path: root/README
2012-01-19README: update (C) entryWolfgang Denk
There are tools that automatically extract this information, so better make it up to date. Signed-off-by: Wolfgang Denk <wd@denx.de>
2012-01-05net: add Calxeda xgmac driverRob Herring
This adds ethernet driver for Calxeda xgmac found on Highbank SOC. Signed-off-by: Rob Herring <rob.herring@calxeda.com> Fix: WARNING: __aligned(size) is preferred over __attribute__((aligned(size))) Signed-off-by: Wolfgang Denk <wd@denx.de>
2011-12-17Add safe vsnprintf and snprintf library functionsSonny Rao
From: Sonny Rao <sonnyrao@chromium.org> These functions are useful in U-Boot because they allow a graceful failure rather than an unpredictable stack overflow when printf() buffers are exceeded. Mostly copied from the Linux kernel. I copied vscnprintf and scnprintf so we can change printf and vprintf to use the safe implementation but still return the correct values. (Simon Glass <sjg@chromium.org> modified this commit a little) Signed-off-by: Sonny Rao <sonnyrao@chromium.org>
2011-12-16README: add documentation for CONFIG_USB_ULPI*Igor Grinberg
Add documentation for CONFIG_USB_ULPI and CONFIG_USB_ULPI_VIEWPORT configuration options. Signed-off-by: Igor Grinberg <grinberg@compulab.co.il>
2011-12-09Add board_pre_console_putc to deal with early console outputSimon Glass
This patch adds support for console output before the console is inited. The main purpose of this is to deal with a very early panic() which would otherwise cause a silent hang. A new board_pre_console_putc() function is added to the board API. If provided by the board it will be called in the event of console output before the console is ready. This function should turn on all UARTs and spray the character out if it possibly can. The feature is controlled by a new CONFIG_PRE_CONSOLE_PUTC option. Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Graeme Russ <graeme.russ@gmail.com>
2011-12-08MPC7xx: remove obsolete "BAB7xx" boardWolfgang Denk
The BAB7xx boards are almost deceased. They cause build warnings, an it's not worth the effort to fix these. Remove the dead body. Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Frank Gottschling <fgottschling@eltec.de>
2011-12-07Introduce generic TPM support in u-bootVadim Bendebury
TPM (Trusted Platform Module) is an integrated circuit and software platform that provides computer manufacturers with the core components of a subsystem used to assure authenticity, integrity and confidentiality. This driver supports version 1.2 of the TCG (Trusted Computing Group) specifications. The TCG specification defines several so called localities in a TPM chip, to be controlled by different software layers. When used on a typical x86 platform during the firmware phase, only locality 0 can be accessed by the CPU, so this driver even while supporting the locality concept presumes that only locality zero is used. This implementation is loosely based on the article "Writing a TPM Device Driver" published on http://ptgmedia.pearsoncmg.com Compiling this driver with DEBUG defined will generate trace of all accesses to TMP registers. This driver has been tested and is being used in three different functional ChromeOS machines (Pinetrail and Sandy Bridge Intel chipsets) all using the same Infineon SLB 9635 TT 1.2 device. A u-boot cli command allowing access to the TPM was also implemented and is being submitted as a second patch. Change-Id: I22a33c3e5b2e20eec9557a7621bd463b30389d73 Signed-off-by: Vadim Bendebury <vbendeb@chromium.org> CC: Wolfgang Denk <wd@denx.de>
2011-11-29powerpc/85xx: clean up and document the QE/FMAN microcode macrosTimur Tabi
Several macros are used to identify and locate the microcode binary image that U-boot needs to upload to the QE or Fman. Both the QE and the Fman use the QE Firmware binary format to package their respective microcode data, which is why the same macros are used for both. A given SOC will only have a QE or an Fman, so this is safe. Unfortunately, the current macro definition and usage has inconsistencies. For example, CONFIG_SYS_FMAN_FW_ADDR was used to define the address of Fman firmware in NOR flash, but CONFIG_SYS_QE_FW_IN_NAND contains the address of NAND. There's no way to know by looking at a variable how it's supposed to be used. In the future, the code which uploads QE firmware and Fman firmware will be merged. Signed-off-by: Timur Tabi <timur@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2011-11-15arm, davinci_emac: fix driver bug if more then 3 PHYs are detectedHeiko Schocher
