path: root/Makefile
2014-05-25sunxi: non-FEL SPL boot support for sun7iIan Campbell
Add support for booting from an MMC card. Signed-off-by: Stefan Roese <sr@denx.de> Signed-off-by: Henrik Nordström <henrik@henriknordstrom.net> Signed-off-by: Ian Campbell <ijc@hellion.org.uk> Reviewed-by: Marek Vasut <marex@denx.de> Cc: Tom Cubie <Mr.hipboi@gmail.com> Reviewed-by: Tom Rini <trini@ti.com>
2014-05-24Merge branch 'master' of git://git.denx.de/u-boot-armTom Rini
2014-05-23examples: select libgcc for non-default architectureAlexey Brodkin
In case of multilib-enabled toolchains if default architecture differ from the one examples are being built for linker will fail to link example object files with libgcc of another (non-compatible) architecture. Interesting enough for years in main Makefile we used CFLAGS/c_flags for this but not for examples. So fixing it now. Signed-off-by: Alexey Brodkin <abrodkin@synopsys.com> Cc: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Tom Rini <trini@ti.com> Cc: Wolfgang Denx <wd@denx.de> Acked-by: WOlfgang Denk <wd@denx.de> Acked-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-05-23Merge branch 'u-boot-microblaze/zynq' into 'u-boot-arm/master'Albert ARIBAUD
2014-05-20Merge remote-tracking branch 'u-boot/master'Albert ARIBAUD
Conflicts: boards.cfg Conflicts were trivial once u-boot-arm/master boards.cfg was reformatted (commit 6130c146) to match u-boot/master's own reformatting (commit 1b37fa83).
2014-05-15build: support a new image u-boot-dtb.imgMasahiro Yamada
In SPL framework, SPL uses u-boot.img to load u-boot.bin. Here, u-boot.img = uImage header + u-boot.bin To use OF control with a separate devicetree, u-boot.dtb must be placed right after u-boot.bin. In this case, u-boot-dtb.bin is generally used. Here, u-boot-dtb.bin = u-boot.bin + u-boot.dtb We need u-boot-dtb.img to use both SPL framework and separate OF control at the same time. u-boot-dtb.img = uImage header + u-boot-dtb.bin For example, Zynq boards already define all of - CONFIG_SPL - CONFIG_OF_CONTROL - CONFIG_OF_SEPARATE So, the support of u-boot-dtb.img is urgent. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Michal Simek <michal.simek@xilinx.com> Acked-by: Simon Glass <sjg@chromium.org> Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2014-05-13arm, davinci: Use CONFIG_SPL_PAD_TO for padding the SPL in an ais imageChristian Riesch
The commits commit b7b5f1a16ca66dfdd817e7339f0e263a5b9f2758 Author: Albert ARIBAUD <albert.u.boot@aribaud.net> da850evm, da850_am18xxevm: convert to CONFIG_SPL_MAX_FOOTPRINT and commit e7497891e34efe5cb2b3a3dc7c6c096c012ede28 Author: Albert ARIBAUD <albert.u.boot@aribaud.net> cam_enc_4xx: convert to CONFIG_SPL_MAX_FOOTPRINT replaced CONFIG_SPL_MAX_SIZE by CONFIG_SPL_MAX_FOOTPRINT. However, CONFIG_SPL_MAX_SIZE is used in the Makefile for padding the SPL when preparing an u-boot.ais image. By removing CONFIG_SPL_MAX_SIZE said commits broke the ais image of the da850evm and cam_enc_4xx configurations. This patch converts the u-boot.ais target to use CONFIG_SPL_PAD_TO instead of CONFIG_SPL_MAX_SIZE for padding the SPL and adds a #define CONFIG_SPL_PAD_TO where it is required. Signed-off-by: Christian Riesch <christian.riesch@omicron.at> Reported-by: Tom Taylor <ttaylor.tampa@gmail.com> Cc: Sudhakar Rajashekhara <sudhakar.raj@ti.com> Cc: Heiko Schocher <hs@denx.de> Cc: Albert ARIBAUD <albert.u.boot@aribaud.net>
2014-05-12kbuild: Fix trailing whitespacesMichal Simek
Trivial fix. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2014-05-12kbuild: build with -Werror=date-time if the compiler supports itMasahiro Yamada
