path: root/README
2013-04-14cosmetic: fix CONFIG_SPL_BSS_MAX_SIZE typo in READMEAlbert ARIBAUD
Signed-off-by: Albert ARIBAUD <albert.u.boot@aribaud.net>
2013-04-14ARM: fix CONFIG_SPL_MAX_SIZE semanticsAlbert ARIBAUD
Remove SPL-related ASSERT() in arch/arm/cpu/u-boot.lds as this file is never used for SPL builds. Rewrite the ASSERT() in arch/arm/cpu/u-boot-spl.lds to separately test image (text,data,rodata...) size, BSS size, and full footprint each against its own max, and make Tegra boards check full footprint. Also, output section mmutable is not used in SPL builds. Remove it. Finally, update README regarding the (now homogeneous) semantics of CONFIG_SPL_[BSS_]MAX_SIZE and add the new CONFIG_SPL_MAX_FOOTPRINT macro. Signed-off-by: Albert ARIBAUD <albert.u.boot@aribaud.net> Reported-by: Benoît Thébaudeau <benoit.thebaudeau@advansee.com>
2013-04-12Merge branch 'u-boot/master' into 'u-boot-arm/master'Albert ARIBAUD
Conflicts: drivers/video/exynos_fb.c
2013-04-12Makefile: Change CONFIG_SPL_PAD_TO to image offsetBenoît Thébaudeau
Change CONFIG_SPL_PAD_TO from a link address to an image offset since this is more handy and closer to the purpose of this config. Automatically define CONFIG_SPL_PAD_TO to CONFIG_SPL_MAX_SIZE (or 0 without CONFIG_SPL_MAX_SIZE). Test that CONFIG_SPL_PAD_TO >= CONFIG_SPL_MAX_SIZE if CONFIG_SPL_PAD_TO is non-zero. Signed-off-by: Benoît Thébaudeau <benoit.thebaudeau@advansee.com>
2013-04-12mtd: nand: mxc_nand: Fix is_16bit_nand()Fabio Estevam
Currently is_16bit_nand() is a per SoC function and it decides the bus nand width by reading some boot related registers. This method works when NAND is the boot medium, but does not work if another boot medium is used. For example: booting from a SD card and then using NAND to store the environment variables, would lead to the following error: NAND bus width 16 instead 8 bit No NAND device found!!! 0 MiB Use CONFIG_SYS_NAND_BUSWIDTH_16BIT symbol to decide the bus width. If it is defined in the board file, then consider 16-bit NAND bus-width, otherwise assume 8-bit NAND is used. This also aligns with Documentation/devicetree/bindings/mtd/nand.txt, which states: nand-bus-width : 8 or 16 bus width if not present 8 Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com> Acked-by: Scott Wood <scottwood@freescale.com> Reviewed-by: Benoît Thébaudeau <benoit.thebaudeau@advansee.com>
2013-04-12mtd: nand: Introduce CONFIG_SYS_NAND_BUSWIDTH_16BITFabio Estevam
Introduce CONFIG_SYS_NAND_BUSWIDTH_16BIT option so that other NAND controller drivers could use it when a 16-bit NAND is deployed. drivers/mtd/nand/ndfc has CONFIG_SYS_NDFC_16BIT, so just rename it, so that other NAND drivers could reuse the same symbol. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com> Acked-by: Scott Wood <scottwood@freescale.com> Reviewed-by: Benoît Thébaudeau <benoit.thebaudeau@advansee.com>
2013-04-11env: Add redundant env support to UBI envJoe Hershberger
Allow the user to specify two UBI volumes to use for the environment Signed-off-by: Joe Hershberger <joe.hershberger@ni.com>
2013-04-11env: Add support for UBI environmentJoe Hershberger
UBI is a better place for the environment on NAND devices because it handles wear-leveling and bad blocks. Gluebi is needed in Linux to access the env as an MTD partition. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com>
2013-04-11ubi: ubifs: Turn off verbose printsJoe Hershberger
The prints are out of control. SILENCE! Signed-off-by: Joe Hershberger <joe.hershberger@ni.com>
2013-04-11ubi: ubifs: Add documentation for READMEJoe Hershberger
Describe the needed CONFIG tokens to enable UBI and UBIFS support. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com>
2013-04-10dfu: NAND specific routines for DFU operationPantelis Antoniou
Support for NAND storage devices to work with the DFU framework. Signed-off-by: Pantelis Antoniou <panto@antoniou-consulting.com> Signed-off-by: Tom Rini <trini@ti.com> Acked-by: Scott Wood <scottwood@freescale.com>
2013-04-10dfu: Support larger than memory transfers.Pantelis Antoniou
