Support two i2c masters per FPGA.
Signed-off-by: Dirk Eibach <dirk.eibach@gdsys.cc>
Acked-by: Heiko Schocher <hs@denx.de>
TFTP source and destination port variable names are
'tftpsrcp' and 'tftpdstp' in the code, but 'tftpsrcport'
and 'tftpdstport' in the README file. Fix the README.
Add environment variable 'tftptimeoutcountmax'. As per the
comments about the global variable tftp_timeout_count_max,
make sure tftptimeoutcountmax is nonnegative.
Introduce configuration option CONFIG_NET_TFTP_VARS,
which controls whether environment variables tftpblocksize,
tftptimeout, and tftptimoueoutcountmax are read by the TFTP
client code. CONFIG_NET_TFTP_VARS defaults to y but can be
set to n by targets with to tight size contraints.
Make bf527-ezkit set CONFIG_NET_TFTP_VARS to n to keep the
target size below limit.
sync with linux v4.2
commit 64291f7db5bd8150a74ad2036f1037e6a0428df2
Author: Linus Torvalds <torvalds@linux-foundation.org>
Date: Sun Aug 30 11:34:09 2015 -0700
Linux 4.2
This update is needed, as it turned out, that fastmap
was in experimental/broken state in kernel v3.15, which
was the last base for U-Boot.
Tested-by: Ezequiel Garcia <ezequiel@vanguardiasur.com.ar>
As there is no TCG specification or recommendation for i2c TPM 1.2,
move tpm_tis_i2c driver to tpm_i2c_infineon. Other tpm vendors like Atmel
or STMicroelectronics may have a different transport protocol for i2c.
Signed-off-by: Christophe Ricard <christophe-h.ricard@st.com>
So far VxWorks bootline can be contructed from various environment
variables, but when these variables do not exist we get these from
corresponding config macros. This is not helpful as it requires
rebuilding U-Boot, and to make sure these config macros take effect
we should not have these environment variables. This is a little
bit complex and confusing.
Now we change the logic to always contruct the bootline from
environments (the only single source), by adding two new variables
"bootdev" and "othbootargs", and adding some comments about network
related settings mentioning they are optional. The doc about the
bootline handling is also updated.
Tested-by: Hannes Schmelzer <oe5hpm@oevsv.at>
We run 4 Arndale boards in our automated test framework, they have
been running quite happily for quite some time using a Debian Wheezy
userspace.
However when upgrading to a Debian Jessie we started seeing frequent
segmentation faults from gcc when building the kernel, to the extent
that it is unable to successfully build the kernel twice in a row, and
often fails on the first attempt.
Searching around I found https://bugs.launchpad.net/arndale/+bug/1081417
which pointed towards http://www.spinics.net/lists/kvm-arm/msg03723.html
and CPU Errata 773022 and 774769.
This errata needs to be applied to all processors in an SMP system,
meaning that the usual strategy of applying them in
arch/arm/cpu/armv7/start.S is not appropriate (since that applies to
the boot processor only). Instead we apply these errata in the secure
monitor which is code that is traversed by all processors as they are
brought up.
The net affect on Arndale is that ACTLR changes from 0x40 to
0x2000042. I ran 17 kernel compile iterations overnight with no
segfaults.
Runtime testing was done on our v2014.10 based branch and forward
ported (with only minimal and trivial contextual conflicts) to current
master, where it has been build tested only.
I suppose in theory these errata apply to any Exynos5250 based boards,
but Arndale is the only one I have access to and I have therefore
chosen to be conservative and only apply it there.
Also, reorder CONFIG_ARM_ERRATA_794072 in README to make the list
numerically sorted.
Signed-off-by: Ian Campbell <ian.campbell@citrix.com>
The driver assumed that I2C1 and I2C2 were always enabled,
and if they were not, then an asynchronous abort was (silently)
raised, to be caught much later on in the Linux kernel.
Fix this by making I2C1 and I2C2 optional just like I2C3 and I2C4
are.
To make the change binary-invariant, declare I2C1 and I2C2 in
every include/configs/ file which defines CONFIG_SYS_I2C_MXC.
Also, while updating README about CONFIG_SYS_I2C_MXC_I2C1 and
CONFIG_SYS_I2C_MXC_I2C2, add missing descriptions for I2C4 speed
(CONFIG_SYS_MXC_I2C4_SPEED) and slave (CONFIG_SYS_MXC_I2C4_SLAVE)
config options.
