path: root/Makefile
2009-10-24Merge branch 'master-sync' of git://git.denx.de/u-boot-armWolfgang Denk
2009-10-24TI OMAP3 SDP3430: Initial SupportTom Rix
Start of support of Texas Instruments Software Development Platform(SDP) for OMAP3430 - SDP3430 Highlights of this platform are: Flash Memory devices: Sibley NOR, Micron 8bit NAND and OneNAND Connectivity: 3 UARTs and expanded 4 UART ports + IrDA Ethernet, USB Other peripherals: TWL5030 PMIC+Audio+Keypad VGA display Expansion ports: Memory devices plugin boards (PISMO) Connectivity board for GPS,WLAN etc. Completely configurable boot sequence and device mapping etc. Support default jumpering and: - UART1/ttyS0 console(legacy sdp3430 u-boot) - UART3/ttyS2 console (matching other boards, and SDP HW docs) - Ethernet - mmc0 - NOR boot Currently the UART1 is enabled by default. for compatibility with other OMAP3 u-boot platforms, enable the #define of CONSOLE_J9. Conflicts: Makefile Fixed the conflict with smdkc100_config by moving omap_sdp3430_config to it is alphabetically sorted location above zoom1. Signed-off-by: David Brownell <david-b@pacbell.net> Signed-off-by: Nishanth Menon <nm@ti.com> Signed-off-by: Tom Rix <Tom.Rix@windriver.com>
2009-10-18TI: DaVinci: DM355 Leopard board supportSandeep Paulraj
This patch adds support for the leopard board which is based on the DM355 SOC. Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2009-10-18TI DaVinci DM646x: Adding initial support for DM6467 EVMSandeep Paulraj
This patch adds the initial support for DM6467 EVM. Other features like NET and NAND support will be added as follow up patches. Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2009-10-18new default shortcut to config & build a boardMike Frysinger
The majority of the time that I build things in U-Boot, I want to just build for the board. I don't make board config tweaks after selecting the board. So add a new pattern rule that allows people to combine two steps in one go: `make foo_config && make` => `make foo` This shouldn't conflict with any existing make rules as the pattern rule is used only the rule doesn't already exist. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2009-10-16ppc/P1_P2_RDB: On-chip BootROM supportDipen Dudhat
On Chip BootROM support for P1 and P2 series RDB platforms. This patch is derived from latest On Chip BootROM support on MPC8536DS Signed-off-by: Dipen Dudhat <dipen.dudhat@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2009-10-16ppc/P1_P2_RDB: NAND Boot SupportDipen Dudhat
NAND Boot support for P1 and P2 series RDB platforms. This patch is derived from NAND Boot support on MPC8536DS. Signed-off-by: Dipen Dudhat <dipen.dudhat@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2009-10-13s5pc1xx: add support SMDKC100 boardMinkyu Kang
Adds new board SMDKC100 that uses s5pc100 SoC Signed-off-by: Minkyu Kang <mk7.kang@samsung.com> Signed-off-by: HeungJun, Kim <riverful.kim@samsung.com>
2009-10-13Support for the OpenRD base boardSimon Kagstrom
The implementation is borrowed from the sheevaplug board and the Marvell 1.1.4 code. Unsupported (or untested) is the SD card, PCIe and SATA. Signed-off-by: Simon Kagstrom <simon.kagstrom@netinsight.net>
2009-10-13Add support for Eukrea CPU9260/CPU9G20 SBCTom Rix
these boards are built around Atmel's AT91SAM9260/9G20 and have up to 64MB of NOR flash, up to 128MB of SDRAM, up to 2GB of NAND and include a 10/100 Ethernet PHY in RMII mode. Signed-off-by: Eric Benard <eric@eukrea.com> Signed-off-by: Tom Rix <Tom.Rix@windriver.com>
2009-10-13Add support for Eukrea CPUAT91 SBCTom Rix
CPUAT91 is built around Atmel's AT91RM9200 and has up to 16MB of NOR flash, up to 128MB of SDRAM, and includes a Micrel KS8721 PHY in RMII mode. Signed-off-by: Eric Benard <eric@eukrea.com> Signed-off-by: Tom Rix <Tom.Rix@windriver.com>
2009-09-30Merge branch 'master' of git://git.denx.de/u-boot-mpc85xxWolfgang Denk
