path: root/README
2011-05-20powerpc/fsl_pci: Fix device tree fixups for newer platformsKumar Gala
We assumed that only a small set of compatiable strings would be needed to find the PCIe device tree nodes to be fixed up. However on newer platforms the simple rules no longer work. We need to allow specifying the PCIe compatiable string for each individual SoC. We introduce CONFIG_SYS_FSL_PCIE_COMPAT for this purpose and set it if the default isn't sufficient. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2011-05-19TFTP: add tftpsrv commandLuca Ceresoli
Signed-off-by: Luca Ceresoli <luca.ceresoli@comelit.it> Cc: Wolfgang Denk <wd@denx.de> Acked-by: Detlev Zundel <dzu@denx.de>
2011-05-12README: Clarify difference of CONFIG_WATCHDOG and CONFIG_HW_WATCHDOGDetlev Zundel
Now that we have the documentation, the code should be changed to reflect it ;) Asd far as I can see, these are the places where HW_WATCHDOG is used instead of WATCHDOG: arch/blackfin/cpu/blackfin/watchdog.c arch/m68k/cpu/mcf547x_8x/cpu.c The relevant maintainers are on CC. Signed-off-by: Detlev Zundel <dzu@denx.de> Cc: Mike Frysinger <vapier@gentoo.org> Cc: TsiChungLiew <Tsi-Chung.Liew@freescale.com>
2011-05-12README: remove spurious lineLuca Ceresoli
2011-05-12Serial: p1011: new vendor init optionsJohn Rigby
Two new options: CONFIG_PL011_SERIAL_RLCR Some vendor versions of PL011 serial ports (e.g. ST-Ericsson U8500) have separate receive and transmit line control registers. Set this variable to initialize the extra register. CONFIG_PL011_SERIAL_FLUSH_ON_INIT On some platforms (e.g. U8500) U-Boot is loaded by a second stage boot loader that has already initialized the UART. Define this variable to flush the UART at init time. empty fifo on init Signed-off-by: John Rigby <john.rigby@linaro.org> Signed-off-by: Rabin Vincent <rabin.vincent@stericsson.com>
2011-04-30Merge branch 'master' of git://git.denx.de/u-boot-mpc85xxWolfgang Denk
2011-04-30cmd_ide: enhance new feature "CONFIG_IDE_AHB"Macpaul Lin
Although most IDE controller is designed to be connected to PCI bridge, there are still some IDE controller support AHB interface for SoC design. The driver implementation of these IDE-AHB controllers differ from other IDE-PCI controller, some additional registers and commands access is required during CMD/DATA I/O. Hence a configuration "CONFIG_IDE_AHB" in cmd_ide.c is required to be defined to support these kinds of SoC controllers. Such as Faraday's FTIDE020 series and Global Unichip's UINF-0301. Signed-off-by: Macpaul Lin <macpaul@andestech.com>
2011-04-28powerpc/85xx: Change timebase divisor to be defined per processorKumar Gala
Introduce new CONFIG_SYS_FSL_TBCLK_DIV on 85xx platforms because different SoCs have different divisor amounts. All the PQ3 parts are /8, the P4080/P4080 is /16, and P2040/P3041/P5020 are /32. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2011-04-28powerpc: use 'video-mode' environment variable to configure DIUTimur Tabi
Use the 'video-mode' environment variable (for Freescale chips that have a DIU display controller) to designate the full video configuration. Previously, the DIU driver used the 'monitor' variable, and it was used only to determine the output video port. The old definition of the "monitor" environment variable only determines which video port to use for output. This variable was set to a number (0, 1, or sometimes 2) to specify a DVI, LVDS, or Dual-LVDS port. The resolution was hard-coded into board-specific code. The Linux command-line arguments needed to be hard-coded to the proper video definition string. Signed-off-by: Timur Tabi <timur@freescale.com> Signed-off-by: Anatolij Gustschin <agust@denx.de>
2011-04-28common: add a grepenv commandKim Phillips
