path: root/README
2013-07-23i2c, soft-i2c: switch to new multibus/multiadapter supportHeiko Schocher
- added to soft_i2c driver new multibus/multiadpater support - adapted all config files, which uses this driver Signed-off-by: Heiko Schocher <hs@denx.de> Cc: Simon Glass <sjg@chromium.org> Cc: Stephen Warren <swarren@wwwdotorg.org>
2013-07-23i2c: common changes for multibus/multiadapter supportHeiko Schocher
Signed-off-by: Heiko Schocher <hs@denx.de> Signed-off-by: Simon Glass <sjg@chromium.org> Cc: Henrik Nordström <henrik@henriknordstrom.net>
2013-07-16Add Atmel I2C tpmDirk Eibach
Add support for Atmel TPM devices with two wire interface. Signed-off-by: Dirk Eibach <dirk.eibach@gdsys.cc> Signed-off-by: Reinhard Pfau <reinhard.pfau@gdsys.cc> Reviewed-by: Simon Glass <sjg@chromium.org> Signed-off-by: Andy Fleming <afleming@freescale.com>
2013-07-16tpm: add AUTH1 cmds for LoadKey2 and GetPubKeyReinhard Pfau
Extend the tpm library with support for single authorized (AUTH1) commands as specified in the TCG Main Specification 1.2. (The internally used helper functions are implemented in a way that they could also be used for double authorized commands if someone needs it.) Provide enums with the return codes from the TCG Main specification. For now only a single OIAP session is supported. OIAP authorized version of the commands TPM_LoadKey2 and TPM_GetPubKey are provided. Both features are available using the 'tpm' command, too. Authorized commands are enabled with CONFIG_TPM_AUTH_SESSIONS. (Note that this also requires CONFIG_SHA1 to be enabled.) Signed-off-by: Reinhard Pfau <reinhard.pfau@gdsys.cc> Signed-off-by: Dirk Eibach <dirk.eibach@gdsys.cc> Acked-by: Che-Liang Chiou <clchiou@chromium.org> Signed-off-by: Andy Fleming <afleming@freescale.com>
2013-07-10Merge branch 'master' of git://git.denx.de/u-boot-videoTom Rini
2013-07-01video: lcd: Make splash_screen_prepare weak, remove config macroRobert Winkler
Remove CONFIG_SPLASH_SCREEN_PREPARE from README Add doc/README.splashprepare to document functionality Signed-off-by: Robert Winkler <robert.winkler@boundarydevices.com> Acked-by: Igor Grinberg <grinberg@compulab.co.il>
2013-06-30dfu: make data buffer size configurableHeiko Schocher
Dfu transfer uses a buffer before writing data to the raw storage device. Make the size (in bytes) of this buffer configurable through environment variable "dfu_bufsiz". Defaut value is configurable through CONFIG_SYS_DFU_DATA_BUF_SIZE Signed-off-by: Heiko Schocher <hs@denx.de> Cc: Pantelis Antoniou <panto@antoniou-consulting.com> Cc: Tom Rini <trini@ti.com> Cc: Lukasz Majewski <l.majewski@samsung.com> Cc: Kyungmin Park <kyungmin.park@samsung.com> Cc: Marek Vasut <marex@denx.de> Cc: Wolfgang Denk <wd@denx.de> Acked-by: Tom Rini <trini@ti.com>
2013-06-26README: align default commands with codeVincent Stehlé
Align the list of default commands mentioned in the configuration options paragraph of the README with the actual definitions found in include/config_cmd_default.h Signed-off-by: Vincent Stehlé <vincent.stehle@freescale.com>
2013-06-26image: Add RSA support for image signingSimon Glass
RSA provides a public key encryption facility which is ideal for image signing and verification. Images are signed using a private key by mkimage. Then at run-time, the images are verified using a private key. This implementation uses openssl for the host part (mkimage). To avoid bringing large libraries into the U-Boot binary, the RSA public key is encoded using a simple numeric representation in the device tree. Signed-off-by: Simon Glass <sjg@chromium.org>
2013-06-26image: Add signing infrastructureSimon Glass