since commits: davinci: emac: add support for more than 1 PHYs 062fe7d332c28ede25626f448681e43d76bb312e davinci: remove obsolete macro CONFIG_EMAC_MDIO_PHY_NUM fb1d6332b5430b90a8fa8ebab709f33a60e9f816 I get following warning on the enbw_cmc board: Err: serial Net: 5 ETH PHY detected miiphy_register: non unique device name 'KSZ8873 @ 0x01' DaVinci-EMAC Hit any key to stop autoboot: 0 Also I see some debug printfs: => run load + emac_close + emac_ch_teardown - emac_ch_teardown + emac_ch_teardown - emac_ch_teardown - emac_close + emac_open - emac_open Using DaVinci-EMAC device reason is 062fe7d332c28ede25626f448681e43d76bb312e new define MAX_PHY. This is set to 3! I get on this board 5 active phys, so this leads in wrong memory writes ... so I changed: - define CONFIG_SYS_DAVINCI_EMAC_PHY_COUNT to set the MAX_PHY value, add a description in README for the new CONFIG_SYS option. - print an error message if more then MAX_PHYs are detected. - fill the active_phy_addr array in a for loop with 0xff - changed printf() in debug_emac() Signed-off-by: Heiko Schocher <hs@denx.de> Cc: Sandeep Paulraj <s-paulraj@ti.com> Cc: Albert ARIBAUD <albert.u.boot@aribaud.net> Cc: Wolfgang Denk <wd@denx.de> Cc: Manjunath Hadli <manjunath.hadli@ti.com> Cc: Prabhakar Lad <prabhakar.csengg@gmail.com> Cc: Mike Frysinger <vapier@gentoo.org> Cc: Tom Rini <tom.rini@gmail.com> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2011-11-04README: Fix supported i.MX SoC list for CONFIG_MXC_SPIFabio Estevam
CONFIG_MXC_SPI currently works on MX31/35/51 boards, so update the README file. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com>
2011-11-03spl, nand: add 4bit HW ecc oob first nand_read_page functionHeiko Schocher
similiar to commit dc7cd8e59ba077f3b4c1a4557c9cd86a31b9ab1f, only adapted for the new spl framework. Signed-off-by: Heiko Schocher <hs@denx.de> Acked-by: Tom Rini <trini@ti.com> Acked-by: Scott Wood <scottwood@freescale.com> Cc: Albert ARIBAUD <albert.u.boot@aribaud.net> Cc: Sandeep Paulraj <s-paulraj@ti.com> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2011-11-03rtc: Make mc13783-rtc driver genericFabio Estevam
Rename mc13783-rtc so that it can be used for both MC13783 and MC13892 PMICs. efikamx board, for example, does use a MC13892 PMIC, but the RTC selection is currently made as: #define CONFIG_RTC_MC13783 ,which is not very obvious. Let the MC13783 and MC13892 RTC be selected by: #define CONFIG_RTC_MC13XXX Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com> Acked-by: Stefano Babic <sbabic@denx.de>
2011-10-28e1000: Allow direct access to the E1000 SPI EEPROM deviceKyle Moffett
As a part of the manufacturing process for some of our custom hardware, we are programming the EEPROMs attached to our Intel 82571EB controllers from software using U-Boot and Linux. This code provides several conditionally-compiled features to assist in our manufacturing process: CONFIG_CMD_E1000: This is a basic "e1000" command which allows querying the controller and (if other config options are set) performing EEPROM programming. In particular, with CONFIG_E1000_SPI this allows you to display a hex-dump of the EEPROM, copy to/from main memory, and verify/update the software checksum. CONFIG_E1000_SPI_GENERIC: Build a generic SPI driver providing the standard U-Boot SPI driver interface. This allows commands such as "sspi" to access the bus attached to the E1000 controller. Additionally, some E1000 chipsets can support user data in a reserved space in the E1000 EEPROM which could be used for U-Boot environment storage. CONFIG_E1000_SPI: The core SPI access code used by the above interfaces. For example, the following commands allow you to program the EEPROM from a USB device (assumes CONFIG_E1000_SPI and CONFIG_CMD_E1000 are enabled): usb start fatload usb 0 $loadaddr 82571EB_No_Mgmt_Discrete-LOM.bin e1000 0 spi program $loadaddr 0 1024 e1000 0 spi checksum update Please keep in mind that the Intel-provided .eep files are organized as 16-bit words. When converting them to binary form for programming you must byteswap each 16-bit word so that it is in little-endian form. This means that when reading and writing words to the SPI EEPROM, the bit ordering for each word looks like this on the wire: Time >>> ------------------------------------------------------------------ ... [7, 6, 5, 4, 3, 2, 1, 0, 15, 14, 13, 12, 11, 10, 9, 8], ... ------------------------------------------------------------------ (MSB is 15, LSB is 0). Signed-off-by: Kyle Moffett <Kyle.D.Moffett@boeing.com> Cc: Ben Warren <biggerbadderben@gmail.com>