u-boot environments, esp. when boards are shared across multiple users, can get pretty large and time consuming to visually parse. The grepenv command this patch adds can be used in lieu of printenv to facilitate searching. grepenv works like printenv but limits its output only to environment strings (variable name and value pairs) that match the user specified substring. the following examples are on a board with a 5313 byte environment that spans multiple screen pages: Example 1: summarize ethernet configuration: => grepenv eth TSEC etact=FM1@DTSEC2 eth=FM1@DTSEC4 ethact=FM1@DTSEC2 eth1addr=00:E0:0C:00:8b:01 eth2addr=00:E0:0C:00:8b:02 eth3addr=00:E0:0C:00:8b:03 eth4addr=00:E0:0C:00:8b:04 eth5addr=00:E0:0C:00:8b:05 eth6addr=00:E0:0C:00:8b:06 eth7addr=00:E0:0C:00:8b:07 eth8addr=00:E0:0C:00:8b:08 eth9addr=00:E0:0C:00:8b:09 ethaddr=00:E0:0C:00:8b:00 netdev=eth0 uprcw=setenv ethact $eth;setenv filename p4080ds/R_PPSXX_0xe/rcw_0xe_2sgmii_rev2_high.bin;setenv start 0xe8000000;protect off all;run upimage;protect on all upuboot=setenv ethact $eth;setenv filename u-boot.bin;setenv start eff80000;protect off all;run upimage;protect on all upucode=setenv ethact $eth;setenv filename fsl_fman_ucode_P4080_101_6.bin;setenv start 0xef000000;protect off all;run upimage;protect on all usdboot=setenv ethact $eth;tftp 1000000 $dir/$bootfile;tftp 2000000 $dir/initramfs.cpio.gz.uboot;tftp c00000 $dir/p4080ds-usdpaa.dtb;setenv bootargs root=/dev/ram rw console=ttyS0,115200 $othbootargs;bootm 1000000 2000000 c00000; => Example 2: detect unused env vars: => grepenv etact etact=FM1@DTSEC2 => Example 3: reveal hardcoded variables; e.g., for fdtaddr: => grepenv fdtaddr fdtaddr=c00000 nfsboot=setenv bootargs root=/dev/nfs rw nfsroot=$serverip:$rootpath ip=$ipaddr:$serverip:$gatewayip:$netmask:$hostname:$netdev:off console=$consoledev,$baudrate $othbootargs;tftp $loadaddr $bootfile;tftp $fdtaddr $fdtfile;bootm $loadaddr - $fdtaddr ramboot=setenv bootargs root=/dev/ram rw console=$consoledev,$baudrate $othbootargs;tftp $ramdiskaddr $ramdiskfile;tftp $loadaddr $bootfile;tftp $fdtaddr $fdtfile;bootm $loadaddr $ramdiskaddr $fdtaddr => grep $fdtaddr fdtaddr=c00000 my_boot=bootm 0x40000000 0x41000000 0x00c00000 my_dtb=tftp 0x00c00000 $prefix/p4080ds.dtb nohvboot=tftp 1000000 $dir/$bootfile;tftp 2000000 $dir/$ramdiskfile;tftp c00000 $dir/$fdtfile;setenv bootargs root=/dev/ram rw ramdisk_size=0x10000000 console=ttyS0,115200;bootm 1000000 2000000 c00000; => This patch also enables the grepenv command by default on corenet_ds based boards (and repositions the DHCP command entry to keep the list sorted). Signed-off-by: Kim Phillips <kim.phillips@freescale.com> Cc: Kumar Gala <kumar.gala@freescale.com> Cc: Andy Fleming <afleming@freescale.com>
2011-04-27Merge branch 'master' of git://git.denx.de/u-boot-armWolfgang Denk
2011-04-27Don't grab memory for LCD if FB address is definedMinkyu Kang
If FB address is defined specific address then don't grab memory for LCD Signed-off-by: Minkyu Kang <mk7.kang@samsung.com> Cc: Albert Aribaud <albert.aribaud@free.fr> Cc: Wolfgang Denk <wd@denx.de> Cc: Stefan Roese <sr@denx.de> Cc: Kim Phillips <kim.phillips@freescale.com> Cc: Andy Fleming <afleming@gmail.com> Cc: Kumar Gala <kumar.gala@freescale.com>
2011-04-27arm: Use optimized memcpy and memset from linuxMatthias Weisser
Using optimized versions of memset and memcpy from linux brings a quite noticeable speed (x2 or better) improvement for these two functions. Here are some numbers for test done with jadecpu | HEAD(1)| HEAD(1)| HEAD(2)| HEAD(2)| | | +patch | | +patch | ---------------------------+--------+--------+--------+--------+ Reset to prompt | 438ms | 330ms | 228ms | 120ms | | | | | | TFTP a 3MB img | 4782ms | 3428ms | 3245ms | 2820ms | | | | | | FATLOAD USB a 3MB img* | 8515ms | 8510ms | ------ | ------ | | | | | | BOOTM LZO img in RAM | 3473ms | 3168ms | 592ms | 592ms | where CRC is | 615ms | 615ms | 54ms | 54ms | uncompress | 2460ms | 2462ms | 450ms | 451ms | final boot_elf | 376ms | 68ms | 65ms | 65ms | | | | | | BOOTM LZO img in FLASH | 3207ms | 2902ms | 1050ms | 1050ms | where CRC is | 600ms | 600ms | 135ms | 135ms | uncompress | 2209ms | 2211ms | 828ms | 828ms | | | | | | Copy 1.4MB from NOR to RAM | 134ms | 72ms | 120ms | 70ms | (1) No dcache (2) dcache enabled in board_init *Does not work when dcache is on Size impact: C version: text data bss dec hex filename 202862 18912 266456 488230 77326 u-boot ASM version: text data bss dec hex filename 203798 18912 266288 488998 77626 u-boot 222712 u-boot.bin Signed-off-by: Matthias Weisser <weisserm@arcor.de>
2011-04-25Default to bootm_size() when CONFIG_SYS_BOOTMAPSZ is not definedGrant Likely
