path: root/api
2017-05-22Kconfig: Add a CONFIG_IDE optionSimon Glass
At present IDE support is controlled by CONFIG_CMD_IDE. Add a separate CONFIG_IDE option so that IDE support can be enabled without requiring the 'ide' command. Update existing users and move the ide driver into drivers/block since it should not be in common/. Signed-off-by: Simon Glass <sjg@chromium.org>
2017-04-08Apparent conflict between CONFIG_BLK and CONFIG_APIfuz@fuz.su
Good evening, I am trying to port FreeBSD to the ASUS Tinker Board, a computer based on the Rockchip 3288 SoC. FreeBSD's boot loader (named loader(8)) needs CONFIG_API to be enabled, but trying to build an U-Boot from trunk with both CONFIG_API and CONFIG_BLK (as required for Rockchip SoC's?) leads to the following build failure: $ CROSS_COMPILE=arm-none-eabi- gmake tinker-rk3288_defconfig all ... CC api/api_storage.o api/api_storage.c: In function 'dev_read_stor': api/api_storage.c:334:9: error: 'struct blk_desc' has no member named 'block_read' if ((dd->block_read) == NULL) { ^~ api/api_storage.c:339:11: error: 'struct blk_desc' has no member named 'block_read' return dd->block_read(dd, start, len, buf); ^~ api/api_storage.c:340:1: warning: control reaches end of non-void function [-Wreturn-type] } ^ gmake[2]: *** [scripts/Makefile.build:281: api/api_storage.o] Fehler 1 gmake[1]: *** [Makefile:1229: api] Fehler 2 gmake: *** [Makefile:460: __build_one_by_one] Error 2 I applied the following fix, but the product doesn't boot. Perhaps that's not a property of the fix though: Yours, Robert Clausecker
2017-02-08kconfig: Add API kconfig fileEmmanuel Vadot
Add kconfig file to enable API support Signed-off-by: Emmanuel Vadot <manu@bidouilliste.com> Reviewed-by: Tom Rini <trini@konsulko.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-01-20api: storage: Test all block device in dev_stor_getEmmanuel Vadot
In a config with one MMC at device id '1' and no MMC at device id '0' (a BeagleBone Black with no sd inserted for example), the current code will first test to access the MMC 0 (sd port), seeing that no device is present it will simply return that no more device are present for this class. This patch fixes this by testing all devices for each class. Signed-off-by: Emmanuel Vadot <manu@bidouilliste.com>
2017-01-20api: Use hashtable function for API_env_enumEmmanuel Vadot
The current code can loop undefinitly as it doesn't parse correctly the env data. Since the env is an hashtable, use the hashtable function for the API_ENV_ENUM api call. Signed-off-by: Emmanuel Vadot <manu@bidouilliste.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2016-12-04Cosmetic api: api_storage.c Spelling correctionWalt Feasel
Make spelling correction for 'from' Signed-off-by: Walt Feasel <waltfeasel@gmail.com>
2016-12-04Cosmetic api: api_storage.c Comment styleWalt Feasel
Make comment style modifications Signed-off-by: Walt Feasel <waltfeasel@gmail.com>
2016-12-04Cosmetic api: api_storage.c Line over 80 charWalt Feasel
Make checkpatch style modification for WARNING: line over 80 characters Signed-off-by: Walt Feasel <waltfeasel@gmail.com>
2016-12-04Cosmetic api: api_storage.c Blank line after {Walt Feasel
Make checkpatch style modification for CHECK: Blank lines aren't necessary after an open brace '{' Signed-off-by: Walt Feasel <waltfeasel@gmail.com>
2016-12-04Cosmetic api: api_storage.c Align parenthesisWalt Feasel
Make checkpatch style modification for CHECK: Alignment should match open parenthesis Signed-off-by: Walt Feasel <waltfeasel@gmail.com>
2016-10-24api: storage: Avoid enumeration for non-configured subsystemEmmanuel Vadot
If a subsystem wasn't configured, avoid enumeration. Signed-off-by: Emmanuel Vadot <manu@bidouilliste.com>
2016-07-22api: Disable api_net when DM is usedMichal Simek
When CONFIG_API is selected with DM_ETH this error is present: api/api_net.c: In function 'dev_enum_net': api/api_net.c:61:35: warning: initialization from incompatible pointer type struct eth_device *eth_current = eth_get_dev(); ^ api/api_net.c:68:39: error: dereferencing pointer to incomplete type memcpy(di->di_net.hwaddr, eth_current->enetaddr, 6); ^ Disable api_net functions when ETH_DM is selected. Signed-off-by: Chris Johns <chrisj@rtems.org> Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2016-05-21Fix FreeBSD loader API so that it works on both 32-bit and 64-bit targets.Stanislav Galabov
