path: root/README
2014-01-02powerpc/mpc85xx: Add support for single source clockingPriyanka Jain
Single-source clocking is new feature introduced in T1040. In this mode, a single differential clock is supplied to the DIFF_SYSCLK_P/N inputs to the processor, which in turn is used to supply clocks to the sysclock, ddrclock and usbclock. So, both ddrclock and syclock are driven by same differential sysclock in single-source clocking mode whereas in normal clocking mode, generally separate DDRCLK and SYSCLK pins provides reference clock for sysclock and ddrclock DDR_REFCLK_SEL rcw bit is used to determine DDR clock source -If DDR_REFCLK_SEL rcw bit is 0, then DDR PLLs are driven in normal clocking mode by DDR_Reference clock -If DDR_REFCLK_SEL rcw bit is 1, then DDR PLLs are driven in single source clocking mode by DIFF_SYSCLK Add code to determine ddrclock based on DDR_REFCLK_SEL rcw bit. Signed-off-by: Poonam Aggrwal <poonam.aggrwal@freescale.com> Signed-off-by: Priyanka Jain <Priyanka.Jain@freescale.com>
2014-01-02board/freescale:Remove use of CONFIG_SPL_NAND_MINIMALPrabhakar Kushwaha
CONFIG_SPL_NAND_MINIMAL should not be used as it was defined for temporary review purpose. So, use CONFIG_SPL_NAND_BOOT config. Signed-off-by: Prabhakar Kushwaha <prabhakar@freescale.com>
2013-12-13Add dumpimage, a tool to extract data from U-Boot imagesGuilherme Maciel Ferreira
Given a multi-file image created through the mkimage's -d option: $ mkimage -A x86 -O linux -T multi -n x86 -d vmlinuz:initrd.img:System.map \ multi.img Image Name: x86 Created: Thu Jul 25 10:29:13 2013 Image Type: Intel x86 Linux Multi-File Image (gzip compressed) Data Size: 13722956 Bytes = 13401.32 kB = 13.09 MB Load Address: 00000000 Entry Point: 00000000 Contents: Image 0: 4040128 Bytes = 3945.44 kB = 3.85 MB Image 1: 7991719 Bytes = 7804.41 kB = 7.62 MB Image 2: 1691092 Bytes = 1651.46 kB = 1.61 MB It is possible to perform the innverse operation -- extracting any file from the image -- by using the dumpimage's -i option: $ dumpimage -i multi.img -p 2 System.map Although it's feasible to retrieve "data files" from image through scripting, the requirement to embed tools such 'dd', 'awk' and 'sed' for this sole purpose is cumbersome and unreliable -- once you must keep track of file sizes inside the image. Furthermore, extracting data files using "dumpimage" tool is faster than through scripting. Signed-off-by: Guilherme Maciel Ferreira <guilherme.maciel.ferreira@gmail.com> Signed-off-by: Simon Glass <sjg@chromium.org>
2013-12-10Merge branch 'master' of git://git.denx.de/u-boot-armTom Rini
Conflicts: board/samsung/trats2/trats2.c include/configs/exynos5250-dt.h Signed-off-by: Tom Rini <trini@ti.com>
2013-12-10Merge branch 'u-boot/master' into 'u-boot-arm/master'Albert ARIBAUD
Conflicts: arch/arm/cpu/armv7/rmobile/Makefile doc/README.scrapyard Needed manual fix: arch/arm/cpu/armv7/omap-common/Makefile board/compulab/cm_t335/u-boot.lds
2013-12-06i2c: samsung: register i2c busses for Exynso5420 and Exynos5250Naveen Krishna Ch
This patch adds the U_BOOT_I2C_ADAP_COMPLETE defines for channels on Exynos5420 and Exynos5250 and also adds support for init function for hsi2c channels Signed-off-by: Naveen Krishna Chatradhi <ch.naveen@samsung.com>
2013-12-02Merge branch 'master' of git://git.denx.de/u-boot-mpc85xxTom Rini
2013-11-25Driver/DDR: Add Freescale DDR driver for ARMYork Sun
Make PowerPC specific code conditional so ARM SoCs can reuse this driver. Add DDR3 driver for ARM. Signed-off-by: York Sun <yorksun@freescale.com>
2013-11-25Driver/DDR: Moving Freescale DDR driver to a common driverYork Sun
Freescale DDR driver has been used for mpc83xx, mpc85xx, mpc86xx SoCs. The similar DDR controllers will be used for ARM-based SoCs. Signed-off-by: York Sun <yorksun@freescale.com>
2013-11-25gpio_led: add support for inverted polarityIgor Grinberg