This patch adds a function getenv_bootm_mapsize() for obtaining the size of the early mapped region accessible by the kernel during early boot. It defaults to CONFIG_SYS_BOOTMAPSZ, or if not defined, defaults to getenv_bootm_size(), which in turn defaults to the size of RAM. getenv_bootm_mapsize() can also be overridden with a "bootm_mapsize" environmental variable. Signed-off-by: Grant Likely <grant.likely@linaro.org>
2011-04-26rtc, rv3029: add trickle charger support.Heiko Schocher
Signed-off-by: Heiko Schocher <hs@denx.de> Acked-by: Detlev Zundel <dzu@denx.de>
2011-04-20Merge branch 'misc' of git://git.denx.de/u-boot-blackfinWolfgang Denk
2011-04-13crc32: make command optionalMike Frysinger
2011-04-13make `go` optionalMike Frysinger
2011-04-13env: make import/export optionalMike Frysinger
2011-04-13x86: Rename i386 to x86Graeme Russ
Signed-off-by: Graeme Russ <graeme.russ@gmail.com>
2011-04-12Make STANDALONE_LOAD_ADDR configurable per boardWolfgang Denk
Rename STANDALONE_LOAD_ADDR into CONFIG_STANDALONE_LOAD_ADDR and allow that the architecture-specific default value gets overwritten by defining the value in the board header file. Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Mike Frysinger <vapier@gentoo.org> Cc: Shinya Kuribayashi <skuribay@ruby.dti.ne.jp> Cc: Daniel Hellstrom <daniel@gaisler.com> Cc: Tsi Chung Liew <tsi-chung.liew@freescale.com> Cc: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2011-04-08Blackfin: ldrinfo: new commandMike Frysinger
Simple command to decode/check an LDR image before we try to boot it. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2011-04-04powerpc: clean up DIU macro definitions for Freescale reference boardsTimur Tabi
Clean up the macro defintions used to enable DIU (video) support on the MPC8610HPCD and the MPC5121ADS so that they look more like the P1022DS, which is newer. Add software cursor support to all three boards. Also document the CONFIG_FSL_DIU_FB in the README. Signed-off-by: Timur Tabi <timur@freescale.com> Acked-by: Anatolij Gustschin <agust@denx.de> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2011-02-21mv: seperate kirkwood and armada from common settingLei Wen
Since there are lots of difference between kirkwood and armada series, it is better to seperate them but still keep the most common file shared by all marvell platform in the mv-common configure file. This patch move the kirkwood only driver definitoin in mv-common to the <soc_name>/config.h. This patch is tested with compilation for armada100 and guruplug. Signed-off-by: Lei Wen <leiwen@marvell.com>
2011-02-02spi: add support SuperH SPI moduleYoshihiro Shimoda
SH7757 has SPI module. This patch supports it. Signed-off-by: Yoshihiro Shimoda <yoshihiro.shimoda.uh@renesas.com> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2011-02-02net: sh_eth: add cache handlingYoshihiro Shimoda
Some CPU needs cache handling. So this patch add the config of CONFIG_SH_ETHER_CACHE_WRITEBACK, and it calls wback function. Signed-off-by: Yoshihiro Shimoda <yoshihiro.shimoda.uh@renesas.com> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2011-02-02README: add description of sh_eth driverYoshihiro Shimoda
2011-01-19Fix defines needed to enable command sha1sumAlexander Holler
Documented is CONFIG_CMD_SHA1, through confusion in the source CONFIG_CMD_SHA1 and CONFIG_CMD_SHA1SUM has to be used to enable sha1sum. Fix both, the documentation and the source, so that only CONFIG_CMD_SHA1SUM is needed to enable the command sha1sum. Signed-off-by: Alexander Holler <holler@ahsoftware.de>
2011-01-17Merge branch 'master' of git://git.denx.de/u-boot-mpc85xxWolfgang Denk
2011-01-17Merge branch 'master' of git://git.denx.de/u-boot-i2cWolfgang Denk
2011-01-14powerpc/8xxx: Refactor SRIO initialization into common codeKumar Gala
