path: root/api/api.c
2019-12-02crc32: Use the crc.h header for crc functionsSimon Glass
Drop inclusion of crc.h in common.h and use the correct header directly instead. With this we can drop the conflicting definition in fw_env.h and rely on the crc.h header, which is already included. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com>
2019-11-07api: storage: Add the missing write operation supportCristian Ciocaltea
API_dev_write(va_list ap) is currently lacking the write support to storage devices because, historically, those devices did not implement block_write() The solution has been tested by loading and booting a (patched) GRUB instance in a QEMU vexpress-a9 environment. The disk write operations were triggered with GRUB's save_env command. Signed-off-by: Cristian Ciocaltea <cristian.ciocaltea@gmail.com>
2019-08-11env: Rename environment.h to env_internal.hSimon Glass
This file contains lots of internal details about the environment. Most code can include env.h instead, calling the functions there as needed. Rename this file and add a comment at the top to indicate its internal nature. Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Joe Hershberger <joe.hershberger@ni.com> Reviewed-by: Simon Goldschmidt <simon.k.r.goldschmidt@gmail.com> [trini: Fixup apalis-tk1.c] Signed-off-by: Tom Rini <trini@konsulko.com>
2019-08-11env: Drop the ACTION typedefSimon Glass
Avoid using a typedef here which is unnecessary. Add an 'env_' prefix to both the enum and its members to make it clear that these are related to the environment. Add an ENV prefix to these two flags so that it is clear what they relate to. Also move them to env.h since they are part of the public API. Use an enum rather than a #define to tie them together. Signed-off-by: Simon Glass <sjg@chromium.org>
2019-08-11env: Drop the ENTRY typedefSimon Glass
U-Boot is not supposed to use typedef for structs anymore. Also this name is the same as the ENTRY() macro used in assembler files, and 'entry' itself is widely used in U-Boot (>8k matches). Drop the typedef and rename the struct to env_entry to reduce confusion. Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2019-08-11env: Move env_set_hex() to env.hSimon Glass
Move env_set_hex() over to the new header file along with env_set_addr() which uses it. Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2017-08-16env: Rename getenv/_f() to env_get()Simon Glass
We are now using an env_ prefix for environment functions. Rename these two functions for consistency. Also add function comments in common.h. Quite a few places use getenv() in a condition context, provoking a warning from checkpatch. These are fixed up in this patch also. Suggested-by: Wolfgang Denk <wd@denx.de> Signed-off-by: Simon Glass <sjg@chromium.org>
2017-08-16env: Rename common functions related to setenv()Simon Glass
We are now using an env_ prefix for environment functions. Rename these commonly used functions, for consistency. Also add function comments in common.h. Suggested-by: Wolfgang Denk <wd@denx.de> Signed-off-by: Simon Glass <sjg@chromium.org>
2017-08-13api: remove superfluous assignmentxypron.glpk@gmx.de
No need to assign a value to sig if the next statement using sig is itself an assignment of a value to sig. Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-01-20api: Use hashtable function for API_env_enumEmmanuel Vadot
The current code can loop undefinitly as it doesn't parse correctly the env data. Since the env is an hashtable, use the hashtable function for the API_ENV_ENUM api call. Signed-off-by: Emmanuel Vadot <manu@bidouilliste.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2016-05-21Fix FreeBSD loader API so that it works on both 32-bit and 64-bit targets.Stanislav Galabov
Specifically tested on MIPS under QEMU (works with all combination of bit-ness and endian-ness) Signed-off-by: Stanislav Galabov <sgalabov@gmail.com>
2016-03-14dm: Drop the block_dev_desc_t typedefSimon Glass
Use 'struct' instead of a typdef. Also since 'struct block_dev_desc' is long and causes 80-column violations, rename it to struct blk_desc. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Tested-by: Stephen Warren <swarren@nvidia.com>
2016-03-08api: Export API structure address as an environment variableStanislav Galabov
This patch makes the U-Boot api export its structure address as an environment variable, so it can be used to directly hint FreeBSD's loader of api's location. The relevant FreeBSD loader change is currently under review at: https://reviews.freebsd.org/D5492 Signed-off-by: Stanislav Galabov <sgalabov@gmail.com>
2011-11-15api: export LCD device to external appsChe-Liang Chiou
This patch exports LCD info-query and bitmap-rendering functions to external apps. This patch is tested on a Seaboard. Because the LCD driver is not yet upstreamed, the test was done in a local downstream repo. Signed-off-by: Che-Liang Chiou <clchiou@chromium.org>
2010-11-28do_reset: unify duplicate prototypesMike Frysinger
The duplication of the do_reset prototype has gotten out of hand, and they're not all in sync. Unify them all in command.h. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2009-05-15api: remove un-needed ifdef CONFIG_API already handle by the MakefileJean-Christophe PLAGNIOL-VILLARD
2008-05-14environment: cleanup prototype declarations of env functions.Wolfgang Denk
2008-05-12Revert "Change env_get_char from a global function ptr to a function."Wolfgang Denk
This reverts commit c0559be371b2a64b1a817088c3308688e2182f93 which is known to break booting from dataflash and NAND.
2008-05-12API: remove duplicate syscall checkJean-Christophe PLAGNIOL-VILLARD
2008-04-17Change env_get_char from a global function ptr to a function.Joakim Tjernlund
This avoids an early global data reference. Signed-off-by: Joakim Tjernlund <Joakim.Tjernlund@transmode.se>
2008-01-10Coding Style cleanup; update CHANGELOGWolfgang Denk
2008-01-09API for external applications.Rafal Jaworowski
This is an API for external (standalone) applications running on top of U-Boot, and is meant to be more extensible and robust than the existing jumptable mechanism. It is similar to UNIX syscall approach. See api/README for more details. Included is the demo application using this new framework (api_examples). Please note this is still an experimental feature, and is turned off by default. Signed-off-by: Rafal Jaworowski <raj@semihalf.com>
