path: root/README
2003-06-15* Fix CONFIG_NET_MULTI support in include/net.hLABEL_2003_06_16_0055wdenk
* Patches by Kyle Harris, 13 Mar 2003: - Add FAT partition support - Add command support for FAT - Add command support for MMC ---- - Add Intel PXA support for video - Add Intel PXA support for MMC ---- - Enable MMC and FAT for lubbock board - Other misc changes for lubbock board
2003-06-05- CFG_RX_ETH_BUFFER added.stroese
2003-06-03* Patches by Udi Finkelstein, 2 June 2003:LABEL_2003_06_04_0200wdenk
- Added support for custom keyboards, initialized by defining a board-specific drv_keyboard_init as well as defining CONFIG_KEYBOARD . - Added support for the RBC823 board. - cpu/mpc8xx/lcd.c now automatically calculates the Horizontal Pixel Count field. * Fix alignment problem in BOOTP (dhcp_leasetime option) [pointed out by Nicolas Lacressonnière, 2 Jun 2003] * Patch by Mark Rakes, 14 May 2003: add support for Intel e1000 gig cards. * Patch by Nye Liu, 3 Jun 2003: fix critical typo in MAMR definition (include/mpc8xx.h) * Fix requirement to align U-Boot image on 16 kB boundaries on PPC. * Patch by Klaus Heydeck, 2 Jun 2003 Minor changes for KUP4K configuration
2003-05-28* Fix data abort exception handling for arm920t CPUwdenk
* Fix alignment problems with flash driver for TRAB board * Patch by Donald White, 21 May 2003: fix calculation of base address in pci_hose_config_device() * Fix bug in command line parsing: "cmd1;cmd2" is supposed to always execute "cmd2", even if "cmd1" fails. Note that this is different to "run var1 var2" where the contents of "var2" will NOT be executed when a command in "var1" fails.
2003-05-23Add zero-copy ramdisk support (requires corresponding kernel support!)wdenk
2003-05-23CONFIG_UART1_CONSOLE added.stroese
2003-05-22* Patch by Dave Ellis, 22 May 2003:LABEL_2003_05_23_0055wdenk
Fix problem with only partially cleared .bss segment * Patch by Rune Torgersen, 12 May 2003: get PCI to work on a MPC8266ADS board; incorporate change to cpu/mpc8260/pci.c to enable overrides of PCI memory parameters
2003-05-20* Patch by David Updegraff, 22 Apr 2003:LABEL_2003_05_20_1630wdenk
update for CrayL1 board * Patch by Pantelis Antoniou, 21 Apr 2003: add boot support for ARTOS (a proprietary OS) * Patch by Steven Scholz, 11 Apr 2003: Add support for RTC DS1338 * Patch by Rod Boyce, 24 Jan 2003: Fix counting of extended partitions in diskboot command
2003-05-12Patch by Mathijs Haarman, 08 May 2003:LABEL_2003_05_12_2355wdenk
Add lan91c96 driver (tested on Lubbock and custom PXA250 board only)
2003-05-03* Add support for Promess ATC boardLABEL_2003_05_03_1700wdenk
* Patch by Keith Outwater, 28 Apr 2003: - Miscellaneous corrections and additions to GEN860T board specific code. - Added GEN860_SC variant to GEN860T. - Miscellaneous corrections to GEN860T documentation. - Correct duplicate entry in U-Boot CREDITS file. - Add GEN860T_SC entry in MAINTAINERS file. - Update CREDITS file with GEN860T_SC info. * Update Smiths Aerospace addresses in MAINTAINERS file * Fix error handling in hush's version of "run" command
2003-04-20* Make sure Block Lock Bits get cleared in R360MPI flash driverwdenk
* MPC823 LCD driver: Fill color map backwards, to allow for steady display when Linux takes over * Patch by Erwin Rol, 27 Feb 2003: Add support for RTEMS (this time for real). * Add support for "bmp info" and "bmp display" commands to load bitmap images; this can be used (for example in a "preboot" command) to display a splash screen very quickly after poweron. * Add support for 133 MHz clock on INCA-IP board
2003-04-12* Patch by Lutz Dennig, 10 Apr 2003:LABEL_2003_04_15_1900wdenk