Moved the SRIO init out of corenet_ds and into common code for 8xxx/QorIQ processors that have SRIO. We mimic what we do with PCIe controllers for SRIO. We utilize the fact that SRIO is over serdes to determine if its configured or not and thus can setup the LAWs needed for it dynamically. We additionally update the device tree (to remove the SRIO nodes) if the board doesn't have SRIO enabled. Introduced the following standard defines for board config.h: CONFIG_SYS_SRIO - Chip has SRIO or not CONFIG_SRIO1 - Board has SRIO 1 port available CONFIG_SRIO2 - Board has SRIO 2 port available (where 'n' is the port #) CONFIG_SYS_SRIOn_MEM_VIRT - virtual address in u-boot CONFIG_SYS_SRIOn_MEM_PHYS - physical address (for law setup) CONFIG_SYS_SRIOn_MEM_SIZE - size of window (for law setup) [ These mimic what we have for PCI and PCIe controllers ] Signed-off-by: Kumar Gala <galak@kernel.crashing.org> Acked-by: Wolfgang Denk <wd@denx.de>
2011-01-10pca953x: support 16-pin devicesChris Packham
This adds support for for the PCA9535/PCA9539 family of gpio devices which have 16 output pins. To let the driver know which devices are 16-pin it is necessary to define CONFIG_SYS_I2C_PCA953X_WIDTH in your board config file. This is used to create an array of {chip, ngpio} tuples that are used to determine the width of a particular chip. For backwards compatibility it is assumed that any chip not defined in CONFIG_SYS_I2C_PCA953X_WIDTH has 8 pins. Acked-by: Peter Tyser <ptyser@xes-inc.com> Tested-by: Peter Tyser <ptyser@xes-inc.com> Signed-off-by: Chris Packham <chris.packham@alliedtelesis.co.nz>
2011-01-09ftgmac100: support of gigabit eth ftgmac100Macpaul Lin
Add Faraday's ftgmac100 (gigabit ethernet) MAC controller's driver. Signed-off-by: Macpaul Lin <macpaul@andestech.com>
2010-11-27Coding Style (white space) cleanupWolfgang Denk
2010-10-29Drop support for CONFIG_SKIP_RELOCATE_UBOOTWolfgang Denk
For ARM systems, before ELF relocation was introduced, CONFIG_SKIP_RELOCATE_UBOOT coul be used to prevent *COPYING* the U-Boot image from whereever it was loaded to it's link address (CONFIG_SYS_TEXT_BASE). The name was badly chosen, as no relocation was performed at all, it was just a memcpy(). With ELF relocation, this does not work like that any more, and related boards need to be fixed anyway. So don't keep this relict any longer. Signed-off-by: Wolfgang Denk <wd@denx.de> Tested-by: Heiko Schocher <hs@denx.de> Tested-by: Reinhard Meyer <u-boot@emk-elektronik.de>
2010-10-27Coding Style cleanupWolfgang Denk
2010-10-18boot: change some arch ifdefs to feature ifdefsJohn Rigby
The routines boot_ramdisk_high, boot_get_cmdline and boot_get_kbd are currently enabled by various combinations of CONFIG_M68K, CONFIG_POWERPC and CONFIG_SPARC. Use CONFIG_SYS_BOOT_<FEATURE> defines instead. CONFIG_SYS_BOOT_RAMDISK_HIGH CONFIG_SYS_BOOT_GET_CMDLINE CONFIG_SYS_BOOT_GET_KBD Define these as appropriate in arch/include/asm/config.h files. Signed-off-by: John Rigby <john.rigby@linaro.org> Acked-by: Wolfgang Denk <wd@denx.de>
2010-10-11README: Add new NAND env featuresScott Wood
CONFIG_ENV_SIZE does not need block alignment. Document CONFIG_ENV_RANGE and CONFIG_ENV_OFFSET_OOB. Signed-off-by: Scott Wood <scottwood@freescale.com>
2010-10-06PCU_E: remove code for yet another corpseWolfgang Denk
The PCU_E board has long reached EOL, and support for it is no longer relevant in current versions of U-Boot. Remove it. Signed-off-by: Wolfgang Denk <wd@denx.de>
2010-09-28Merge branch 'next' of /home/wd/git/u-boot/nextWolfgang Denk
Conflicts: include/ppc4xx.h Signed-off-by: Wolfgang Denk <wd@denx.de>
2010-09-28README: Fix description of version numbering schemeThomas Weber
The version numbering scheme was changed in Oct, 2008. This patch brings the documentation to the actual level. The description is taken from: http://www.denx.de/wiki/U-Boot/ReleaseCycle Signed-off-by: Thomas Weber <weber@corscience.de> Changed text slightly. Signed-off-by: Wolfgang Denk <wd@denx.de>
2010-09-23Remove unused CONFIG_SERIAL_SOFTWARE_FIFO featureStefan Roese
This patch removes the completely unused CONFIG_SERIAL_SOFTWARE_FIFO feature from U-Boot. It has only been implemented for PPC4xx and was not used at all. So let's remove it and make the code smaller and cleaner. Signed-off-by: Stefan Roese <sr@denx.de> Acked-by: Detlev Zundel <dzu@denx.de>
2010-09-23ppc4xx: Remove now unused CONFIG_UART1_CONSOLEStefan Roese
CONFIG_UART1_CONSOLE was a PPC4xx specific implementation and is now removed since the move from the 4xx UART driver to the common NS16550 UART driver. Let's remove all references to this define now. Signed-off-by: Stefan Roese <sr@denx.de>
