path: root/README
2005-09-26Add board support for armadillo HT1070Wolfgang Denk
Patch by Rowel Atienza, 06 Apr 2005
2005-09-24Update for TFTP using a fixed UDP portWolfgang Denk
Use the approved environment variable names. Added "tftpdstp" to allow ports other than 69 per Tolunay Orkun's recommendation. Patch by Jerry Van Baren, 12 Jan 2005
2005-09-24Allow to force TFTP to use a fixed UDP portWolfgang Denk
(Add a configuration option CONFIG_TFTP_PORT and optional env variable tftpport) Patch by Jerry Van Baren, 10 Jan 2005
2005-09-22Add SM501 support to HH405 board.Stefan Roese
Add support for gzip compressed bmp's (CONFIG_VIDEO_BMP_GZIP). Add support for eeprom write-enable (CFG_EEPROM_WREN). Patch by Stefan Roese, 22 Sep 2005
2005-08-02Merge with rsync://git-user@source.denx.net/git/u-boot.gitJon Loeliger
2005-08-01Major cleanup for AMCC PPC4xx eval boards.Stefan Roese
Patch by Stefan Roese, 01 Aug 2005
2005-07-29* Patch by Ron Alder, 11 July 2005Lunsheng Wang
Add Xianghua Xiao and Lunsheng Wang's support for the GDA MPC8540 EVAL board.
2005-05-03README: add explanation about patch policywdenk
net/net.c: fix indentation
2005-04-13* Fixes for TQM8560 board:wdenk
- fix clock rates - remove debug messages - fix flash sector protection * Patch by Steven Scholz, 07 Apr 2005: Fix warning in cpu/arm920t/at91rm9200/i2c.c
2005-04-06Patch by Steven Scholz, 06 Apr 2005:wdenk
- creating SoC subdir for Atmel AT91RM9200 cpu/arm920t/at91rm9200 - moving code out of cpu/at91rm9200 into cpu/arm920t/at91rm9200
2005-04-05* Patch by Ladislav Michl, 05 Apr 2005:wdenk
Add support for VoiceBlue board. * Patch by Ladislav Michl, 05 Apr 2005: Fix netboot_common() prototypes. * Cleanup.
2005-04-04Patch by Steven Scholz, 4 Apr 2005:wdenk
- remove all references to CONFIG_INIT_CRITICAL for ARM based boards - introduce two new configuration options instead: CONFIG_SKIP_LOWLEVEL_INIT and CONFIG_SKIP_RELOCATE_UBOOT
2005-04-03Patches by Josef Wagner, 29 Oct 2004:wdenk
- Add support for MicroSys CPU87 board - Add support for MicroSys PM854 board
2005-04-03* Patch by Richard Klingler, 03 Apr 2005:wdenk
Add call to eth_halt() in net/net.c when called functions fail after eth_init() has been called. * Patch by Sam Song, 3 April 2005: - Update README.Netconsole - Update README
2005-04-02Prepare for SoC rework of ARM code:wdenk
- rename CONFIG_BOOTBINFUNC into CONFIG_INIT_CRITICAL - rename memsetup into lowlevel_init (function name and source files)
2005-02-24* Add support for ext2 filesystems and image timestamps to TQM5200 boardwdenk
* Add reset code for Coral-P on INKA4x0 board * Patch by Martin Krause, 28 Jun 2004: Update for TRAB board. * Fix some missing "volatile"s in MPC5xxx FEC driver
2005-01-09* Patches by Richard Woodruff, 01 Oct 2004:wdenk
add support for the TI OMAP2420 processor and its H4 reference board * Patch by Christian Pellegrin, 24 Sep 2004: Added support for NE2000 compatible (DP8390, DP83902) NICs.
2004-12-16Code cleanup.wdenk
2004-12-16CONFIG_MX_CYCLIC description addedstroese
2004-12-10* Clean up CMC PU2 flash driverwdenk
* Update MAINTAINERS file * Fix bug in MPC823 LCD driver
2004-10-28Patch by TsiChung Liew, 23 Sep 2004:wdenk
- add support for MPC8220 CPU - Add support for Alaska and Yukon boards
2004-10-17Code cleanup for GCC-3.3.x compilerswdenk
2004-10-10Patches by Scott McNutt, 24 Aug 2004:wdenk
- Add support for Altera Nios-II processors. - Add support for Psyent PCI-5441 board. - Add support for Psyent PK1C20 board.