2009-09-30Merge branch 'master' of git://git.denx.de/u-boot-nand-flashWolfgang Denk
2009-09-30On-chip ROM boot: MPC8536DS supportMingkai Hu
The MPC8536E is capable of booting from the on-chip ROM - boot from eSDHC and boot from eSPI. When power on, the porcessor excutes the ROM code to initialize the eSPI/eSDHC controller, and loads the mian U-Boot image from the memory device that interfaced to the controller, such as the SDCard or SPI EEPROM, to the target memory, e.g. SDRAM or L2SRAM, then boot from it. The memory device should contain a specific data structure with control word and config word at the fixed address. The config word direct the process how to config the memory device, and the control word direct the processor where to find the image on the memory device, or where copy the main image to. The user can use any method to store the data structure to the memory device, only if store it on the assigned address. The on-chip ROM code will map the whole 4GB address space by setting entry0 in the TLB1, so the main image need to switch to Address space 1 to disable this mapping and map the address space again. This patch implements loading the mian U-Boot image into L2SRAM, so the image can configure the system memory by using SPD EEPROM. Signed-off-by: Mingkai Hu <Mingkai.hu@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2009-09-30NAND boot: MPC8536DS supportMingkai Hu
MPC8536E can support booting from NAND flash which uses the image u-boot-nand.bin. This image contains two parts: a 4K NAND loader and a main U-Boot image. The former is appended to the latter to produce u-boot-nand.bin. The 4K NAND loader includes the corresponding nand_spl directory, along with the code twisted by CONFIG_NAND_SPL. The main U-Boot image just like a general U-Boot image except the parts that included by CONFIG_SYS_RAMBOOT. When power on, eLBC will automatically load from bank 0 the 4K NAND loader into the FCM buffer RAM where CPU can execute the boot code directly. In the first stage, the NAND loader copies itself to RAM or L2SRAM to free up the FCM buffer RAM, then loads the main image from NAND flash to RAM or L2SRAM and boot from it. This patch implements the NAND loader to load the main image into L2SRAM, so the main image can configure the RAM by using SPD EEPROM. In the first stage, the NAND loader copies itself to the second to last 4K address space, and uses the last 4K address space as the initial RAM for stack. Obviously, the size of L2SRAM shouldn't be less than the size of the image used. If so, the workaround is to generate another image that includes the code to configure the RAM by SPD and load it to L2SRAM first, then relocate the main image to RAM to boot up. Signed-off-by: Mingkai Hu <Mingkai.hu@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2009-09-28Refactor OneNAND IPL codeKyungmin Park
Refactoring the OneNAND IPL code and some minor fixed: - Remove unnecessary header file - Fix wrong access at read interrupt - The recent OneNAND has 4KiB pagesize Also Board can override OneNAND IPL image Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com>
2009-09-25sbc8349: tidy up Makefile to use new configuration script.Paul Gortmaker
Commit 804d83a5 allows us to move all the configuration variation tweaks out of the top level Makefile and down into the board config header. This takes advantage of that for the sbc8349 board. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com> Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2009-09-24sbc85x0: tidy up Makefile to use new configuration script.Paul Gortmaker
Commit 804d83a5 allows us to move all the configuration variation tweaks out of the top level Makefile and down into the boards config header. This takes advantage of that for the sbc8540/sbc8560 boards. There were a couple of cheezy comments pointing at incorrect files, or files that don't exist, so I've cleaned those up too. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2009-09-24sbc8548: allow enabling PCI via a make config optionPaul Gortmaker
