path: root/Makefile
2009-01-23microblaze: Rename ml401 to microblaze-genericMichal Simek
2009-01-21Prepare v2009.01v2009.01Wolfgang Denk
2009-01-18Prepare 2009.01-rc3v2009.01-rc3Wolfgang Denk
Update CHANGELOG Signed-off-by: Wolfgang Denk <wd@denx.de>
2009-01-16sh: Fix up rsk7203 target for out of tree buildKieran Bingham
Fix up rsk7203 target to build successfully using out-of-tree build. Signed-off-by: Kieran Bingham <kbingham@mpc-data.co.uk> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2009-01-06at91: add at91sam9xeek board supportNicolas Ferre
At91sam9xe is basically an at91sam9260 with embedded flash. We can manage it as another entry for at91sam9260 in the Makefile. Check documentation at : http://www.atmel.com/dyn/products/product_card.asp?part_id=4263 Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com> Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2009-01-06fix bmp_logo.h make dependencies to allow parallel buildJean-Christophe PLAGNIOL-VILLARD
2009-01-06at91: Fix Atmel's at91sam9 boards out of tree buildJean-Christophe PLAGNIOL-VILLARD
introduced in commit 89a7a87f084c Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2008-12-19XPedite5200 board supportPeter Tyser
Initial support for Extreme Engineering Solutions XPedite5200 - a MPC8548-based PMC single board computer. Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2008-12-19XPedite5370 board supportPeter Tyser
Initial support for Extreme Engineering Solutions XPedite5370 - a MPC8572-based 3U VPX single board computer with a PMC/XMC site. Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2008-12-19Add support for PCA953x I2C gpio devicesPeter Tyser
Initial support for NXP's 4 and 8 bit I2C gpio expanders (eg pca9537, pca9557, etc). The CONFIG_PCA953X define enables support for the devices while the CONFIG_CMD_PCA953X define enables the pca953x command. The CONFIG_CMD_PCA953X_INFO define enables an 'info' sub-command which provides summary information for the given pca953x device. Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2008-12-16Prepare 2009.01-rc1v2009.01-rc1Wolfgang Denk
2008-12-16Makefile: fix dependency problem with parallel buildsWolfgang Denk
Parallel builds (using "make -jN") would occasionally fail with error messages like include/autoconf.mk:212: *** missing separator. Stop. Line numbers and affected boards were changing. Obviously some Makefiles included autoconf.mk while it was still being written to. As a fix, we now write to a temporary file first and then rename it, so that it is really ready to use as soon as it appears. Signed-off-by: Wolfgang Denk <wd@denx.de>
2008-12-13Merge branch 'master' of git://git.denx.de/u-boot-ppc4xxWolfgang Denk
2008-12-13Merge branch 'master' of git://git.denx.de/u-boot-shWolfgang Denk
2008-12-10sh: fix rsk7203 and MigoR out of tree buildJean-Christophe PLAGNIOL-VILLARD
Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2008-12-10ppc4xx: Update TEXT_BASE for CPCI405 boardsMatthias Fuchs
This patch fixes building U-Boot for CPCI405 boards. Signed-off-by: Matthias Fuchs <matthias.fuchs@esd-electronics.com> Signed-off-by: Stefan Roese <sr@denx.de>
2008-12-10microblaze: Remove XUPV2P boardMichal Simek
--- Microblaze platforms use generic settings and to have many platforms is confusing that's why I decided to remove this platform from U-BOOT. ml401 tree is sufficient for covering all Microblaze platforms. This change will go through microblaze custodian tree.