Using __DATE__, __TIME__ would make the build non-deterministic. If the code needs to refer to build date/time, use U_BOOT_DATE and U_BOOT_TIME in include/generated/timestamp_autogenerated.h instead. This commit has been imported from Linux Kernel, which should be applied to U-Boot too: commit fe7c36c7bde12190341722af69358e42171162f3 Author: Josh Triplett <josh@joshtriplett.org> Date: Mon Dec 23 13:56:06 2013 -0800 Makefile: Build with -Werror=date-time if the compiler supports it GCC 4.9 and newer have a new warning -Wdate-time, which warns on any use of __DATE__, __TIME__, or __TIMESTAMP__, which would make the build non-deterministic. Now that the kernel does not use any of those macros, turn on -Werror=date-time if available, to keep it that way. The kernel already (optionally) records this information at build time in a single place; other kernel code should not duplicate that. Signed-off-by: Josh Triplett <josh@joshtriplett.org> Signed-off-by: Michal Marek <mmarek@suse.cz> Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-05-12Prepare v2014.07-rc1v2014.07-rc1Tom Rini
2014-05-09Merge branch 'u-boot/master'Albert ARIBAUD
Conflicts: drivers/net/Makefile (trivial merge)
2014-04-25Merge branch 'master' of git://git.denx.de/u-boot-mpc85xxTom Rini
2014-04-23Revert "build: Use filechk rules to create and update u-boot.lds"Masahiro Yamada
This reverts commit a8b993eb81c142a439c24b871a2317f765fe5397. Commit a8b993eb claims it fixes u-boot.lds rule by replacing $(call if_changed) with $(call filechk). But the problem had already been fixed by commit 395e60cd a few days before commit a8b993eb was posted. There is no reason to apply commit a8b993eb. What is worse is $(call filechk) is too strong to fix the problem and looks weird. Date of the two patches: [1] commit 395e60cdc292dc0183c6867d34b43f14a373df55 Author: Masahiro Yamada <yamada.m@jp.panasonic.com> AuthorDate: Wed Apr 9 20:10:43 2014 +0900 Commit: Tom Rini <trini@ti.com> CommitDate: Fri Apr 11 10:08:42 2014 -0400 replaces $(call if_changed) -> $(call if_changed_dep) [2] commit a8b993eb81c142a439c24b871a2317f765fe5397 Author: Jon Loeliger <jon.loeliger@oracle.com> AuthorDate: Tue Apr 15 16:09:37 2014 -0500 Commit: Tom Rini <trini@ti.com> CommitDate: Fri Apr 18 16:14:16 2014 -0400 replaces $(call if_changed) -> $(call filechk) A conflict must have happened when applying [2], but somehow it was applied, sadly. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Jon Loeliger <jon.loeliger@oracle.com> Cc: Andreas Bießmann <andreas.devel@googlemail.com> Cc: Tom Rini <trini@ti.com>
2014-04-22Makefile: Add support of CONFIG_SPL_FSL_PBLPrabhakar Kushwaha
Objective of this target to have concatenate binary having - SPL binary in PBL command format - U-boot binary Signed-off-by: Prabhakar Kushwaha <prabhakar@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
2014-04-21Merge branch 'u-boot-ti/master' into 'u-boot-arm/master'Albert ARIBAUD
2014-04-18build: Use filechk rules to create and update u-boot.ldsJon Loeliger
Prior to this patch, the top-level linker script u-boot.lds used a simple $(call if_changed) check when generated. That mechanism misses cases where a possible include file change induces a change in the u-boot.lds too. This patch converts it to a stronger check using ($call filechk) that will also notice differences in file contents and will catch changes due to pre-processing as well. Signed-off-by: Jon Loeliger <jon.loeliger@oracle.com>
2014-04-18kbuild: add user-supplied CPPFLAGS, AFLAGS and CFLAGSMasahiro Yamada
Like Linux Kernel, this commit provides environment variables KCPPFLAGS, KAFLAGS and KCFLAGS, which are useful to pass additional options. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-04-18kbuild: sync with Linux Kernel v3.15-rc1Masahiro Yamada