Some GPIO connected LEDs have inverted polarity. Introduce new config option: CONFIG_GPIO_LED_INVERTED_TABLE for the specifying the inverted GPIO LEDs list and add support for this in the gpio_led driver. Signed-off-by: Igor Grinberg <grinberg@compulab.co.il> Tested-by: Ilya Ledvich <ilya@compulab.co.il>
2013-11-25README: document the CONFIG_GPIO_LED symbolIgor Grinberg
The CONFIG_GPIO_LED symbol does not have any documentation in the README file. Document the CONFIG_GPIO_LED symbol. Signed-off-by: Igor Grinberg <grinberg@compulab.co.il>
2013-11-13i2c, zynq: convert zynq i2c driver to new multibus/multiadapter frameworkHeiko Schocher
- add zync i2c driver to new multibus/multiadpater support - adapted all config files, which uses this driver Signed-off-by: Heiko Schocher <hs@denx.de> Cc: Joe Hershberger <joe.hershberger@ni.com> Cc: Michal Simek <michal.simek@xilinx.com>
2013-11-13i2c, omap24xx: convert driver to new mutlibus/mutliadapter frameworkHeiko Schocher
- add omap24xx driver to new multibus/multiadpater support - adapted all config files, which uses this driver Tested on the am335x based siemens boards rut, dxr2 and pxm2 posted here: http://patchwork.ozlabs.org/patch/263211/ Signed-off-by: Heiko Schocher <hs@denx.de> Tested-by: Tom Rini <trini@ti.com> Cc: Lars Poeschel <poeschel@lemonage.de> Cc: Steve Sakoman <sakoman@gmail.com> Cc: Thomas Weber <weber@corscience.de> Cc: Tom Rix <Tom.Rix@windriver.com> Cc: Grazvydas Ignotas <notasas@gmail.com> Cc: Enric Balletbo i Serra <eballetbo@iseebcn.com> Cc: Luca Ceresoli <luca.ceresoli@comelit.it> Cc: Igor Grinberg <grinberg@compulab.co.il> Cc: Ilya Yanok <yanok@emcraft.com> Cc: Stefano Babic <sbabic@denx.de> Cc: Nishanth Menon <nm@ti.com> Cc: Pali Rohár <pali.rohar@gmail.com> Cc: Peter Barada <peter.barada@logicpd.com> Cc: Nagendra T S <nagendra@mistralsolutions.com> Cc: Michael Jones <michael.jones@matrix-vision.de> Cc: Raphael Assenat <raph@8d.com> Acked-by: Igor Grinberg <grinberg@compulab.co.il> Acked-by: Stefano Babic <sbabic@denx.de>
2013-11-13i2c: sh_i2c: Update to new CONFIG_SYS_I2C frameworkNobuhiro Iwamatsu
This updates to new I2C framwwork on sh_i2c. And this also updates boards(kzm9g and ecovec) that using sh_i2c. Signed-off-by: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2013-11-11arm, am33x: make RTC32K OSC enable configurableHeiko Schocher
As http://www.denx.de/wiki/view/U-Boot/DesignPrinciples#2_Keep_it_Fast states: "Initialize devices only when they are needed within U-Boot" enable the RTC32K OSC only, if CONFIG_SPL_AM33XX_ENABLE_RTC32K_OSC is enabled. Enable this in ti_am335x_common.h, so all boards in mainline should work as before. Signed-off-by: Heiko Schocher <hs@denx.de> Cc: Tom Rini <trini@ti.com>
2013-11-11bootcount: store bootcount var in environmentHeiko Schocher
If no softreset save registers are found on the hardware "bootcount" is stored in the environment. To prevent a saveenv on all reboots, the environment variable "upgrade_available" is introduced. If "upgrade_available" is 0, "bootcount" is always 0 therefore no need to save the environment on u-boot boot, if "upgrade_available" is 1 "bootcount" is incremented in the environment and environment gets written on u-boot start. So the Userspace Applikation must set the "upgrade_available" and "bootcount" variable to 0 (for example with fw_setenv), if a boot was successfully. Signed-off-by: Heiko Schocher <hs@denx.de>
2013-11-08Merge branch 'master' of git://www.denx.de/git/u-boot-usbTom Rini
2013-11-08usb: ums: add ums exit feature by ctrl+c or by detach usb cablePrzemyslaw Marczak
This patch allows exiting from UMS mode to u-boot prompt by detaching usb cable or by pressing ctrl+c. Add new config: CONFIG_USB_CABLE_CHECK. If defined then board file should provide function: usb_cable_connected() (include/usb.h) that return 1 if cable is connected and 0 otherwise. Changes v2: - add a note to the README Signed-off-by: Przemyslaw Marczak <p.marczak@samsung.com> Cc: Marek Vasut <marex@denx.de>