Add a structure to describe an algorithm which can sign and (later) verify images. Signed-off-by: Simon Glass <sjg@chromium.org>
2013-06-26cros: adds cros_ec keyboard driverHung-ying Tyan
This patch adds the driver for keyboard that's controlled by ChromeOS EC. Signed-off-by: Randall Spangler <rspangler@chromium.org> Signed-off-by: Simon Glass <sjg@chromium.org> Signed-off-by: Vincent Palatin <vpalatin@chromium.org> Signed-off-by: Hung-ying Tyan <tyanh@chromium.org> Acked-by: Simon Glass <sjg@chromium.org>
2013-06-24Merge branch 'master' of git://git.denx.de/u-boot-spiTom Rini
2013-06-23sf: Add bank addr code in CONFIG_SPI_FLASH_BARJagannadha Sutradharudu Teki
Defined bank addr code on CONFIG_SPI_FLASH_BAR macro, to reduce the size for existing boards which has < 16Mbytes SPI flashes. It's upto user which has provision to use the bank addr code for flashes which has > 16Mbytes. Signed-off-by: Jagannadha Sutradharudu Teki <jaganna@xilinx.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2013-06-20common/Makefile: Add new symbol CONFIG_SPL_ENV_SUPPORT for environment in SPLYing Zhang
There will need the environment in SPL for reasons other than network support (in particular, hwconfig contains info for how to set up DDR). Add a new symbol CONFIG_SPL_ENV_SUPPORT to replace CONFIG_SPL_NET_SUPPORT for environment in common/Makefile. Signed-off-by: Ying Zhang <b40530@freescale.com> Reviewed-by: Tom Rini <trini@ti.com> Signed-off-by: Andy Fleming <afleming@freescale.com>
2013-06-20powerpc/mpc85xx: support application without resetvec segment in the linker ↵Ying Zhang
script For SD/SPI 2-stage bootloader, the On-Chip Rom code loads the SPL into L2 SRAM, then jump to it to begin execution. After that, the SPL loads the final uboot image into DDR, then jump to it to begin execution. The segment .resetvec in the SPL and in final U-boot is useless. So, add new symbols CONFIG_SYS_MPC85XX_NO_RESETVEC for this application. If CONFIG_SYS_MPC85XX_NO_RESETVEC is set, the segment .resetvec is excluded and the segment .bootpg is placed in the previous 4K of the segment .text. Signed-off-by: Ying Zhang <b40530@freescale.com> Signed-off-by: Andy Fleming <afleming@freescale.com>
2013-06-20powerpc/boot: Change the macro of Boot from SRIO and PCIE master moduleLiu Gang
Currently, the macro "CONFIG_SYS_FSL_SRIO_PCIE_BOOT_MASTER" can enable the master module of Boot from SRIO and PCIE on a platform. But this is not a silicon feature, it's just a specific booting mode based on the SRIO and PCIE interfaces. So it's inappropriate to put the macro into the file arch/powerpc/include/asm/config_mpc85xx.h. Change the macro "CONFIG_SYS_FSL_SRIO_PCIE_BOOT_MASTER" to "CONFIG_SRIO_PCIE_BOOT_MASTER", remove them from arch/powerpc/include/asm/config_mpc85xx.h file, and add those macros in configuration header file of each board which can support the master module of Boot from SRIO and PCIE. Signed-off-by: Liu Gang <Gang.Liu@freescale.com> Signed-off-by: Andy Fleming <afleming@freescale.com>
2013-06-20board/bsc9131rdb: Add DSP side tlb and lawsPriyanka Jain
BSC9131RDB is a Freescale Reference Design Board for BSC9131 SoC which is a integrated device that contains one powerpc e500v2 core and one DSP starcore. To support DSP starcore -Creating LAW and TLB for DSP-CCSR space. -Creating LAW for DSP-core subsystem M2 memory Signed-off-by: Priyanka Jain <Priyanka.Jain@freescale.com> Signed-off-by: Poonam Aggrwal <poonam.aggrwal@freescale.com> Signed-off-by: Prabhakar Kushwaha <prabhakar@freescale.com> Signed-off-by: Andy Fleming <afleming@freescale.com>
2013-06-20powerpc/mpc85xx:No NOR boot, do not compile IFC errata A003399Prabhakar Kushwaha
