path: root/README
2011-02-21mv: seperate kirkwood and armada from common settingLei Wen
Since there are lots of difference between kirkwood and armada series, it is better to seperate them but still keep the most common file shared by all marvell platform in the mv-common configure file. This patch move the kirkwood only driver definitoin in mv-common to the <soc_name>/config.h. This patch is tested with compilation for armada100 and guruplug. Signed-off-by: Lei Wen <leiwen@marvell.com>
2011-02-02spi: add support SuperH SPI moduleYoshihiro Shimoda
SH7757 has SPI module. This patch supports it. Signed-off-by: Yoshihiro Shimoda <yoshihiro.shimoda.uh@renesas.com> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2011-02-02net: sh_eth: add cache handlingYoshihiro Shimoda
Some CPU needs cache handling. So this patch add the config of CONFIG_SH_ETHER_CACHE_WRITEBACK, and it calls wback function. Signed-off-by: Yoshihiro Shimoda <yoshihiro.shimoda.uh@renesas.com> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2011-02-02README: add description of sh_eth driverYoshihiro Shimoda
2011-01-19Fix defines needed to enable command sha1sumAlexander Holler
Documented is CONFIG_CMD_SHA1, through confusion in the source CONFIG_CMD_SHA1 and CONFIG_CMD_SHA1SUM has to be used to enable sha1sum. Fix both, the documentation and the source, so that only CONFIG_CMD_SHA1SUM is needed to enable the command sha1sum. Signed-off-by: Alexander Holler <holler@ahsoftware.de>
2011-01-17Merge branch 'master' of git://git.denx.de/u-boot-mpc85xxWolfgang Denk
2011-01-17Merge branch 'master' of git://git.denx.de/u-boot-i2cWolfgang Denk
2011-01-14powerpc/8xxx: Refactor SRIO initialization into common codeKumar Gala
Moved the SRIO init out of corenet_ds and into common code for 8xxx/QorIQ processors that have SRIO. We mimic what we do with PCIe controllers for SRIO. We utilize the fact that SRIO is over serdes to determine if its configured or not and thus can setup the LAWs needed for it dynamically. We additionally update the device tree (to remove the SRIO nodes) if the board doesn't have SRIO enabled. Introduced the following standard defines for board config.h: CONFIG_SYS_SRIO - Chip has SRIO or not CONFIG_SRIO1 - Board has SRIO 1 port available CONFIG_SRIO2 - Board has SRIO 2 port available (where 'n' is the port #) CONFIG_SYS_SRIOn_MEM_VIRT - virtual address in u-boot CONFIG_SYS_SRIOn_MEM_PHYS - physical address (for law setup) CONFIG_SYS_SRIOn_MEM_SIZE - size of window (for law setup) [ These mimic what we have for PCI and PCIe controllers ] Signed-off-by: Kumar Gala <galak@kernel.crashing.org> Acked-by: Wolfgang Denk <wd@denx.de>
2011-01-10pca953x: support 16-pin devicesChris Packham
This adds support for for the PCA9535/PCA9539 family of gpio devices which have 16 output pins. To let the driver know which devices are 16-pin it is necessary to define CONFIG_SYS_I2C_PCA953X_WIDTH in your board config file. This is used to create an array of {chip, ngpio} tuples that are used to determine the width of a particular chip. For backwards compatibility it is assumed that any chip not defined in CONFIG_SYS_I2C_PCA953X_WIDTH has 8 pins. Acked-by: Peter Tyser <ptyser@xes-inc.com> Tested-by: Peter Tyser <ptyser@xes-inc.com> Signed-off-by: Chris Packham <chris.packham@alliedtelesis.co.nz>
2011-01-09ftgmac100: support of gigabit eth ftgmac100Macpaul Lin
Add Faraday's ftgmac100 (gigabit ethernet) MAC controller's driver. Signed-off-by: Macpaul Lin <macpaul@andestech.com>
2010-11-27Coding Style (white space) cleanupWolfgang Denk
2010-10-29Drop support for CONFIG_SKIP_RELOCATE_UBOOTWolfgang Denk
For ARM systems, before ELF relocation was introduced, CONFIG_SKIP_RELOCATE_UBOOT coul be used to prevent *COPYING* the U-Boot image from whereever it was loaded to it's link address (CONFIG_SYS_TEXT_BASE). The name was badly chosen, as no relocation was performed at all, it was just a memcpy(). With ELF relocation, this does not work like that any more, and related boards need to be fixed anyway. So don't keep this relict any longer. Signed-off-by: Wolfgang Denk <wd@denx.de> Tested-by: Heiko Schocher <hs@denx.de> Tested-by: Reinhard Meyer <u-boot@emk-elektronik.de>