This commit imports Kbuild-related updates from v3.14 to v3.15-rc1. - commit 3d3d6b8474204b6819688c9800774d52d370a538 kbuild: LLVMLinux: Adapt warnings for compilation with clang - commit 61163efae02040f66a95c8ed17f4407951ba58fa kbuild: LLVMLinux: Add Kbuild support for building kernel with Clang - commit 79192ca8ebd9a25c583aa46024a250fef1e7766f scripts: objdiff: detect object code changes between two commits - commit 1c9e70a55b088d97a59241744fe459409d0c3582 kbuild: create a build directory automatically for out-of-tree build - commit a03fcb50e816a69acffb13b5e56db75063aeba8a kbuild: remove redundant '.*.cmd' pattern from make distclean - commit 13338935f1574a2dcd1c891461b0dcc42f8cff42 kbuild: move "quote" to Kbuild.include to be consistent - commit bfdfaeae500a3b194b73b01e92a8034791a58b7f kbuild: specify build_docproc as a phony target - commit f4d4ffc03efc864645b990e1d579bbe1b8e358a4 kbuild: dtbs_install: new make target - commit 1e64ff42ea3d8d2fc8aa71f9717b3c1cb6c2f893 Kbuild, lto: Disable LTO for asm-offsets.c - commit ccbef1674a1579842c7dbdf554efca85d2cd245a Kbuild, lto: add ld-version and ld-ifversion macros - commit ae63b2d7bdd9bd66b88843be0daf8e37d8f0b574 scripts/tags.sh: Ignore *.mod.c - commit e36aaea28972c57a32a3ba5365e61633739719b9 kbuild: Fix silent builds with make-4 Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-04-17k2hk: add support for k2hk SOC and EVMVitaly Andrianov
k2hk EVM is based on Texas Instruments Keystone2 Hawking/Kepler SoC. Keystone2 SoC has ARM v7 Cortex-A15 MPCore processor. Please refer the ti/k2hk_evm/README for details on the board, build and other information. This patch add support for keystone architecture and k2hk evm. Signed-off-by: Vitaly Andrianov <vitalya@ti.com> Signed-off-by: Murali Karicheri <m-karicheri2@ti.com> Signed-off-by: WingMan Kwok <w-kwok2@ti.com> Signed-off-by: Sandeep Nair <sandeep_n@ti.com>
2014-04-14Prepare v2014.04v2014.04Tom Rini
2014-04-11kbuild: fix a bug in regeneration of linker scriptsMasahiro Yamada
In some use cases, SPL linker script was not updated even when it should be. For instance, $ make tricoder_config all [ build complete ] ... modify include/configs/tricoder.h $ make spl/u-boot-spl.lds should be updated in this case, but it wasn't. To fix this problem, linker scripts generation should be handled by $(call if_changed_dep,...) rather than by $(call if_changed,...). Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Reported-by: Andreas Bießmann <andreas.devel@googlemail.com> Tested-by: Andreas Bießmann <andreas.devel@googlemail.com>
2014-04-08Merge branch 'u-boot/master' into 'u-boot-arm/master'Albert ARIBAUD
Conflicts: arch/arm/cpu/arm926ejs/mxs/Makefile include/configs/trats.h include/configs/trats2.h include/mmc.h
2014-04-04arm: mxs: Add support for generating signed BootStreamMarek Vasut
This patch adds the groundwork for generating signed BootStream, which can be used by the HAB library in i.MX28. We are adding a new target, u-boot-signed.sb , since the process for generating regular non-signed BootStream is much easier. Moreover, the signed bootstream depends on external _proprietary_ _binary-only_ tool from Freescale called 'cst', which is available only under NDA. To make things even uglier, the CST or HAB mandates a kind-of circular dependency. The problem is, unlike the regular IVT, which is generated by mxsimage, the IVT for signed boot must be generated by hand here due to special demands of the CST. The U-Boot binary (or SPL binary) and IVT are then signed by the CST as a one block. But here is the problem. The size of the entire image (U-Boot, IVT, CST blocks) must be appended at the end of IVT. But the size of the entire image is not known until the CST has finished signing the U-Boot and IVT. We solve this by expecting the CST block to be always 3904B (which it is in case two files, U-Boot and the hand-made IVT, are signed in the CST block). Signed-off-by: Marek Vasut <marex@denx.de> Cc: Stefano Babic <sbabic@denx.de>
2014-04-04Merge branch 'master' of git://git.denx.de/u-boot-arm into masterStefano Babic
