Raw images of U-Boot can be stored inside MMC partitions, so it makes sense to
read the partition table, looking for a partition number instead of using
a fixed sector address.
Signed-off-by: Paul Kocialkowski <contact@paulk.fr>
Reviewed-by: Tom Rini <trini@ti.com>
[trini: Only add mmc_load_image_raw_partition() when
CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_PARTITION to avoid warning, add missing
conversion in spl_mmc_load_image()]
CONFIG_SYS_MMC_SD_FS_BOOT_PARTITION ought to be called
CONFIG_SYS_MMCSD_FS_BOOT_PARTITION to keep it consistent with other config
options such as: CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR.
In addition, it is not related to raw mode booting but to fs mode instead.
drivers/serial/serial-uclass.c
The README file states that the macros beginning with "CONFIG_SYS_"
depend on the hardware etc. and should not be meddled with if you do
not what you're doing.
We have already screwed up with this policy; we have given the prefix
"CONFIG_SYS_" to many user-selectable configurations.
Here, "CONFIG_SYS_HUSH_PARSER" is one of them. Users can enable it
if they want to use a more powerful command line parser, or disable it
if they only need a simple one.
This commit attempts to rename CONFIG_SYS_HUSH_PARSER to
CONFIG_HUSH_PARSER and move it to Kconfig.
Every board maintainer is expected to enable CONFIG_HUSH_PARSER
(= add "CONFIG_HUSH_PARSER=y" to his defconfig file) and remove
"#define CONFIG_SYS_HUSH_PARSER" from his header file.
Some filesystems have a UUID stored in its superblock. To
allow using root=UUID=... for the kernel command line we
need a way to read-out the filesystem UUID.
changes rfc -> v1:
- make the environment variable an option parameter. If not
given, the UUID is printed out. If given, it is stored in the env
variable.
- corrected typos
- return error codes
changes v1 -> v2:
- fix return code of do_fs_uuid(..)
- document do_fs_uuid(..)
- implement fs_uuid_unsuported(..) be more consistent with the
way other optional functionality works
changes v2 -> v3:
- change ext4fs_uuid(..) to make use of #if .. #else .. #endif
construct to get rid of unreachable code
Hit any key to stop autoboot: 0
=> fsuuid
fsuuid - Look up a filesystem UUID
Usage:
fsuuid <interface> <dev>:<part>
- print filesystem UUID
fsuuid <interface> <dev>:<part> <varname>
- set environment variable to filesystem UUID
=> fsuuid mmc 0:1
d9f9fc05-45ae-4a36-a616-fccce0e4f887
=> fsuuid mmc 0:2
eb3db83c-7b28-499f-95ce-9e0bb21cda81
=> fsuuid mmc 0:1 uuid1
=> fsuuid mmc 0:2 uuid2
=> printenv uuid1
uuid1=d9f9fc05-45ae-4a36-a616-fccce0e4f887
=> printenv uuid2
uuid2=eb3db83c-7b28-499f-95ce-9e0bb21cda81
Signed-off-by: Christian Gmeiner <christian.gmeiner@gmail.com>
Add documentation for the various driver model options that are now
available.
Add an additional function for adding information to the device tree before
booting. This permits additions which are not board-specific.
Acked-by: Anatolij Gustschin <agust@denx.de>
enable to boot only a raw u-boot.bin image from nand with the
CONFIG_SPL_NAND_RAW_ONLY define. This option saves space on
boards where spl space is low.
Reviewed-by: Andreas Bießmann <andreas.devel@googlemail.com>
Reviewed-by: Bo Shen <voice.shen@atmel.com>
Correct environment variable for output directory is KBUILD_OUTPUT.
Signed-off-by: Timo Ketola <timo@exertus.fi>
Update documentation according to the EXT SPL support patch set.
Signed-off-by: Guillaume GARDET <guillaume.gardet@free.fr>
Cc: Tom Rini <trini@ti.com>
There's a definition in stdint.h (provided by gcc) which will be more correct
if available.
Define CONFIG_USE_STDINT to use this feature, or USE_STDINT=1 on the 'make'
commmand.
This adjusts the settings for x86 and sandbox, with both have 64-bit options.
Signed-off-by: Gabe Black <gabeblack@google.com>
Reviewed-by: Gabe Black <gabeblack@chromium.org>
Tested-by: Gabe Black <gabeblack@chromium.org>
Reviewed-by: Bill Richardson <wfrichar@google.com>
Rewritten to be an option, since stdint.h is often available only in glibc.
Changed to preserve a clear boundary between stdint and non-stdint
CONFIG_SYS_HZ is always defined as 1000 in config_fallbacks.h
(but some boards still have redundant definitions).
This commit moves the definition and the document in README to
Kconfig. Since lib/Kconfig can assure that CONFIG_SYS_HZ is 1000,
the sanity check in lib/time.c should be removed.
Add target to build it automatically upon "make" / MAKEALL. This can/should
be set by board / cpu specific headers if a special U-Boot image is
required for this SoC / board.
