Take this part of the README and put it into rST format.
It is quite confusing that CONFIG_SYS_I2C selects the legacy I2C and
CONFIG_DM_I2C selects the current I2C. The deadline to migrate I2C is less
than a year away.
Also we want to have a CONFIG_I2C for U-Boot proper just like we have
CONFIG_SPL_I2C for SPL, so we can simplify the Makefile rules.
Rename this symbol so it is clear it is going away.
Hyphens are missing in various places where the intent is to create an
adjective. Fix it.
These boards have not been converted to CONFIG_DM_USB by the deadline
and is also missing conversion to CONFIG_DM. Remove it.
This is also the last PL010_SERIAL using board, so remove those
references.
Cc: Sergey Kostanbaev <sergey.kostanbaev@fairwaves.ru>
This board has not been converted to CONFIG_DM_PCI by the deadline and is
also missing conversion to CONFIG_DM. Remove it. This is also the last
of the ARCH_MPC8641/MPC8610 platforms, so remove that support as well.
Cc: Paul Gortmaker <paul.gortmaker@windriver.com>
Cc: Priyanka Jain <priyanka.jain@nxp.com>
Having WATCHDOG_RESET() called automatically from the timer interrupt
runs counter to the idea of a watchdog device - if the board runs into
an infinite loops with interrupts still enabled, the watchdog will
never fire.
When using CONFIG_(SPL_)WDT, the watchdog_reset function is a lot more
complicated than just poking a few SOC-specific registers - it
involves accessing all kinds of global data, and if the interrupt
happens at the wrong time (say, in the middle of an WATCHDOG_RESET()
call from ordinary code), that can end up corrupting said global data.
Allow the board to opt out of calling WATCHDOG_RESET() from the timer
interrupt handler by setting CONFIG_SYS_WATCHDOG_FREQ to 0 - as that
setting is currently nonsensical (it would be compile-time
divide-by-zero), it cannot affect any existing boards.
Add documentation for both the existing and extended meaning of
CONFIG_SYS_WATCHDOG_FREQ.
Signed-off-by: Rasmus Villemoes <rasmus.villemoes@prevas.dk>
The U-Boot source moves to https://source.denx.de/u-boot/u-boot.git
effective 2021-02-28.
OF_STDOUT_PATH was meant to hold the devicetree path to the serial
console, to be put into the linux,stdout-path property of the chosen node.
The only user of that was sunxi, and it was actually wrong for years
there: the paths hardcoded in sunxi_common.h were not matching the DTs,
evident by the leading 0's in nodenames, which have been removed years
ago.
On top of that, "linux,stdout-path" is now deprecated for a while (Linux
commit 2a9d832cc9aae from November 2014), and also all modern DTs
(including those included in U-Boot) carry a "stdout-path" property
already.
So remove the stanza from sunxi_common.h, and, since this was the last
user, also remove the associated bits from the rest of U-Boot.
Signed-off-by: Andre Przywara <andre.przywara@arm.com>
This patch completely removes CONFIG_PCI_ENUM_ONLY from the PCI code as
it is not configured for any board (any more). With this removal, some
PCI related files get cleaned up a bit.
Additional, dm_pciauto_setup_device() is now static, as it's not
referenced from any code outside of this C file.
Cc: Bin Meng <bmeng.cn@gmail.com>
Add the command "pwm" for controlling the pwm channels. This
command provides pwm invert/config/enable/disable functionalities
via PWM uclass drivers
Signed-off-by: Pragnesh Patel <pragnesh.patel@sifive.com>
Move CONFIG_SYS_PROMPT_HUSH_PS2 in Kconfig, depending
on CONFIG_HUSH_PARSER, and remove the default value defined
in cli_hush.c under __U_BOOT__.
The -i option of the dumpimage tool has been removed so it should no
longer be documented in the README file. Refer readers to the tool's
help output rather than maintain a copy of the usage in the README.
Finally, adjust the example dumpfile invocation in imagetool.h to use
the -o option instead of the removed -i option.
Fixes: 12b831879a76 ("tools: dumpimage: Simplify arguments")
Signed-off-by: Tyler Hicks <tyhicks@linux.microsoft.com>
Cc: Martyn Welch <martyn.welch@collabora.com>
Acked-by: Martyn Welch <martyn.welch@collabora.com>
Convert all the other http:// links to https:// .
www.denx.de/twiki/ seems to move to www.denx.de/wiki/ ,
so change it.
