path: root/Makefile
2008-04-25Merge branch 'master' of /home/wd/git/u-boot/lwmon5Wolfgang Denk
Conflicts: common/cmd_bootm.c common/cmd_log.c include/common.h post/board/lwmon5/Makefile post/board/lwmon5/dsp.c post/board/lwmon5/dspic.c post/board/lwmon5/fpga.c post/board/lwmon5/gdc.c post/board/lwmon5/sysmon.c post/board/lwmon5/watchdog.c Signed-off-by: Wolfgang Denk <wd@denx.de>
2008-04-24crc32: use uint32_t rather than unsigned longMike Frysinger
The envcrc.c does sizeof(unsigned long) when calculating the crc, but this is done with the build toolchain instead of the target tool chain, so if the build is a 64bit system but the target is 32bits, the size will obviously be wrong. This converts all unsigned long stuff related to crc32 to uint32_t types. Compile tested only: output of ./tools/envcrc when run on a 32bit build system matches that of a 64bit build system. Signed-off-by: Mike Frysinger <vapier@gentoo.org> Acked-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2008-04-22Merge branch 'master' of git://www.denx.de/git/u-boot-ppc4xxWolfgang Denk
2008-04-22POST: move CONFIG_POST to MakefilesYuri Tikhonov
Introduce the new logical option CONFIG_HAS_POST which is set when the platform has CONFIG_POST set. Use CONFIG_HAS_POST in the post/ Makefiles to determine should the POST libs be compiled for the selected target platform, or not. To avoid breaking u-boot linking process, the empty post/libpost.a file is created for platforms which do not have POSTs. Signed-off-by: Yuri Tikhonov <yur@emcraft.com> Signed-off-by: Wolfgang Denk <wd@denx.de>
2008-04-20Makefile: remove nand_spl/System.map when cleaning up.Wolfgang Denk
2008-04-18Support for the MX31ADS evaluation board from FreescaleGuennadi Liakhovetski
This patch adds support for the MX31ADS evaluation board from Freescale, initialization code is copied from RedBoot sources, also provided by Freescale. Signed-off-by: Guennadi Liakhovetski <lg@denx.de>
2008-04-18ppc4xx: Add Glacier NAND booting targetStefan Roese
2008-04-18Reorder ARM boards in MakefileUlf Samuelsson
Rearrange ARM boards in Makefile so that ARM926EJ-S boards are no longer under ARM92xT header. Signed-off-by: Ulf Samuelsson <ulf@atmel.com> Ack-By Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2008-04-18Fix dependency generation for older gcc versionsVlad Lungu
With gcc 3.3.3 at least, compilation fails with Generating include/autoconf.mk gcc: compilation of header file requested make: *** [include/autoconf.mk] Error 1 since commit 16fe77752eee099b9fb61ed73460e51cc94b37ba. Signed-off-by: Vlad Lungu <vlad@comsys.ro>
2008-04-13Allow use of ARCH=powerpc when buildingKumar Gala
The linux kernel is now mostly ARCH=powerpc, so to make life easier allow use to use ARCH=powerpc and convert it to ARCH=ppc. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2008-04-13Support for LinkStation / KuroBox HD and HG PPC modelsGuennadi Liakhovetski
This patch is based on the port by Mihai Georgian (see linkstation.c for Copyright information) and implements support for LinkStation / KuroBox HD and HG PPC models from Buffalo Technology, whereby HD is deactivated at the moment, pending network driver fixing. Notice to users: this is pretty much a barebone port. Support for network on HG models is already in the U-Boot mainline, but you might also want patches to switch fan / phy modes depending on the negotiated ethernet parameters. This patch also doesn't support console switching, booting EM mode, Buffalo specific ext2 magic number. So, if you want to use any of those, you need additional patches. Otherwise this patche provides a fully functional u-boot with a network console on your system. Signed-off-by: Guennadi Liakhovetski <lg@denx.de>
2008-04-13Phytec Phycore-i.MX31 supportSascha Hauer
