path: root/README
2014-05-12common/board_f: Initialized global data for generic boardYork Sun
Some platforms (tested on mpc85xx, mpc86xx) use global data before calling function baord_inti_f(). The data should not be cleared later. Any arch which uses global data in generic board board_init_f() should define CONFIG_SYS_GENERIC_GLOBAL_DATA. Signed-off-by: York Sun <yorksun@freescale.com> CC: Scott Wood <scottwood@freescale.com> CC: Simon Glass <sjg@chromium.org> CC: Albert ARIBAUD <albert.u.boot@aribaud.net> Acked-by: Simon Glass <sjg@chromium.org>
2014-05-12serial: nsl16550: add hw flow control supportKaricheri, Muralidharan
keystone serial hw support hw flow control. This patch enables hw flow control for keystone EVMs as an optional feature based on CONFIG_SERIAL_HW_FLOW_CONTROL. Signed-off-by: Murali Karicheri <m-karicheri2@ti.com>
2014-05-09Merge branch 'tom' of git://git.denx.de/u-boot-x86Tom Rini
2014-05-09sandbox: Update and expand the READMESimon Glass
Now that sandbox has a good base of features, the README is quite out of date. Update it, and document the new features. Signed-off-by: Simon Glass <sjg@chromium.org>
2014-05-09Merge branch 'u-boot/master'Albert ARIBAUD
Conflicts: drivers/net/Makefile (trivial merge)
2014-05-05usb: dfu: fix boards wo USB cable detectionMateusz Zalega
Former usb_cable_connected() patch broke compilation of boards which do not support this feature. I've renamed usb_cable_connected() to g_dnl_usb_cable_connected() and added its default implementation to gadget downloader driver code. There's only one driver of this kind and it's unlikely there'll be another, so there's no point in keeping it in /common. Previously this function was declared in usb.h. I've moved it, since it's more appropriate to keep it in g_dnl.h - usb.h seems to be intended for USB host implementation. Existing code, confronted with default -EOPNOTSUPP return value, continues as if the cable was connected. CONFIG_USB_CABLE_CHECK was removed. Change-Id: Ib9198621adee2811b391c64512f14646cefd0369 Signed-off-by: Mateusz Zalega <m.zalega@samsung.com> Acked-by: Marek Vasut <marex@denx.de> Acked-by: Lukasz Majewski <l.majewski@samsung.com>
2014-04-25Merge branch 'master' of git://git.denx.de/u-boot-mpc85xxTom Rini
2014-04-22Makefile: Add support of CONFIG_SPL_FSL_PBLPrabhakar Kushwaha
Objective of this target to have concatenate binary having - SPL binary in PBL command format - U-boot binary Signed-off-by: Prabhakar Kushwaha <prabhakar@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
2014-04-22powerpc:Add support of SPL non-relocationPrabhakar Kushwaha
Current SPL code base has BSS section placed after reset_vector. This means they have to relocate to use the global variables. This put an implicit requirement of having SPL size = Memory/2. To avoid relocation: - Move bss_section within SPL range - Modify relocate_code() Signed-off-by: Prabhakar Kushwaha <prabhakar@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
2014-04-22mpc85xx/t104x: Add deep sleep framework supportTang Yuantian
When T104x soc wakes up from deep sleep, control is passed to the primary core that starts executing uboot. After re-initialized some IP blocks, like DDRC, kernel will take responsibility to continue to restore environment it leaves before. Signed-off-by: Tang Yuantian <Yuantian.Tang@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
2014-04-22driver/ddr/fsl: Add DDR4 support to Freescale DDR driverYork Sun
Mostly reusing DDR3 driver, this patch adds DDR4 SPD handling, register calculation and programming. Signed-off-by: York Sun <yorksun@freescale.com>
2014-04-22QE/FMAN: modify CONFIG_SYS_QE_FMAN_FW_ADDR to CONFIG_SYS_FMAN_FW_ADDR and ↵Zhao Qiang
CONFIG_SYS_QE_FW_ADDR CONFIG_SYS_QE_FMAN_FW_ADDR is used to both Fman and QE for microcode address. Now using CONFIG_SYS_FMAN_FW_ADDR for Fman microcode address, and CONFIG_SYS_QE_FW_ADDR for QE microcode address. Signed-off-by: Zhao Qiang <B45475@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