I checked all links in this patch are valid.
Signed-off-by: Naoki Hayama <naoki.hayama@lineo.co.jp>
%s/overwride/override/
doc/arch/index.rst is a list of links to each architecture.
As for the sandbox details, doc/arch/sandbox.rst looks better.
Removed:
- /arch/openrisc
Added:
- /arch/xtensa
- /env
This patch include these updates
- Git repository has moved to GitLab
- HTTPS access to the file server is allowed
- pre-built images are no longer available
This patch includes these updates
- Change http://lists.denx.de/pipermail/u-boot
to https://lists.denx.de/pipermail/u-boot
- http://dir.gmane.org/gmane.comp.boot-loaders.u-boot
is broken, so remove it
- Another archive https://marc.info/?l=u-boot
is available, so add it
Additional information:
dir.gmane.org has moved to news.gmane.io, but it only allows
access to the archive via NNTP.
- Server: news.gmane.io
- Group : gmane.comp.boot-loaders.u-boot
I don't include this information in this patch because
it's not very useful without web interfaces.
Done with:
./tools/moveconfig.py VIDEO_BMP_RLE8
Done with:
./tools/moveconfig.py VIDEO_BMP_GZIP
The 3 suspicious migration because CMD_BMP and SPLASH_SCREEN
are not activated in these defconfigs:
- trats_defconfig
- s5pc210_universal_defconfig
- trats2_defconfig
Bring in the assorted changes that have been staged in the 'next' branch
prior to release.
I suppose 'these' might be 'there'.
At present it is not possible to tell from a script where the setup block
is, or where the image was loaded to. Add environment variables for this.
Reviewed-by: Wolfgang Wallner <wolfgang.wallner@br-automation.com>
CONFIG_SPLASH_SCREEN
CONFIG_SPLASH_SCREEN_ALIGN
CONFIG_SPLASHIMAGE_GUARD
CONFIG_SPLASH_SOURCE
Add support for RFC 7440: "TFTP Windowsize Option".
This optional feature allows the client and server
to negotiate a window size of consecutive blocks to send as an
alternative for replacing the single-block lockstep schema.
windowsize can be defined statically during compilation by
setting CONFIG_TFTP_WINDOWSIZE, or defined in runtime by
setting an environment variable: "tftpwindowsize"
If not defined, the windowsize is set to 1, meaning that it
behaves as it was never defined.
Choosing the appropriate windowsize depends on the specific
network topology, underlying NIC.
You should test various windowsize scenarios and see which
best work for you.
Setting a windowsize too big can actually decreases performance.
Signed-off-by: Ramon Fried <rfried.dev@gmail.com>
CONFIG_SYS_MMCSD_FS_BOOT_PARTITION
CONFIG_BOOTP_SEND_HOSTNAME
CONFIG_SPL_NAND_BASE
CONFIG_SPL_NAND_IDENT
CONFIG_SPL_NAND_DRIVERS
CONFIG_SPL_NAND_ECC
CONFIG_SPL_NAND_SIMPLE
Add Kconfig entries for the dc2114x driver and convert various boards.
Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com>
Cc: Ramon Fried <rfried.dev@gmail.com>
It is useful to be able to find hex values and strings in a memory range.
Add a command to support this.
cmd: Fix 'md' and add a memory-search command
At present 'md.q' is broken. This series provides a fix for this. It also
implements a new memory-search command called 'ms'. It allows searching
memory for hex and string data.
END
This variable is unset anywhere and only unset on a number of platforms.
Remove all relevant code.
CONFIG_BAUDRATE
Add Kconfig entries for the eepro100 driver and convert various boards.
This code is never enabled, last board that used it was ELPPC which
was removed some 5 years ago, so just remove this code altogether.