Signed-off-by: Albert ARIBAUD (3ADEV) <albert.aribaud@3adev.fr>
This arch does not seem to be supported / used at all in the current
U-Boot mainline source tree any more. So lets remove the core u8500 code
and code that was only referenced by this platform.
Please note that this patch also removes these config options:
- CONFIG_PL011_SERIAL_RLCR
- CONFIG_PL011_SERIAL_FLUSH_ON_INIT
As they only seem to be referenced by u8500 based boards. Without any
such board in the current code, these config option don't make sense
any more. Lets remove them as well.
If someone still wants to use this platform, then please send patches
to re-enable support by adding at least one board that references this
code.
Cc: Mathieu Poirier <mathieu.poirier@linaro.org>
Cc: John Rigby <john.rigby@linaro.org>
Cc: Albert Aribaud <albert.u.boot@aribaud.net>
Reviewed-by: Masahiro Yamada <yamada.masahiro@socionext.com>
The address of the I2C TPM is now defined in the device tree so there is no
need for the CONFIG options.
Remove them from the README and board config to avoid confusion.
Acked-by: Christophe Ricard <christophe-h.ricard@st.com>
Add Kconfig options in preparation for moving boards to use Kconfig.
Add workaround for Cortex-A15 ARM erratum 801819 which says in summary
that "A livelock can occur in the L2 cache arbitration that might
prevent a snoop from completing. Under certain conditions this can
cause the system to deadlock. "
Recommended workaround is as follows:
Do both of the following:
1) Do not use the write-back no-allocate memory type.
2) Do not issue write-back cacheable stores at any time when the cache
is disabled (SCTLR.C=0) and the MMU is enabled (SCTLR.M=1). Because it
is implementation defined whether cacheable stores update the cache when
the cache is disabled it is not expected that any portable code will
execute cacheable stores when the cache is disabled.
For implementations of Cortex-A15 configured without the “L2 arbitration
register slice” option (typically one or two core systems), you must
also do the following:
3) Disable write-streaming in each CPU by setting ACTLR[28:25] = 0b1111
So, we provide an option to disable write streaming on OMAP5 and DRA7.
It is a rare condition to occur and may be enabled selectively based
on platform acceptance of risk.
Applies to: A15 revisions r2p0, r2p1, r2p2, r2p3 or r2p4 and REVIDR[3]
is set to 0.
Note: certain unicore SoCs *might* not have REVIDR[3] not set, but
might not meet the condition for the erratum to occur when they donot
have ACP (Accelerator Coherency Port) hooked to ACE (AXI Coherency
Extensions). Such SoCs will need the work around handled in the SoC
specific manner, since there is no ARM generic manner to detect such
configurations.
Based on ARM errata Document revision 18.0 (22 Nov 2013)
Suggested-by: Richard Woodruff <r-woodruff2@ti.com>
Suggested-by: Brad Griffis <bgriffis@ti.com>
Reviewed-by: Brad Griffis <bgriffis@ti.com>
Signed-off-by: Nishanth Menon <nm@ti.com>
In order to achieve reproducible builds in U-Boot, timestamps that are defined
at build-time have to be somewhat eliminated. The SOURCE_DATE_EPOCH environment
variable allows setting a fixed value for those timestamps.
Simply by setting SOURCE_DATE_EPOCH to a fixed value, a number of targets can be
built reproducibly. This is the case for e.g. sunxi devices.
However, some other devices might need some more tweaks, especially regarding
the image generation tools.
Signed-off-by: Paul Kocialkowski <contact@paulk.fr>
FASTBOOT is defined both by CONFIG_USB_FUNCTION_FASTBOOT AND CONFIG_CMD_FASTBOOT, so it doesn't
make much sense to have a CONFIG_USB_FASTBOOT prefix for fastboot-specific options, especially
given that other config options for fastboot use the CONFIG_FASTBOOT prefix.
This replaces the CONFIG_USB_FASTBOOT prefix with CONFIG_FASTBOOT, for consistency.
USB download gadget functions such as thor and dfu have a separate config option
for the USB gadget part of the code, independent from the command part.
This switches the fastboot USB gadget to the same scheme, for better
consistency.
Tested-by: Lukasz Majewski <l.majewski@samsung.com>
Test HW: Odroid_XU3 (Exynos5422), trats (Exynos4210)
This introduces a coherent scheme for naming USB download gadget and functions
config options. The download USB gadget config option is moved to
CONFIG_USB_GADGET_DOWNLOAD for better consistency with other gadgets and each
function's config option is moved to a CONFIG_USB_FUNCTION_ prefix.