2014-04-22powerpc/mpc85xx: SECURE BOOT- Add secure boot target for B4860QDSAneesh Bansal
Changes: 1. L2 cache is being invalidated by Boot ROM code for e6500 core. So removing the invalidation from start.S 2. Clear the LAW and corresponding configuration for CPC. Boot ROM code uses it as hosekeeping area. 3. For Secure boot, CPC is configured as SRAM and used as house keeping area. This configuration is to be disabled once in uboot. Earlier this disabling of CPC as SRAM was happening in cpu_init_r. As a result cache invalidation function was getting skipped in case CPC is configured as SRAM.This was causing random crashes. Signed-off-by: Ruchika Gupta <ruchika.gupta@freescale.com> Signed-off-by: Aneesh Bansal <aneesh.bansal@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
2014-04-20cosmetic: README: add some entries to Directory HierarchyMasahiro Yamada
2014-04-20mips: xburst: remove remainders of dead boardMasahiro Yamada
Commit 54e458de deleted qi_lb60 board support because of the incompatible license issue. There is no board with XBurst CPU. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Daniel Schwierzeck <daniel.schwierzeck@gmail.com>
2014-04-17NAND: DaVinci: allow forced disable of subpage writesKaricheri, Muralidharan
This patch introduces a configurable mechanism to disable subpage writes in the DaVinci NAND driver. Signed-off-by: Vitaly Andrianov <vitalya@ti.com> Signed-off-by: Murali Karicheri <m-karicheri2@ti.com> Acked-by: Tom Rini <trini@ti.com>
2014-04-17README: Add CONFIG_SPL_OS_BOOT to READMETom Rini
2014-04-17mtd: Add a CONFIG_SPL_MTD_SUPPORT for a more full NAND subsystem in SPLTom Rini
This mainly converts the am335x_spl_bch driver to the "normal" format which means a slight change to nand_info within the driver. Acked-by: Scott Wood <scottwood@freescale.com> Signed-off-by: Tom Rini <trini@ti.com>
2014-04-17Merge branch 'next'Tom Rini
2014-04-08Merge branch 'u-boot/master' into 'u-boot-arm/master'Albert ARIBAUD
Conflicts: arch/arm/cpu/arm926ejs/mxs/Makefile include/configs/trats.h include/configs/trats2.h include/mmc.h
2014-04-07ARM: Add workaround for Cortex-A9 errata 761320Nitin Garg
Full cache line writes to the same memory region from at least two processors might deadlock the processor. Exists on r1, r2, r3 revisions. Signed-off-by: Nitin Garg <nitin.garg@freescale.com> Acked-by: Fabio Estevam <fabio.estevam@freescale.com>
2014-04-07ARM: Add workaround for Cortex-A9 errata 794072Nitin Garg
A short loop including a DMB instruction might cause a denial of service on another processor which executes a CP15 broadcast operation. Exists on r1, r2, r3, r4 revisions. Signed-off-by: Nitin Garg <nitin.garg@freescale.com> Acked-by: Dirk Behme <dirk.behme@de.bosch.com>
2014-04-02new commands: uuid and guid - generate random unique identifierPrzemyslaw Marczak
Those commands basis on implementation of random UUID generator version 4 which is described in RFC4122. The same algorithm is used for generation both ids but string representation is different as below. char: 0 9 14 19 24 36 xxxxxxxx-xxxx-xxxx-xxxx-xxxxxxxxxxxx UUID: be be be be be GUID: le le le be be Commands usage: - uuid [<varname>] - guid [<varname>] The result is saved in environment as a "varname" variable if argument is given, if not then it is printed. New config: - CONFIG_CMD_UUID Signed-off-by: Przemyslaw Marczak <p.marczak@samsung.com> Cc: Stephen Warren <swarren@nvidia.com> Cc: Lukasz Majewski <l.majewski@samsung.com> Cc: trini@ti.com
2014-03-23usb: dfu: introduce dfuMANIFEST stateHeiko Schocher
