path: root/Makefile
2012-07-07Makefile: Add u-boot.spr build target (SPEAr)Stefan Roese
On x600 (SPEAr600) U-Boot is appended to U-Boot SPL. Both images are created using mkimage (crc etc), so that the ROM bootloader can check its integrity. Padding needs to be done to the SPL image (with mkimage header) and not the binary. Otherwise the resulting image which is loaded/copied by the ROM bootloader to SRAM doesn't fit. The resulting image containing both U-Boot images is called u-boot.spr. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Amit Virdi <amit.virdi@st.com> Cc: Vipin Kumar <vipin.kumar@st.com>
2012-05-25create lib/tizen directoryDonghwa Lee
This directory includes tizen logo data, common tizen library and so on. Signed-off-by: Donghwa Lee <dh09.lee@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Acked-by: Minkyu Kang <mk7.kang@samsung.com> [ agust: change to conditionally build lib/tizen directory ] Signed-off-by: Anatolij Gustschin <agust@denx.de>
2012-05-15Makefile: Add a 'checkthumb' ruleTom Rini
This rule confirms that if we're on ARM and we have enabled THUMB builds that we have a new enough toolchain to produce a working binary. Changes in v2: - Switch to ALL-$(CONFIG_SYS_THUMB_BUILD) in arch/arm/config.mk (Mike F) - Simplfy checkthumb test after doing the above Signed-off-by: Tom Rini <trini@ti.com> Acked-by: Mike Frysinger <vapier@gentoo.org>
2012-04-25Prepare v2012.04.01v2012.04.01Wolfgang Denk
2012-04-21Prepare v2012.04v2012.04Wolfgang Denk
Also tiny style cleanup to tools/patman/README Signed-off-by: Wolfgang Denk <wd@denx.de>
2012-04-18Prepare v2012.04-rc3v2012.04-rc3Wolfgang Denk
2012-04-16Prepare v2012.04-rc2; minor Coding Style cleanupv2012.04-rc2Wolfgang Denk
2012-03-31Prepare v2012.04-rc1v2012.04-rc1Wolfgang Denk
2012-03-30Define CPUDIR for the .lds link scriptSimon Glass
Most link scripts differ only in the directory containing the start.o file. Make this a #define to remove this last difference. (Note that if start.o were disallowed outside the CPU start directory then we wouldn't even need this. But that is a separate discussion.) Signed-off-by: Simon Glass <sjg@chromium.org>
2012-03-30Allow arch directory to contain .lds without requiring MakefileSimon Glass
The Makefile for a CPU is in arch/($ARCH)/cpu/$(CPU). We want to support having an .lds file in arch/$(ARCH)/cpu without requiring an additional Makefile there. This change makes it clear that we expect a Makefile in the same directory as the link script except in this case. Signed-off-by: Simon Glass <sjg@chromium.org>
2012-03-26IXP: Move PDNB3 and SCPU from Makefile to boards.cfgMarek Vasut
Signed-off-by: Marek Vasut <marex@denx.de> Cc: Bryan Hundven <bryanhundven@gmail.com> Cc: Michael Schwingen <rincewind@discworld.dascon.de>
2012-03-26config.mk: Check for -fstack-usage supportTom Rini
Acked-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Tom Rini <trini@ti.com>
2012-03-06tools: checkstack.pl from Linux added to toolsTom Rini
Added from Linux - commit 62aa2b537c6f5957afd98e29f96897419ed5ebab Signed-off-by: Tom Rini <trini@ti.com>
2012-03-06Makefile: Remove mmc_spl related enteriesChander Kashyap
As mmc_spl now follows SPL infrastructure, removed unwanted entries in Makefile for mmc_spl related compilation. Signed-off-by: Chander Kashyap <chander.kashyap@linaro.org>
2012-02-12ARM: Convert spear3xx and spear6xx boards to boards.cfgAmit Virdi
Signed-off-by: Amit Virdi <amit.virdi@st.com> Acked-by: Stefan Roese <sr@denx.de>
2012-02-12EXYNOS: SMDK5250: Add MMC SPL supportChander Kashyap