2010-10-27Coding Style cleanupWolfgang Denk
2010-10-18boot: change some arch ifdefs to feature ifdefsJohn Rigby
The routines boot_ramdisk_high, boot_get_cmdline and boot_get_kbd are currently enabled by various combinations of CONFIG_M68K, CONFIG_POWERPC and CONFIG_SPARC. Use CONFIG_SYS_BOOT_<FEATURE> defines instead. CONFIG_SYS_BOOT_RAMDISK_HIGH CONFIG_SYS_BOOT_GET_CMDLINE CONFIG_SYS_BOOT_GET_KBD Define these as appropriate in arch/include/asm/config.h files. Signed-off-by: John Rigby <john.rigby@linaro.org> Acked-by: Wolfgang Denk <wd@denx.de>
2010-10-11README: Add new NAND env featuresScott Wood
CONFIG_ENV_SIZE does not need block alignment. Document CONFIG_ENV_RANGE and CONFIG_ENV_OFFSET_OOB. Signed-off-by: Scott Wood <scottwood@freescale.com>
2010-10-06PCU_E: remove code for yet another corpseWolfgang Denk
The PCU_E board has long reached EOL, and support for it is no longer relevant in current versions of U-Boot. Remove it. Signed-off-by: Wolfgang Denk <wd@denx.de>
2010-09-28Merge branch 'next' of /home/wd/git/u-boot/nextWolfgang Denk
Conflicts: include/ppc4xx.h Signed-off-by: Wolfgang Denk <wd@denx.de>
2010-09-28README: Fix description of version numbering schemeThomas Weber
The version numbering scheme was changed in Oct, 2008. This patch brings the documentation to the actual level. The description is taken from: http://www.denx.de/wiki/U-Boot/ReleaseCycle Signed-off-by: Thomas Weber <weber@corscience.de> Changed text slightly. Signed-off-by: Wolfgang Denk <wd@denx.de>
2010-09-23Remove unused CONFIG_SERIAL_SOFTWARE_FIFO featureStefan Roese
This patch removes the completely unused CONFIG_SERIAL_SOFTWARE_FIFO feature from U-Boot. It has only been implemented for PPC4xx and was not used at all. So let's remove it and make the code smaller and cleaner. Signed-off-by: Stefan Roese <sr@denx.de> Acked-by: Detlev Zundel <dzu@denx.de>
2010-09-23ppc4xx: Remove now unused CONFIG_UART1_CONSOLEStefan Roese
CONFIG_UART1_CONSOLE was a PPC4xx specific implementation and is now removed since the move from the 4xx UART driver to the common NS16550 UART driver. Let's remove all references to this define now. Signed-off-by: Stefan Roese <sr@denx.de>
2010-09-19New implementation for internal handling of environment variables.Wolfgang Denk
Motivation: * Old environment code used a pessimizing implementation: - variable lookup used linear search => slow - changed/added variables were added at the end, i. e. most frequently used variables had the slowest access times => slow - each setenv() would calculate the CRC32 checksum over the whole environment block => slow * "redundant" envrionment was locked down to two copies * No easy way to implement features like "reset to factory defaults", or to select one out of several pre-defined (previously saved) sets of environment settings ("profiles") * No easy way to import or export environment settings ====================================================================== API Changes: - Variable names starting with '#' are no longer allowed I didn't find any such variable names being used; it is highly recommended to follow standard conventions and start variable names with an alphanumeric character - "printenv" will now print a backslash at the end of all but the last lines of a multi-line variable value. Multi-line variables have never been formally defined, allthough there is no reason not to use them. Now we define rules how to deal with them, allowing for import and export. - Function forceenv() and the related code in saveenv() was removed. At the moment this is causing build problems for the only user of this code (schmoogie - which has no entry in MAINTAINERS); may be fixed later by implementing the "env set -f" feature. Inconsistencies: - "printenv" will '\\'-escape the '\n' in multi-line variables, while "printenv var" will not do that. ====================================================================== Advantages: - "printenv" output much better