2013-11-08README: remove wrong config nameIgor Grinberg
There is no CONFIG_PCA953X_INFO symbol. U-Boot uses CONFIG_CMD_PCA953X_INFO instead, which is described in "Monitor Functions" section and thus no need to be repeated in the "GPIO Support" section. Remove the whole line. Signed-off-by: Igor Grinberg <grinberg@compulab.co.il>
2013-11-08cmd_nvedit.c: Add env exists commandAndrew Ruder
env exists is a way to test (in hush) if an environment variable exists. A workaround existed using printenv but this new command doesn't require all the stdout/stderr redirection to prevent printing information to the screen. Example: $ set testexists 1 $ env exists testexists && echo "yes" yes $ env exists testexists || echo "no" $ set testexists $ env exists testexists && echo "yes" $ env exists testexists || echo "no" no $ Signed-off-by: Andrew Ruder <andrew.ruder@elecsyscorp.com>
2013-10-30video, cfb_console: make background and foreground color configurableHeiko Schocher
make CONSOLE_BG_COL/CONSOLE_FG_COL configurable through board config file. Clear video screen in video_init(). Signed-off-by: Heiko Schocher <hs@denx.de> Cc: Anatolij Gustschin <agust@denx.de>
2013-10-17README: I2C: Fix indentNobuhiro Iwamatsu
2013-10-17i2c: Add support for Renesas rcarNobuhiro Iwamatsu
This supports i2c controller for Renesas rcar. Signed-off-by: Hisashi Nakamura <hisashi.nakamura.ak@renesas.com> Signed-off-by: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com>
2013-10-17i2c: mxc: move to new subsystemtrem
Signed-off-by: Philippe Reynes <tremyfr@yahoo.fr>
2013-10-14Coding Style cleanup: replace leading SPACEs by TABsWolfgang Denk
Signed-off-by: Wolfgang Denk <wd@denx.de> [trini: Drop changes for PEP 4 following python tools] Signed-off-by: Tom Rini <trini@ti.com>
2013-10-08Merge branch 'master' of git://git.denx.de/u-boot-armTom Rini
2013-10-07omap1510inn: arm925t: remove supportAlbert ARIBAUD
omap1510inn is orphan and has been for years now. Reove it and, as it was the only arm925t target, also remove arm925t support. Update doc/README.scrapyard accordingly. Signed-off-by: Albert ARIBAUD <albert.u.boot@aribaud.net>
2013-10-02Merge branch 'master' of git://git.denx.de/u-boot-armTom Rini
2013-09-24dfu: ram supportAfzal Mohammed
DFU spec mentions it as a method to upgrade firmware (software stored in writable non-volatile memory). It also says other potential uses of DFU is beyond scope of the spec. Here such a beyond the scope use is being attempted - directly pumping binary images from host via USB to RAM. This facility is a developer centric one in that it gives advantage over upgrading non-volatile memory for testing new images every time during development and/or testing. Directly putting image onto RAM would speed up upgrade process. This and convenience was the initial thoughts that led to doing this, speed improvement over MMC was only 1 second though - 6 sec on RAM as opposed to 7 sec on MMC in beagle bone, perhaps enabling cache and/or optimizing DFU framework to avoid multiple copy for ram (if worth) may help, and on other platforms and other boot media like NAND maybe improvement would be higher. And for a platform that doesn't yet have proper DFU suppport for non-volatile media's, DFU to RAM can be used. Another minor advantage would be to increase life of mmc/nand as it would be less used during development/testing. usage: <image name> ram <start address> <size> eg. kernel ram 0x81000000 0x1000000 Downloading images to RAM using DFU is not something new, this is acheived in openmoko also. DFU on RAM can be used for extracting RAM contents to host using dfu upload. Perhaps this can be extended to io for squeezing out register dump through usb, if it is worth. Signed-off-by: Afzal Mohammed <afzal.mohd.ma@gmail.com> Cc: Heiko Schocher <hs@denx.de> Cc: Marek Vasut <marex@denx.de> Cc: Lukasz Majewski <l.majewski@samsung.com> Cc: Pantelis Antoniou <panto@antoniou-consulting.com> Cc: Gerhard Sittig <gsi@denx.de> Acked-by: Marek Vasut <marex@denx.de> Acked-by: Lukasz Majewski <l.majewski@samsung.com> Acked-by: Heiko Schocher <hs@denx.de>