This patch adds support for MMC SPL booting. Signed-off-by: Chander Kashyap <chander.kashyap@linaro.org> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2012-01-16ARM:AM33XX: Replace CONFIG_AM335X with CONFIG_AM33XXChandan Nath
This patch is added to replace CONFIG_AM335X symbol with CONFIG_AM333XX for AM33XX platforms. Signed-off-by: Chandan Nath <chandan.nath@ti.com> Signed-off-by: Tom Rini <trini@ti.com> Tested-by: Thomas Weber <weber@corscience.de>
2011-12-24arm, davinci: Add support for generating AIS images to the MakefileChristian Riesch
Signed-off-by: Christian Riesch <christian.riesch@omicron.at> Cc: Stefano Babic <sbabic@denx.de> Cc: Heiko Schocher <hs@denx.de> Cc: Mike Frysinger <vapier@gentoo.org>
2011-12-23Prepare v2011.12v2011.12Wolfgang Denk
2011-12-21Prepare v2011.12-rc3v2011.12-rc3Wolfgang Denk
2011-12-20Makefile: fix distclean and *_config rules to be less noiseLauri Hintsala
Signed-off-by: Lauri Hintsala <lauri.hintsala@bluegiga.com>
2011-12-19Prepare v2011.12-rc2v2011.12-rc2Wolfgang Denk
2011-12-12Prepare v2011.12-rc1v2011.12-rc1Wolfgang Denk
2011-12-11USB: Add generic ULPI layer and a viewportJana Rapava
Add partial ULPI specification implementation that should be enough to interface the ULPI PHYs in the boot loader context. Add a viewport implementation for Chipidea/ARC based controllers. Signed-off-by: Jana Rapava <fermata7@gmail.com> Signed-off-by: Igor Grinberg <grinberg@compulab.co.il> Cc: Remy Bohmer <linux@bohmer.net> Cc: Stefano Babic <sbabic@denx.de> Cc: Wolfgang Grandegger <wg@denx.de> Cc: Simon Glass <sjg@chromium.org>
2011-12-10ARM: convert "omap730p2" boards to boards.cfgWolfgang Denk
Signed-off-by: Wolfgang Denk <wd@denx.de> Dave Peverley <dpeverley@mpc-data.co.uk> Acked-by: Tom Rini <trini@ti.com>
2011-12-10ARM: convert "omap16xx" boards to boards.cfgWolfgang Denk
Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Kshitij Gupta <kshitij@ti.com> Acked-by: Tom Rini <trini@ti.com>
2011-12-10ARM: convert "apollon" board to use boards.cfgWolfgang Denk
Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Kyungmin Park <kyungmin.park@samsung.com> Cc: Albert Aribaud <albert.u.boot@aribaud.net>
2011-12-09i.mx: introduce the armv7/imx-common folderJason Liu
In order to support the coming MX6 platform and to reducde the duplicated code, we had better move some common files or functions to the imx-common folder for sharing. This patch does the following: - move speed.c file from armv7/mx5/speed.c to armv7/imx-common/speed.c - move armv7/mx5/timer.c to armv7/imx-common/timer.c, no any new feature added but just fix the checkpatch errors in the old file and remove the CONFIG_SYS_MX5_CLK32 reference in the file - create one new file cpu.c file to store the common function with i.mx5/6 Signed-off-by: Jason Liu <jason.hui@linaro.org> Cc:Stefano Babic <sbabic@denx.de> Acked-by: Stefano Babic <sbabic@denx.de>
2011-12-09S5PC2XX: Rename S5pc2XX to exynosChander Kashyap
As per new naming convention for Samsung SoC's, all Cortex-A9 and Cortex-A15 based SoC's will be classified under the name Exynos. Cortex-A9 and Cortex-A15 based SoC's will be sub-classified as Exynos4 and Exynos5 respectively. In order to better adapt and reuse code across various upcoming Samsung Exynos based boards, all uses of s5pc210 prefix/suffix/directory-names are renamed in this patch. s5pc210 is renamed as exynos4210 and S5PC210/s5pc210 suffix/prefix are renamed as exynos4/EXYNOS4. Signed-off-by: Chander Kashyap <chander.kashyap@linaro.org> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2011-12-07Merge branch 'master' of git://git.denx.de/u-boot-mpc83xxWolfgang Denk