on nand flash using ubi, after the download of the new image into the flash, the "rest" of the nand sectors get erased while flushing the medium. With current u-boot version dfu-util may show: Starting download: [##################################################] finished! state(7) = dfuMANIFEST, status(0) = No error condition is present unable to read DFU status as get_status is not answered while erasing sectors, if erasing needs some time. So do the following changes to prevent this: - introduce dfuManifest state According to dfu specification ( http://www.usb.org/developers/devclass_docs/usbdfu10.pdf ) section 7: "the device enters the dfuMANIFEST-SYNC state and awaits the solicitation of the status report by the host. Upon receipt of the anticipated DFU_GETSTATUS, the device enters the dfuMANIFEST state, where it completes its reprogramming operations." - when stepping into dfuManifest state, sending a PollTimeout DFU_MANIFEST_POLL_TIMEOUT in ms, to the host, so the host (dfu-util) waits the PollTimeout before sending a get_status again. Signed-off-by: Heiko Schocher <hs@denx.de> Cc: Lukasz Majewski <l.majewski@samsung.com> Cc: Kyungmin Park <kyungmin.park@samsung.com> Cc: Marek Vasut <marex@denx.de> Cc: Pantelis Antoniou <panto@antoniou-consulting.com>
2014-03-21aes: Add 'aes' command to access AES-128-CBCMarek Vasut
Add simple 'aes' command, which allows using the AES-128-CBC encryption and decryption functions from U-Boot command line. Signed-off-by: Marek Vasut <marex@denx.de>
2014-03-04Add 64-bit data support for memory commandsYork Sun
Add 64-bit data for memory commands, such as md, mw, mm, cmp. The new size ".q " is introduced. For 64-bit architecture, 64-bit data is enabled by default, by detecting compiler __LP64__. It is optional for other architectures. Signed-off-by: York Sun <yorksun@freescale.com>
2014-02-26Merge branch 'master' of git://git.denx.de/u-boot-armTom Rini
Conflicts: arch/arm/cpu/armv7/config.mk board/ti/am43xx/mux.c include/configs/am43xx_evm.h Signed-off-by: Tom Rini <trini@ti.com>
2014-02-26arm: Switch to -mno-unaligned-access when supported by the compilerTom Rini
When we tell the compiler to optimize for ARMv7 (and ARMv6 for that matter) it assumes a default of SCTRL.A being cleared and unaligned accesses being allowed and fast at the hardware level. We set this bit and must pass along -mno-unaligned-access so that the compiler will still breakdown accesses and not trigger a data abort. To better help understand the requirements of the project with respect to unaligned memory access, the Documentation/unaligned-memory-access.txt file has been added as doc/README.unaligned-memory-access.txt and is taken from the v3.14-rc1 tag of the kernel. Cc: Albert ARIBAUD <albert.u.boot@aribaud.net> Cc: Mans Rullgard <mans@mansr.com> Signed-off-by: Tom Rini <trini@ti.com>
2014-02-26arm: remove unneeded symbol offsets and _TEXT_BASEAlbert ARIBAUD
Remove the last uses of symbol offsets in ARM U-Boot. Remove some needless uses of _TEXT_BASE. Remove all _TEXT_BASE definitions. Signed-off-by: Albert ARIBAUD <albert.u.boot@aribaud.net>
2014-02-21driver/ddr: Add 256 byte interleaving supportYork Sun
Freescale LayerScape SoCs support controller interleaving on 256 byte size. This interleaving is mandoratory. Signed-off-by: York Sun <yorksun@freescale.com>
2014-02-21Driver/ddr: Add support of different DDR base addressYork Sun
DDR base address has been the same from the view of core and DDR controllers. This has changed for Freescale ARM-based SoCs. Controllers setup DDR memory in a contiguous space and cores view it at separated locations. Signed-off-by: York Sun <yorksun@freescale.com>
2014-02-21driver/ddr: Change Freescale ARM DDR driver to support both big and little ↵York Sun
endian Initially it was believed the DDR controller on Freescale ARM would have big endian. But some platform will have little endian. Signed-off-by: York Sun <yorksun@freescale.com>
2014-02-21fs/fdos: RemoveTom Rini
We have an unused FAT implementation in fs/fdos, remove. Signed-off-by: Tom Rini <trini@ti.com>
2014-02-20Merge branch 'master' of git://git.denx.de/u-boot-armTom Rini
2014-02-20Merge branch 'u-boot/master' into 'u-boot-arm/master'Albert ARIBAUD
Conflicts: Makefile drivers/net/npe/Makefile These two conflicts arise from commit 0b2d3f20 ("ARM: NET: Remove the IXP NPE ethernet driver") and are resolved by deleting the drivers/net/npe/Makefile file and removing the CONFIG_IXP4XX_NPE line from Makefile.