Update for R360MPI board * Add new meaning to "autostart" environment variable: If set to "no", a standalone image passed to the "bootm" command will be copied to the load address (and eventually uncompressed), but NOT be started. This can be used to load and uncompress arbitrary data. * Set max brightness for MN11236 displays on TRAB board
2003-04-05* Patch by Arun Dharankar, 4 Apr 2003:LABEL_2003_04_05_0300wdenk
Add IDMA example code (tested on 8260 only) * Add support for Purple Board (MIPS64 5Kc) * Add support for MIPS64 5Kc CPUs * Fix missing setting of "loadaddr" and "bootfile" on ARM and MIPS * Patch by Denis Peter, 04 Apr 2003: - update MIP405-4 board * Patches by Denis Peter, 03 April 2003: - fix PCI IRQs on MPL boards - fix two more un-relocated pointer problems * Fix behaviour of "run" command: - print error message iv variable does not exist - terminate processing of arguments in case of error * Patches by Peter Figuli, 10 Mar 2003 - Add support for BTUART on PXA platform - Add support for WEP EP250 (PXA) board * Fix flash problems on INCA-IP; add tool to allow bruning images to flash using a BDI2000 * Implement fix for I2C Edge Conditions problem for all boards that use the bit-banging driver (common/soft_i2c.c) * Add patches by Robert Schwebel, 31 Mar 2003: - csb226 board: bring in sync with innokom/memsetup.S - csb226 board: fix MDREFR handling - misc doc fixes / extensions - innokom board: cleanup, MDREFR fix in memsetup.S, config update - add BOOT_PROGRESS to armlinux.c
2003-04-04U-Boot version environment variable "ver" added (CONFIG_VERSION_VARIABLE).stroese
2003-03-31* Patch by Martin Winistoerfer, 23 Mar 2003wdenk
- Add port to MPC555/556 microcontrollers - Add support for cmi customer board with Intel 28F128J3A, 28F320J3A or 28F640J3A flash. * Patch by Rick Bronson, 28 Mar 2003: - fix common/cmd_nand.c
2003-03-31* Patch by Arun Dharankar, 24 Mar 2003:wdenk
- add threads / scheduler example code * Add patches by Robert Schwebel, 31 Mar 2003: - add ctrl-c support for kermit download - align bdinfo output on ARM * Add CPU ID, version, and clock speed for INCA-IP
2003-03-26* Patch by Rick Bronson, 16 Mar 2003:wdenk
Add support for Atmel AT91RM9200DK w/NAND * Patches by Robert Schwebel, 19 Mar 2003: - use arm-linux-gcc as default compiler for ARM - fix i2c fixup code - fix missing baudrate setting - added $loadaddr / CFG_LOAD_ADDR support to loadb - moved "ignoring trailing characters" _before_ u-boot wants to print out diagnostics messages; removes bogus characters at the end of transmission * Patch by John Zhan, 18 Mar 2003: Add support for SinoVee Microsystems SC8xx boards * Patch by Rolf Offermanns, 21 Mar 2003: ported the dnp1110 related changes from the current armboot cvs to current u-boot cvs. smc91111 does not work. problem marked in smc91111.c, grep for "FIXME". * Patch by Brian Auld, 25 Mar 2003: Add support for STM flash chips on ebony board * Add PCI support for MPC8250 Boards (PM825 module) * Patch by Stefan Roese, 25 Mar 2003:
2003-03-06* Patches by David Müller, 31 Jan 2003:LABEL_2003_03_06_2255wdenk
- minimal setup for CardBus bridges - add EEPROM read/write support in the CS8900 driver - add support for the builtin I2C controller in the Samsung s3c24x0 chips - add support for MPL's VCMA9 (Samsung s3c2410 based) board * Patch by Steven Scholz, 04 Feb 2003: add support for RTC DS1307 * Patch by Reinhard Meyer, 5 Feb 2003: fix PLPRCR/SCCR init sequence on 8xx to allow for changes of EBDF by software * Patch by Vladimir Gurevich, 07 Feb 2003: "API-compatibility patch" for 4xx I2C driver
2003-03-06* Patches by Robert Schwebel, 06 Mar 2003:wdenk