Conflicts: arch/arm/cpu/arm926ejs/mxs/mxsimage.mx23.cfg arch/arm/cpu/arm926ejs/mxs/mxsimage.mx28.cfg Signed-off-by: Stefano Babic <sbabic@denx.de>
2014-04-04Revert "arm: mxs: Add support for generating signed BootStream"Stefano Babic
This reverts commit 53e6b14e037c9f72e6d03244c32d8d597e2e0234. Patch does not merge anymore with u-boot-arm and must be rebased. Signed-off-by: Stefano Babic <sbabic@denx.de>
2014-04-02imx: add rules for U-Boot DTB supportStefano Babic
2014-03-31Prepare v2014.04-rc3v2014.04-rc3Tom Rini
2014-03-31arm: mxs: Add support for generating signed BootStreamMarek Vasut
2014-03-31Kbuild: allow building tools without board configurationMasahiro Yamada
Prior to Kbuild, U-Boot could build under tools/ directory withour configuring for a specific board. That feature was lost when switching to Kbuild. This patch revives it again by adding a make target "tools-only". Usage: $ make tools-only Neither board configuration nor cross compiler are required to build host tools. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Suggested-by: Alexey Brodkin <Alexey.Brodkin@synopsys.com> Cc: Simon Glass <sjg@chromium.org> Cc: Tom Rini <trini@ti.com> Acked-by: Alexey Brodkin <abrodkin@synopsys.com>
2014-03-28kbuild: fix bugs in cleaning targetsMasahiro Yamada
"make clean", "make clobber", "make mrproper" and "make distclean" missed to clean-up some files when they were run with O=<some_dir> option. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Reported-by: Wolfgang Denk <wd@denx.de>
2014-03-28kbuild: create a build directory automatically for out-of-tree buildMasahiro Yamada
Prior to Kbuild, the build system created a build directory, when it did not exist, for out-of-tree build. This feature was dropped when we switched to Kbuild because many of lines in makefiles were copied from Linux Kernel. (In Linux Kernel, we have to create a build directory by ourselves before starting build.) That feature seems worth reviving for less typing even if our code and Linux Kernel diverge. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Suggested-by: Simon Glass <sjg@chromium.org> Acked-by: Simon Glass <sjg@chromium.org> Tested-by: Simon Glass <sjg@chromium.org>
2014-03-28kbuild: Rename UIMAGE to MKIMAGEMarek Vasut
U-Boot uses the 'mkimage' tool to produce various image types, not only uImage image type. Rename the invocation name from UIMAGE to MKIMAGE. The following command was used to do the replacement: git grep 'quiet_cmd_mkimage.* = UIMAGE' | cut -d : -f 1 | \ xargs -i sed -i "s@\(quiet_cmd_mkimage\)\(.*\) = UIMAGE @\1\2 = MKIMAGE@" {} Signed-off-by: Marek Vasut <marex@denx.de> Cc: Tom Rini <trini@ti.com> Cc: Masahiro Yamada <yamada.m@jp.panasonic.com> Acked-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-03-12kbuild: delete *.pyc files by "make distclean"Masahiro Yamada
The tools "buildman" and "patman" are written in Python. When we run them, "*.pyc" files are created under tools/buildman, tools/patman directories. They should be cleaned up by "make distclean". Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Tom Rini <trini@ti.com> Acked-by: Simon Glass <sjg@chromium.org>
2014-03-12kbuild: delete SPLTREE and TPLTREEMasahiro Yamada
These variable are no longer used. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-03-12kbuild: rename OBJTREE to objtreeMasahiro Yamada
Prior to Kbuild, $(OBJTREE) was used for pointing to the top of build directory with absolute path. In Kbuild style, $(objtree) is used instead. This commit renames OBJTREE to objtree and delete the defition of OBJTREE. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-03-12kbuild: rename SRCTREE to srctreeMasahiro Yamada