2011-10-27cosmetic: s/BOARD_LATE_INIT/CONFIG_BOARD_LATE_INITHelmut Raiger
This renames BOARD_LATE_INIT to CONFIG_BOARD_LATE_INIT. Along the way it removes some leftover #define BOARD_LATE_INIT 1 and adds some basic documentation for board specific callbacks in README. Signed-off-by: Helmut Raiger <helmut.raiger@hale.at> Acked-by: Stefano Babic <sbabic@denx.de>
2011-10-27README: improve documentation of network related CONFIG_ settingsWolfgang Denk
Add documentation for CONFIG_GATEWAYIP and CONFIG_NETMASK; also add information which environment variables are set. Signed-off-by: Wolfgang Denk <wd@denx.de> Acked-by: Simon Glass <sjg@chromium.org>
2011-10-27README: white-space cleanupWolfgang Denk
2011-10-26FAT: Add FAT write featureDonggeun Kim
In some cases, saving data in RAM as a file with FAT format is required. This patch allows the file to be written in FAT formatted partition. The usage is similar with reading a file. First, fat_register_device function is called before file_fat_write function in order to set target partition. Then, file_fat_write function is invoked with desired file name, start ram address for writing data, and file size. Signed-off-by: Donggeun Kim <dg77.kim@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com>
2011-10-26fdt: ARM: Add fdtcontroladdr to set device tree address in environmentSimon Glass
This adds support for a new environment variable called 'fdtcontroladdr'. If defined, the hex address is used as the address of the control fdt for U-Boot. Note: I have not changed CONFIG_PRAM section as I already have an outstanding patch on that. Signed-off-by: Simon Glass <sjg@chromium.org>
2011-10-26fdt: Add support for a separate device tree (CONFIG_OF_SEPARATE)Simon Glass
This adds support for an FDT to be build as a separate binary file called u-boot.dtb. This can be concatenated with the U-Boot binary to provide a device tree located at run-time by U-Boot. The Makefile is modified to provide this file in u-boot-dtb.bin. Signed-off-by: Simon Glass <sjg@chromium.org>
2011-10-26fdt: Add support for embedded device tree (CONFIG_OF_EMBED)Simon Glass
This new option allows U-Boot to embed a binary device tree into its image to allow run-time control of peripherals. This device tree is for U-Boot's own use and is not necessarily the same one as is passed to the kernel. The device tree compiler output should be placed in the $(obj) rooted tree. Since $(OBJCOPY) insists on adding the path to the generated symbol names, to ensure consistency it should be invoked from the directory where the .dtb file is located and given the input file name without the path. This commit contains my entry for the ugliest Makefile / shell interaction competition. Signed-off-by: Simon Glass <sjg@chromium.org>
2011-10-26fdt: ARM: Add device tree control of U-Boot (CONFIG_OF_CONTROL)Simon Glass
This adds a device tree pointer to the global data. It can be set by board code. A later commit will add support for making a device tree binary blob available to U-Boot for run-time configuration. Signed-off-by: Simon Glass <sjg@chromium.org>
2011-10-26net: tftpput: implement tftp logicSimon Glass
This adds logic to tftp.c to implement the tftp 'put' command, and updates the README. Signed-off-by: Simon Glass <sjg@chromium.org>
2011-10-22doc/README: documents and readme for NDS32 archMacpaul Lin
Documents and READMEs for NDS32 architecture. It patch also provides usage of SoC AG101 and board ADP-AG101. Signed-off-by: Macpaul Lin <macpaul@andestech.com>
2011-10-17README: document standard image variablesJason Hobbs
With these documented, we can start pushing towards standardizing their use across boards. Signed-off-by: Jason Hobbs <jason.hobbs@calxeda.com> Cc: Mike Frysinger <vapier@gentoo.org>
2011-10-12Merge branch 'master' of git://git.denx.de/u-boot-mipsWolfgang Denk
* 'master' of git://git.denx.de/u-boot-mips: MIPS: Jz4740: Add qi_lb60 board support MIPS: Jz4740: Add NAND driver MIPS: Ingenic XBurst Jz4740 processor support
2011-10-10MIPS: Ingenic XBurst Jz4740 processor supportXiangfu Liu