- fix bug in BOOTP code (must use NetCopyIP) - update of CSB226 port - clear BSS segment on XScale - added support for i2c_init_board() function - update to the Innokom plattform * Extend support for redundand environments for configurations where environment size < sector size
2003-03-06* Patch by Robert Schwebel, 21 Jan 2003:LABEL_2003_03_06_0050wdenk
- Add support for Innokom board - Don't complain if "install" fails - README cleanup (remove duplicated lines) - Update PXA header files * Add documentation for existing POST code (doc/README.POST) * Patch by Laudney Ren, 15 Jan 2003: Fix handling of redundand environment in "tools/envcrc.c" * Patch by Detlev Zundel, 28 Feb 2003: Add bedbug support for 824x systems * Add support for 16 MB flash configuration of TRAB board * Patch by Erwin Rol, 27 Feb 2003: Add support for RTEMS * Add image information to README * Fix dual PCMCIA slot support (when running with just one slot populated) * Add VFD type detection to trab board * extend drivers/cs8900.c driver to synchronize ethaddr environment variable with value in the EEPROM
2003-02-28* Add support for 16 MB flash configuration of TRAB boardLABEL_2003_02_28_0150wdenk
* Patch by Erwin Rol, 27 Feb 2003: Add support for RTEMS * Add image information to README * Fix dual PCMCIA slot support (when running with just one slot populated) * Add VFD type detection to trab board * extend drivers/cs8900.c driver to synchronize ethaddr environment variable with value in the EEPROM * Start adding MIPS support files
2003-01-13Add support for V37 boardLABEL_2003_01_14_0055wdenk
(patch by Jón Benediktsson, 11 Dec 2002)
2002-12-17Prepare for release of version 0.2.0wdenk
2002-12-17* Use 1-byte-read instead of -write for iprobe() functionwdenk
Add i2c commands to PM826 config * extend I2C POST code: check for list on known addresses
2002-12-03* Fix startup problems with VFD display on TRABLABEL_2002_12_03_2230wdenk
* Patch by Pierre Aubert, 20 Nov 2002 Add driver for Epson SED13806 graphic controller. Add support for BMP logos in cfb_console driver.
2002-11-21* Added support for both PCMCIA slots (at the same time!) on MPC8xxLABEL_2002_11_22_0015wdenk
* Patch by Rod Boyce, 21 Nov 2002: fix PCMCIA on MBX8xx board * Patch by Pierre Aubert , 21 Nov 2002 Add CFG_CPM_POST_WORD_ADDR to make the offset of the bootmode word in DPRAM configurable
2002-11-18* Patch by Daniel Engström, 13 Nov 2002:LABEL_2002_11_18_0115wdenk
Add support for i386 architecture and AMD SC520 board * Patch by Pierre Aubert, 12 Nov 2002: Add support for DOS filesystem and booting from DOS floppy disk
2002-11-10* Vince Husovsky, 7 Nov 2002:LABEL_2002_11_10_2310wdenk
Add "-n" to linker options to get rid of "Not enough room for program headers" problem * Patch by David Müller, 05 Nov 2002 Rename CONFIG_PLL_INPUT_FREQ to CONFIG_SYS_CLK_FREQ so we can use an already existing name * Patch by Pierre Aubert, 05 Nov 2002 Hardware related improvements in FDC boot code * Patch by Holger Schurig, 5 Nov 2002: Make the PXA really change it's frequency * Patch by Pierre Aubert, 05 Nov 2002 Add support for slave serial Spartan 2 FPGAs * Fix uninitialized memory (MAC address) in 8xx SCC/FEC ethernet drivers
2002-11-05* Patch by Robert Schwebel, 04 Nov 2002:LABEL_2002_11_05_0120wdenk
- use watchdog to reset PXA250 systems - added progress callbacks to (some of the) ARM code - update for Cogent CSB226 board * Add support for FPS860 board
2002-11-03* Fix mdelay() on TRAB - this was still the debugging version withwdenk
seconds instead of ms. * Patch by Robert Schwebel, 1 Nov 2002: XScale related cleanup (affects all ARM boards) * Cleanup of names, warnings, and README.