readable (sorted) - faster! - extendable (additional variable properties can be added) - new, powerful features like "factory reset" or easy switching between several different environment settings ("profiles") Disadvantages: - Image size grows by typically 5...7 KiB (might shrink a bit again on systems with redundant environment with a following patch series) ====================================================================== Implemented: - env command with subcommands: - env print [arg ...] same as "printenv": print environment - env set [-f] name [arg ...] same as "setenv": set (and delete) environment variables ["-f" - force setting even for read-only variables - not implemented yet.] - end delete [-f] name not implemented yet ["-f" - force delete even for read-only variables] - env save same as "saveenv": save environment - env export [-t | -b | -c] addr [size] export internal representation (hash table) in formats usable for persistent storage or processing: -t: export as text format; if size is given, data will be padded with '\0' bytes; if not, one terminating '\0' will be added (which is included in the "filesize" setting so you can for exmple copy this to flash and keep the termination). -b: export as binary format (name=value pairs separated by '\0', list end marked by double "\0\0") -c: export as checksum protected environment format as used for example by "saveenv" command addr: memory address where environment gets stored size: size of output buffer With "-c" and size is NOT given, then the export command will format the data as currently used for the persistent storage, i. e. it will use CONFIG_ENV_SECT_SIZE as output block size and prepend a valid CRC32 checksum and, in case of resundant environment, a "current" redundancy flag. If size is given, this value will be used instead of CONFIG_ENV_SECT_SIZE; again, CRC32 checksum and redundancy flag will be inserted. With "-b" and "-t", always only the real data (including a terminating '\0' byte) will be written; here the optional size argument will be used to make sure not to overflow the user provided buffer; the command will abort if the size is not sufficient. Any remainign space will be '\0' padded. On successful return, the variable "filesize" will be set. Note that filesize includes the trailing/terminating '\0' byte(s). Usage szenario: create a text snapshot/backup of the current settings: => env export -t 100000 => era ${backup_addr} +${filesize} => cp.b 100000 ${backup_addr} ${filesize} Re-import this snapshot, deleting all other settings: => env import -d -t ${backup_addr} - env import [-d] [-t | -b | -c] addr [size] import external format (text or binary) into hash table, optionally deleting existing values: -d: delete existing environment before importing; otherwise overwrite / append to existion definitions -t: assume text format; either "size" must be given or the text data must be '\0' terminated -b: assume binary format ('\0' separated, "\0\0" terminated) -c: assume checksum protected environment format addr: memory address to read from size: length of input data; if missing, proper '\0' termination is mandatory - env default -f reset default environment: drop all environment settings and load default environment - env ask name [message] [size] same as "askenv": ask for environment variable - env edit name same as "editenv": edit environment variable - env run same as "run": run commands in an environment variable ====================================================================== TODO: - drop default env as implemented now; provide a text file based initialization instead (eventually using several text files to incrementally build it from common blocks) and a tool to convert it into a binary blob / object file. - It would be nice if we could add wildcard support for environment variables; this is needed for variable name auto-completion, but it would also be nice to be able to say "printenv ip*" or "printenv *addr*" - Some boards don't link any more due to the grown code size: DU405, canyonlands, sequoia, socrates. => cc: Matthias Fuchs <matthias.fuchs@esd-electronics.com>, Stefan Roese <sr@denx.de>, Heiko Schocher <hs@denx.de> - Dropping forceenv() causes build problems on schmoogie => cc: Sergey Kubushyn <ksi@koi8.net> - Build tested on PPC and ARM only; runtime tested with NOR and NAND flash only => needs testing!! Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Matthias Fuchs <matthias.fuchs@esd-electronics.com>, Cc: Stefan Roese <sr@denx.de>, Cc: Heiko Schocher <hs@denx.de> Cc: Sergey Kubushyn <ksi@koi8.net>
