Update CHANGELOG.
Update CHANGELOG.
lowlevel_init.S is not used any more so remove it.
As consequence, we also don't have to generate u-boot.lds
but can use a static version as before.
This also fixes the out-of-tree build problem introduced
with commit f0a2c7b4 "at91: add support for the PM9263 board"
The PM9263 board is based on the AT91SAM9263-EK board.
Here is the page on Ronetix website:
http://www.ronetix.at/starter_kit_9263.html
Signed-off-by: Ilko Iliev <iliev@ronetix.at>
move to linux usb driver organisation
as following
drivers/usb/gadget
drivers/usb/host
drivers/usb/musb
Signed-off-by: Remy Bohmer <linux@bohmer.net>
Fix out-of-tree build of the imx31_phycore_eet target.
Reported-by: Wolfgang Denk <wd@denx.de>
Signed-off-by: Guennadi Liakhovetski <lg@denx.de>
The AT91RM9200-EK Evaluation Board supports the AT91RM9200
ARM9-based 32-bit RISC microcontroller and enables real-time code development
and evaluation.
Here is the chip page on Atmel website:
http://www.atmel.com/dyn/products/tools_card.asp?tool_id=3507
with
- NOR (cfi driver)
- DataFlash
- USB OHCI
- Net
- I2C (hard)
Signed-off-by: Ulf Samuelsson <ulf@atmel.com>
Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com>
This change makes the process of symlinking libfdt_internal.h
unnecessary
crc32.c uses the zlib.h header in include/u-boot/zlib.h. The symlink
was previously necessary to give U-Boot's version of zlib.h precedence
over the host computer's version of zlib.h.
The original code did not generate autoconf.mk until after some targets
dependencies had already been calculated, for example the directories in
the SUBDIRS variable
This patch adds MPC8569MDS board support. The UART, QE UEC1 and UEC2, BRD
EEPROM on I2C2 bus, PCI express and DDR3 SPD are supported in this patch.
Signed-off-by: Haiying Wang <Haiying.Wang@freescale.com>
Signed-off-by: Hillel Avni <Hillel.Avni@freescale.com>
This pretty unintelligent interface is used on some RTC chips.
Signed-off-by: Detlev Zundel <dzu@denx.de>
AT91sam9g20 is an evolution of the at91sam9260 with a faster clock speed.
The AT91SAM9G20-EK board is an updated revision of the AT91SAM9260-EK board.
It is essentially the same, with a few minor differences.
http://www.atmel.com/dyn/products/product_card.asp?part_id=4337
Signed-off-by: Justin Waters <justin.waters@timesys.com>
Update CHANGELOG
The U-Boot UBIFS implementation is largely a direct copy from the current
Linux version (2.6.29-rc6). As already done in the UBI version we have an
"abstraction layer" to redefine or remove some OS calls (e.g. mutex_lock()
...). This makes it possible to use the original Linux code with very
little changes. And by this we can better update to later Linux versions.
I removed some of the Linux features that are not used in the U-Boot
version (e.g. garbage-collection, write support).
CC: Artem Bityutskiy <dedekind@infradead.org>
CC: Adrian Hunter <ext-Adrian.Hunter@nokia.com>
This patch adds LZO decompression support to U-Boot. It is needed for
the upcoming UBIFS support, since UBIFS uses LZO as default compressor/
decompressor. Since we only support read-only in UBIFS, only the
decompressor is needed.
All this is copied with minor changes from the current Linux kernel
version (2.6.28-rc8).
This patch only implements this LZO decompressor support for PPC.
Other platforms using UBIFS will have to add the required
"include/asm/unaligned.h" as well. It should be fairly easy to copy this
from the Linux source tree as I have done it for PPC in this patch.
This is the InterControl custom device based on the MPC5200B chip.
Signed-off-by: Grzegorz Bernacki <gjb@semihalf.com>
This patch adds support for the kmsupx4 board from Keymile,
based on a Freescale MPC852T CPU
- serial console on SMC1
- 32 MB SDRAM
- 32 MB NOR Flash
- Ethernet over SCC3
- I2C Bitbang
renaming the "mgsuvd" board port into "km8xx", because
there come more similar boards from keymile.
Compiling the mgsuvd board with "make mgsuvd_config"
remains.
Update CHANEGLOG, fix minor coding style issue.
We can built 'make sh7785lcr_32bit_config'. And add new command "pmb"
for this mode. This command changes PMB for using 512MB system memory.
Signed-off-by: Yoshihiro Shimoda <shimoda.yoshihiro@renesas.com>
The "eet" variant of the imx31_phycore board has an OLED display, using a
s6e63d6 display controller on the first SPI interface, using GPIO57 as a
chip-select for it. With this configuration you can display 256 colour BMP
images in 16-bit RGB (RGB565) LCD mode.
Acked-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
Commit e4943ec5 moved the ARM boards to a vendor directory but forgot
to adapt the cleanup rules in the Makefile
Signed-off-by: Peter Griffin <pgriffin@mpc-data.co.uk>
The TQM8548_AG is a variant of the TQM8548 module with 1 GiB memory,
CAN and without PCI/PCI-X and RTC. U-Boot can be built for this module
with "$ make TQM8548_AG_config".
Signed-off-by: Wolfgang Grandegger <wg@grandegger.com>
The TQM8548_BE is a variant of the TQM8548 module with NAND and CAN
interface. With NAND support, the image is significantly larger and
TEXT_BASE is adjusted accordingly. U-Boot can be built for this
module with "$ make TQM8548_BE_config".
This patch adds support for Dave/DENX QongEVB-LITE i.MX31-based board.
Signed-off-by: Ilya Yanok <yanok@emcraft.com>
Support for Zoom MDK with OMAP3430. Details of Zoom MDK available here:
http://www.logicpd.com/products/devkit/ti/zoom_mobile_development_kit
Signed-off-by: Nishanth Menon <nm@ti.com>
Signed-off-by: Jason Kridner <jkridner@beagleboard.org>
Add Pandora support.
Signed-off-by: Grazvydas Ignotas <notasas@gmail.com>
Signed-off-by: Dirk Behme <dirk.behme@googlemail.com>
Add EVM board support.
Signed-off-by: Manikandan Pillai <mani.pillai@ti.com>
Add Overo board support.
Signed-off-by: Steve Sakoman <sakoman@gmail.com>
