path: root/README
2002-11-05* Patch by Robert Schwebel, 04 Nov 2002:LABEL_2002_11_05_0120wdenk
- use watchdog to reset PXA250 systems - added progress callbacks to (some of the) ARM code - update for Cogent CSB226 board * Add support for FPS860 board
2002-11-03* Fix mdelay() on TRAB - this was still the debugging version withwdenk
seconds instead of ms. * Patch by Robert Schwebel, 1 Nov 2002: XScale related cleanup (affects all ARM boards) * Cleanup of names, warnings, and README.