Previously we didn't support upload/download larger than available memory. This is pretty bad when you have to update your root filesystem for example. This patch removes that limitation (and the crashes when you transfered any file larger than 4MB) by making raw image writes be done in chunks and making file maximum size be configurable. The sequence number is a 16 bit counter; make sure we handle rollover correctly. This fixes the wrong transfers for large (> 256MB) images. Also utilize a variable to handle initialization, so that we don't rely on just the counter sent by the host. Signed-off-by: Pantelis Antoniou <panto@antoniou-consulting.com> Signed-off-by: Tom Rini <trini@ti.com>
2013-04-10README: Document current DFU CONFIG optionsTom Rini
Add documentation for the current DFU config options. DFU is a standard USB device class so more information is available from usb.org Signed-off-by: Tom Rini <trini@ti.com>
2013-04-08omap3_beagle: Flush UART3 xmit on enable if TEMT is brokenManfred Huber
Flush UART3 xmit on enable if TEMT is broken On some OMAP3 devices when UART3 is configured for boot mode before SPL starts only THRE bit is set. We have to empty the transmitter before initialization starts. This patch avoids the use of CONFIG_SYS_NS16550_BROKEN_TEMT. Signed-off-by: Manfred Huber <man.huber@arcor.de> Tested-by: Javier Martinez Canillas <javier@dowhile0.org> Tested-by: Andreas Bießmann <andreas.devel@googlemail.com>
2013-04-02README: document the requirements for CONFIG_SYS_HZStephen Warren
CONFIG_SYS_HZ must be 1000, and get_timer() must therefore return ms. Document this. README text provided by Tom Rini. Signed-off-by: Stephen Warren <swarren@wwwdotorg.org>
2013-04-01Consolidate bool typeYork Sun
'bool' is defined in random places. This patch consolidates them into a single header file include/linux/types.h, using stdbool.h introduced in C99. All other #define, typedef and enum are removed. They are all consistent with true = 1, false = 0. Replace FALSE, False with false. Replace TRUE, True with true. Skip *.py, *.php, lib/* files. Signed-off-by: York Sun <yorksun@freescale.com>
2013-03-24Merge branch 'u-boot-ti/master' into 'u-boot-arm/master'Albert ARIBAUD
2013-03-22ARM: implement erratum 716044 workaroundStephen Warren
Add common code to enable the workaround for ARM erratum 716044. This will be enabled for Tegra. Signed-off-by: Stephen Warren <swarren@nvidia.com>
2013-03-22Allow AM335x MPU core clock speed to be specified in the board config fileMark Jackson
Allow AM335x MPU core clock speed to be specified in the board config file. To use, add the following to the board's config file:- #define CONFIG_SYS_MPUCLK <desired clock freq in MHz> Signed-off-by: Mark Jackson <mpfj@newflow.co.uk> Acked-by: Peter Korsgaard <jacmet@sunsite.dk>
2013-03-18Merge branch 'master' of git://git.denx.de/u-boot-armTom Rini
Albert's rework of the linker scripts conflicted with Simon's making everyone use __bss_end. We also had a minor conflict over README.scrapyard being added to in mainline and enhanced in u-boot-arm/master with proper formatting. Conflicts: arch/arm/cpu/ixp/u-boot.lds arch/arm/cpu/u-boot.lds arch/arm/lib/Makefile board/actux1/u-boot.lds board/actux2/u-boot.lds board/actux3/u-boot.lds board/dvlhost/u-boot.lds board/freescale/mx31ads/u-boot.lds doc/README.scrapyard include/configs/tegra-common.h Build tested for all of ARM and run-time tested on am335x_evm. Signed-off-by: Tom Rini <trini@ti.com>
2013-03-15Add CONFIG_SYS_SYM_OFFSETS to support offset symbolsSimon Glass
Link symbols as created by the link script can either be absolute or relative to the text start. This option switches between the two options so that we can support both. As we convert architectures over to generic board, we can see if this option is actually needed, or whether it is possible to unify this feature also. Signed-off-by: Simon Glass <sjg@chromium.org>
2013-03-15__HAVE_ARCH_GENERIC_BOARD controls availabilty of generic boardSimon Glass
We are introducing a new unified board setup. Add a check to make sure that board config files do not define CONFIG_SYS_GENERIC_BOARD unless their architecture defines __HAVE_ARCH_GENERIC_BOARD __HAVE_ARCH_GENERIC_BOARD will currently not be the default setting, but we can switch this later when most architecture support generic board. Signed-off-by: Simon Glass <sjg@chromium.org>
2013-03-13ARM: implement some Cortex-A9 errata workaroundsStephen Warren