This patch adds support for the Phytec Phycore-i.MX31 board Signed-off-by: Sascha Hauer <s.hauer@pengutronix.de> Signed-off-by: Guennadi Liakhovetski <lg@denx.de>
2008-04-13mx31 litekit supportSascha Hauer
This patch adds support for the mx31 litekit board Signed-off-by: Sascha Hauer <s.hauer@pengutronix.de> Signed-off-by: Guennadi Liakhovetski <lg@denx.de>
2008-04-13Separate omap24xx specific code from arm1136Sascha Hauer
Move omap24xx code to cpu/arm1136/omap24xx, rename include/asm-arm/arch-arm1136 to cpu/arm1136/omap24xx. Signed-off-by: Sascha Hauer <s.hauer@pengutronix.de> Signed-off-by: Guennadi Liakhovetski <lg@denx.de>
2008-04-13Merge branch 'master' of git://www.denx.de/git/u-boot-sparcWolfgang Denk
2008-04-11Revert merge of git://www.denx.de/git/u-boot-arm, commit 62479b18:Wolfgang Denk
Reverting became necessary after it turned out that the patches in the u-boot-arm repo were modified, and in some cases corrupted. This reverts the following commits: 066bebd6353e33af3adefc3404560871699e9961 7a837b7310166ae8fc8b8d66d7ef01b60a80f9d6 c88ae20580b2b01487b4cdcc8b2a113f551aee36 a147e56f03871bba4f05058d5e04ce7deb010b04 d6674e0e2a6a1f033945f78838566210d3f28c95 8c8463cce44d849e37744749b32d38e1dfb12e50 c98b47ad24b2d91f41c09a3d62d7f70ad84f4b7d 8bf69d81782619187933a605f1a95ee1d069478d 8c16cb0d3b971f46fbe77c072664c0f2dcd4471d a574a73852a527779234e73e17e7597fd8128882 1377b5583a48021d983e1fd565f7d40c89e84d63 1704dc20917b4f71e373e2c888497ee666d40380 Signed-off-by: Wolfgang Denk <wd@denx.de>
2008-04-08SPARC/LEON2: added support for Gaisler simulator GRSIM/TSIM for SPARC/LEON2 ↵Daniel Hellstrom
targets. See www.gaisler.com for information. Signed-off-by: Daniel Hellstrom <daniel@gaisler.com>
2008-04-08SPARC/LEON3: added support for GR-CPCI-AX2000 FPGA AX board. The FPGA is ↵Daniel Hellstrom
exchangeable but a standard LEON3 design is assumed. See www.gaisler.com for information. Signed-off-by: Daniel Hellstrom <daniel@gaisler.com>
2008-04-08SPARC/LEON3: added support for Altera NIOS Development kit (STRATIX II ↵Daniel Hellstrom
Edition) with GRLIB template design. See www.gaisler.com for information. Signed-off-by: Daniel Hellstrom <daniel@gaisler.com>
2008-04-08SPARC/LEON3: added support for Gaisler GRSIM/TSIM2 SPARC/LEON3 simulatorn. ↵Daniel Hellstrom
2008-04-08SPARC/LEON3: added support for GR-XC3S-1500 board with GRLIB template ↵Daniel Hellstrom
design. See www.gaisler.com for board information. Signed-off-by: Daniel Hellstrom <daniel@gaisler.com>
2008-04-08SPARC: Added support for SPARC LEON2 SOC Processor.Daniel Hellstrom
2008-04-08SPARC: Added support for SPARC LEON3 SOC processor.Daniel Hellstrom
2008-04-08SPARC: Added generic support for SPARC architecture.Daniel Hellstrom
2008-04-08Merge branch 'master' of git://www.denx.de/git/u-boot-at91Wolfgang Denk
2008-04-08Merge branch 'master' of git://www.denx.de/git/u-boot-coldfireWolfgang Denk
2008-04-08Merge branch 'master' of git://www.denx.de/git/u-boot-blackfinWolfgang Denk
2008-04-08Merge branch 'master' of git://www.denx.de/git/u-boot-armWolfgang Denk
2008-04-08Merge branch 'master' of git://www.denx.de/git/u-boot-shWolfgang Denk
2008-04-01Add support for AT91SAM9260EKStelian Pop
Support for booting from internal DataFlash, external DataFlash card or NAND flash is available. Signed-off-by: Stelian Pop <stelian@popies.net>
2008-04-01Move at91cap9 specific files to at91sam9 directoryStelian Pop
AT91CAP9 and AT91SAM9 SoCs are very close hardware wise, so a common infrastructure can be used. Let this infrastructure be named after the AT91SAM9 family, and move the existing AT91CAP9 files to the new place. Signed-off-by: Stelian Pop <stelian@popies.net>
2008-03-31ColdFire: Remove R5200 boardTsiChung Liew
This board never went into production Signed-off-by: Zachary P. Landau <zachary.landau@labxtechnologies.com> Acked-by: TsiChung Liew <Tsi-Chung.Liew@freescale.com> Acked-by: John Rigby <jrigby@freescale.com>