E.g. used by Marvell Armada XP to automatically build the u-boot.kwb
target.
Cc: Masahiro Yamada <yamada.m@jp.panasonic.com>
It does seem to work (tested on link), so update the docs.
This is the USB host controller used on the Altera SoCFPGA and Raspbery Pi.
This code has three checkpatch warnings, but to make sure it stays at least
readable and clear, these are not fixed. These bugs are in the USB request
handling combinatorial logic, so any abstracting of those is out of question.
Tested on DENX MCV (Altera SoCFPGA 5CSFXC6C6U23C8N) and RPi B+ (BCM2835).
Signed-off-by: Oleksandr Tymoshenko <gonzo@bluezbox.com>
Signed-off-by: Stephen Warren <swarren@wwwdotorg.org>
Cc: Chin Liang See <clsee@altera.com>
Cc: Dinh Nguyen <dinguyen@altera.com>
Acked-by: Pavel Machek <pavel@denx.de>
Cc: Vince Bridgers <vbridger@altera.com>
Tested-by: Dinh Nguyen <dinguyen@opensource.altera.com>
SEC registers can be of type Little Endian or big Endian depending upon
Freescale SoC. Here SoC defines the register type of SEC IP.
So update acessor functions with common SEC acessor functions to take care
both type of endianness.
Signed-off-by: Ruchika Gupta <ruchika.gupta@freescale.com>
Reviewed-by: York Sun <yorksun@freescale.com>
U-boot has been initializing DDR for the main memory. The presumption
is the memory stays as a big continuous block, either linear or
interleaved. This change is to support putting some DDR controllers
to separated space without counting into main memory. The standalone
memory controller could use different number of DIMM slots.
Signed-off-by: York Sun <yorksun@freescale.com>
- implement 'fastboot flash' for eMMC devices
Signed-off-by: Steve Rae <srae@broadcom.com>
Acked-by: Lukasz Majewski <l.majewski@samsung.com>
A merge error ended up repeating a similar sentence twice. Fix it.
- Use _defconfig instead of _config, but still _config is working.
- Corrected README.sandbox path in ./README
Signed-off-by: Jagannadha Sutradharudu Teki <jaganna@gmail.com>
The default format for arm64 Linux kernels is the "Image" format,
described in Documentation/arm64/booting.txt. This, along with an
optional gzip compression on top is all that is generated by default.
The Image format has a magic number within the header for verification,
a text_offset where the Image must be run from, an image_size that
includes the BSS and reserved fields.
This does not support automatic detection of a gzip compressed image.
resync ubi subsystem with linux:
commit 455c6fdbd219161bd09b1165f11699d6d73de11c
Author: Linus Torvalds <torvalds@linux-foundation.org>
Date: Sun Mar 30 20:40:15 2014 -0700
Linux 3.14
A nice side effect of this, is we introduce UBI Fastmap support
to U-Boot.
Cc: Sergey Lapin <slapin@ossfans.org>
Cc: Scott Wood <scottwood@freescale.com>
Cc: Joerg Krause <jkrause@posteo.de>
It's not unusual for DHCP servers to take a couple hundred milliseconds
to respond to DHCP discover messages. One possible reason for the delay
can be that the server checks (typically using an ARP request) that the
IP it's about to hand out isn't in use yet. To make matters worse, some
servers may also queue up requests and process them sequentially, which
can cause excessively long delays if clients retry too fast.
Commit f59be6e850b3 ("net: BOOTP retry timeout improvements") shortened
the retry timeouts significantly, but the BOOTP/DHCP implementation in
U-Boot doesn't handle that well because it will ignore incoming replies
to earlier requests. In one particular setup this increases the time it
takes to obtain a DHCP lease from 630 ms to 8313 ms.
This commit attempts to fix this in two ways. First it increases the
initial retry timeout from 10 ms to 250 ms to give DHCP servers some
more time to respond. At the same time a cache of outstanding DHCP
request IDs is kept so that the implementation will know to continue
transactions even after a retransmission of the DISCOVER message. The
maximum retry timeout is also increased from 1 second to 2 seconds. An
ID cache of size 4 will keep DHCP requests around for 8 seconds (once
the maximum retry timeout has been reached) before dropping them. This
should give servers plenty of time to respond. If it ever turns out
that this isn't enough, the size of the cache can easily be increased.
With this commit the DHCP lease on the above-mentioned setup still takes
longer (1230 ms) than originally, but that's an acceptable compromise to
improve DHCP lease acquisition time for a broader range of setups.
To make it easier to benchmark DHCP in the future, this commit also adds
the time it took to obtain a lease to the final "DHCP client bound to
address x.x.x.x" message.
Signed-off-by: Thierry Reding <treding@nvidia.com>
CONFIG_BOARD_SIZE_LIMIT was introduced by f3a14d37 [Makefile: allow
boards to check file size limits] and is in use by several boards, but
never got documented.