2013-09-23README: update ARM register usageJeroen Hofstee
Besides the change of this patchset it also updates the README to reflect that GOT-generated relocations are no longer supported on ARM. cc: Albert ARIBAUD <albert.u.boot@aribaud.net> Signed-off-by: Jeroen Hofstee <jeroen@myspectrum.nl>
2013-09-20Cosmetic: Fix a number of typos, no functional changes.Robert P. J. Day
Fix various misspellings of things like "environment", "kernel", "default" and "volatile", and throw in a couple grammar fixes. Signed-off-by: Robert P. J. Day <rpjday@crashcourse.ca>
2013-09-20Cosmetic: Update some info in the README "arch" section.Robert P. J. Day
Tidy up, reorder, and add newer info to the arch/ directory subsection of the README file. Signed-off-by: Robert P. J. Day <rpjday@crashcourse.ca>
2013-09-19ARM: s3c44b0: remove remainders of dead boardMasahiro Yamada
Because commit 5dc5f36 removed B2 board support, arch/arm/cpu/s3c44b0/* and arch/arm/include/asm/arch-s3c44b0/* are not necessary anymore. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Wolfgang Denk <wd@denx.de> Cc: Andrea Scian <andrea.scian@dave-tech.it>
2013-09-12Merge and reformat boards.cfg and MAINTAINERSAlbert ARIBAUD
Put all informations about targets, including state (active or orphan) and maintainers, in boards.cfg; remove MAINTAINERS; adjust the build system accordingly. Signed-off-by: Albert ARIBAUD <albert.u.boot@aribaud.net>
2013-09-03documentation: add more compression configsKees Cook
This adds the missing compression config items to the README. Signed-off-by: Kees Cook <keescook@chromium.org> Acked-by: Simon Glass <sjg@chromium.org>
2013-08-20TPL : introduce the TPL based on the SPLYing Zhang
Due to the nand SPL on some board(e.g. P1022DS)has a size limit, it can not be more than 4K. So, the SPL cannot initialize the DDR with the SPD code. This patch introduces TPL to enable a loader stub that is loaded by the code from the SPL. It initializes the DDR with the SPD or other operations. The TPL's size is sizeable, the maximum size is decided by the memory's size that TPL runs. It initializes the DDR through SPD code, and copys final uboot image to DDR. So there are three stage uboot images: * spl_boot, * tpl_boot, * final uboot image Signed-off-by: Ying Zhang <b40530@freescale.com> Acked-by: York Sun <yorksun@freescale.com>
2013-08-20powerpc: p1022ds: Enable P1022DS to boot from SD Card with SPLYing Zhang
Enable p1022ds to start from eSDHC with SPL. Signed-off-by: Ying Zhang <b40530@freescale.com> Acked-by: York Sun <yorksun@freescale.com>
2013-08-20powerpc: mpc85xx: Support booting from SD Card with SPLYing Zhang
The code from the internal on-chip ROM. It loads the final uboot image into DDR, then jump to it to begin execution. The SPL's size is sizeable, the maximum size must not exceed the size of L2 SRAM. It initializes the DDR through SPD code, and copys final uboot image to DDR. So there are two stage uboot images: * spl_boot, 96KB size. The env variables are copied to L2 SRAM, so that ddr spd code can get the interleaving mode setting in env. It loads final uboot image from offset 96KB. * final uboot image, size is variable depends on the functions enabled. Signed-off-by: Ying Zhang <b40530@freescale.com> Acked-by: York Sun <yorksun@freescale.com>
2013-08-18Merge branch 'master' of git://88.191.163.10/u-boot-armTom Rini
Fixup an easy conflict over adding the clk_get prototype and USB_OTG defines for am33xx having moved. Conflicts: arch/arm/include/asm/arch-am33xx/hardware.h Signed-off-by: Tom Rini <trini@ti.com>