Prior to this commit, to enable PCI, you had to go manually edit the board config header, and if you had 33MHz PCI, you had to manually change CONFIG_SYS_NS16550_CLK too, which was not real user friendly, This adds the typical PCI and clock speed make targets to the toplevel Makefile in accordance with what is being done with other boards (i.e. using the "-t" to mkconfig). Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2009-09-24ppc/85xx: Simplify the top makefile for P1_P2_RDB boardsKumar Gala
2009-09-24ppc/85xx: Simplify the top makefile for 36-bit config for P2020DSKumar Gala
2009-09-24ppc/85xx: Simplify the top makefile for 36-bit config for MPC8572DSKumar Gala
2009-09-24ppc/85xx: simplify the top makefile for 36-bit config for mpc8536dsMingkai Hu
2009-09-15Merge branch 'master' of git://git.denx.de/u-boot-microblazeWolfgang Denk
2009-09-14microblaze: Remove AtmarkTechno Suzaku boardMichal Simek
Users should use microblaze-generic platform. This platform is longer not supported. Signed-off-by: Michal Simek <monstr@monstr.eu>
2009-09-11ppc4xx: Rename compactcenter to intipDirk Eibach
Signed-off-by: Dirk Eibach <eibach@gdsys.de> Signed-off-by: Stefan Roese <sr@denx.de>
2009-09-10mkimage: Add Kirkwood Boot Image support (kwbimage)Prafulla Wadaskar
This patch adds support for "kwbimage" (Kirkwood Boot Image) image types to the mkimage code. For details refer to docs/README.kwbimage This patch is tested with Sheevaplug board Signed-off-by: Prafulla Wadaskar <prafulla@marvell.com> Acked-by: Ron Lee <ron@debian.org> Signed-off-by: Prafulla Wadaskar <prafulla@marvell.com>
2009-09-10Remove "atmel_df_pow2" binary with "make clean"Wolfgang Denk
Commit 65f6f07b added support for the atmel_df_pow2 standalone program but missed to add a rule to remove it to the "clean" make target. Signed-off-by: Wolfgang Denk <wd@denx.de>
2009-09-07Merge branch 'master' of git://git.denx.de/u-boot-armWolfgang Denk
2009-09-05ARM: DaVinci: Adding Support for DaVinci DM365 EVMSandeep Paulraj
This patch adds support for the DM365 EVM. It has been tested on a DM365 EVM. Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2009-09-05Add support for the DevKit8000 boardFrederik Kriewitz
This patch adds support for the DevKit8000 board. Signed-off-by: Frederik Kriewitz <frederik@kriewitz.eu>
2009-09-05omap3: move the other boards to board/Jean-Christophe PLAGNIOL-VILLARD
2009-09-05arm: move Logicpd's boards to board/logicpd/Jean-Christophe PLAGNIOL-VILLARD
2009-09-05omap: move TI's boards to board/ti/Jean-Christophe PLAGNIOL-VILLARD
2009-09-02Blackfin: cm-bf537u: new board portHarald Krapfenbauer
The CM-BF537U is similar to the CM-BF537E module, but enough to need its own board port. Signed-off-by: Harald Krapfenbauer <Harald.Krapfenbauer@bluetechnix.at> Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2009-09-01Support for the Calao TNY-A9260/TNY-A9G20 boardsAlbin Tonnerre
The Calao TNY-A9260 and TNY-9G20 are boards manufactured and sold by Calao Systems <http://www.calao-systems.com>. Their components are very similar to the AT91SAM9260EK board, so their configuration is based on the configuration of this board. There are however some differences: different clocks, no LCD, no ethernet. They also can use SPI EEPROM to store the environment. Signed-off-by: Albin Tonnerre <albin.tonnerre@free-electrons.com> Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2009-09-01Add support for the Calao SBC35-A9G20 boardAlbin Tonnerre