Jz4740 is a multimedia application processor targeting for mobile devices like e-Dictionary, eBook, portable media player (PMP) and GPS navigator. Jz4740 is powered by Ingenic 360 MHz XBurst CPU core (JzRISC), in which RISC/SIMD/DSP hybrid instruction set architecture provides high integration, high performance and low power consumption. JzRISC incorporated in Jz4740 is the advanced and power-efficient 32-bit RISC core, compatible with MIPS32, with 16K I-Cache and 16K D-Cache, and can operate at speeds up to 400 MHz. On-chip modules such as LCD controller, embedded audio codec, multi- channel SAR-ADC, AC97/I2S controller and camera I/F offer a rich suite of peripherals for multimedia application. NAND controller (SLC/MLC), USB (host 1.1 and device 2.0), UART, I2C, SPI, etc. are also available. For more info about Ingenic XBurst Jz4740: http://en.ingenic.cn/eng/ http://www.linux-mips.org/wiki/Ingenic This patch introduces XBurst CPU support in U-Boot. It's compatible with MIPS32, but requires a bit different cache maintenance, timer routines, and boot mechanism using USB boot tool, so XBurst support can go into a separate new home, cpu/xburst/. Signed-off-by: Xiangfu Liu <xiangfu@openmobilefree.net> Acked-by: Daniel <zpxu@ingenic.cn> Signed-off-by: Shinya Kuribayashi <skuribay@pobox.com>
2011-10-09powerpc/8xxx: Add support for interactive DDR programming interfaceYork Sun
Interactive DDR debugging provides a user interface to view and modify SPD, DIMM parameters, board options and DDR controller registers before DDR is initialized. With this feature, developers can fine-tune DDR for board bringup and other debugging without frequently having to reprogram the flash. To enable this feature, define CONFIG_FSL_DDR_INTERACTIVE in board header file and set an environment variable to activate it. Syntax: setenv ddr_interactive on After reset, U-boot prompts before initializing DDR controllers FSL DDR> The available commands are print print SPD and intermediate computed data reset reboot machine recompute reload SPD and options to default and recompute regs edit modify spd, parameter, or option compute recompute registers from current next_step to end next_step shows current next_step help this message go program the memory controller and continue with u-boot The first command should be "compute", which reads data from DIMM SPDs and board options, performs the calculation then stops before setting DDR controller. A user can use "print" and "edit" commands to view and modify anything. "Go" picks up from current step with any modification and compltes the calculation then enables the DDR controller to continue u-boot. "Recompute" does it over from fresh reading. Signed-off-by: York Sun <yorksun@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2011-10-09cmd_time: add time commandChe-liang Chiou
The 'time' command runs and reports execution time of commands. Sample usage: -------------------- u-boot# time crc 0x1000 1000 CRC32 for 00001000 ... 00001fff ==> ae94dc4b time: 0.004 seconds, 4 ticks -------------------- Signed-off-by: Che-Liang Chiou <clchiou@chromium.org> Acked-by: Mike Frysinger <vapier@gentoo.org>
2011-10-09README: fix typos and such.Wolfgang Denk
Reported-by: Michael Jones <michael.jones@matrix-vision.de> Signed-off-by: Wolfgang Denk <wd@denx.de>
2011-10-09README: fix documentation of CONFIG_SHOW_BOOT_PROGRESSWolfgang Denk
Some previous changes added code right in the middle of the description of CONFIG_SHOW_BOOT_PROGRESS. Move this text down. Fix formatting while we are at it. Signed-off-by: Wolfgang Denk <wd@denx.de>
2011-10-05net: drop !NET_MULTI codeMike Frysinger
This is long over due. All but two net drivers have been converted, but those have now been dropped. The only thing left to do is actually delete all references to NET_MULTI and code that is compiled when that is not defined. So here we scrub the core code. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2011-10-05console: Implement pre-console bufferGraeme Russ
Allow redirection of console output prior to console initialisation to a temporary buffer. To enable this functionality, the board (or arch) must define: - CONFIG_PRE_CONSOLE_BUFFER - Enable pre-console buffer - CONFIG_PRE_CON_BUF_ADDR - Base address of pre-console buffer - CONFIG_PRE_CON_BUF_SZ - Size of pre-console buffer (in bytes) The pre-console buffer will buffer the last CONFIG_PRE_CON_BUF_SZ bytes Any earlier characters are silently dropped.