2004-10-09Patch by Sam Song, 21 August 2004:wdenk
- Fix a typo in README - Align "(RO)" output for "flinfo" after "protect on" - Add RESET support for RPXlite_DW board; adjust CPU:BUS frequency ratio 1:1 when core frequency less than 50MHz
2004-10-09Patch by Steven Scholz, 16 Aug 2004:wdenk
- Introducing the concept of SoCs "./cpu/$(CPU)/$(SOC)" - creating subdirs for SoCs ./cpu/arm920t/imx and ./cpu/arm920t/s3c24x0 - moving SoC specific code out of cpu/arm920t/ into cpu/arm920t/$(SOC)/ - moving drivers/s3c24x0_i2c.c and drivers/serial_imx.c out of drivers/ into cpu/arm920t/$(SOC)/
2004-09-28* Patch by Yuli Barcohen, 13 Jul 2004:wdenk
Allow clock setting on MPC866/MPC885 series chips according to environment variable `cpuclk' * Patch by Yuli Barcohen, 20 Apr 2004: Remove unnecessary redefine of CPM_DATAONLY_SIZE for MPC826x
2004-08-02* Patch by Andreas Engel, 12 Jul 2004:wdenk
Replaced hardcoded PL011 clock frequency with config variable. Fixed wrong CONFIG_CMD_DFL doc. * Patch by Thomas Viehweger, 09 Jun 2004: make it possible to remove chpart when there is only one partition
2004-07-11Add cerf250 to MAINTAINERS and READMEwdenk
2004-07-11* Cleanupwdenk
* Patch by Mark Jonas, 05 Jul 2004: add support for the Total5100's and Total5200's LCD screen * Patches by Dan Eisenhut, 01 Jul 2004: - README fixes. - Move doc2000.h include to prevent compiler warning on some boards
2004-07-11* Patch by Martin Krause, 30 Jun 2004:wdenk
Add support for TQM5200 board * Patch by Martin Krause, 29 Jun 2004: Add loopw command: infinite write loop on address range
2004-07-10Patches by Yasushi Shoji, 29 Jun 2004:wdenk
- add empty include/asm-microblaze/processor.h - add to CREDITS and MAINTAINERS - add gd initialization - add MicroBlaze and SUZAKU board to MAKEALL script - add reset support for SUZAKU - add flush_cache() for MicroBlaze - add CFG_FLASH_SIZE to include/configs/suzaku.h since we have fixed size flash memory on SUZAKU
2004-07-10* Rename SBC8560 into sbc8560 for consistencywdenk
* Patch by Daniel Poirot, 24 Jun 2004: Add support for Wind River's sbc8240 board * Patches by Yasushi Shoji, 26 Jun 2004: - drivers/serial_xuartlite.c: fix "return 0" in void function - add microblaze support to mkimage tool
2004-07-10* Patch by Fred Klatt, 25 Jun 2004:wdenk
Add support for WindRiver's SBC8560 board * Patch by Nicolas Lacressonniere, 24 Jun 2004 Small Bugs fixes for "at91rm9200dk" board: - Timing modifications for SPI DataFlash access - Fix NAND flash detection bug * Patch by Nicolas Lacressonniere, 24 Jun 2004: Add Support for Flash AT49BV6416 for AT91RM9200DK board
2004-06-30* Fix "cls" command when used with splash screenLABEL_2004_07_01_1200wdenk
* Increase NFS download timeout (now 1 min - 10 sec is to short for a slow download of a big image)
2004-06-09Patch by Sam Song, 09 Jun 2004:wdenk
- Add support for RPXlite_DW board - Update FLASH driver for 4*AM29DL323DB90VI - Add option configuration of CFG_ENV_IS_IN_NVRAM on RPXlite_DW board
2004-06-09* Patch by Tom Armistead, 04 Jun 2004:wdenk
Add support for MAX6900 RTC * Patches by Ladislav Michl, 03 Jun 2004: - fix cfi_flash.c on LE systems - let 'make mrproper' delete u-boot.img as well - turn printf into debug in cfi_flash.c
2004-06-09Patch by Jian Zhang, 20 May 2004:wdenk
add support for environment in NAND flash
2004-06-09* Patch by Paul Ruhland, 17 May 2004:wdenk
- Add support for the Logic Zoom LH7A40x based SDK board(s), specifically the LPD7A400. * Patches by Robert Schwebel, 15 May 2004: - call MAC address reading code also for SMSC91C111; - make SMSC91C111 timeout configurable, remove duplicate code - fix get_timer() for PXA - update doc/README.JFFS2 - use "bootfile" env variable also for jffs2
2004-06-08* Patch by Rishi Bhattacharya, 08 May 2004:wdenk
Add support for TI OMAP5912 OSK Board * Patch by Sam Song May, 07 May 2004: Fix typo of UPM table for rmu board
2004-06-06* Patch by Dave Peverley, 30 Apr 2004:wdenk
Add support for OMAP730 Perseus2 Development board * Patch by Alan J. Luse, 29 Apr 2004: Fix flash chip-select (OR0) option register setting on FADS boards. * Patch by Alan J. Luse, 29 Apr 2004: Report MII network speed and duplex setting properly when auto-negotiate is not enabled. * Patch by Jarrett Redd, 29 Apr 2004: Fix hang on reset on Ocotea board due to flash in wrong mode.