IFC errata A003399 is valid for IFC NOR boot i.e.if no on-board NOR flash or no NOR boot, do not compile its workaround. Signed-off-by: Prabhakar Kushwaha <prabhakar@freescale.com> Signed-off-by: Andy Fleming <afleming@freescale.com>
2013-06-14Merge branch 'master' of git://www.denx.de/git/u-boot-mmcTom Rini
2013-06-13env_mmc: allow negative CONFIG_ENV_OFFSETStephen Warren
A negative value of CONFIG_ENV_OFFSET is treated as a backwards offset from the end of the eMMC device/partition, rather than a forwards offset from the start. This is useful when a single board may be stuffed with different eMMC devices, each of which has a different capacity, and you always want the environment to be stored at the very end of the device (or eMMC boot partition for example). One example of this case is NVIDIA's Ventana reference board. Signed-off-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Andy Fleming <afleming@freescale.com>
2013-06-13README: document CONFIG_ENV_IS_IN_MMCStephen Warren
Describe the meaning of CONFIG_ENV_IS_IN_MMC, and all related defines that must or can be set when using that option. Signed-off-by: Stephen Warren <swarren@nvidia.com> Reviewed-by: Peter Korsgaard <jacmet@sunsite.dk> Acked-by: Tom Rini <trini@ti.com> Signed-off-by: Andy Fleming <afleming@freescale.com>
2013-06-12usb: hub: make minimum power-on delay configurableKuo-Jung Su
This patch makes the minimum power-on delay for USB HUB become configurable. The original design waits at least 100 msec here, but some EHCI controlers(e.g. Faraday EHCI) are known to require much longer delay interval. Signed-off-by: Kuo-Jung Su <dantesu@faraday-tech.com> CC: Marek Vasut <marex@denx.de>
2013-06-07pci: introduce CONFIG_PCI_INDIRECT_BRIDGE optionGabor Juhos
The pci_indirect.c file is always compiled when CONFIG_PCI is defined although the indirect PCI bridge support is not needed by every board. Introduce a new CONFIG_PCI_INDIRECT_BRIDGE config option and only compile indirect PCI bridge support if this options is enabled. Also add the new option into the configuration files of the boards which needs that. Compile tested for powerpc, x86, arm and nds32. MAKEALL results: powerpc: --------------------- SUMMARY ---------------------------- Boards compiled: 641 Boards with warnings but no errors: 2 ( ELPPC MPC8323ERDB ) ---------------------------------------------------------- Note: the warnings for ELPPC and MPC8323ERDB are present even without the actual patch. x86: --------------------- SUMMARY ---------------------------- Boards compiled: 1 ---------------------------------------------------------- arm: --------------------- SUMMARY ---------------------------- Boards compiled: 311 ---------------------------------------------------------- nds32: --------------------- SUMMARY ---------------------------- Boards compiled: 3 ---------------------------------------------------------- Cc: Tom Rini <trini@ti.com> Cc: Daniel Schwierzeck <daniel.schwierzeck@googlemail.com> Signed-off-by: Gabor Juhos <juhosg@openwrt.org>
2013-06-07spl_mmc: add Falcon mode support for raw variantPeter Korsgaard
If Falcon mode support is enabled (and the system isn't directed into booting u-boot), it will instead try to load kernel from sector CONFIG_SYS_MMCSD_RAW_MODE_KERNEL_SECTOR and CONFIG_SYS_MMCSD_RAW_MODE_ARGS_SECTORS of kernel argument parameters starting from sector CONFIG_SYS_MMCSD_RAW_MODE_ARGS_SECTOR. Signed-off-by: Peter Korsgaard <peter.korsgaard@barco.com>
2013-06-07spl_mmc: add Falcon mode support for FAT variantPeter Korsgaard