The agreed split of the top of memory is 256M for debug server and 256M
for MC. This patch implements the split.
In addition, the MC mem must be 512MB aligned, so the amount of memory
to hide must be 512MB to achieve that alignment.
Signed-off-by: Stuart Yoder <stuart.yoder@freescale.com>
Signed-off-by: Prabhakar Kushwaha <prabhakar@freescale.com>
Reviewed-by: York Sun <yorksun@freescale.com>
Since the help text is added in drivers/mtd/spi/Kconfig
Signed-off-by: Jagan Teki <jteki@openedev.com>
This patch adds CONFIG_SPI_FLASH_DATAFLASH descrition on README
file for more readble for users.
Add MTD layer driver for spi, original patch from:
http://git.denx.de/?p=u-boot/u-boot-mips.git;a=commitdiff;h=bb246819cdc90493dd7089eaa51b9e639765cced
Changes from Heiko Schocher against this patch:
- Remove compile error if not defining CONFIG_SPI_FLASH_MTD:
LD drivers/mtd/spi/built-in.o
drivers/mtd/spi/sf_probe.o: In function `spi_flash_mtd_unregister':
/home/hs/abb/imx6/u-boot/drivers/mtd/spi/sf_internal.h:168: multiple definition of `spi_flash_mtd_unregister'
drivers/mtd/spi/sf_params.o:/home/hs/abb/imx6/u-boot/drivers/mtd/spi/sf_internal.h:168: first defined here
drivers/mtd/spi/sf_ops.o: In function `spi_flash_mtd_unregister':
make[1]: *** [drivers/mtd/spi/built-in.o] Fehler 1
make: *** [drivers/mtd/spi] Fehler 2
- Add a README entry.
- Add correct writebufsize, to fit with Linux v3.14
MTD, UBI/UBIFS sync.
Note (From Jagan): For testing raw mtd parition erase/read/write operations
using cmd_sf, sf_mtd should be required to register the spi flash device to
MTD layer but the sf_mtd_info ops were not required until and unless if we
use any flash filesystem layer say for example UBI. Due to this the foot-print
got increased ~290bytes in non-UBI case here that should be acceptible.
Signed-off-by: Daniel Schwierzeck <daniel.schwierzeck@gmail.com>
Tested-by: Jagannadh Teki <jteki@openedev.com>
Reviewed-by: Jagannadh Teki <jteki@openedev.com>
them from include/configs.
Unlike most configuration options defining this actually disables
support for a feature (parallel flash). Eventually the logic behind this
should probably be flipped so that '#ifndef CONFIG_SYS_NO_FLASH' becomes
'#ifdef CONFIG_HAS_PARALLEL_FLASH' but for now lets document the
existing behaviour.
Signed-off-by: Chris Packham <judge.packham@gmail.com>
These defines for a 2nd autoboot stop and delay string are nearly unused. Only
sc3 defines CONFIG_AUTOBOOT_DELAY_STR2. And a patch to remove this most likely
unmaintained board is also posted to the list.
By removing these defines the code will become cleaner and moving the remaining
compile options to Kconfig will get easier.
Allow the features that use env_attrs to specify regexs for the name
We really don't want boards defining fixed MAC addresses in their config
so we just remove the option to set it in a fixed way. If you must have
a MAC address that was not provisioned, then use the random MAC address
functionality.
Implement the random ethaddr fallback in eth.c so it is in a common
place and not reimplemented in each board or driver that wants this
behavior.
On my A10 OlinuxIno Lime I noticed a huge (5+ seconds) delay coming from
console_init_r. This turns out to be caused by the preconsole buffer flushing
to the cfb_console. The Lime only has a 16 bit memory bus and that is already
heavy used to scan out the 1920x1080 framebuffer.
The problem is that print_pre_console_buffer() was printing the buffer once
character at a time and the cfb_console code then ends up doing a cache-flush
for touched display lines for each character.
This commit fixes this by first building a 0 terminated buffer and then
printing it in one puts() call, avoiding unnecessary cache flushes.
This changes the time for the flush from 5+ seconds to not noticable.
The downside of this approach is that the pre-console buffer needs to fit
on the stack, this is not that much to ask since we are talking about plain
text here. This commit also adjusts the sunxi CONFIG_PRE_CON_BUF_SZ to
actually fit on the stack. Sunxi currently is the only user of the pre-console
code so no other boards need to be adjusted.