2010-09-19New implementation for internal handling of environment variables.Wolfgang Denk
Motivation: * Old environment code used a pessimizing implementation: - variable lookup used linear search => slow - changed/added variables were added at the end, i. e. most frequently used variables had the slowest access times => slow - each setenv() would calculate the CRC32 checksum over the whole environment block => slow * "redundant" envrionment was locked down to two copies * No easy way to implement features like "reset to factory defaults", or to select one out of several pre-defined (previously saved) sets of environment settings ("profiles") * No easy way to import or export environment settings ====================================================================== API Changes: - Variable names starting with '#' are no longer allowed I didn't find any such variable names being used; it is highly recommended to follow standard conventions and start variable names with an alphanumeric character - "printenv" will now print a backslash at the end of all but the last lines of a multi-line variable value. Multi-line variables have never been formally defined, allthough there is no reason not to use them. Now we define rules how to deal with them, allowing for import and export. - Function forceenv() and the related code in saveenv() was removed. At the moment this is causing build problems for the only user of this code (schmoogie - which has no entry in MAINTAINERS); may be fixed later by implementing the "env set -f" feature. Inconsistencies: - "printenv" will '\\'-escape the '\n' in multi-line variables, while "printenv var" will not do that. ====================================================================== Advantages: - "printenv" output much better readable (sorted) - faster! - extendable (additional variable properties can be added) - new, powerful features like "factory reset" or easy switching between several different environment settings ("profiles") Disadvantages: - Image size grows by typically 5...7 KiB (might shrink a bit again on systems with redundant environment with a following patch series) ====================================================================== Implemented: - env command with subcommands: - env print [arg ...] same as "printenv": print environment - env set [-f] name [arg ...] same as "setenv": set (and delete) environment variables ["-f" - force setting even for read-only variables - not implemented yet.] - end delete [-f] name not implemented yet ["-f" - force delete even for read-only variables] - env save same as "saveenv": save environment - env export [-t | -b | -c] addr [size] export internal representation (hash table) in formats usable for persistent storage or processing: -t: export as text format; if size is given, data will be padded with '\0' bytes; if not, one terminating '\0' will be added (which is included in the "filesize" setting so you can for exmple copy this to flash and keep the termination). -b: export as binary format (name=value pairs separated by '\0', list end marked by double "\0\0") -c: export as checksum protected environment format as used for example by "saveenv" command addr: memory address where environment gets stored size: size of output buffer With "-c" and size is NOT given, then the export command will format the data as currently used for the persistent storage, i. e. it will use CONFIG_ENV_SECT_SIZE as output block size and prepend a valid CRC32 checksum and, in case of resundant environment, a "current" redundancy flag. If size is given, this value will be used instead of CONFIG_ENV_SECT_SIZE; again, CRC32 checksum and redundancy flag will be inserted. With "-b" and "-t", always only the real data (including a terminating '\0' byte) will be written; here the optional size argument will be used to make sure not to overflow the user provided buffer; the command will abort if the size is not sufficient. Any remainign space will be '\0' padded. On successful return, the variable "filesize" will be set. Note that filesize includes the trailing/terminating '\0' byte(s). Usage szenario: create a