2013-08-16RFC: bootm: Add silent_linux environment variableSimon Glass
At present the console for linux is silent if the U-Boot console is silent, unless CONFIG_SILENT_U_BOOT_ONLY is set. I wonder if a better way would be to have an environment variable to control this? Then we can control the verbosity from scripts, and set the variable to 'no' for those boards that want Linux to boot with console output. Signed-off-by: Simon Glass <sjg@chromium.org>
2013-08-09board/bsc9132qds: Add DSP side tlb and lawsPriyanka Jain
BSC9132QDS is a Freescale Reference Design Board for BSC9132 SoC which is a integrated device that contains two powerpc e500v2 cores and two DSP starcores. To support DSP starcore -Creating LAW and TLB for DSP-CCSR space. -Creating LAW for DSP-core subsystem M2 and M3 memory -Creating LAW for 1GB DDR which is connected exclusively to DSP-cores Signed-off-by: Manish Jaggi <manish.jaggi@freescale.com> Signed-off-by: Priyanka Jain <Priyanka.Jain@freescale.com> Acked-by: York Sun <yorksun@freescale.com>
2013-08-09mpc85xx: Base emulator supportYork Sun
Prepare for emulator support for mpc85xx parts. Disable DDR training and skip wrlvl_cntl_2 and wrlvl_cntl_3 registers. These two registers improve stability but not supported by emulator. Add CONFIG_FSL_TBCLK_EXTRA_DIV for possible adjustment to time base. Signed-off-by: York Sun <yorksun@freescale.com>
2013-07-31Merge git://git.denx.de/u-boot-armStefano Babic
Conflicts: board/freescale/mx6qsabrelite/Makefile board/freescale/mx6qsabrelite/mx6qsabrelite.c include/configs/mx6qsabrelite.h Signed-off-by: Stefano Babic <sbabic@denx.de>
2013-07-27imx: Add documentation for imx specific commandsRobert Winkler
CONFIG_CMD_HDMIDETECT CONFIG_CMD_BMODE Signed-off-by: Robert Winkler <robert.winkler@boundarydevices.com> Acked-by: Otavio Salvador <otavio@ossystems.com.br>
2013-07-24Merge branch 'master' of git://git.denx.de/u-boot-i2cTom Rini
The sandburst-specific i2c drivers have been deleted, conflict was just over the SPDX conversion. Conflicts: board/sandburst/common/ppc440gx_i2c.c board/sandburst/common/ppc440gx_i2c.h Signed-off-by: Tom Rini <trini@ti.com>
2013-07-24Licenses: introduce SPDX Unique Lincense IdentifiersWolfgang Denk
Like many other projects, U-Boot has a tradition of including big blocks of License headers in all files. This not only blows up the source code with mostly redundant information, but also makes it very difficult to generate License Clearing Reports. An additional problem is that even the same lincenses are referred to by a number of slightly varying text blocks (full, abbreviated, different indentation, line wrapping and/or white space, with obsolete address information, ...) which makes automatic processing a nightmare. To make this easier, such license headers in the source files will be replaced with a single line reference to Unique Lincense Identifiers as defined by the Linux Foundation's SPDX project [1]. For example, in a source file the full "GPL v2.0 or later" header text will be replaced by a single line: SPDX-License-Identifier: GPL-2.0+ We use the SPDX Unique Lincense Identifiers here; these are available at [2]. Note: From the legal point of view, this patch is supposed to be only a change to the textual representation of the license information, but in no way any change to the actual license terms. With this patch applied, all files will still be licensed under the same terms they were before. Note 2: The apparent difference between the old "COPYING" and the new "Licenses/gpl-2.0.txt" only results from switching to the upstream version of the license which is differently formatted; there are not any actual changes to the content. Note 3: There are some recurring questions about linense issues, such as: - Is a "All Rights Reserved" clause a problem in GPL code? - Are files without any license header a problem? - Do we need license headers at all? The