Specifically tested on MIPS under QEMU (works with all combination of bit-ness and endian-ness) Signed-off-by: Stanislav Galabov <sgalabov@gmail.com>
2016-05-17dm: scsi: Rename CONFIG_CMD_SCSI to CONFIG_SCSISimon Glass
This option currently enables both the command and the SCSI functionality. Rename the existing option to CONFIG_SCSI since most of the code relates to the feature. Signed-off-by: Simon Glass <sjg@chromium.org>
2016-03-14dm: blk: Rename get_dev() to blk_get_dev()Simon Glass
The current name is too generic. Add a 'blk_' prefix to aid searching and make its purpose clearer. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Tested-by: Stephen Warren <swarren@nvidia.com>
2016-03-14dm: Drop the block_dev_desc_t typedefSimon Glass
Use 'struct' instead of a typdef. Also since 'struct block_dev_desc' is long and causes 80-column violations, rename it to struct blk_desc. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Tested-by: Stephen Warren <swarren@nvidia.com>
2016-03-08api: Export API structure address as an environment variableStanislav Galabov
This patch makes the U-Boot api export its structure address as an environment variable, so it can be used to directly hint FreeBSD's loader of api's location. The relevant FreeBSD loader change is currently under review at: https://reviews.freebsd.org/D5492 Signed-off-by: Stanislav Galabov <sgalabov@gmail.com>
2016-02-08api: Add FreeBSD API support for MIPS platformsStanislav Galabov
This patch adds U-Boot API support (used by FreeBSD loader) for MIPS platforms. Signed-off-by: Stanislav Galabov <sgalabov@gmail.com>
2016-01-13block: pass block dev not num to read/write/erase()Stephen Warren
This will allow the implementation to make use of data in the block_dev structure beyond the base device number. This will be useful so that eMMC block devices can encompass the HW partition ID rather than treating this out-of-band. Equally, the existence of the priv field is crying out for this patch to exist. Signed-off-by: Stephen Warren <swarren@nvidia.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2015-09-15api_storage: Fix non-first storage device enumerationAndreas Färber
When enabling CONFIG_API and chain-loading GRUB2 on jetson-tk1, only the eMMC would show up as (hd0), but not the SD card, leading to GRUB not finding its configuration and modules, falling back to a rescue shell. This is because enum_ended would get set for !more after returning a cookie for the first MMC device in group 3. Fix this by properly setting the "more" argument also in the case of the first storage device of a group. Signed-off-by: Andreas Färber <afaerber@suse.de>
2015-04-18net: Remove the bd* parameter from net stack functionsJoe Hershberger
This value is not used by the network stack and is available in the global data, so stop passing it around. For the one legacy function that still expects it (init op on old Ethernet drivers) pass in the global pointer version directly to avoid changing that interface. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> Reported-by: Simon Glass <sjg@chromium.org> Reviewed-by: Simon Glass <sjg@chromium.org> Signed-off-by: Simon Glass <sjg@chromium.org> (Trival fix to remove an unneeded variable declaration in 4xx_enet.c)
2014-08-21api: fix build without CMD_NET supportJeroen Hofstee
Provide stubs in case that no NET interface is supported. Signed-off-by: Jeroen Hofstee <jeroen@myspectrum.nl>
2014-03-07powerpc: mpc8260: consolidate CONFIG_MPC8260 and CONFIG_8260Masahiro Yamada
Before this commit, CONFIG_MPC8260 and CONFIG_8260 were used mixed-up. All boards with mpc8260 cpu defined both of them: - CONFIG_MPC8260 was defined in board config headers and include/common.h - CONFIG_8260 was defined arch/powerpc/cpu/mpc8260/config.mk We do not need to have both of them. This commit keeps only CONFIG_MPC8260. This commit does: - Delete CONFIG_8260 and CONFIG_MPC8260 definition in config headers and include/common.h - Rename CONFIG_8260 to CONFIG_MPC8260 in arch/powerpc/cpu/mpc8260/config.mk. - Rename #ifdef CONFIG_8260 to #ifdef CONFIG_MPC8260 Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Wolfgang Denk <wd@denx.de>