2010-08-09net ppc: fix ethernet device names with spacesHeiko Schocher
since commit 1384f3bb8a4f9066805b70c1418eda78ecb73fdd ethernet names with spaces drop a Warning: eth device name has a space! message. This patch fix it for: - "FEC ETHERNET" devices found on mpc512x, mpc5xxx, mpc8xx and mpc8220 boards. renamed to "FEC". - "SCC ETHERNET" devices found on mpc8xx, mpc82xx based boards. Renamed to "SCC". - "HDLC ETHERNET" devices found on mpc8xx boards Renamed to "HDLC" - "FCC ETHERNET" devices found on mpc8260 and mpc85xx based boards. Renamed to "FCC" Tested on the kup4k board. Signed-off-by: Heiko Schocher <hs@denx.de> Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2010-08-04Rename getenv_r() into getenv_f()Wolfgang Denk
While running from flash, i. e. before relocation, we have only a limited C runtime environment without writable data segment. In this phase, some configurations (for example with environment in EEPROM) must not use the normal getenv(), but a special function. This function had been called getenv_r(), with the idea that the "_r" suffix would mean the same as in the _r_eentrant versions of some of the C library functions (for example getdate vs. getdate_r, getgrent vs. getgrent_r, etc.). Unfortunately this was a misleading name, as in U-Boot the "_r" generally means "running from RAM", i. e. _after_ relocation. To avoid confusion, rename into getenv_f() [as "running from flash"] Signed-off-by: Wolfgang Denk <wd@denx.de> Acked-by: Detlev Zundel <dzu@denx.de>
2010-07-22i2c: soft_i2c: add simple GPIO implementationMike Frysinger
Since the vast majority of GPIO I2C implementations behave the same way, support the common GPIO framework with default settings. This adds two new defines CONFIG_SOFT_I2C_GPIO_{SCL,SDA} so that boards which want GPIO I2C support need only define these. Signed-off-by: Mike Frysinger <vapier@gentoo.org> Tested-by: Thomas Chou <thomas@wytron.com.tw>
2010-06-13Prepare v2010-rc2v2010.06-rc2Wolfgang Denk
2010-05-28nios: remove nios-32 archThomas Chou
The nios-32 arch is obsolete and broken. So it is removed. Signed-off-by: Thomas Chou <thomas@wytron.com.tw>
2010-05-28nios2: fix r15 issue for gcc4Thomas Chou
The "-ffixed-r15" option doesn't work well for gcc4. Since we don't use gp for small data with option "-G0", we can use gp as global data pointer. This allows compiler to use r15. It is necessary for gcc4 to work properly. Signed-off-by: Thomas Chou <thomas@wytron.com.tw> Signed-off-by: Scott McNutt <smcnutt@psyent.com>
2010-05-03Program net device MAC addresses after initializingBen Warren
Add a new function to the eth_device struct for programming a network controller's hardware address. After all network devices have been initialized and the proper MAC address for each has been determined, make a device driver call to program the address into the device. Only device instances with valid unicast addresses will be programmed. Signed-off-by: Ben Warren <biggerbadderben@gmail.com> Acked-by: Detlev Zundel <dzu@denx.de> Tested-by: Prafulla Wadaskar <prafulla@marvell.com> Tested-by: Heiko Schocher <hs@denx.de> Tested-by: Thomas Chou <thomas@wytron.com.tw>
2010-04-24Merge branch 'master' of git://git.denx.de/u-boot-i2cWolfgang Denk
2010-04-19fsl_i2c: Added a callpoint for i2c_board_late_initRichard Retanubun
This patch adds a callpoint in i2c_init that allows board specific i2c board initialization (typically for i2c bus reset) that is called after i2c_init operations, allowing the i2c_board_late_init function to use the pre-configured i2c bus speed and slave address.