* 'master' of git://git.denx.de/u-boot-mpc83xx: powerpc/83xx: fix sdram initialization for keymile boards powerpc/mpc83xx: cleanup makefile for mpc83xx
2011-12-07Introduce generic TPM support in u-bootVadim Bendebury
TPM (Trusted Platform Module) is an integrated circuit and software platform that provides computer manufacturers with the core components of a subsystem used to assure authenticity, integrity and confidentiality. This driver supports version 1.2 of the TCG (Trusted Computing Group) specifications. The TCG specification defines several so called localities in a TPM chip, to be controlled by different software layers. When used on a typical x86 platform during the firmware phase, only locality 0 can be accessed by the CPU, so this driver even while supporting the locality concept presumes that only locality zero is used. This implementation is loosely based on the article "Writing a TPM Device Driver" published on http://ptgmedia.pearsoncmg.com Compiling this driver with DEBUG defined will generate trace of all accesses to TMP registers. This driver has been tested and is being used in three different functional ChromeOS machines (Pinetrail and Sandy Bridge Intel chipsets) all using the same Infineon SLB 9635 TT 1.2 device. A u-boot cli command allowing access to the TPM was also implemented and is being submitted as a second patch. Change-Id: I22a33c3e5b2e20eec9557a7621bd463b30389d73 Signed-off-by: Vadim Bendebury <vbendeb@chromium.org> CC: Wolfgang Denk <wd@denx.de>
2011-12-06Add a "tidy" build optionAndy Fleming
It is sometimes desireable to clean up the byproducts of the build process without removing the executable results. "make clean" is close, but leaves the build directory with a large number of *.depend* files. This new build option invokes make clean, and then removes the depend files. Signed-off-by: Andy Fleming <afleming@freescale.com>
2011-12-05Makefile: add tools/mkenvimage to target 'clean'Horst Kronstorfer
Signed-off-by: Horst Kronstorfer <hkronsto@frequentis.com> Acked-by: Mike Frysinger <vapier@gentoo.org>
2011-11-22tools/env: use lib/crc32.c directlyAndreas Bießmann
Instead of linking the file into $(obj) tree use directly the source file. This also prevents littered source tree if building not out-of-tree. Signed-off-by: Andreas Bießmann <biessmann@corscience.de> Acked-by: Mike Frysinger <vapier@gentoo.org>
2011-11-21Merge branch 'sr@denx.de' of git://git.denx.de/u-boot-stagingWolfgang Denk
* 'sr@denx.de' of git://git.denx.de/u-boot-staging: Makefile: Add the missing dependency for spl target gpio: Adapt PCA9698 to standard GPIO API
2011-11-18Makefile: Add the missing dependency for spl targetAneesh V
Wolfgang's patch for build time improvement is bringing out issues due to missing dependencies in the top-level Makefile. I get errors such as the below while building with many threads. make[1]: /home/a0393566local/u-boot-denx/tools/mkimage: Command not found This also allows one to do: $ make spl/u-boot-spl.bin if you want to build only spl Cc: Wolfgang Denk <wd@denx.de> Signed-off-by: Aneesh V <aneesh@ti.com>
2011-11-16Merge branch 'master' of git://git.denx.de/u-boot-videoWolfgang Denk
* 'master' of git://git.denx.de/u-boot-video: api: export LCD device to external apps font: split font data from video_font.h tools: logo: split bmp arrays from bmp_logo.h lcd: add clear and draw bitmap declaration VIDEO: mx3fb: GCC4.6 fix build warnings Powerpc/DIU: Fixed the 800x600 and 1024x768 resolution bug