Signed-off-by: Sascha Silbe <t-uboot@infra-silbe.de>
Signed-off-by: Markus Niebel <Markus.Niebel@tq-group.com>
boards.cfg
The _config part is gone for sure, the _defconfig target could at least
work. I have not verified this for all targets though.
if status register do never set MXC_CSPICTRL_TC, spi_xchg_single
endless loops. Add a timeout here to prevent endless hang.
Cc: Dirk Behme <dirk.behme@gmail.com>
Reviewed-by: Jagannadha Sutradharudu Teki <jaganna@xilinx.com>
Add support for re-relocation malloc() in arm's start-up code.
Set up and zero global data before board_init_f() is called so that we can
remove the need for CONFIG_SYS_GENERIC_GLOBAL_DATA.
If we are to have driver model before relocation we need to support some
way of calling memory allocation routines.
The standard malloc() is pretty complicated:
1. It uses some BSS memory for its state, and BSS is not available before
relocation
2. It supports algorithms for reducing memory fragmentation and improving
performace of free(). Before relocation we could happily just not support
free().
3. It includes about 4KB of code (Thumb 2) and 1KB of data. However since
this has been loaded anyway this is not really a problem.
The simplest way to support pre-relocation malloc() is to reserve an area
of memory and allocate it in increasing blocks as needed. This
implementation does this.
To enable it, you need to define the size of the malloc() pool as described
in the README. It will be located above the pre-relocation stack on
supported architectures.
Note that this implementation is only useful on machines which have some
memory available before dram_init() is called - this includes those that
do no DRAM init (like tegra) and those that do it in SPL (quite a few
boards). Enabling driver model preior to relocation for the rest of the
boards is left for a later exercise.
enable the W#/Vpp signal to disable writing to the status
register on ST MICRON flashes like the N25Q128 thorugh
the new config option CONFIG_SYS_SPI_ST_ENABLE_WP_PIN
Cc: Jagannadha Sutradharudu Teki <jagannadh.teki@gmail.com>
add basic support for the pwm modul found on imx6.
Pieces of this code are based on linux code from drivers/pwm/pwm-imx.c
Commit "cd3de83f1476 Linux 3.16-rc4"
sha256 has some beefy memory footprint.
Make it optional for constrained systems.
Signed-off-by: Dirk Eibach <dirk.eibach@gdsys.cc>
IHS I2C master support was merely a hack in the osd driver.
Now it is a proper u-boot I2C framework driver, supporting the
v2.00 master features.
The option can be used to save the environment in spi flash.
Implementation code is already exist in command/env_sf.c. But
the documentation is missing.
This patch add the details for this option to the README file.
Signed-off-by: Josh Wu <josh.wu@atmel.com>
In README file, add document for the missing configuration option:
CONFIG_ENV_IS_IN_FAT.
Adding support to load and start the Layerscape Management Complex (MC)
firmware. First, the MC GCR register is set to 0 to reset all cores. MC
firmware and DPL images are copied from their location in NOR flash to
DDR. MC registers are updated with the location of these images.
Deasserting the reset bit of MC GCR register releases core 0 to run.
Core 1 will be released by MC firmware. Stop bits are not touched for
this step. U-boot waits for MC until it boots up. In case of a failure,
device tree is updated accordingly. The MC firmware image uses FIT format.
Signed-off-by: J. German Rivera <German.Rivera@freescale.com>
Signed-off-by: Lijun Pan <Lijun.Pan@freescale.com>
Signed-off-by: Shruti Kanetkar <Shruti@Freescale.com>
Add a note to encourage people to convert drivers to use driver model.
When debugging drivers it is useful to see what I/O accesses were done
and in what order.
Even if the individual accesses are of little interest it can be useful to
verify that the access pattern is consistent each time an operation is
performed. In this case a checksum can be used to characterise the operation
of a driver. The checksum can be compared across different runs of the
operation to verify that the driver is working properly.
In particular, when performing major refactoring of the driver, where the
access pattern should not change, the checksum provides assurance that the
refactoring work has not broken the driver.
Add an I/O tracing feature and associated commands to provide this facility.
It works by sneaking into the io.h heder for an architecture and redirecting
I/O accesses through its tracing mechanism.
For now no commands are provided to examine the trace buffer. The format is
fairly simple, so 'md' is a reasonable substitute.
Note: The checksum feature is only useful for I/O regions where the contents
do not change outside of software control. Where this is not suitable you can
fall back to manually comparing the addresses. It might be useful to enhance
tracing to only checksum the accesses and not the data read/written.
make the use of legacy image format configurable through
the config define CONFIG_IMAGE_FORMAT_LEGACY.
When relying on signed FIT images with required signature check
the legacy image format should be disabled. Therefore introduce
this new define and enable legacy image format if CONFIG_FIT_SIGNATURE
is not set. If CONFIG_FIT_SIGNATURE is set disable per default
the legacy image format.
Cc: Lars Steubesand <lars.steubesand@philips.com>
Cc: Mike Pearce <mike@kaew.be>