2010-04-13Update README to reflect new directory structurePeter Tyser
Also fix up some whitespace issues that were introduced when moving directory locations. Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2010-04-13ppc: Move cpu/$CPU to arch/ppc/cpu/$CPUPeter Tyser
2010-04-13Rename lib_generic/ to lib/Peter Tyser
Now that the other architecture-specific lib directories have been moved out of the top-level directory there's not much reason to have the '_generic' suffix on the common lib directory. Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2010-04-13Move lib_$ARCH directories to arch/$ARCH/libPeter Tyser
Also move lib_$ARCH/config.mk to arch/$ARCH/config.mk This change is intended to clean up the top-level directory structure and more closely mimic Linux's directory organization. Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2010-04-08video: cfb_console.c: add support for RLE8 bitmapsAnatolij Gustschin
Allow displaying 8-bit RLE BMP images. Signed-off-by: Anatolij Gustschin <agust@denx.de>
2010-03-21TFTP: allow for adjustable retransmission timoutWolfgang Denk
So far, TFTP negotiated a fixed retransmission timeout of 5 seconds. In some cases (busy networks, slow TFTP servers) this caused very slow transfers. A new environment variable "tftptimeout" allows to set this timeout. Lowering this value may make downloads succeed faster in networks with high packet loss rates or with unreliable TFTP servers. Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Ben Warren <biggerbadderben@gmail.com> Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2010-01-31new at91_emac network driver (NET_MULTI api)Jens Scharsig
* add's at91_emac (AT91RM9200) network driver (NET_MULTI api) * enable driver with CONFIG_DRIVER_AT91EMAC * generic PHY initialization * modify AT91RM9200 boards to use NET_MULTI driver * the drivers has been tested with LXT971 Phy and DM9161 Phy at MII and RMII interface Signed-off-by: Jens Scharsig <js_at_ng@scharsoft.de> Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2010-01-26ppc: Update README about the new GOT ptr.Joakim Tjernlund
r14 is no longer used as non volatile GOT ptr. Instead the volatile r12 is used so be sure to do GET_GOT in asm code when you need to access global data. Signed-off-by: Joakim Tjernlund <Joakim.Tjernlund@transmode.se>
2010-01-18cmd_eeprom: I2C updatesHeiko Schocher
- CONFIG_ENV_EEPROM_IS_ON_I2C define this, if you have I2C and SPI activated, and your EEPROM, which holds the environment, is on the I2C bus. - CONFIG_I2C_ENV_EEPROM_BUS if you have an Environment on an EEPROM reached over I2C muxes, you can now define, how to reach this EEPROM. Signed-off-by: Heiko Schocher <hs@denx.de>
2009-12-08common: delete CONFIG_SYS_64BIT_VSPRINTF and CONFIG_SYS_64BIT_STRTOULHeiko Schocher
There is more and more usage of printing 64bit values, so enable this feature generally, and delete the CONFIG_SYS_64BIT_VSPRINTF and CONFIG_SYS_64BIT_STRTOUL defines. Signed-off-by: Heiko Schocher <hs@denx.de>
2009-12-07smc911x: update SMC911X related configuration descriptionMike Rapoport
Since commit 736fead8fdbf8a8407048bebc373cd551d01ec98 "Convert SMC911X Ethernet driver to CONFIG_NET_MULTI API" SMC911X configration options are called CONFIG_SMC911X rather than CONFIG_DRIVER_SMC911X. Update README to reflect that change. Signed-off-by: Mike Rapoport <mike@compulab.co.il>
2009-12-05README: Rearrange paragraphs to regain linear arrangement.Detlev Zundel
Two later additions to the Configuration Option section unfortunately split the description of Show boot progress and the list of its call outs. Signed-off-by: Detlev Zundel <dzu@denx.de>
2009-12-02README: Update the list of directories.Robert P. J. Day
Bring the directory listing more into line with current content. Signed-off-by: Robert P. J. Day <rpjday@crashcourse.ca>
2009-10-27Add 'editenv' commandPeter Tyser
The editenv command can be used to edit an environment variable. Editing an environment variable is useful when one wants to tweak an existing variable, for example fix a typo or change the baudrate in the 'bootargs' environment variable. Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2009-10-27Revert "env: only build env_embedded and envcrc when needed"Wolfgang Denk
Breaks building on many boards, and no really clean fix available yet. This reverts commit 6dab6add2d8ee80905234b326abc3de11be1d178.
2009-10-18env: only build env_embedded and envcrc when neededMike Frysinger
The env code is protected by the ENV_IS_EMBEDDED define, so attempting to compile the code when this isn't defined is pointless. Now that the env headers have unified around CONFIG_ENV_IS_EMBEDDED, convert the build system to only build the env objects when this is enabled. And now that the env code is conditionally compiled, we can drop the source code checks. For people who want to extract the environment manually, add a new option CONFIG_BUILD_ENVCRC that only enables the envcrc utility. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2009-09-25mucmc52, uc101: delete ata@3a00 node, if no CF card is detectedHeiko Schocher
U-Boot can detect if an IDE device is present or not. If not, and this new config option is activated, U-Boot removes the ATA node from the DTS before booting Linux, so the Linux IDE driver does not probe the device and crash. This is needed for buggy hardware (uc101) where no pull down resistor is connected to the signal IDE5V_DD7. Signed-off-by: Heiko Schocher <hs@denx.de>