If Falcon mode support is enabled (and the system isn't directed into booting u-boot), it will instead try to load kernel from CONFIG_SPL_FAT_LOAD_KERNEL_NAME file and kernel argument parameters from CONFIG_SPL_FAT_LOAD_ARGS_NAME, both from the same partition as u-boot. Signed-off-by: Peter Korsgaard <peter.korsgaard@barco.com>
2013-06-03tpm: Reorganize the I2C TPM driverTom Wai-Hong Tam
This patch does a similar code reogranzation from http://patchwork.ozlabs.org/patch/132179/ which is based on an old version of code (fdt support and bus selection still not in). It merges this tidy-up on top of the recent code. It does not make any logical change. tpm.c implements the interface defined in tpm.h based on underlying LPC or I2C TPM driver. tpm.c and the underlying driver communicate throught tpm_private.h. Note: Merging the LPC driver with tpm.c is left to future patches. Change-Id: Ie1384f5f9e3935d3bc9a44adf8de80c5a70a5f2b Signed-off-by: Tom Wai-Hong Tam <waihong@chromium.org> Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Simon Glass <sjg@chromium.org>
2013-06-03tpm: Rename generic_lpc_tpm to tpm_tis_lpcChe-liang Chiou
The new name is more aligned with Linux kernel's naming of TPM driver. Signed-off-by: Peter Huewe <peter.huewe@infineon.com> Signed-off-by: Che-Liang Chiou <clchiou@chromium.org> Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Mike Frysinger <vapier@gentoo.org> Reviewed-by: Simon Glass <sjg@chromium.org> Tested-by: Tom Wai-Hong Tam <waihong@chromium.org>
2013-05-30Merge branch 'u-boot/master' into 'u-boot-arm/master'Albert ARIBAUD
Conflicts: common/cmd_fpga.c drivers/usb/host/ohci-at91.c
2013-05-16README: Correct reference for CONFIG_SUPPORT_RAW_INITRDTom Rini
2013-05-15Power: remove support for Freescale MPC8220Wolfgang Denk
The Freescale MPC8220 Power Architecture processors have long reached EOL; Freescale does not even list these any more on their web site. Remove the code to avoid wasting maitaining efforts on dead stuff. Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Andy Fleming <afleming@gmail.com>
2013-05-14image: Add CONFIG_FIT_SPL_PRINT to control FIT image printing in SPLSimon Glass
This code is very large, and in SPL it isn't always useful to print out image information (in fact there might not even be a console active). So disable this feature unless this option is set. Signed-off-by: Simon Glass <sjg@chromium.org>
2013-05-13blackfin: bf609: add softswitch config commandBob Liu
Add softswitch_output command for bf609-ezkit to enable softswitches. Signed-off-by: Bob Liu <lliubbo@gmail.com> Signed-off-by: Sonic Zhang <sonic.zhang@analog.com>
2013-05-11Merge branch 'u-boot-ti/master' into 'u-boot-arm/master'Albert ARIBAUD
2013-05-11Merge branch 'u-boot-imx/master' into 'u-boot-arm/master'Albert ARIBAUD
Conflicts: drivers/mtd/nand/mxc_nand_spl.c include/configs/m28evk.h
2013-05-10ARM: OMAP5: Fix warm reset with USB cable connectedLokesh Vutla
Warm reset on OMAP5 freezes when USB cable is connected. Fix requires PRM_RSTTIME.RSTTIME1 to be programmed with the time for which reset should be held low for the voltages and the oscillator to reach stable state. There are 3 parameters to be considered for calculating the time, which are mostly board and PMIC dependent. -1- Time taken by the Oscillator to shut + restart -2- PMIC OTP times -3- Voltage rail ramp times, which inturn depends on the PMIC slew rate and value of the voltage ramp needed. In order to keep the code in u-boot simple, have a way for boards to specify a pre computed time directly using the 'CONFIG_OMAP_PLATFORM_RESET_TIME_MAX_USEC' option. If boards fail to specify the time, use a default as specified by 'CONFIG_DEFAULT_OMAP_RESET_TIME_MAX_USEC' instead. Using the default value translates into some ~22ms and should work in all cases. However in order to avoid this large delay hiding other bugs, its recommended that all boards look at their respective data sheets and specify a pre computed and optimal value using 'CONFIG_OMAP_PLATFORM_RESET_TIME_MAX_USEC' In order to help future board additions to compute this config option value, add a README at doc/README.omap-reset-time which explains how to compute the value. Also update the toplevel README with the additional option and pointers to doc/README.omap-reset-time. Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com> [rnayak@ti.com: Updated changelog and added the README] Signed-off-by: Rajendra Nayak <rnayak@ti.com>
2013-05-01Add SLRE - Super Light Regular Expression libraryWolfgang Denk
Downloaded from http://slre.sourceforge.net/ and adapted for U-Boot environment. Used to implement regex operations on environment variables. Code size is ~ 3.5 KiB on PPC. To enable this code, define the CONFIG_REGEX option in your board config file. Note: There are more recent versions of the SLRE library available at http://slre.googlecode.com ; unfortunately, the new code has a heavily reorked API which makes it less usable for our purposes: - the return code is strings, which are more difficult to process - we don't get any information any more which sub-string of the data was matched by the given regex - it is much more cumbersome to work with arbitrary expressions, where for example the number of substrings for capturing are not known at compile time Also, there does not seem to be any real changes or improvements of the functionality. Because of this, we deliberately stick with the older code. Note 2: the test code (built when SLRE_TEST is defined) was modified to allow for more extensive testing; now we can test the regexp matching on all lines on a text file (instead of the whole data in the file as a single block). Signed-off-by: Wolfgang Denk <wd@denx.de>
2013-04-28Add fuse API and commandsBenoît Thébaudeau
This can be useful for fuse-like hardware, OTP SoC options, etc. Signed-off-by: Benoît Thébaudeau <benoit.thebaudeau@advansee.com>
2013-04-22flash: Add optional verify-after-write featureStefan Roese
Sometimes it might make sense to verify the written data to NOR flash. This patch adds this feature. To enable this verify-after-write, you need to define CONFIG_FLASH_VERIFY in your board config header. Please note that this option is useless in nearly all cases, since such flash programming errors usually are detected earlier while unprotecting/erasing/programming. Please only enable this option if you really know what you are doing. Signed-off-by: Stefan Roese <sr@denx.de>
2013-04-14cosmetic: fix CONFIG_SPL_BSS_MAX_SIZE typo in READMEAlbert ARIBAUD
Signed-off-by: Albert ARIBAUD <albert.u.boot@aribaud.net>
2013-04-14ARM: fix CONFIG_SPL_MAX_SIZE semanticsAlbert ARIBAUD
Remove SPL-related ASSERT() in arch/arm/cpu/u-boot.lds as this file is never used for SPL builds. Rewrite the ASSERT() in arch/arm/cpu/u-boot-spl.lds to separately test image (text,data,rodata...) size, BSS size, and full footprint each against its own max, and make Tegra boards check full footprint. Also, output section mmutable is not used in SPL builds. Remove it. Finally, update README regarding the (now homogeneous) semantics of CONFIG_SPL_[BSS_]MAX_SIZE and add the new CONFIG_SPL_MAX_FOOTPRINT macro. Signed-off-by: Albert ARIBAUD <albert.u.boot@aribaud.net> Reported-by: Benoît Thébaudeau <benoit.thebaudeau@advansee.com>
2013-04-12Merge branch 'u-boot/master' into 'u-boot-arm/master'Albert ARIBAUD
Conflicts: drivers/video/exynos_fb.c
2013-04-12Makefile: Change CONFIG_SPL_PAD_TO to image offsetBenoît Thébaudeau
