other platforms do.
The Xtensa processor architecture is a configurable, extensible,
and synthesizable 32-bit RISC processor core provided by Tensilica, inc.
This is the second part of the basic architecture port, adding the
'arch/xtensa' directory and a readme file.
Signed-off-by: Chris Zankel <chris@zankel.net>
Signed-off-by: Max Filippov <jcmvbkbc@gmail.com>
For most of architectures in U-Boot, virtual address is straight
mapped to physical address. So, it makes sense to have generic
defines of ioremap and friends in <linux/io.h>.
All of them are just empty and will disappear at compile time, but
they will be helpful to implement drivers which are counterparts of
Linux ones.
I notice MIPS already has its own implementation, so I added a
Kconfig symbol CONFIG_HAVE_ARCH_IOREMAP which MIPS (and maybe
Sandbox as well) can select.
Reviewed-by: Daniel Schwierzeck <daniel.schwierzeck@gmail.com>
Update the sandbox MMC emulation to use driver model for MMC operations.
These are no longer used. The migration is complete. Drop these options.
Acked-by: Angelo Dureghello <angelo@sysam.it>
Acked-by: Andreas Bießmann <andreas@biessmann.org>
Prepare sub-folder for device-tree files. Make support for
device-tree on MIPS available in Kbuild/Kconfig.
Signed-off-by: Daniel Schwierzeck <daniel.schwierzeck@gmail.com>
Signed-off-by: Purna Chandra Mandal <purna.mandal@microchip.com>
Add private libgcc
Signed-off-by: Angelo Dureghello <angelo@sysam.it>