2014-02-20i2c, bootcount: add support for bootcounter on i2c devicesHeiko Schocher
add support for bootcounter on an i2c device. And add a README for all bootcounter options. Signed-off-by: Heiko Schocher <hs@denx.de>
2014-02-19doc: README: Correct file name of signature verification documentationDetlev Zundel
Signed-off-by: Detlev Zundel <dzu@denx.de>
2014-02-19README: document CONFIG_CMD_FS_GENERICStephen Warren
This enables generic filesystem commands such as load and ls, which automatically work with multiple filesystem types, without having to be told which is present, unlike e.g. ext2load, fatls. Signed-off-by: Stephen Warren <swarren@nvidia.com>
2014-02-19Merge branch 'u-boot-pxa/master' into 'u-boot-arm/master'Albert ARIBAUD
2014-02-06ARM: IXP: Remove the IXP architecture supportMarek Vasut
The architecture is unmaintained and dead, remove it. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Albert Aribaud <albert.u.boot@aribaud.net> Cc: Michael Schwingen <michael@schwingen.org> Cc: Tom Rini <trini@ti.com>
2014-02-04Merge branch 'clk' of git://www.denx.de/git/u-boot-microblazeTom Rini
2014-02-04common: Add new clk commandMichal Simek
Command provides just dump subcommand for showing clock frequencies in a soc. Signed-off-by: Michal Simek <michal.simek@xilinx.com> Acked-by: Stefano Babic <sbabic@denx.de>
2014-02-03driver/ifc:Change accessor function to take care of endiannessPrabhakar Kushwaha
IFC registers can be of type Little Endian or big Endian depending upon Freescale SoC. Here SoC defines the register type of IFC IP. So update acessor functions with common IFC acessor functions to take care both type of endianness. Signed-off-by: Prabhakar Kushwaha <prabhakar@freescale.com> Acked-by: York Sun <yorksun@freescale.com>
2014-01-21powerpc:Rename CONFIG_PBLRCW_CONFIG & CONFIG_SYS_FSL_PBL_PBIPrabhakar Kushwaha
Rename CONFIG_PBLRCW_CONFIG and CONFIG_PBLRCW_CONFIG. Also add their details in README. Signed-off-by: Prabhakar Kushwaha <prabhakar@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
2014-01-12sf: Add CONFIG_SF_DUAL_FLASHJagannadha Sutradharudu Teki
This config will use for defining greater than single flash support. currently - DUAL_STACKED and DUAL_PARALLEL. Signed-off-by: Jagannadha Sutradharudu Teki <jaganna@xilinx.com>
2014-01-02powerpc/mpc85xx: Add support for single source clockingPriyanka Jain
Single-source clocking is new feature introduced in T1040. In this mode, a single differential clock is supplied to the DIFF_SYSCLK_P/N inputs to the processor, which in turn is used to supply clocks to the sysclock, ddrclock and usbclock. So, both ddrclock and syclock are driven by same differential sysclock in single-source clocking mode whereas in normal clocking mode, generally separate DDRCLK and SYSCLK pins provides reference clock for sysclock and ddrclock DDR_REFCLK_SEL rcw bit is used to determine DDR clock source -If DDR_REFCLK_SEL rcw bit is 0, then DDR PLLs are driven in normal clocking mode by DDR_Reference clock -If DDR_REFCLK_SEL rcw bit is 1, then DDR PLLs are driven in single source clocking mode by DIFF_SYSCLK Add code to determine ddrclock based on DDR_REFCLK_SEL rcw bit. Signed-off-by: Poonam Aggrwal <poonam.aggrwal@freescale.com> Signed-off-by: Priyanka Jain <Priyanka.Jain@freescale.com>
2014-01-02board/freescale:Remove use of CONFIG_SPL_NAND_MINIMALPrabhakar Kushwaha
CONFIG_SPL_NAND_MINIMAL should not be used as it was defined for temporary review purpose. So, use CONFIG_SPL_NAND_BOOT config. Signed-off-by: Prabhakar Kushwaha <prabhakar@freescale.com>
2013-12-13Add dumpimage, a tool to extract data from U-Boot imagesGuilherme Maciel Ferreira
Given a multi-file image created through the mkimage's -d option: $ mkimage -A x86 -O linux -T multi -n x86 -d vmlinuz:initrd.img:System.map \ multi.img Image Name: x86 Created: Thu Jul 25 10:29:13 2013 Image Type: Intel x86 Linux Multi-File Image (gzip compressed) Data Size: 13722956 Bytes = 13401.32 kB = 13.09 MB Load Address: 00000000 Entry Point: 00000000 Contents: Image 0: 4040128 Bytes = 3945.44 kB = 3.85 MB Image 1: 7991719 Bytes = 7804.41 kB = 7.62 MB Image 2: 1691092 Bytes = 1651.46 kB = 1.61 MB It is possible to perform the innverse operation -- extracting any file from the image -- by using the dumpimage's -i option: $ dumpimage -i multi.img -p 2 System.map Although it's feasible to retrieve "data files" from image through scripting, the requirement to embed tools such 'dd', 'awk' and 'sed' for this sole purpose is cumbersome and unreliable -- once you must keep track of file sizes inside the image. Furthermore, extracting data files using "dumpimage" tool is faster than through scripting. Signed-off-by: Guilherme Maciel Ferreira <guilherme.maciel.ferreira@gmail.com> Signed-off-by: Simon Glass <sjg@chromium.org>
2013-12-10Merge branch 'master' of git://git.denx.de/u-boot-armTom Rini
Conflicts: board/samsung/trats2/trats2.c include/configs/exynos5250-dt.h Signed-off-by: Tom Rini <trini@ti.com>
2013-12-10Merge branch 'u-boot/master' into 'u-boot-arm/master'Albert ARIBAUD
Conflicts: arch/arm/cpu/armv7/rmobile/Makefile doc/README.scrapyard Needed manual fix: arch/arm/cpu/armv7/omap-common/Makefile board/compulab/cm_t335/u-boot.lds