Prior to Kbuild, $(TOPDIR) or $(SRCTREE) was used for pointing to the top of source directory. (No difference between the two.) In Kbuild style, $(srctree) is used for instead. This commit renames SRCTREE to srctree and deletes the defition of SRCTREE. Note that SRCTREE in scripts/kernel-doc, scripts/docproc.c, doc/DocBook/Makefile should be keep. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-03-12kbuild: rename TOPDIR to stctreeMasahiro Yamada
Prior to Kbuild, $(TOPDIR) or $(SRCTREE) was used for pointing to the top of source directory. (No difference between the two.) In Kbuild style, $(srctree) is used instead. This commit renames TOPDIR to srctree and delete the defition of TOPDIR. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-03-12kbuild: use $(KBUILD_SRC) to check out-of-tree buildMasahiro Yamada
Non-empty $(KBUILD_SRC) means out-of-tree build. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-03-12kirkwood: kwbimage: refactor CONFIG_SYS_KWD_CONFIGMasahiro Yamada
Pull out "$(SRCTREE)/" from CONFIG_SYS_KWD_CONFIG and push it into the top Makefile. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Michael Walle <michael@walle.cc> Cc: Simon Guinot <simon.guinot@sequanux.org> Cc: Dave Purdy <david.c.purdy@gmail.com> Cc: Stefan Herbrechtsmeier <stefan@herbrechtsmeier.net> Cc: Luka Perkov <luka@openwrt.org> Cc: Valentin Longchamp <valentin.longchamp@keymile.com> Cc: Jason Cooper <u-boot@lakedaemon.net> Cc: Siddarth Gore <gores@marvell.com> Cc: Prafulla Wadaskar <prafulla@marvell.com> Cc: Eric Cooper <ecc@cmu.edu> Cc: Suriyan Ramasami <suriyan.r@gmail.com>
2014-03-12freescale: pblimage: refactor CONFIG_SYS_FSL_PBL_{PBI, RCW}Masahiro Yamada
Pull out "$(SRCTREE)/" from CONFIG_SYS_FSL_PBL_PBI and CONFIG_SYS_FSL_PBL_RCW and push it into the top Makefile. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: York Sun <yorksun@freescale.com> Cc: Poonam Aggrwal <poonam.aggrwal@freescale.com> Cc: Valentin Longchamp <valentin.longchamp@keymile.com>
2014-03-12kbuild,mxs: use short logs for MXS imagesMasahiro Yamada
Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Fabio Estevam <fabio.estevam@freescale.com> Cc: Otavio Salvador <otavio@ossystems.com.br> Cc: Lauri Hintsala <lauri.hintsala@bluegiga.com> Acked-by: Marek Vasut <marex@denx.de>
2014-03-10Prepare v2014.04-rc2v2014.04-rc2Tom Rini
2014-03-10kbuild: fix a bug of make rule of version_autogenerated.hMasahiro Yamada
include/generated/version_autogenerated.h was not correctly generated on the parallel build (with -j option). Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Reported-by: Andreas Bießmann <andreas.devel@googlemail.com>
2014-03-07kbuild: move "checkgcc4" to PowerPC archprepareMasahiro Yamada
"checkgcc4" is used only for PowerPC. Move it to arch/powerpc/config.mk. To make sure gcc is new enough before beginning build, run "checkgcc4" during "archprepare". Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-03-07kbuild: move "checkthumb" to ARM archprepareMasahiro Yamada
"checkthumb" makes sense only for ARM architecture. Move it to arch/arm/config.mk. To make sure gcc supports THUMB mode before beginning build, run "checkthumb" during "archprepare". Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-03-07kbuild: improve Kbuild speedMasahiro Yamada
Kbuild brought about many advantages for us but a significant performance regression was reported by Simon Glass. After some discussions and analysis, it turned out its main cause is in $(call cc-option,...). Historically, U-Boot parses all config.mk (arch/*/config.mk and board/*/config.mk) every time descending into subdirectories. That means cc-options are evaluated over and over again. $(call cc-option,...) is useful but costly. So we want to evaluate them only in ./Makefile and spl/Makefile and export compiler flags. This commit changes the build system as follows: - Modify scripts/Makefile.build to not include config.mk Instead, add $(PLATFORM_CPPFLAGS) to asflags-y, ccflags-y, cppflags-y. - Export many variables Going forward, Kbuild will