2011-11-15tools: logo: split bmp arrays from bmp_logo.hChe-Liang Chiou
The generated header bmp_logo.h is useful even outside common/lcd.c for the logo dimension. However, the problem is, the generated bmp_logo.h cannot be included multiple times because bmp_logo_palette[] and bmp_logo_bitmap[] are defined in the bmp_logo.h. This patch fixes this by defining these arrays in another header bmp_logo_data.h and in bmp_logo.h only declaring these arrays. Signed-off-by: Che-Liang Chiou <clchiou@chromium.org> Acked-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Anatolij Gustschin <agust@denx.de>
2011-11-15omap5: Add omap5_evm board build support.Sricharan
This patch adds the build support for the omap5_evm board. Signed-off-by: sricharan <r.sricharan@ti.com> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2011-11-11powerpc/mpc83xx: cleanup makefile for mpc83xxYork Sun
Remove symbolic link generated by compiling. Fix makefile for out-of-tree compiling error. Signed-off-by: York Sun <yorksun@freescale.com> Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2011-11-11iMX28: Add u-boot.sb target to MakefileMarek Vasut
Signed-off-by: Marek Vasut <marek.vasut@gmail.com> Cc: Stefano Babic <sbabic@denx.de> Cc: Wolfgang Denk <wd@denx.de> Cc: Detlev Zundel <dzu@denx.de>
2011-11-08Merge branch 'master' of git://git.denx.de/u-boot-armWolfgang Denk
* 'master' of git://git.denx.de/u-boot-arm: Arm: re-introduce the MACH_TYPE_XXXXXX for EB_CPUX9K2 board arm: jadecpu: Readd MACH_TYPE_JADECPU at91: defined mach-types for otc570 board in board config file at91: defined mach-types for meesc board in board config file mx31pdk: Enable D and I caches ehci-mxc: remove incorrect comment README: Fix supported i.MX SoC list for CONFIG_MXC_SPI mx53: Turn off child clocks before reconfigure perclk_root qong: enable support for compressed images imx: imx31_phycore.h: fix checkpatch warnings vision2: Remove unused get_board_rev function mx53smd: Remove unused get_board_rev function mx53ard: Remove unused get_board_rev function mx53evk: Remove unused get_board_rev function mx53evk: Add RTC support mx53loco: Remove unused get_board_rev function mx53evk: Remove unneeded '1' from mx53evk.h OMAP3: mvblx: Initial support for mvBlueLYNX-X ARM: dig297: Define MACH_TYPE_OMAP3_CPS and CONFIG_MACH_TYPE omap3: mem: Move comments next to definitions omap3: mem: Clean-up whitespaces omap3: mem: Define and use common macros Davinci: ea20: added PREBOOT to configuration Davinci: ea20: added I2C support Davinci: ea20: added video support VIDEO: davinci: add framebuffer to da8xx ARM: Davinci: added missing registers to hardware.h Davinci: ea20: add gpios for LCD backlight control Davinci: ea20: add gpio for keeping power on in board_late_init Davinci: ea20: Add default U-Boot environment Davinci: ea20: Add early init to get early output from console Davinci: ea20: Add NAND support Davinci: ea20: set GPIOs to hold MII-Phy in reset and set UART0-Switch for console Davinci: ea20: set console on UART0 arm, davinci: add cam_enc_4xx support arm926ejs, davinci: add missing spi defines for dm365 arm926ejs, davinci: add cpuinfo for dm365 arm, davinci: add lowlevel function for dm365 soc arm, davinci: add header files for dm365 spl, nand: add 4bit HW ecc oob first nand_read_page function arm, davinci: add support for new spl framework spl: add option for adding post memory test to the SPL framework net, davinci_emac: make