text snapshot/backup of the current settings: => env export -t 100000 => era ${backup_addr} +${filesize} => cp.b 100000 ${backup_addr} ${filesize} Re-import this snapshot, deleting all other settings: => env import -d -t ${backup_addr} - env import [-d] [-t | -b | -c] addr [size] import external format (text or binary) into hash table, optionally deleting existing values: -d: delete existing environment before importing; otherwise overwrite / append to existion definitions -t: assume text format; either "size" must be given or the text data must be '\0' terminated -b: assume binary format ('\0' separated, "\0\0" terminated) -c: assume checksum protected environment format addr: memory address to read from size: length of input data; if missing, proper '\0' termination is mandatory - env default -f reset default environment: drop all environment settings and load default environment - env ask name [message] [size] same as "askenv": ask for environment variable - env edit name same as "editenv": edit environment variable - env run same as "run": run commands in an environment variable ====================================================================== TODO: - drop default env as implemented now; provide a text file based initialization instead (eventually using several text files to incrementally build it from common blocks) and a tool to convert it into a binary blob / object file. - It would be nice if we could add wildcard support for environment variables; this is needed for variable name auto-completion, but it would also be nice to be able to say "printenv ip*" or "printenv *addr*" - Some boards don't link any more due to the grown code size: DU405, canyonlands, sequoia, socrates. => cc: Matthias Fuchs <matthias.fuchs@esd-electronics.com>, Stefan Roese <sr@denx.de>, Heiko Schocher <hs@denx.de> - Dropping forceenv() causes build problems on schmoogie => cc: Sergey Kubushyn <ksi@koi8.net> - Build tested on PPC and ARM only; runtime tested with NOR and NAND flash only => needs testing!! Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Matthias Fuchs <matthias.fuchs@esd-electronics.com>, Cc: Stefan Roese <sr@denx.de>, Cc: Heiko Schocher <hs@denx.de> Cc: Sergey Kubushyn <ksi@koi8.net>
2010-08-09net ppc: fix ethernet device names with spacesHeiko Schocher
since commit 1384f3bb8a4f9066805b70c1418eda78ecb73fdd ethernet names with spaces drop a Warning: eth device name has a space! message. This patch fix it for: - "FEC ETHERNET" devices found on mpc512x, mpc5xxx, mpc8xx and mpc8220 boards. renamed to "FEC". - "SCC ETHERNET" devices found on mpc8xx, mpc82xx based boards. Renamed to "SCC". - "HDLC ETHERNET" devices found on mpc8xx boards Renamed to "HDLC" - "FCC ETHERNET" devices found on mpc8260 and mpc85xx based boards. Renamed to "FCC" Tested on the kup4k board. Signed-off-by: Heiko Schocher <hs@denx.de> Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2010-08-04Rename getenv_r() into getenv_f()Wolfgang Denk
While running from flash, i. e. before relocation, we have only a limited C runtime environment without writable data segment. In this phase, some configurations (for example with environment in EEPROM) must not use the normal getenv(), but a special function. This function had been called getenv_r(), with the idea that the "_r" suffix would mean the same as in the _r_eentrant versions of some of the C library functions (for example getdate vs. getdate_r, getgrent vs. getgrent_r, etc.). Unfortunately this was a misleading name, as in U-Boot the "_r" generally means "running from RAM", i. e. _after_ relocation. To avoid confusion, rename into getenv_f() [as "running from flash"] Signed-off-by: Wolfgang Denk <wd@denx.de> Acked-by: Detlev Zundel <dzu@denx.de>
2010-07-22i2c: soft_i2c: add simple GPIO implementationMike Frysinger
Since the vast majority of GPIO I2C implementations behave the same way, support the common GPIO framework with default settings. This adds two new defines CONFIG_SOFT_I2C_GPIO_{SCL,SDA} so that boards which want GPIO I2C support need only define these. Signed-off-by: Mike Frysinger <vapier@gentoo.org> Tested-by: Thomas Chou <thomas@wytron.com.tw>
2010-06-13Prepare v2010-rc2v2010.06-rc2Wolfgang Denk