Various errata exist in the Cortex-A9 CPU, and may be worked around by setting some bits in a CP15 diagnostic register. Add code to implement the workarounds, enabled by new CONFIG_ options. This code was taken from the Linux kernel, v3.8, arch/arm/mm/proc-v7.S, and modified to remove the logic to conditionally apply the WAR (since we know exactly which CPU we're running on given the U-Boot configuration), and use r0 instead of r10 for consistency with the rest of U-Boot's cpu_init_cp15(). Signed-off-by: Stephen Warren <swarren@nvidia.com> Acked-by: Simon Glass <sjg@chromium.org>
2013-03-11Feature Removal: disable "mtest" command by defaultWolfgang Denk
The "mtest" command is of little practical use (if any), and experience has shown that a large number of board configurations define useless or even dangerous start and end addresses. If not even the board maintainers are able to figure out which memory range can be reliably tested, how can we expect such from the end users? As this problem comes up repeatedly, we rather do not enable this command by default, so only people who know what they are doing will be confronted with it. As this changes the user interface, we allow for a grace period before this change takes effect. For now, we make "mtest" configurable through the CONFIG_CMD_MEMTEST variable, which is defined in include/config_cmd_default.h; we also add an entry to doc/feature-removal-schedule.txt which announces the removal of this default setting in two releases from now, i. e. with v2013.07. Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Tom Rini <trini@ti.com>
2013-03-11Merge u-boot/master into u-boot-ti/masterTom Rini
In master we had already taken a patch to fix the davinci GPIO code for CONFIG_SOC_DM646X and in u-boot-ti we have additional patches to support DA830 (which is CONFIG_SOC_DA8XX && !CONFIG_SOC_DA850). Resolve these conflicts manually and comment the #else/#endif lines for clarity. Conflicts: arch/arm/include/asm/arch-davinci/gpio.h drivers/gpio/da8xx_gpio.c Signed-off-by: Tom Rini <trini@ti.com>
2013-03-11lcd: implement a callback for splashimageNikita Kiryanov
On some architectures certain values of splashimage will lead to a data abort exception. Document the problem, and implement a callback for splashimage to reject such values. Cc: Anatolij Gustschin <agust@denx.de> Cc: Wolfgang Denk <wd@denx.de> Signed-off-by: Nikita Kiryanov <nikita@compulab.co.il> Acked-by: Igor Grinberg <grinberg@compulab.co.il>
2013-03-08lcd: add option for board specific splash screen preparationNikita Kiryanov
Currently there is no logical place to put the code that prepares the splash image data. The splash image data should be ready in memory before bmp_display() is called, and after the environment is ready (since lcd.c looks for the splash image in an address specified by the environment variable "splashimage"). Our window of opportunity in board_init_r() is therefore: between env_relocate() and bmp_display(), and from the available options only the lcd related functions in drv_lcd_init() seem appropriate for such lcd oriented code. Add the option to prepare the splash image data in lcd_logo() right before it is sent to be displayed. Cc: Anatolij Gustschin <agust@denx.de> Cc: Jeroen Hofstee <jeroen@myspectrum.nl> Signed-off-by: Nikita Kiryanov <nikita@compulab.co.il> Signed-off-by: Igor Grinberg <grinberg@compulab.co.il>
2013-03-04sandbox: Add 'sb' command to access filesystem featuresSimon Glass
The new 'sb' command is intended to deal with sandbox-specific features that have no parallel in other archs. This commit adds two sub-commands to list a directory and read a file from the host filesystem. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@ti.com>
2013-02-28sandbox: Add un/map_sysmen() to deal with sandbox's ram_bufSimon Glass