clock divider in MDIO control register configurable arm, usb, davinci: make USBPHY_CTL register configurable usb, davinci: add enable_vbus() weak function omap3evm: fix errors caused by multiple definitions omap3evm: Add (quick) configuration for NAND only omap3evm: Add (quick) configuration for MMC/SD only omap3evm: move common config options to new file omap3evm: Prepare to split configuration omap3evm: Reorder related config options omap/spl: actually enable the console davinci_emac: compilation fix, phy is array now omap3evm: Set environment variable 'ethaddr' arm, arm926: fix missing symbols in NAND_SPL mode arm, davinci: Add function lpsc_syncreset() arm, davinci: replace CONFIG_PRELOADER with CONFIG_SPL_BUILD arm/km: portl2 environment address update to P1B arm/km: adapt bootcounter evaluation arm/km: enable jffs2 cmds arm/km: trigger reconfiguration for the Xilinx FPGA arm/km: add boardid and hwkey to kernel command line ARM: Reintroduce MACH_TYPE_KM_KIRKWOOD for keymile ARM boards netspace_v2: enable I2C EEPROM support netspace_v2: fix SDRAM configuration armada100: define CONFIG_SYS_CACHELINE_SIZE pantheon: define CONFIG_SYS_CACHELINE_SIZE kirkwood: define CONFIG_SYS_CACHELINE_SIZE kirkwood: drop empty asm-offsets.s file arm/km/mgcoge3un: enhance "waitforne" feature arm/km: add variable waitforne to mgcoge3un gplugD: Fix for error:MACH_TYPE_SHEEVAD undeclared ARM: dreamplug: fix compilation ARM: DockStar: fix compilation ARM: netspace_v2: fix warnings am335x: Drop board_sysinfo struct am335x: Temporarily add MACH_TYPE define misc:pmic:samsung Enable PMIC driver at C210 Universal target dcache:s5p CONFIG_SYS_CACHELINE_SIZE added for s5p UNIVERSAL C210 target dcache:s5p CONFIG_SYS_CACHELINE_SIZE added for s5p GONI target smdkv310: use macro for mmc data read function address smdkv310: use spl framework for mmc spl SMDKV310: use get_ram_size() to validate dram size SMDKV310: Initialize board id using CONFIG_MACH_TYPE ORIGEN : use absolute paths and fix tool naming ORIGEN : enable device tree support MX25: tx25: Fix building due to missing MACH_TYPE mx31: Add board support for HALE TT-01 mx31: add ESD control registers mx31: define pins and init for UART2 and CSPI3 MX35: add support for flea3 board MX51: vision2: add MACH_TYPE in config file vision2: Remove unused header file mx51evk: Remove unused get_board_rev function mx51evk: Remove unneeded '1' from mx51evk.h I2C: Fix mxc_i2c.c problem on imx31_phycore mx35pdk: Add RTC support mx51evk: Use GPIO API for configuring the IOMUX mx51evk: Add RTC support rtc: Make mc13783-rtc driver generic qong: remove unneeded IOMUX settings qong: Use mx31_set_gpr to setup USBH2 pins mx31: Introduce mx31_set_gpr function mx31pdk: Add MC13783 PMIC support qong: remove unneeded "1" from qong.h misc: pmic: fix regression in pmic_fsl.c (SPI) mx5 configs: CONFIG_PRIME should really be CONFIG_ETHPRIME MX35: Drop unnecessary prototypes from imx-regs.h I2C: added I2C-2 and I2C-3 to MX35 MX35: factorize common assembly code MX35: add reset cause as provided by other i.MX MX35: add pins definition for UART3 MX35: added ESDC structure to imx-regs
2011-11-07ColdFire:Moving the remaining coldfire boards to boards.cfgJason Jin
Move the coldfire boards to boards.cfg. The config name for the EB+MCF-EV123 boards are changed to EB-MCF-EV123 as the '+' cannot be recognized. Signed-off-by: Jason Jin <Jason.jin@freescale.com>
2011-11-03arm, davinci: add support for new spl frameworkHeiko Schocher