2011-09-29powerpc/85xx: introduce and document CONFIG_SYS_CCSRBAR macrosTimur Tabi
Introduce the CONFIG_SYS_CCSRBAR_PHYS_HIGH and CONFIG_SYS_CCSRBAR_PHYS_LOW macros, which contain the high and low portions of CONFIG_SYS_CCSRBAR_PHYS. This is necessary for the assembly-language code that relocates CCSR, since the assembler does not understand 64-bit constants. CONFIG_SYS_CCSRBAR_PHYS is automatically defined from the CONFIG_SYS_CCSRBAR_PHYS_HIGH and CONFIG_SYS_CCSRBAR_PHYS_LOW macros, so it should not be defined in a board header file. Similarly, CONFIG_SYS_CCSRBAR_DEFAULT is defined for each SOC in config_mpc85xx.h, so it should also not be defined in the board header file. CONFIG_SYS_CCSR_DO_NOT_RELOCATE is a "short-cut" macro that guarantees that CONFIG_SYS_CCSRBAR_PHYS is set to the same value as CONFIG_SYS_CCSRBAR_DEFAULT, and so CCSR will not be relocated. Since CONFIG_SYS_CCSRBAR_DEFAULT is locked to a fixed value, multi-stage U-Boot builds (e.g. NAND) are required to relocate CCSR only during the last stage (i.e. the "real" U-Boot). All other stages should define CONFIG_SYS_CCSR_DO_NOT_RELOCATE to ensure that CCSR is not relocated. README is updated with descriptions of all the CONFIG_SYS_CCSRBAR_xxx macros. Signed-off-by: Timur Tabi <timur@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2011-09-11Minor coding style cleanup.Wolfgang Denk
2011-08-03README: fix arm920t/at91 pathAndreas Bießmann
2011-07-31README: update MIPS related informationsDaniel Schwierzeck
Amend section 'Directory Hierarchy' for current MIPS directory. Describe config options for MIPS. Signed-off-by: Daniel Schwierzeck <daniel.schwierzeck@googlemail.com> Acked-by: Thomas Langer <thomas.langer@lantiq.com> Signed-off-by: Shinya Kuribayashi <skuribay@pobox.com>
2011-07-30README: udate Coding Style description to current status quoWolfgang Denk
2011-07-28cosmetic: spell fixes etc.Michael Jones
Signed-off-by: Michael Jones <michael.jones@matrix-vision.de> Acked-by: Detlev Zundel <dzu@denx.de>
2011-07-26env: allow people to force envcrc buildingMike Frysinger
For people who want to manually extract the embedded environment so that it can be manually packed into the final u-boot image, add a config opt to force building of the envcrc tool. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2011-07-26replace CONFIG_PRELOADER with CONFIG_SPL_BUILDAneesh V
replace all occurences of CONFIG_PRELOADER with CONFIG_SPL_BUILD Signed-off-by: Aneesh V <aneesh@ti.com>
2011-07-26spl: add initial support for a generic SPL frameworkDaniel Schwierzeck
Signed-off-by: Aneesh V <aneesh@ti.com> Signed-off-by: Daniel Schwierzeck <daniel.schwierzeck@googlemail.com>
2011-07-19Merge branch 'master' of git://git.denx.de/u-boot-mmcWolfgang Denk
* 'master' of git://git.denx.de/u-boot-mmc: mmc: rescan fails on empty slot AT91:mmc:fix multiple read/write error mmc: Access mode validation for eMMC cards > 2 GiB mmc: sh_mmcif: add support for Renesas MMCIF mmc: fix the condition for MMC version 4 MMC: add marvell sdhci driver MMC: add sdhci generic framework MMC: add erase function to both mmc and sd MMC: unify mmc read and write operation mmc: Tegra2: Enable SD/MMC driver for Seaboard and Harmony mmc: Tegra2: SD/MMC driver for Seaboard - eMMC on SDMMC4, SDIO on SDMMC3
2011-07-18Merge branch 'master' of git://git.denx.de/u-boot-armWolfgang Denk
