common/cmd_bootm.c
cpu/mpc8xx/cpu.c
Signed-off-by: Bartlomiej Sieka <tur@semihalf.com>
Signed-off-by: Gerald Van Baren <vanbaren@cideas.com>
Signed-off-by: Tor Krill <tor@excito.com>
Create doc/uImage.FIT documentation directory with the following files:
- command_syntax_extensions.txt : extended command syntax description
- howto.txt : short usage howto
- source_file_format.txt : internal new uImage format description
Add example image source files:
- kernel.its
- kernel_fdt.its
- multi.its
Update README appropriately.
Signed-off-by: Marian Balakowicz <m8@semihalf.com>
Save FIT configuration provied in the first bootm argument and use it
when to get ramdisk/FDT subimages when second and third (ramdisk/FDT)
arguments are not specified.
This patch allocates a set of show_boot_progress() IDs for new uImage format
and adds show_boot_progress() calls in new uImage format handling code.
Makefile
doc/README.standalone
R29 was an unlucky choice as with recent toolchains (gcc-4.2.x) gcc
will refuse to use load/store multiple insns; instead, it issues a
list of simple load/store instructions upon function entry and exit,
resulting in bigger code size, which in turn makes the build for a
few boards fail.
Use r2 instead.
allow to load the microde from flash or ram by download it through
the serial or other.
Signed-off-by: TsiChungLiew <Tsi-Chung.Liew@freescale.com>
Signed-off by: John Rigby <jrigby@freescale.com>
This patch adds support for the SPI controller found on Freescale PowerPC
processors such as the MCP834x family. Additionally, a new config option,
CONFIG_HARD_SPI, is added for general purpose SPI controller use.
[PATCH] net: add 'ethrotate' environment variable
This patch replaces the buildtime configuration option
CONFIG_NET_DO_NOT_TRY_ANOTHER through the 'ethrotate' runtime
configuration veriable. See README.
Signed-off-by: Matthias Fuchs <matthias.fuchs@esd-electronics.com>
Signed-off-by: Marcel Ziswiler <marcel@ziswiler.com>
This patch removes the FPGA subsystem configuration through
the CONFIG_FPGA bitmask configuration option.
See README for the new options:
CONFIG_FPGA,
CONFIG_FPGA_<vendor>,
CONFIG_FPGA_<family>
As noted by Kim Phillips, these lists tend to become out of date.
Signed-off-by: Haavard Skinnemoen <hskinnemoen@atmel.com>
Changed the wording to properly describe the shadowing
of the environment from ROM to RAM
Signed-off-by: Bruce Adler <bruce.adler@acm.org>
and make some minor corrections to the FDT part of the README.
Implemented IETF RFC2090, Multicast TFTP. Initial implementation
on Realtek RTL8139 and Freescale TSEC.
Signed-off-by: David Updegraff <dave@cray.com>
Signed-off-by: Ben Warren <bwarren@qstreams.com>
Added CONFIG_BOOTP_SERVERIP to allow the tftp server to be different
from the bootp server
Signed-off-by: Wilson Callan <wcallan@savantav.com>
CHANGELOG
fs/fat/fat.c
include/configs/MPC8560ADS.h
include/configs/pcs440ep.h
net/eth.c
All of the choices for CONFIG_BOOTP_ are now documented in
the README file. You must now individually select exactly
the set that you want using a series of
#define CONFIG_BOOTP_<x>
statements in the board port config files now.
- Show on the Status LEDs, some States of the board.
- Get the MAC addresses from the EEProm
- use PREBOOT
- use the CF on the board.
- check the U-Boot image in the Flash with a SHA1
checksum.
- use dynamic TLB entries generation for the SDRAM
Added board/freescale/m5329evb, cpu/mcf532x, drivers/net,
drivers/serial, immap_5329.h, m5329.h, mcfrtc.h,
include/configs/M5329EVB.h, lib_m68k/interrupts.c, and
rtc/mcfrtc.c
Modified CREDITS, MAKEFILE, Makefile, README, common/cmd_bdinfo.c,
common/cmd_mii.c, include/asm-m68k/byteorder.h, include/asm-m68k/fec.h,
include/asm-m68k/io.h, include/asm-m68k/mcftimer.h,
include/asm-m68k/mcfuart.h, include/asm-m68k/ptrace.h,
include/asm-m68k/u-boot.h, lib_m68k/Makefile, lib_m68k/board.c,
lib_m68k/time.c, net/eth.c and rtc/Makefile
Signed-off-by: TsiChung Liew <Tsi-Chung.Liew@freescale.com>
This patch adds USB event poll support, which could be used in usbkbd
and other usb devices driver when the asynchronous interrupt
processing is supported.
Signed-off-by: Zhang Wei <wei.zhang@freescale.com
include/asm-microblaze/microblaze_intc.h
include/linux/stat.h
Modifications to the existing code to support the new fdt command.
Signed-off-by: Rodolfo Giometti <giometti@linux.it>
drivers/Makefile
Fix the merge conflict in file drivers/Makefile
Signed-off-by: Roy Zang <tie-fei.zang@freescale.com>
This patch switches to the desired I2C bus when the date/dtt
commands are called. This can be configured using the
CFG_RTC_BUS_NUM and/or CFG_DTT_BUS_NUM defines.
The conflicts due to a new mpc7448 p3m7448 board is in the main tree.
Merge branch 'master' into hpc2
MAKEALL
cpu/74xx_7xx/cpu.c
cpu/74xx_7xx/cpu_init.c
cpu/74xx_7xx/speed.c