Signed-off-by: Heiko Schocher <hs@denx.de> Cc: Albert ARIBAUD <albert.u.boot@aribaud.net> Cc: Sandeep Paulraj <s-paulraj@ti.com> Cc: Scott Wood <scottwood@freescale.com> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2011-11-03sandbox: Adjust Makefile so that standalone/api are not builtSimon Glass
The check for sandbox architecture is too early in the Makefile, so standalone and api are built regardless. This moves the check until after autoconf.mk has been read. This fixes a build breakage. Signed-off-by: Simon Glass <sjg@chromium.org>
2011-11-03Reduce build timesWolfgang Denk
U-Boot Makefiles contain a number of tests for compiler features etc. which so far are executed again and again. On some architectures (especially ARM) this results in a large number of calls to gcc. This patch makes sure to run such tests only once, thus largely reducing the number of "execve" system calls. Example: number of "execve" system calls for building the "P2020DS" (Power Architecture) and "qong" (ARM) boards, measured as: -> strace -f -e trace=execve -o /tmp/foo ./MAKEALL <board> -> grep execve /tmp/foo | wc -l Before: After: Reduction: ================================== P2020DS 20555 15205 -26% qong 31692 14490 -54% As a result, built times are significantly reduced, typically by 30...50%. Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Andy Fleming <afleming@gmail.com> Cc: Kumar Gala <galak@kernel.crashing.org> Cc: Albert Aribaud <albert.aribaud@free.fr> cc: Graeme Russ <graeme.russ@gmail.com> cc: Mike Frysinger <vapier@gentoo.org> Tested-by: Graeme Russ <graeme.russ@gmail.com> Tested-by: Matthias Weisser <weisserm@arcor.de> Tested-by: Sanjeev Premi <premi@ti.com> Tested-by: Simon Glass <sjg@chromium.org> Tested-by: Macpaul Lin <macpaul@gmail.com> Acked-by: Mike Frysinger <vapier@gentoo.org>
2011-10-27ARM:AM33XX: Added timer supportChandan Nath
This patch adds timer support for AM33xx platform. Signed-off-by: Chandan Nath <chandan.nath@ti.com> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2011-10-26fdt: Add support for a separate device tree (CONFIG_OF_SEPARATE)Simon Glass
This adds support for an FDT to be build as a separate binary file called u-boot.dtb. This can be concatenated with the U-Boot binary to provide a device tree located at run-time by U-Boot. The Makefile is modified to provide this file in u-boot-dtb.bin. Signed-off-by: Simon Glass <sjg@chromium.org>
2011-10-26fdt: Add support for embedded device tree (CONFIG_OF_EMBED)Simon Glass
This new option allows U-Boot to embed a binary device tree into its image to allow run-time control of peripherals. This device tree is for U-Boot's own use and is not necessarily the same one as is passed to the kernel. The device tree compiler output should be placed in the $(obj) rooted tree. Since $(OBJCOPY) insists on adding the path to the generated symbol names, to ensure consistency it should be invoked from the directory where the .dtb file is located and given the input file name without the path. This commit contains my entry for the ugliest Makefile / shell interaction competition. Signed-off-by: Simon Glass <sjg@chromium.org>
2011-10-22autoconf.mk.dep: use target cflags, not hostMike Frysinger
The current autoconf.mk.dep rule uses the host cflags when executing the target compiler (which includes target header files). We don't want to mix the target compiler and host compiler flags, so change it to CFLAGS. Otherwise we get things like -pedantic which the U-Boot source code does not build with. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