* 'master' of git://git.denx.de/u-boot-arm: ARM: MX5: Fix broken leftover TO-2 errata workaround MX31: Cleanup clock function scb9328: Add ARM relocation support am3517evm: change console device from ttyS2 to ttyO2 Remove volatile qualifier in get_ram_size() calls TI: TNETV107X Fix Build Error ARM: add missing CONFIG_SKIP_LOWLEVEL_INIT for armv7 arm: add CONFIG_MACH_TYPE setting and documentation arm: add __ilog2 function Timer: Fix misuse of ARM *timer_masked() functions outside arch/arm EfikaMX: Enable EXT2 booting EfikaMX: Add missing CONFIG_SYS_TEXT_BASE EfikaMX: Use correct imximage.cfg MX27: Update to autogenerated asm-offsets.h MX5: Update to autogenerated asm-offsets.h imx: Add support for zmx25 board imx: Make imx25 compatible to mxc_gpio driver and fix in tx25 imx: Add auto generation of asm-offsets.h for imx25 imx: Add support for USB EHCI on imx25 imx: Use correct imx25 reset.c imx: Add get_tbclk() function for imx25 ARM: Update maintainer of board scb9328 mx27: Make the UART port number explicit build: Add targets for auto gen of asm-offsets.h and use it in imx35 mx31pdk: cosmetic: Fix line over 80 characters
2011-07-17arm: add CONFIG_MACH_TYPE setting and documentationIgor Grinberg
CONFIG_MACH_TYPE is used to set the machine type number in the common arm code instead of setting it in the board code. Boards with dynamically discoverable machine types can still set the machine type number in the board code. Signed-off-by: Igor Grinberg <grinberg@compulab.co.il>
2011-07-16Add uboot "fdt_high" enviroment variableDavid A. Long
Add a new "fdt_high" enviroment variable. This can be used to control (or prevent) the relocation of the flattened device tree on boot. It can be used to prevent relocation of the fdt into highmem. The variable behaves similarly to the existing "initrd_high" variable. Signed-off-by: David A. Long <dave.long@linaro.org>
2011-07-15mmc: sh_mmcif: add support for Renesas MMCIFYoshihiro Shimoda
Some Renesas SuperH have MMCIF module. This driver supports it. Signed-off-by: Yoshihiro Shimoda <yoshihiro.shimoda.uh@renesas.com> Acked-by: Andy Fleming <afleming@freescale.com>
2011-07-11powerpc/mpc8xxx: Enable calculation for fixed DDR chipsYork Sun
We used to have fixed parameters for soldered DDR chips. This patch introduces CONFIG_SYS_DDR_RAW_TIMING to enable calculation based on timing data from DDR chip datasheet, implemneted in board-specific files or header files. Signed-off-by: York Sun <yorksun@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2011-07-04armv7: add PL310 support to u-bootAneesh V
PL310 is the L2$ controller from ARM used in many SoCs including the Cortex-A9 based OMAP4430 Add support for some of the key PL310 operations - Invalidate all - Invalidate range - Flush(clean & invalidate) all - Flush range Signed-off-by: Aneesh V <aneesh@ti.com>
2011-07-04armv7: cache maintenance operations for armv7Aneesh V
- Add a framework for layered cache maintenance - separate out SOC specific outer cache maintenance from maintenance of caches known to CPU - Add generic ARMv7 cache maintenance operations that affect all caches known to ARMv7 CPUs. For instance in Cortex-A8 these opertions will affect both L1 and L2 caches. In Cortex-A9 these will affect only L1 cache - D-cache operations supported: - Invalidate entire D-cache - Invalidate D-cache range - Flush(clean & invalidate) entire D-cache - Flush D-cache range - I-cache operations supported: - Invalidate entire I-cache - Add maintenance functions for TLB, branch predictor array etc. - Enable -march=armv7-a so that armv7 assembly instructions can be used Signed-off-by: Aneesh V <aneesh@ti.com>
2011-07-01NAND: Add 16bit NAND support for the NDFCAlex Waterman
This patch adds support for 16 bit NAND devices attached to the NDFC on ppc4xx processors. Two config entries were added: CONFIG_SYS_NDFC_16 - Setting this tells the NDFC that a 16 bit device is attached. CONFIG_SYS_NDFC_EBC0_CFG - This is for the External Bus Controller configuration register. Also, a new ndfc_read_byte() function was added which does not first convert the data to little endian. The NAND SPL was also modified to do 16bit bad block testing when a 16 bit chip is being used. Signed-off-by: Alex Waterman <awaterman@dawning.com> Signed-off-by: Scott Wood <scottwood@freescale.com>