2013-11-25Makefile: descend into subdirectories only when CONFIG_API is definedMasahiro Yamada
All objects under api/ and examples/api/ directories are selected by CONFIG_API. So we can move CONFIG_API switch to the top Makefile. In order to use CONFIG_API, the definition of SUBDIR_EXAMPLES-y must be moved after "sinlude $(obj)include/autoconf.mk". Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2013-11-01dts, api, test: convert makefiles to Kbuild styleMasahiro Yamada
2013-05-15Power: remove support for Freescale MPC8220Wolfgang Denk
The Freescale MPC8220 Power Architecture processors have long reached EOL; Freescale does not even list these any more on their web site. Remove the code to avoid wasting maitaining efforts on dead stuff. Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Andy Fleming <afleming@gmail.com>
2013-03-21api/api_display: use the getters for console size infoJeroen Hofstee
cc: Che-Liang Chiou <clchiou@chromium.org> Acked-by: Che-Liang Chiou <clchiou@chromium.org> Signed-off-by: Jeroen Hofstee <jeroen@myspectrum.nl>
2011-11-15api: export LCD device to external appsChe-Liang Chiou
This patch exports LCD info-query and bitmap-rendering functions to external apps. This patch is tested on a Seaboard. Because the LCD driver is not yet upstreamed, the test was done in a local downstream repo. Signed-off-by: Che-Liang Chiou <clchiou@chromium.org>
2011-10-05net: drop !NET_MULTI codeMike Frysinger
This is long over due. All but two net drivers have been converted, but those have now been dropped. The only thing left to do is actually delete all references to NET_MULTI and code that is compiled when that is not defined. So here we scrub the core code. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2010-11-28do_reset: unify duplicate prototypesMike Frysinger
The duplication of the do_reset prototype has gotten out of hand, and they're not all in sync. Unify them all in command.h. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2009-07-23api: Fix broken build on ARM.Piotr Ziecik
This patch fixes broken build introduced by commit 84bf7ca522e94ec402a1264b01971b924b7e268f (api: remove un-needed ifdef CONFIG_API already handle by the Makefile). Signed-off-by: Piotr Ziecik <kosmo@semihalf.com>
2009-06-1283xx: Replace CONFIG_MPC83XX with CONFIG_MPC83xxPeter Tyser
Use the standard lowercase "xx" capitalization that other Freescale architectures use for CPU defines to prevent confusion and errors Signed-off-by: Peter Tyser <ptyser@xes-inc.com> Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2009-05-15api: remove un-needed ifdef CONFIG_API already handle by the MakefileJean-Christophe PLAGNIOL-VILLARD
2008-10-14api: fix type mismatchMatthias Fuchs
This patch fixes a type mismatch and thus removes a compiler warning when compiling with CONFIG_API on powerpc. Signed-off-by: Matthias Fuchs <matthias.fuchs@esd-electronics.com>
2008-10-14api: Fix building with CONFIG_APIMatthias Fuchs
This patch fixes building with CONFIG_API and CONFIG_USB_STORAGE. USB_MAX_STOR_DEV is defined in include/usb.h, but needed in api/api_storage.c. Signed-off-by: Matthias Fuchs <matthias.fuchs@esd-electronics.com>
2008-08-06Fix merge problemsStefan Roese
2008-05-14environment: cleanup prototype declarations of env functions.Wolfgang Denk
2008-05-12Revert "Change env_get_char from a global function ptr to a function."Wolfgang Denk
This reverts commit c0559be371b2a64b1a817088c3308688e2182f93 which is known to break booting from dataflash and NAND.
2008-05-12API: remove duplicate syscall checkJean-Christophe PLAGNIOL-VILLARD
2008-04-17Change env_get_char from a global function ptr to a function.Joakim Tjernlund
This avoids an early global data reference. Signed-off-by: Joakim Tjernlund <Joakim.Tjernlund@transmode.se>
2008-02-14Fix remaining CONFIG_COMMANDSJean-Christophe PLAGNIOL-VILLARD
update comments Fix coding style Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2008-01-29API: Convert conditional building to the new scheme.Rafal Jaworowski
This fixes a build breakage with CONFIG_API enabled, which appeared after the recent changes in the U-Boot build system. Signed-off-by: Rafal Jaworowski <raj@semihalf.com>
2008-01-10Coding Style cleanup; update CHANGELOGWolfgang Denk
