path: root/Makefile
2008-03-09Makefile: make build silently again.Wolfgang Denk
2008-03-09ADS5121: fix out of tree buildWolfgang Denk
and simplify Makefile a bit. Signed-off-by: Wolfgang Denk <wd@denx.de>
2008-03-08Release v1.3.2Wolfgang Denk
2008-03-04Makefile: fix problem with out-of-tree builds introduced by 5013c09fWolfgang Denk
Commit 5013c09f (Makefile: cleanup "clean" target) introduced a problem for out-of-tree builds which caused "make clean" to fail. Signed-off-by: Wolfgang Denk <wd@denx.de>
2008-03-03Makefile: Fix missing unconfig and mkconfig useJean-Christophe PLAGNIOL-VILLARD
2008-03-02Prepare v1.3.2-rc2 release candidatev1.3.2-rc3Wolfgang Denk
2008-03-02Makefile: cleanup "clean" targetWolfgang Denk
Make sure CDPATH settings cannot interfere. Update CHANGELOG. Signed-off-by: Wolfgang Denk <wd@denx.de>
2008-03-02add cscope build targetLi Yang
Add cscope build target to generate cscope database for code browsing. Signed-off-by: Li Yang <leoli@freescale.com>
2008-03-02MPC5121e ADS PCI support take 3John Rigby
Adds PCI support for MPC5121 Tested with drivers/net/rtl8139.c Support is conditional since PCI on old silicon does not work. ads5121_PCI_config turns on PCI In this version, condition compilation of PCI code has been moved from ifdef in board/ads5121/pci.c to board/ads5121/Makefile as suggested by Jean-Christophe PLAGNIOL-VILLARD Signed-off-by: John Rigby <jrigby@freescale.com>
2008-02-24Coding style cleanup. Prepare v1.3.2-rc2 release candidatev1.3.2-rc2Wolfgang Denk
2008-02-22Merge branch 'master' of git://www.denx.de/git/u-boot-coldfireWolfgang Denk
2008-02-22error check autoconf.mk generationMike Frysinger
If any of the steps for generating autoconf.mk fail currently, they go unnoticed. To fix, we can simply add 'set -e' to the long list of commands. This is simpler and more robust than placing '|| exit $$?' after every line. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2008-02-22Fix bug in dependency checkingStefano Babic
By adding VERSION_FILE to the PHONY targets the script /tools/setlocalversion is always called and version_autogenerated.h is replaced only if the script find a modified source file. Signed-off-by: Stefano Babic <sbabic@denx.de>
2008-02-22Makefile: add target for $(LDSCRIPT)Mike Frysinger
If the $(LDSCRIPT) does not exist (normally it's board/$(BOARD)/u-boot.lds), then change into the board directory and try and create it. This allows you to generate the linker script on the fly based upon board defines (like the Blackfin boards do). There should be no regressions due to this change as the normal case is to already have a u-boot.lds file. If that's the case, then there's nothing to generate, and so make will always exit. The fix here is that if the linker script does not exist, the implicit rules take over and attempt to guess how to generate the file. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2008-02-20ColdFire: Fix missing code flash size for M5485EVBTsiChungLiew
Signed-off-by: James Mahan <kmahan@freescale.com> Signed-off-by: TsiChung Liew <Tsi-Chung.Liew@freescale.com>
2008-02-15Merge branch '080202_at91rm9200dk' of git://linux-arm.org/u-boot-armdevPeter Pearse
2008-02-15Merge branch '080131_artila' of git://linux-arm.org/u-boot-armdevPeter Pearse
2008-02-15Merge branch '080116_at91cap9' of git://linux-arm.org/u-boot-armdevPeter Pearse
2008-02-15Merge branch '070524_netstar' of git://linux-arm.org/u-boot-armdevPeter Pearse
2008-02-15Prepare v1.3.2-rc1 release candidatev1.3.2-rc1Wolfgang Denk
2008-02-15Merge branch 'master' of git://www.denx.de/git/u-boot-ppc4xxWolfgang Denk
2008-02-15Merge branch 'master' of git://www.denx.de/git/u-boot-blackfinWolfgang Denk
Conflicts: Makefile doc/README.standalone Signed-off-by: Wolfgang Denk <wd@denx.de>
2008-02-14only update version header as neededMike Frysinger