2008-03-31ColdFire: Added M5275EVB support.Matthew Fettke
Signed-off-by: Matthew Fettke <mfettke@videon-central.com> Signed-off-by: TsiChung Liew <Tsi-Chung.Liew@freescale.com> Acked-by: John Rigby <jrigby@freescale.com>
2008-03-30Blackfin: unify cpu and boot modesMike Frysinger
All of the duplicated code for Blackfin processors and boot modes have been unified. After all, the core is the same for all processors, just the peripheral set differs (which gets handled in the drivers). Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2008-03-30Support for the MX31ADS evaluation board from FreescaleGuennadi Liakhovetski
2008-03-30Phytec Phycore-i.MX31 supportSascha Hauer
2008-03-30mx31 litekit supportSascha Hauer
2008-03-30Separate omap24xx specific code from arm1136Sascha Hauer
2008-03-30Adds support for the Prodrive PMDRA board, based on a DM6441Pieter Voorthuijsen
Signed-off-by: Pieter Voorthuijsen <pv@prodrive.nl>
2008-03-28sh: Add support Renesas Solutions R2D plus boardNobuhiro Iwamatsu
R2D plus is SH reference board used with SH7751R. This board has 266Mhz CPU, 64MB SDRAM, Cardbus, CF interface, one PCI bus, VGA, and two Ethernet controller. Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2008-03-28sh: Added support for SH7720 based board MPR2.Mark Jonas
Signed-off-by: Mark Jonas <mark.jonas@de.bosch.com> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2008-03-28sh: Add support Renesas Solutions R7780MPYusuke Goda
Renesas Solutions R7780MP is a reference board on SH7780. This board has serial, 10/100 base Ethernet deivice, CF slot and VGA devices. This board can set extension board. Extension board has 10/100/1000 base Ethernet device, PCI slot, S-ATA, iDVR slot. Signed-off-by: Yusuke Goda <goda.yusuke@renesas.com> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2008-03-28sh: Add support Renesas Solutions Migo-R boardgoda.yusuke
Migo-R is a board based on SH7722 and has may devices. In this patch, supported SCIF, NOR flash and Ethernet. Signed-off-by: Yusuke Goda <goda.yusuke@renesas.com> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2008-03-27ppc4xx: Add AMCC Glacier 406GT eval board supportStefan Roese
This patch adds support for the AMCC Glacier 460GT eval board. The main difference to the Canyonlands board are listed here: - 4 ethernet ports instead of 2 - no SATA port - no USB port Currently EMAC2+3 are not working. This will be fixed in a later release. Signed-off-by: Stefan Roese <sr@denx.de>
2008-03-26Merge branch 'new-image' of git://www.denx.de/git/u-boot-testingBartlomiej Sieka
Conflicts: common/cmd_bootm.c cpu/mpc8xx/cpu.c Signed-off-by: Bartlomiej Sieka <tur@semihalf.com>
2008-03-26Merge branch 'master' of git://www.denx.de/git/u-boot-mipsWolfgang Denk
2008-03-26Add Flex-OneNAND booting supportKyungmin Park
Flex-OneNAND is a monolithic integrated circuit with a NAND Flash array using a NOR Flash interface. This on-chip integration enables system designers to reduce external system logic and use high-density NAND Flash in applications that would otherwise have to use more NOR components. Flex-OneNAND enables users to configure to partition it into SLC and MLC areas in more flexible way. While MLC area of Flex-OneNAND can be used to store data that require low reliability and high density, SLC area of Flex-OneNAND to store data that need high reliability and high performance. Flex-OneNAND can let users take advantage of storing these two different types of data into one chip, which is making Flex-OneNAND more cost- and space-effective. Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com>
2008-03-25FSL: Move board/mpc8266ads under board/freescaleJon Loeliger
2008-03-25FSL: Move board/mpc7448hpc2 under board/freescaleJon Loeliger
2008-03-25FSL: Move board/mpc8260ads under board/freescaleJon Loeliger