The Calao SBC35-A9G20 board is manufactured and sold by Calao Systems <http://www.calao-systems.com>. It is built around an AT91SAM9G20 ARM SoC running at 400MHz. It features an Ethernet port, an SPI RTC backed by an onboard battery , an SD/MMC slot, a CompactFlash slot, 64Mo of SDRAM, 256Mo of NAND flash, two USB host ports, and an USB device port. More informations can be found at <http://www.calao-systems.com/articles.php?lng=en&pg=5936> Signed-off-by: Albin Tonnerre <albin.tonnerre@free-electrons.com>
2009-09-01imx27lite: add support for imx27lite board from LogicPDIlya Yanok
This patch adds support for i.MX27-LITEKIT development board from LogicPD. This board uses i.MX27 SoC and has 2MB NOR flash, 64MB NAND flash, FEC ethernet controller integrated into i.MX27. Signed-off-by: Ilya Yanok <yanok@emcraft.com> Acked-by: Wolfgang Denk <wd@denx.de>
2009-08-31Merge branch 'next' of ../nextWolfgang Denk
2009-08-31Prepare 2009.08v2009.08Wolfgang Denk
Update CHANGELOG Signed-off-by: Wolfgang Denk <wd@denx.de>
2009-08-2885xx: Added support for P1011RDB and P2010RDBPoonam Aggrwal
P1011 and P2010 are single core variants of P1010 and P2020 respectively. The board(RDB) will be same. Signed-off-by: Poonam Aggrwal <poonam.aggrwal@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2009-08-2885xx: P1020RDB Support AddedPoonam Aggrwal
2009-08-2885xx: Add support for P2020RDB boardPoonam Aggrwal
The code base adds P1 & P2 RDB platforms support. The folder and file names can cater to future SOCs of P1/P2 family. P1 & P2 processors are 85xx platforms, part of Freescale QorIQ series. Tested following on P2020RDB: 1. eTSECs 2. DDR, NAND, NOR, I2C. Signed-off-by: Poonam Aggrwal <poonam.aggrwal@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2009-08-288xxx: Refactored common cpu specific code for 85xx/86xx into one file.Poonam Aggrwal
Removed same code pieces from cpu/mpc85xx/cpu.c and cpu/mpc86xx/cpu.c and moved to cpu/mpc8xxx/cpu.c(new file) Signed-off-by: Poonam Aggrwal <poonam.aggrwal@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2009-08-28stx: create common vendor/board hierarchy for STx boardsAlex Dubov
Move files belonging to the STx boards into common vendor directory and update the Makefile to reflect this. Signed-off-by: Alex Dubov <oakad@yahoo.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2009-08-2885xx: Add a 36-bit physical configuration for MPC8536DSKumar Gala
We move all IO addressed (CCSR, localbus, PCI) above the 4G boundary to allow for larger memory sizes. Signed-off-by: Kumar Gala <galak@kernel.crashing.org> Acked-by: Wolfgang Denk <wd@denx.de> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2009-08-25Add support for the galaxy5200Eric Millbrandt
Add support for the DEKA Research and Development galaxy5200 board The galaxy5200 is an Freescale mpc5200 based embedded industrial control board. Signed-off-by: Eric Millbrandt <emillbrandt@dekaresearch.com>
2009-08-23start a linker script helper fileMike Frysinger
Start a common header file for common linker script code (such as workarounds for older linkers) rather than doing this in the build system. As fallout, we no longer execute the linker every time config.mk is included by a build file (which can easily be 70+ times), but rather only execute it once. This also fixes a bug in the major version checking by creating a macro to easily compare versions and keep people from making the same common mistake (forgetting to check major and minor together). Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2009-08-22Prepare 2009.08-rc3v2009.08-rc3Wolfgang Denk
Update CHANGELOG, minor Coding Style cleanup. Signed-off-by: Wolfgang Denk <wd@denx.de>
2009-08-21mpc83xx: sbc8349 - make enabling PCI more user friendlyPaul Gortmaker
Prior to this commit, to enable PCI, you had to go manually edit the board config header, which isn't really user friendly. This adds the typical PCI make targets to the toplevel Makefile in accordance with what is being done with other boards. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com> Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