Change CONFIG_SPL_PAD_TO from a link address to an image offset since this is more handy and closer to the purpose of this config. Automatically define CONFIG_SPL_PAD_TO to CONFIG_SPL_MAX_SIZE (or 0 without CONFIG_SPL_MAX_SIZE). Test that CONFIG_SPL_PAD_TO >= CONFIG_SPL_MAX_SIZE if CONFIG_SPL_PAD_TO is non-zero. Signed-off-by: Benoît Thébaudeau <benoit.thebaudeau@advansee.com>
2013-04-12mtd: nand: mxc_nand: Fix is_16bit_nand()Fabio Estevam
Currently is_16bit_nand() is a per SoC function and it decides the bus nand width by reading some boot related registers. This method works when NAND is the boot medium, but does not work if another boot medium is used. For example: booting from a SD card and then using NAND to store the environment variables, would lead to the following error: NAND bus width 16 instead 8 bit No NAND device found!!! 0 MiB Use CONFIG_SYS_NAND_BUSWIDTH_16BIT symbol to decide the bus width. If it is defined in the board file, then consider 16-bit NAND bus-width, otherwise assume 8-bit NAND is used. This also aligns with Documentation/devicetree/bindings/mtd/nand.txt, which states: nand-bus-width : 8 or 16 bus width if not present 8 Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com> Acked-by: Scott Wood <scottwood@freescale.com> Reviewed-by: Benoît Thébaudeau <benoit.thebaudeau@advansee.com>
2013-04-12mtd: nand: Introduce CONFIG_SYS_NAND_BUSWIDTH_16BITFabio Estevam
Introduce CONFIG_SYS_NAND_BUSWIDTH_16BIT option so that other NAND controller drivers could use it when a 16-bit NAND is deployed. drivers/mtd/nand/ndfc has CONFIG_SYS_NDFC_16BIT, so just rename it, so that other NAND drivers could reuse the same symbol. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com> Acked-by: Scott Wood <scottwood@freescale.com> Reviewed-by: Benoît Thébaudeau <benoit.thebaudeau@advansee.com>
2013-04-11env: Add redundant env support to UBI envJoe Hershberger
Allow the user to specify two UBI volumes to use for the environment Signed-off-by: Joe Hershberger <joe.hershberger@ni.com>
2013-04-11env: Add support for UBI environmentJoe Hershberger
UBI is a better place for the environment on NAND devices because it handles wear-leveling and bad blocks. Gluebi is needed in Linux to access the env as an MTD partition. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com>
2013-04-11ubi: ubifs: Turn off verbose printsJoe Hershberger
The prints are out of control. SILENCE! Signed-off-by: Joe Hershberger <joe.hershberger@ni.com>
2013-04-11ubi: ubifs: Add documentation for READMEJoe Hershberger
Describe the needed CONFIG tokens to enable UBI and UBIFS support. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com>
2013-04-10dfu: NAND specific routines for DFU operationPantelis Antoniou
Support for NAND storage devices to work with the DFU framework. Signed-off-by: Pantelis Antoniou <panto@antoniou-consulting.com> Signed-off-by: Tom Rini <trini@ti.com> Acked-by: Scott Wood <scottwood@freescale.com>
2013-04-10dfu: Support larger than memory transfers.Pantelis Antoniou
Previously we didn't support upload/download larger than available memory. This is pretty bad when you have to update your root filesystem for example. This patch removes that limitation (and the crashes when you transfered any file larger than 4MB) by making raw image writes be done in chunks and making file maximum size be configurable. The sequence number is a 16 bit counter; make sure we handle rollover correctly. This fixes the wrong transfers for large (> 256MB) images. Also utilize a variable to handle initialization, so that we don't rely on just the counter sent by the host. Signed-off-by: Pantelis Antoniou <panto@antoniou-consulting.com> Signed-off-by: Tom Rini <trini@ti.com>