following excerpt from an e-mail by Daniel B. Ravicher should help with these: | Message-ID: <4ADF8CAA.5030808@softwarefreedom.org> | Date: Wed, 21 Oct 2009 18:35:22 -0400 | From: "Daniel B. Ravicher" <ravicher@softwarefreedom.org> | To: Wolfgang Denk <wd@denx.de> | Subject: Re: GPL and license cleanup questions | | Mr. Denk, | | Wolfgang Denk wrote: | > - There are a number of files which do not include any specific | > license information at all. Is it correct to assume that these files | > are automatically covered by the "GPL v2 or later" clause as | > specified by the COPYING file in the top level directory of the | > U-Boot source tree? | | That is a very fact specific analysis and could be different across the | various files. However, if the contributor could reasonably be expected | to have known that the project was licensed GPLv2 or later at the time | she made her contribution, then a reasonably implication is that she | consented to her contributions being distributed under those terms. | | > - Do such files need any clean up, for example should we add GPL | > headers to them, or is this not needed? | | If the project as a whole is licensed under clear terms, you need not | identify those same terms in each file, although there is no harm in | doing so. | | > - There are other files, which include both a GPL license header | > _plus_ some copyright note with an "All Rights Reserved" clause. It | > has been my understanding that this is a conflict, and me must ask | > the copyright holders to remove such "All Rights Reserved" clauses. | > But then, some people claim that "All Rights Reserved" is a no-op | > nowadays. License checking tools (like OSLC) seem to indicate this is | > a problem, but then we see quite a lot of "All rights reserved" in | > BSD-licensed files in gcc and glibc. So what is the correct way to | > deal with such files? | | It is not a conflict to grant a license and also reserve all rights, as | implicit in that language is that you are reserving all "other" rights | not granted in the license. Thus, a file with "Licensed under GPL, All | Rights Reserved" would mean that it is licensed under the GPL, but no | other rights are given to copy, modify or redistribute it. | | Warm regards, | --Dan | | Daniel B. Ravicher, Legal Director | Software Freedom Law Center (SFLC) and Moglen Ravicher LLC | 1995 Broadway, 17th Fl., New York, NY 10023 | (212) 461-1902 direct (212) 580-0800 main (212) 580-0898 fax | ravicher@softwarefreedom.org www.softwarefreedom.org [1] http://spdx.org/ [2] http://spdx.org/licenses/ Signed-off-by: Wolfgang Denk <wd@denx.de>
2013-07-23i2c, ppc4xx_i2c: switch to new multibus/multiadapter supportDirk Eibach
Signed-off-by: Dirk Eibach <dirk.eibach@gdsys.cc> Cc: Heiko Schocher <hs@denx.de> Cc: Stefan Roese <sr@denx.de> Tested-by: Stefan Roese <sr@denx.de>
2013-07-23tegra: i2c: Enable new CONFIG_SYS_I2C frameworkSimon Glass
This enables CONFIG_SYS_I2C on Tegra, updating existing boards and the Tegra i2c driver to support this. Signed-off-by: Simon Glass <sjg@chromium.org> Signed-off-by: Heiko Schocher <hs@denx.de>
2013-07-23i2c, multibus: get rid of CONFIG_I2C_MUXHeiko Schocher
CONFIG_I2C_MUX is replaced through the new i2c multibus/multiadapter framework, configured through CONFIG_SYS_I2C. As CONFIG_I2C_MUX is only used on the keymile boards, and they are now completely moved to the new framework, remove CONFIG_I2C_MUX. Signed-off-by: Heiko Schocher <hs@denx.de> Cc: Holger Brunck <holger.brunck@keymile.com> Tested-By: Holger Brunck <holger.brunck@keymile.com>
2013-07-23i2c, fsl_i2c: switch to new multibus/multiadapter supportHeiko Schocher
- added to fsl_i2c driver new multibus/multiadpater support - adapted all config files, which uses this driver Signed-off-by: Heiko Schocher <hs@denx.de> Cc: Simon Glass <sjg@chromium.org> Cc: Stephen Warren <swarren@wwwdotorg.org>