Constantly rebuilding the version header will force useless relinking, so we simply need to compare the new header with the existing one before updating it. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2008-02-14OneNAND Initial Program Loader (IPL) supportKyungmin Park
This patch enables the OneNAND boot within U-Boot. Before this work, we used another OneNAND IPL called X-Loader based on open source. With this work, we can build the oneboot.bin image without other program. The build sequence is simple. First, it compiles the u-boot.bin Second, it compiles OneNAND IPL Finally, it becomes the oneboot.bin from OneNAND IPL and u-boot.bin The mechanism is similar with NAND boot except it boots from itself. Another thing is that you can only use the OneNAND IPL only to work other bootloader such as RedBoot and so on. Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com>
2008-02-14Merge branch 'for-1.3.2'Stefan Roese
2008-02-14Move AT91RM9200DK board support under board/atmelHaavard Skinnemoen
We already have a vendor subdir for Atmel, so we should use it. Signed-off-by: Haavard Skinnemoen <hskinnemoen <at> atmel.com>
2008-02-14Support for Artila M-501 starter kitTimo Tuunainen
Kimmo Leppala / Sysart and Timo Tuunainen / Sysart
2008-02-14AT91CAP9 support : move board files to Atmel vendor directory.Stelian Pop
AT91CAP9 support : move at91cap9adk board files to Atmel vendor directory. Signed-off-by: Stelian Pop <stelian@popies.net>
2008-02-14AT91CAP9 support : build integrationStelian Pop
2008-02-14Update board NetStarPeter Pearse
Signed-off-by: Ladislav Michl <ladis@linux-mips.org>
2008-02-14ppc4xx: HCU4/5. Fix make O=../xxNiklaus Giger
Signed-off-by: Niklaus Giger <niklaus.giger@netstal.com>
2008-02-14Add dependencies to avoid race conditions with parallel make.Johannes Stezenbach
Signed-off-by: Johannes Stezenbach <js@sig21.net>
2008-02-12Merge branch 'master' of /home/wd/git/u-boot/custodiansWolfgang Denk
2008-02-04generate u-boot.ldr for Blackfin targetsMike Frysinger
2008-02-04move Blackfin cpu object list to respective cpu directoriesMike Frysinger
2008-02-04add support for Blackfin symbol prefixes to examplesMike Frysinger
2008-02-04unify the Blackfin board targetsMike Frysinger
2008-02-04ARM: Board voiceblue updateLadislav Michl
2008-01-29API: Convert conditional building to the new scheme.Rafal Jaworowski
This fixes a build breakage with CONFIG_API enabled, which appeared after the recent changes in the U-Boot build system. Signed-off-by: Rafal Jaworowski <raj@semihalf.com>
2008-01-23Merge branch 'master' of git://www.denx.de/git/u-boot-ixpWolfgang Denk
2008-01-23Merge branch 'master' of git://www.denx.de/git/u-boot-mipsWolfgang Denk
2008-01-23Merge branch 'master' of git://www.denx.de/git/u-boot-avr32Wolfgang Denk
2008-01-23Merge branch 'master' of git://www.denx.de/git/u-boot-coldfireWolfgang Denk
2008-01-23Merge branch 'master' of git://www.denx.de/git/u-boot-ppc4xxWolfgang Denk
2008-01-18Merge branch 'master' of git://www.denx.de/git/u-bootShinya Kuribayashi
2008-01-18AVR32: ATNGW100 board supportHaavard Skinnemoen
Add support for the ATNGW100 Network Gateway reference design, including flash, ethernet and MMC support. Signed-off-by: Haavard Skinnemoen <hskinnemoen@atmel.com>
2008-01-18Add AcTux board supportMichael Schwingen
Hi, The patch adds 4 boards, called AcTux-1 .. AcTux-4. This patch contains the files that contain changes for multiple boards, the board-specific files follow as separate patches. Signed-off-by: Michael Schwingen <michael@schwingen.org>
2008-01-17ColdFire: MCF547x_8x - Add M5475EVB and M5485EVB supportTsiChungLiew
Signed-off-by: TsiChungLiew <Tsi-Chung.Liew@freescale.com> Signed-off by: John Rigby <jrigby@freescale.com>
2008-01-17ColdFire: Add MCF5227x cpu and M52277EVB support-1TsiChungLiew
2008-01-17ColdFire: Add M5373EVB platform support - 2TsiChungLiew
