path: root/arch/Kconfig
2015-04-18dm: select CONFIG_DM* optionsMasahiro Yamada
As mentioned in the previous commit, adding default values in each Kconfig causes problems because it does not co-exist with the "depends on" syntax. (Please note this is not a bug of Kconfig.) We should not do so unless we have a special reason. Actually, for CONFIG_DM*, we have no good reason to do so. Generally, CONFIG_DM is not a user-configurable option. Once we convert a driver into Driver Model, the board only works with Driver Model, i.e. CONFIG_DM must be always enabled for that board. So, using "select DM" is more suitable rather than allowing users to modify it. Another good thing is, Kconfig warns unmet dependencies for "select" syntax, so we easily notice bugs. Actually, CONFIG_DM and other related options have been added without consistency: some into arch/*/Kconfig, some into board/*/Kconfig, and some into configs/*_defconfig. This commit prefers "select" and cleans up the following issues. [1] Never use "CONFIG_DM=n" in defconfig files It is really rare to add "CONFIG_FOO=n" to disable CONFIG options. It is more common to use "# CONFIG_FOO is not set". But here, we do not even have to do it. Less than half of OMAP3 boards have been converted to Driver Model. Adding the default values to arch/arm/cpu/armv7/omap3/Kconfig is weird. Instead, add "select DM" only to appropriate boards, which eventually eliminates "CONFIG_DM=n", etc. [2] Delete redundant CONFIGs Sandbox sets CONFIG_DM in arch/sandbox/Kconfig and defines it again in configs/sandbox_defconfig. Likewise, OMAP3 sets CONFIG_DM arch/arm/cpu/armv7/omap3/Kconfig and defines it also in omap3_beagle_defconfig and devkit8000_defconfig. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2015-04-03serial-arc: switch to DMAlexey Brodkin
Now when all infrastructure in ARC is ready for it let's switch ARC UART to driver model. Signed-off-by: Alexey Brodkin <abrodkin@synopsys.com> Cc: Masahiro Yamada <yamada.masahiro@socionext.com> Cc: Simon Glass <sjg@chromium.org>
2015-03-28generic-board: select SYS_GENERIC_BOARD for some architecturesMasahiro Yamada
We have done with the generic board conversion for all the boards of ARC, Blackfin, M68000, MicroBlaze, MIPS, NIOS2, Sandbox, X86. Let's select SYS_GENERIC_BOARD for those architectures, so we can tell which architecture has finished the conversion at a glance. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Alexey Brodkin <abrodkin@synopsys.com>
2015-03-28generic-board: move __HAVE_ARCH_GENERIC_BOARD to KconfigMasahiro Yamada
Move the option to Kconfig renaming it to CONFIG_HAVE_GENERIC_BOARD. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Alexey Brodkin <abrodkin@synopsys.com>
2015-02-12powerpc: Permit device tree control of U-Boot (CONFIG_OF_CONTROL)Simon Glass
Enable this in the Kconfig so that PowerPC boards can use device tree to configure U-Boot. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-02-09arc: build libgcc in U-BootAlexey Brodkin
This way we may have very limited set of functions implemented so we save some space. Also it allows us to build U-Boot for any ARC core with the same one toolchain because we don't rely on pre-built libgcc. For example: * we may use little-endian toolchain but build U-Boot for ether endianess * we may use non-multilibbed uClibc toolchain but build U-Boot for whatever ARC CPU flavour that current GCC supports Private libgcc built from generic C implementation contributes only 144 bytes to .text section so we don't see significant degradation of size: --->8--- $ arc-linux-size u-boot.libgcc-prebuilt text data bss dec hex filename 222217 24912 214820 461949 70c7d u-boot.libgcc-prebuilt $ arc-linux-size u-boot.libgcc-private text data bss dec hex filename 222361 24912 214820 462093 70d0d u-boot.libgcc-private --->8--- Also I don't notice visible performance degradation compared to pre-built libgcc (where at least "*div*" functions are had-written in assembly) on typical operations of downloading 10Mb uImage over TFTP and bootm. Signed-off-by: Alexey Brodkin <abrodkin@synopsys.com>
2014-10-23kconfig: move CONFIG_USE_PRIVATE_LIBGCC to KconfigMasahiro Yamada
The private libgcc is supported only on ARM, MIPS, PowerPC, SH, x86. Those architectures should "select" HAVE_PRIVATE_LIBGCC and CONFIG_USE_PRIVATE_LIBGCC should depend on it. Currently, this option is enabled on Tegra boards and x86 architecture. Move the definition from header files to Kconfig. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Tested-by: Simon Glass <sjg@chromium.org> Acked-by: Simon Glass <sjg@chromium.org> Cc: Stephen Warren <swarren@nvidia.com> Cc: Tom Warren <twarren@nvidia.com>
2014-09-25kconfig: move CONFIG_OF_* to KconfigMasahiro Yamada
This commit moves: CONFIG_OF_CONTROL CONFIG_OF_SEPARATE CONFIG_OF_EMBED CONFIG_OF_HOSTFILE Because these options are currently not supported for SPL, the "Device Tree Control" menu does not appear in the SPL configuration. Note: zynq-common.h should be adjusted so as not to change the default value of CONFIG_SPL_FAT_LOAD_PAYLOAD_NAME. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Acked-by: Simon Glass <sjg@chromium.org> Cc: Stephen Warren <swarren@nvidia.com> Cc: Minkyu Kang <mk7.kang@samsung.com> Acked-by: Michal Simek <michal.simek@xilinx.com>
2014-09-13kconfig: add CONFIG_SYS_{ARCH, CPU, ...} type def to arch/KconfigMasahiro Yamada
This commit adds the type definitions (+ help messages) of CONFIG_SYS_{ARCH, CPU, SOC, VENDOR, BOARD, CONFIG_NAME} to arch/Kconfig, which would save lots of type defs for taget boards. (See also the next commit.) Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-07-30kconfig: add basic Kconfig filesMasahiro Yamada
This commit adds more Kconfig files, which were written by hand. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Acked-by: Simon Glass <sjg@chromium.org>