Sandbox doesn't actually provide U-Boot access to the machine's physical memory. Instead it provides a RAM buffer of configurable size, and all memory accesses are within that buffer. Sandbox memory starts at 0 and is CONFIG_DRAM_SIZE bytes in size. Allowing access outside this buffer might produce unpredictable results in the event of an error, and would expose the host machine's memory architecture to the sandbox U-Boot. Most U-Boot functions assume that they can just access memory at given address. For sandbox this is not true. Add a map_sysmem() call which converts a U-Boot address to a system address. In most cases this is a NOP, but for sandbox it returns a pointer to that memory inside the RAM buffer. To get a U-Boot feature to work correctly within sandbox, you should call map_sysmem() to get a pointer to the address, and then use that address for any U-Boot memory accesses. Signed-off-by: Simon Glass <sjg@chromium.org>
2013-02-22imls: Add support to list images in NAND deviceVipin Kumar
This patch adds support to list images in NAND flash through imls Signed-off-by: Vipin Kumar <vipin.kumar@st.com>
2013-02-14x86: Remove unused real mode codeSimon Glass
This code is pretty old and we want to support only 32-bit systems now. Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Graeme Russ <graeme.russ@gmail.com>
2013-02-14x86: Rename CONFIG_NO_X86_RESET_VECTOR to CONFIG_X86_RESET_VECTORSimon Glass
Invert the polarity of this option to simplify the Makefile logic. Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Gabe Black <gabeblack@chromium.org>
2013-01-16Merge remote-tracking branch 'mpc83xx/next'Kim Phillips
2013-01-14VIDEO: better document the correct use of CONFIG_FB_ADDRWolfgang Denk
Signed-off-by: Wolfgang Denk <wd@denx.de> cc: Anatolij Gustschin <agust@denx.de>
2013-01-11Merge branch 'master' of git://git.denx.de/u-boot-armTom Rini
2013-01-11Merge branch 'u-boot-ti/master' into 'u-boot-arm/master'Albert ARIBAUD
2013-01-10serial/ns16550: add an option to avoid hanging on broken platformsJavier Martinez Canillas
Some platforms (e.g. IGEPv2 board) has a broken ns16550 UART that does not set the TEMT bit when the transmitter is empty in SPL. This makes U-Boot to hang while waiting for TEMT to be set. Add a new option to avoid this: CONFIG_SYS_NS16550_BROKEN_TEMT 16550 UART set the Transmitter Empty (TEMT) Bit when all output has finished and the transmitter is totally empty. U-Boot waits for this bit to be set to initialize the serial console. On some broken platforms this bit is not set in SPL making U-Boot to hang while waiting for TEMT. Define this option to avoid it. Signed-off-by: Javier Martinez Canillas <javier.martinez@collabora.co.uk>
2013-01-10Add option to display customised memory informationSimon Glass
Some boards want to report more than just memory size. For example, it might be useful to display the memory type (DDR2, DDR3) or manufacturer. Add a weak function to support this requirement, accessed through a new 'meminfo' command. Any example of the DRAM: output is below, just for illustration: SMDK5250 # meminfo DRAM: 2 GiB Elpida DDR3 @ 800MHz Signed-off-by: Simon Glass <sjg@chromium.org>
2013-01-10arm: Add CONFIG_DISPLAY_BOARDINFO_LATE to display board info on LCDSimon Glass
This option displays board info after stdio is running, so that it will appear on the LCD. If it is displayed earlier, the board info will appear on the serial console but not on the LCD. Here follows a blow-by-blow description. 1a. Without CONFIG_DISPLAY_BOARDINFO_LATE, on serial: U-Boot 2011.12-02550-g037e1c5-dirty (Nov 15 2012 - 14:29:42) for SMDK5250 CPU: S5PC520 @ 1700MHz Board: Google Snow, rev 0 I2C: ready DRAM: 2 GiB Elpida DDR3 @ 800MHz MMC: S5P MSHC0: 0, S5P MSHC1: 1 SF: Detected W25Q32 with page size 4 KiB, total 4 MiB *** Warning - bad CRC, using default environment In: mkbp-keyb Out: lcd Err: lcd Net: No ethernet found. Hit any key to stop autoboot: 0 SMDK5250 # 1b. Without CONFIG_DISPLAY_BOARDINFO_LATE, on LCD (note machine info is missing): In: mkbp-keyb Out: lcd Err: lcd Net: No ethernet found. Hit any key to stop autoboot: 0 SMDK5250 # 2a. With CONFIG_DISPLAY_BOARDINFO_LATE, on serial: U-Boot 2011.12-02550-g037e1c5 (Nov 15 2012 - 14:27:40) for SMDK5250 CPU: S5PC520 @ 1700MHz I2C: ready DRAM: 2 GiB Elpida DDR3 @ 800MHz MMC: S5P MSHC0: 0, S5P MSHC1: 1 SF: Detected W25Q32 with page size 4 KiB, total 4 MiB *** Warning - bad CRC, using default environment Model: Google Snow In: mkbp-keyb Out: lcd Err: lcd Net: No ethernet found. Hit any key to stop autoboot: 0 SMDK5250 # 2b. With CONFIG_DISPLAY_BOARDINFO_LATE, on LCD (note machine info is present): Model: Google Snow In: mkbp-keyb Out: lcd Err: lcd Net: No ethernet found. Hit any key to stop autoboot: 0 SMDK5250 # Since the LCD is all that a typical user sees, it is useful to display the model there. We may be able to rearrange things some other way one day, but at present this seems like a convenient way of getting the required behaviour. Signed-off-by: Simon Glass <sjg@chromium.org>