CONFIG_CMD_ASKENV
CONFIG_CMD_BMP
CONFIG_CMD_BOOTD
CONFIG_CMD_CACHE
CONFIG_CMD_CRC32
CONFIG_CMD_DHCP
CONFIG_CMD_ENV
CONFIG_CMD_EXPORTENV
CONFIG_CMD_EXT2
CONFIG_CMD_EXT4
CONFIG_CMD_FLASH
CONFIG_CMD_FS_GENERIC
CONFIG_CMD_FUSE
CONFIG_CMD_GPIO
CONFIG_CMD_GPT
CONFIG_CMD_GREPENV
CONFIG_CMD_I2C
CONFIG_CMD_IMLS
CONFIG_CMD_IMPORTENV
CONFIG_CMD_LOADB
CONFIG_CMD_LOADS
CONFIG_CMD_MEMINFO
CONFIG_CMD_MII
CONFIG_CMD_MTDPARTS
CONFIG_CMD_NAND
CONFIG_CMD_NAND_TRIMFFS
CONFIG_CMD_NFS
CONFIG_CMD_PCA953X
CONFIG_CMD_PCA953X_INFO
CONFIG_CMD_PCI
CONFIG_CMD_PING
CONFIG_CMD_READ
CONFIG_CMD_SF
CONFIG_CMD_SPI
CONFIG_CMD_SPL
CONFIG_CMD_SPL_WRITE_SIZE
CONFIG_CMD_TIME
CONFIG_CMD_TRACE
CONFIG_CMD_UBI
CONFIG_CMD_UBIFS
CONFIG_CMD_UNZIP
CONFIG_FS_EXT4
CONFIG_BZIP2
CONFIG_GZIP
CONFIG_LZO
CONFIG_ZLIB
CONFIG_LZMA
CONFIG_LZO
Convert ENV_ACCESS_IGNORE_FORCE to Kconfig, no functional change.
Move below defines which are used by mtest utility to Kconfig.
CONFIG_SYS_MEMTEST_START
CONFIG_SYS_MEMTEST_END
Signed-off-by: Ashok Reddy Soma <ashok.reddy.soma@xilinx.com>
[trini: Fix kmcoge5ne board, re-run migration as well]
There is no real need to exactly define space for saving patterns for
alternate memory test. It is much easier to allocate space on the stack and
use it instead of trying to find out space where pattern should be saved.
For example if you want to test the whole DDR memory you can't save patter
to DDR and you need to find it out. On Xilinx devices DDR or OCM addresses
were chosen but that means that OCM needs to be mapped and U-Boot has
access permission there.
It is easier to remove this limitation and simply save it on stack because
it is very clear that memory test can't rewrite U-Boot and U-Boot has also
full access to memory where runs from.
These macros are not used by any board, remove them to simplify
the driver. The EEPROM accessors are still retained however, as
those might still be useful.
Remove the references in README on CONFIG_SYS_RCAR_I2C_* not use
in U-Boot drivers/i2c/rcar_i2c.c, since commit a4d9aafadb31 ("i2c:
rcar_i2c: Remove the driver") and commit a06a0ac36d59 ("i2c: rcar_i2c:
Add DM and DT capable I2C driver")
Checked by the command: grep -r SYS_RCAR_I2C *
And these CONFIG are only defined in
arch/arm/mach-rmobile/include/mach/rcar-base.h
Only replace CONFIF_ by CONFIG_
MinGW build for U-Boot tools has been broken for years. The official
support of Windows build is now MSYS2. Remove the MinGW support codes.
Signed-off-by: Bin Meng <bin.meng@windriver.com>
boards.cfg is not delivered with the U-Boot source. So it is preferable to
look at configs/*_defconfig to identify available deconfigs.
Fix a typo.
Update some reference in README file detected by
scripts/documentation-file-ref-check
*.README => README.*
Reviewed-by: Heinrich Schuchardt <xypron.glpk@gmx.de>
As indicated elsewhere in the README, the standalone CHANGELOG file was
removed in 2010. Drop the instructions for creating patches on creating
a standalone CHANGELOG entry.
Signed-off-by: Karl Palsson <karlp@tweak.net.au>
Both CMD_MX_CYCLIC and MX_CYCLIC are in use and defined in Kconfig,
but only the non-CMD version currently does anything. This changes all
usages to prefer the CMD_MX_CYCLIC option (since it's only affecting
addition of the commands), and switches defconfigs using the non-CMD
version to use the CMD version.
Signed-off-by: Joel Johnson <mrjoel@lixil.net>
This is not really a CONFIG since it is not intended to be set by boards.
Move it into the compiler header with other similar defines, and rename
it.
This seems pretty old now. It has not been converted to driver model and
is not used by any boards.
Drop it.