CONFIG_VIDEO_VGA is no longer needed thus remove it.
The timer clock is system clock divided by 4, not fixed 12MHz.
This is common to the SoC, not board specific. Primary core is
fixed when u-boot still runs in board_f. Secondary cores are
fixed by reading a variable set by u-boot.
Signed-off-by: York Sun <yorksun@freescale.com>
CC: Mark Rutland <mark.rutland@arm.com>
Add built-in memory test to catch errors after DDR is initialized, before
any other transactions. To enable this test, define CONFIG_FSL_DDR_BIST.
An environmental variable "ddr_bist" is checked before starting test.
It takes a while (several seconds) depending on system memory size.
Some SoCs have more than two I2C busses. Instead of adding ifdef
to the driver, macros are put into board header file where
CONFIG_SYS_I2C_MXC is defined.
CC: Heiko Schocher <hs@denx.de>
flashes"
This reverts commit 562f8df18da62ae02c4ace1e530451fe82c3312d.
Note: Even un-reverting this patch couldn't works as expected, based
on the latest testing from Heiko Schocher.
Signed-off-by: Jagannadha Sutradharudu Teki <jagannadh.teki@gmail.com>
Move CONFIG_BOOT_STAGE and its associated options to Kconfig. Adjust
existing users and code.
Finish eliminating CamelCase from net.c and other failures
Sometimes, for example if the display is mounted in portrait mode or even if it
is mounted landscape but rotated by 180 degrees, we need to rotate our content
of the display respectively the framebuffer, so that user can read the messages
which are printed out.
For this we introduce the feature called "CONFIG_LCD_ROTATION", this may be
defined in the board-configuration if needed. After this the lcd_console will
be initialized with a given rotation from "vl_rot" out of "vidinfo_t" which is
provided by the board specific code.
If CONFIG_LCD_ROTATION is not defined, the console will be initialized with
0 degrees rotation.
Signed-off-by: Hannes Petermaier <hannes.petermaier@br-automation.com>
Signed-off-by: Hannes Petermaier <oe5hpm@oevsv.at>
Acked-by: Nikita Kiryanov <nikita@compulab.co.il>
[agust: fixed 'struct vidinfo' has no member named 'vl_rot' errors]
introduce CONFIG_SPL_PANIC_ON_RAW_IMAGE.
An SPL which define this will panic() if the
image it has loaded does not have a mkimage
signature.
The CONFIG_MTD_NAND_VERIFY_WRITE has been removed from Linux for some
time and a more generic method of NAND verification now exists in U-Boot.
Tested-by: Heiko Schocher <hs@denx.de>
Move the option to Kconfig renaming it to CONFIG_HAVE_GENERIC_BOARD.
Reviewed-by: Alexey Brodkin <abrodkin@synopsys.com>
The Driver Model description in README was removed by commit
65eb659e56fa (README: remove description about driver model
configuration options), and was revived by mistake by commit
b79dadf846e5 when resolving the conflict.
621766: Under a specific set of conditions, executing a sequence of
NEON or vfp load instructions can cause processor deadlock
Impacts: Every Cortex-A8 processors with revision lower than r2p1
Work around: Set L1NEON to 1
Based on ARM errata Document revision 20.0 (13 Nov 2010)
Tested-by: Matt Porter <mporter@konsulko.com>
430973: Stale prediction on replaced inter working branch causes
Cortex-A8 to execute in the wrong ARM/Thumb state
Work around: Set IBE to 1
454179: Stale prediction may inhibit target address misprediction on
next predicted taken branch
Work around: Set IBE and disable branch size mispredict to 1
Also provide a hook for SoC specific handling to take place if needed.
Add workaround for Cortex-A15 ARM erratum 798870 which says
"If back-to-back speculative cache line fills (fill A and fill B) are
issued from the L1 data cache of a CPU to the L2 cache, the second
request (fill B) is then cancelled, and the second request would have
detected a hazard against a recent write or eviction (write B) to the
same cache line as fill B then the L2 logic might deadlock."
Implementations for SoC families such as Exynos, OMAP5/DRA7 etc
will be widely different.
Every SoC has slightly different manner of setting up access to L2ACLR
and similar registers since the Secure Monitor handling of Secure
Monitor Call(smc) is diverse. Hence an weak function is introduced
which may be overriden to implement SoC specific accessor implementation.