2013-01-10Document the CONFIG_DISPLAY_BOARDINFO optionSimon Glass
Add a short note about this in the README. Signed-off-by: Simon Glass <sjg@chromium.org>
2013-01-10arm: Add CONFIG_DELAY_ENVIRONMENT to delay environment loadingSimon Glass
This option delays loading of the environment until later, so that only the default environment will be available to U-Boot. This can address the security risk of untrusted data being used during boot. Any time you load untrusted data you expose yourself to a bug in the code. The attacker gets to choose the data so can sometimes carefully craft it to exploit a bug. We try to avoid touching user-controlled data during a verified boot unless strictly necessary. Since the default environment is good enough in this case (or you would just change it), this gets around the problem by just not loading the environment. When CONFIG_DELAY_ENVIRONMENT is defined, it is convenient to have a run-time way of enabling loading of the environment. Add this to the fdt as /config/delay-environment. Note: This patch depends on http://patchwork.ozlabs.org/patch/194342/ Signed-off-by: Doug Anderson <dianders@chromium.org> Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Doug Anderson <dianders@chromium.org>
2012-12-22Merge branch 'master' of git://git.denx.de/u-boot-armTom Rini
2012-12-19powerpc/mpc83xx: add support for new SPLScott Wood
This adds arch support for PPC mpc83xx to boot "minimal" (4K) SPLs using the new infrastructure. Existing nand_spl targets are updated to deal with the name change from nand_init.c to spl_minimal.c (as in theory this isn't limited to NAND anymore). Signed-off-by: Scott Wood <scottwood@freescale.com> Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2012-12-19spl: Change PAD_TO to CONFIG_SPL_PAD_TOScott Wood
This was already used by some SPL targets, and allows the pad amount to be specified by board config headers rather than only in makefile fragments. Also supply a pad-to of zero if the variable is undefined. It works without this, but this avoids relying on undocumented behavior. Signed-off-by: Scott Wood <scottwood@freescale.com> Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2012-12-19spi: Add SPI flash testSimon Glass
It is useful to have a basic SPI flash test, which tests that the SPI chip, the SPI bus and the driver are behaving. This test erases part of the flash, writes data and reads it back as a sanity check that all is well. Use CONFIG_SF_TEST to enable it. Signed-off-by: Simon Glass <sjg@chromium.org>
2012-12-19Merge remote-tracking branch 'u-boot/master' into u-boot-arm-mergedAllen Martin
Conflicts: README arch/arm/cpu/armv7/exynos/clock.c board/samsung/universal_c210/universal.c drivers/misc/Makefile drivers/power/power_fsl.c include/configs/mx35pdk.h include/configs/mx53loco.h include/configs/seaboard.h
2012-12-15powerpc: remove not used CONFIG_SYS_TFTP_LOADADDRtrem
CONFIG_SYS_TFTP_LOADADDR is defined on severals boards, but it's never used. So we can safely removed it. Signed-off-by: Philippe Reynes <tremyfr@yahoo.fr>
2012-12-13env: Add support for access control to .flagsJoe Hershberger
Add support for read-only, write-once, and change-default. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com>
2012-12-13env: Add a command to display details about env flagsJoe Hershberger
Similar to the env callback command, this will show details about the options available, the static list, and the currently active variables. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com>
2012-12-13env: Add environment variable flagsJoe Hershberger
Currently just validates variable types as decimal, hexidecimal, boolean, ip address, and mac address. If the entry is not found in the env ".flags", then look in the static one. This allows the env to override the static definitions, but prevents the need to have every definition in the environment distracting you. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com>