not parse config.mk files when it descends into subdirectories. If we want to set variables in config.mk and use them in subdirectories, they must be exported. This is the list of variables to get exported: PLATFORM_CPPFLAGS CPUDIR BOARDDIR OBJCOPYFLAGS LDFLAGS LDFLAGS_FINAL (used in nand_spl/board/*/*/Makefile) CONFIG_STANDALONE_LOAD_ADDR (used in examples/standalone/Makefile) SYM_PREFIX (used in examples/standalone/Makefile) RELFLAGS (used in examples/standalone/Makefile) - Delete CPPFLAGS This variable has been replaced with PLATFORM_CPPFLAGS - Copy gcclibdir from example/standalone/Makefile to arch/sparc/config.mk The reference in CONFIG_STANDALONE_LOAD_ADDR must be resolved before it is exported. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Reported-by: Simon Glass <sjg@chromium.org> Acked-by: Simon Glass <sjg@chromium.org> Tested-by: Simon Glass <sjg@chromium.org> [on Sandbox] Tested-by: Stephen Warren <swarren@nvidia.com> [on Tegra]
2014-03-07kbuild: add CONFIG_ prefix to USE_PRIVATE_LIBGCCMasahiro Yamada
Before this commit, USE_PRIVATE_LIBGCC was defined in arch-specific config.mk and referenced in arch/$(ARCH)/lib/Makefile. We are not happy about parsing config.mk again and again. We have to keep the same behavior with a different way. By adding "CONFIG_" prefix, this macro appears in include/autoconf.mk, include/spl-autoconf.mk. (And treating USE_PRIVATE_LIBGCC as CONFIG macro is reasonable enough.) Tegra SoC family defined USE_PRIVATE_LIBGCC as "yes" in arch/arm/cpu/arm720t/tegra*/config.mk, whereas did not define it in arch/arm/cpu/armv7/tegra*/config.mk. It means Tegra enables PRIVATE_LIBGCC only for SPL. We can describe the same behavior by adding #ifdef CONFIG_SPL_BUILD # define CONFIG_USE_PRIVATE_LIBGCC #endif to include/configs/tegra-common.h. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Tom Warren <twarren@nvidia.com> Cc: Simon Glass <sjg@chromium.org> Acked-by: Stephen Warren <swarren@nvidia.com>
2014-03-07xilinx: delete meaningless .gitignore filesMasahiro Yamada
config.tmp is never generated Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Michal Simek <michal.simek@xilinx.com> Acked-by: Michal Simek <michal.simek@xilinx.com>
2014-03-04kbuild: allow empty board directoriesMasahiro Yamada
U-Boot has compelled all boards to have board/${BOARD}/ or board/${VENDOR}/${BOARD}/ directory. Sometimes it does not seem suitable for some boards, for example Sandbox. (Is it a board?) And arcangel4 board has nothing to compile under the board directory. This commit makes the build system more flexible: If '<none>' is given to the 6th column (=Board name) of boards.cfg, Kbuild will not descend into the board directory. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-03-04kbuild: add "cross_tools" target to build tools for the targetMasahiro Yamada
Programs in tools/ directory are usually built for the host. But some of them (mkimage, dumpimge, gen_eth_addr, etc.) are useful on the target OS too. Actually, prior to Kbuild, U-Boot could build tools for the target like follows: $ make <target_board>_config $ export CROSS_COMPILE=<cross_gcc_prefix> $ make HOSTCC=${CROSS_COMPILE}gcc HOSTSTRIP=${CROSS_COMPILE}strip tools In Kbuild, we can no longer replace HOSTCC at the command line. In order to get back that feature, this commit adds "cross-tools" target. Usage: Build tools for the host $ make CROSS_COMPILE=<cross_gcc_prefix> tools Build tools for the target $ make CROSS_COMPILE=<cross_gcc_prefix> cross_tools Besides, "make cross_tools" strip tools programs because we generally expect smaller storages on embedded systems. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Reported-by: Heiko Schocher <hs@denx.de> Cc: Wolfgang Denk <wd@denx.de> Cc: Tom Rini <trini@ti.com> Tested-by: Heiko Schocher <hs@denx.de> Acked-by: Heiko Schocher <hs@denx.de>
