Add support for Atmel AT91RM9200DK w/NAND
* Patches by Robert Schwebel, 19 Mar 2003:
- use arm-linux-gcc as default compiler for ARM
- fix i2c fixup code
- fix missing baudrate setting
- added $loadaddr / CFG_LOAD_ADDR support to loadb
- moved "ignoring trailing characters" _before_ u-boot wants to
print out diagnostics messages; removes bogus characters at the
end of transmission
* Patch by John Zhan, 18 Mar 2003:
Add support for SinoVee Microsystems SC8xx boards
* Patch by Rolf Offermanns, 21 Mar 2003:
ported the dnp1110 related changes from the current armboot cvs to
current u-boot cvs. smc91111 does not work. problem marked in
smc91111.c, grep for "FIXME".
* Patch by Brian Auld, 25 Mar 2003:
Add support for STM flash chips on ebony board
* Add PCI support for MPC8250 Boards (PM825 module)
* Patch by Stefan Roese, 25 Mar 2003:
- 16/32 MB and 50/80 MHz support with auto-detection for IP860
- ETH05 and BEDBUG support for CU824
- added support for MicroSys CPC45
- new BOOTROM/FLASH0 and DOC base for PM826
* Patch by Robert Schwebel, 12 Mar 2003:
Fix the chpart command on innokom board
* Name cleanup:
mv include/asm-i386/ppcboot-i386.h include/asm-i386/u-boot-i386.h
s/PPCBoot/U-Boot/ in some files
s/pImage/uImage/ in some files
* Patch by Detlev Zundel, 15 Jan 2003:
Fix '' command line quoting
* Patch by The LEOX team, 19 Jan 2003:
- add support for the ELPT860 board
- add support for Dallas ds164x RTC
- minimal setup for CardBus bridges
- add EEPROM read/write support in the CS8900 driver
- add support for the builtin I2C controller in the Samsung s3c24x0 chips
- add support for MPL's VCMA9 (Samsung s3c2410 based) board
* Patch by Steven Scholz, 04 Feb 2003:
add support for RTC DS1307
* Patch by Reinhard Meyer, 5 Feb 2003:
fix PLPRCR/SCCR init sequence on 8xx to allow for
changes of EBDF by software
* Patch by Vladimir Gurevich, 07 Feb 2003:
"API-compatibility patch" for 4xx I2C driver
- fix bug in BOOTP code (must use NetCopyIP)
- update of CSB226 port
- clear BSS segment on XScale
- added support for i2c_init_board() function
- update to the Innokom plattform
* Extend support for redundand environments for configurations where
environment size < sector size
- Add support for Innokom board
- Don't complain if "install" fails
- README cleanup (remove duplicated lines)
- Update PXA header files
* Add documentation for existing POST code (doc/README.POST)
* Patch by Laudney Ren, 15 Jan 2003:
Fix handling of redundand environment in "tools/envcrc.c"
* Patch by Detlev Zundel, 28 Feb 2003:
Add bedbug support for 824x systems
* Add support for 16 MB flash configuration of TRAB board
* Patch by Erwin Rol, 27 Feb 2003:
Add support for RTEMS
* Add image information to README
* Fix dual PCMCIA slot support (when running with just one
slot populated)
* Add VFD type detection to trab board
* extend drivers/cs8900.c driver to synchronize ethaddr environment
variable with value in the EEPROM
slot populated)
* Start adding MIPS support files
(patch by Jón Benediktsson, 11 Dec 2002)
Add i2c commands to PM826 config
* extend I2C POST code: check for list on known addresses
* Patch by Pierre Aubert, 20 Nov 2002
Add driver for Epson SED13806 graphic controller.
Add support for BMP logos in cfb_console driver.
* Patch by Rod Boyce, 21 Nov 2002:
fix PCMCIA on MBX8xx board
* Patch by Pierre Aubert , 21 Nov 2002
Add CFG_CPM_POST_WORD_ADDR to make the offset of the
bootmode word in DPRAM configurable
Add support for i386 architecture and AMD SC520 board
* Patch by Pierre Aubert, 12 Nov 2002:
Add support for DOS filesystem and booting from DOS floppy disk
Add "-n" to linker options to get rid of "Not enough room for
program headers" problem
* Patch by David Müller, 05 Nov 2002
Rename CONFIG_PLL_INPUT_FREQ to CONFIG_SYS_CLK_FREQ
so we can use an already existing name
* Patch by Pierre Aubert, 05 Nov 2002
Hardware related improvements in FDC boot code
* Patch by Holger Schurig, 5 Nov 2002:
Make the PXA really change it's frequency
Add support for slave serial Spartan 2 FPGAs
* Fix uninitialized memory (MAC address) in 8xx SCC/FEC ethernet
drivers
- use watchdog to reset PXA250 systems
- added progress callbacks to (some of the) ARM code
- update for Cogent CSB226 board
* Add support for FPS860 board
seconds instead of ms.
* Patch by Robert Schwebel, 1 Nov 2002:
XScale related cleanup (affects all ARM boards)
* Cleanup of names, warnings, and README.