2004-06-06Patch by Tolunay Orkun, 20 Apr 2004:wdenk
- README update: add CONFIG_CSB272 and csb272_config - add descriptions for some MII/PHY options, CONFIG_I2CFAST, and i2cfast environment variable
2004-05-29Fix CONFIG_ETH*ADDR for Ocotea board.LABEL_2004_05_29_1850wdenk
Sort Makefile. Update docs.
2004-05-03* Fix minor NAND JFFS2 related issuewdenk
* Fixes for SL811 USB controller: - implement workaround for broken memory stick - improve error handling * Increase packet send timeout to 10 ms in cpu/mpc8xx/scc.c to better cope with congested networks.
2004-04-23* Modify KUP4X board configuration to use SL811 driver for USB memoryLABEL_2004_04_23_2240wdenk
sticks (including FAT / VFAT filesystem support) * Add SL811 Host Controller Interface driver for USB * Add CFG_I2C_EEPROM_ADDR_OVERFLOW desription to README * Patch by Pantelis Antoniou, 19 Apr 2004: Allow to use shell style syntax (i. e. ${var} ) with standard parser. Minor patches for Intracom boards. * Patch by Christian Pell, 19 Apr 2004: cleanup support for CF/IDE on PCMCIA for PXA25X
2004-04-18* Patch by Dan Malek, 07 Apr 2004:wdenk
- Add support for RPC/STx GP3, Motorola 8560 board - Update 85xx TSEC driver so it searches MII for first available PHY and uses that one. - Add functions to support console MII commands. * Patch by Tolunay Orkun, 07 Apr 2004: Move initialization of bi_iic_fast[] from board_init_f() to board_init_r() * Patch by Yasushi Shoji, 07 Apr 2004: Cleanup microblaze port * Patch by Sangmoon Kim, 07 Apr 2004: Add auto SDRAM module detection for Debris board
2004-04-18* Patch by Yasushi Shoji, 07 Apr 2004:wdenk
- add support for microblaze processors - add support for AtmarkTechno "suzaku" board
2004-04-18* Cleanup, minor fixeswdenk
* Patch by Rune Torgersen, 16 Apr 2004: LBA48 fixes * Patches by Pantelis Antoniou, 16 Apr 2004: - Fix some compile problems; add "once" functionality for the netretry variable
2004-04-18Patches by Pantelis Antoniou, 16 Apr 2004:wdenk
- add support for a new version of an Intracom board and fix various other things on others. - add verify support to the crc32 command (define CONFIG_CRC32_VERIFY to enable it) - fix FEC driver for MPC8xx systems: 1. fix compilation problems for boards that use dynamic allocation of DPRAM 2. shut down FEC after network transfers - HUSH parser fixes: 1. A new test command was added. This is a simplified version of the one in the bourne shell. 2. A new exit command was added which terminates the current executing script. 3. Fixed handing of $? (exit code of last executed command)
2004-04-15* Patch by Stephen Williams, 01 Apr 2004:wdenk
Add support for Picture Elements JSE board * Patch by Christian Pell, 01 Apr 2004: Add CompactFlash support for PXA systems.