2008-12-09Merge branch 'master' of git://git.denx.de/u-boot-at91Wolfgang Denk
2008-12-08Remove unneeded CONFIG_SHELL referencesPeter Tyser
Make should be using the bash shell by default which makes CONFIG_SHELL unnecessary Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2008-12-08Use bash for default GNU Make shell applicationPeter Tyser
Some Make script commands rely on bash-specific features like brace expansion, so default to bash for the SHELL variable with a fallback to the standard sh shell Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2008-12-06Update U-Boot's build timestamp on every compilePeter Tyser
Use the GNU 'date' command to auto-generate a new U-Boot timestamp on every compile. Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2008-12-06at91: Choose environment variables location within make config targetNicolas Ferre
This patch adds the possiblity to choose the media where the environment will be located. This allow to choose this fundamental configuration without editing config files. Documentation file added. Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com> Acked-by: Stelian Pop <stelian@popies.net> Acked-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2008-12-05FPGA: move fpga drivers to drivers/fpgaJean-Christophe PLAGNIOL-VILLARD
2008-11-19UBI: Add basic UBI support to U-Boot (Part 8/8)Kyungmin Park
This patch adds basic UBI (Unsorted Block Image) support to U-Boot. It's based on the Linux UBI version and basically has a "OS" translation wrapper that defines most Linux specific calls (spin_lock() etc.) into no-ops. Some source code parts have been uncommented by "#ifdef UBI_LINUX". This makes it easier to compare this version with the Linux version and simplifies future UBI ports/bug-fixes from the Linux version. Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Signed-off-by: Stefan Roese <sr@denx.de>
2008-11-10toplevel Makefile: Add MPC8641HPCN_36BIT targetBecky Bruce
This will enable CONFIG_PHYS_36BIT for MPC8641HPCN. Signed-off-by: Becky Bruce <becky.bruce@freescale.com>
2008-11-09Merge branch 'master' of git://git.denx.de/u-boot-at91Wolfgang Denk
2008-11-04Makefile/at91sam9: move some at91sam9 to the correct subsection for arm926ejsJean-Christophe PLAGNIOL-VILLARD
2008-11-04Custom AFEB9260 board supportSergey Lapin
This patch provides support for AFEB9260 board, a product of OpenSource hardware and software. Some commertial projects are made with this design. A board is basically AT91SAM9260-EK with some modifications and different peripherals and different parts used. Main purpose of this project is to gain experience in hardware design. More info: http://groups.google.com/group/arm9fpga-evolution-board (In Russian only, sorry). Subversion repository: svn://194.85.238.22/home/users/george/svn/arm9eb Signed-off-by: Sergey Lapin <slapin@ossfans.org>
2008-11-03ColdFire: Add MCF5301x CPU and M53017EVB supportTsiChung Liew
Signed-off-by: TsiChung Liew <Tsi-Chung.Liew@freescale.com>
2008-11-03ColdFire: Add SBF support for M52277EVBTsiChung Liew
Add serial boot support Signed-off-by: TsiChung Liew <Tsi-Chung.Liew@freescale.com>
2008-10-31sh: rsk7203: Moved rsk7203 board to board/renesasNobuhiro Iwamatsu
2008-10-31sh: MigoR: Moved MigoR board to board/renesasNobuhiro Iwamatsu
2008-10-31sh: r2dplus: Moved r2dplus board to board/renesasNobuhiro Iwamatsu
2008-10-31sh: sh7763rdp: Moved sh7763rdp board to board/renesasNobuhiro Iwamatsu
2008-10-31sh: sh7785lcr: Moved sh7785lcr board to board/renesasNobuhiro Iwamatsu
2008-10-31sh: r7780mp: Moved r7780mp board to board/renesasNobuhiro Iwamatsu
2008-10-31sh: ap325rxa: Moved ap325rxa board to board/renesasNobuhiro Iwamatsu
2008-10-24ppc4xx: New board avnet fx12 minimodulGeorg Schardt
This patch adds support for the avnet fx12 minimodul. It needs the "ppc4xx: Generic architecture for xilinx ppc405" patch from Ricardo. Signed-off-by: Georg Schardt <schardt@team-ctech.de> Signed-off-by: Ricardo Ribalda Delgado <ricardo.ribalda@uam.es> Signed-off-by: Stefan Roese <sr@denx.de>
2008-10-24ppc4xx: Generic architecture for xilinx ppc405(v3)Ricardo Ribalda Delgado
As "ppc44x: Unification of virtex5 pp440 boards" did for the xilinx ppc440 boards, this patch presents a common architecture for all the xilinx ppc405 boards. Any custom xilinx ppc405 board can be added very easily with no code duplicity. This patch also adds a simple generic board, that can be used on almost any design with xilinx ppc405 replacing the file ppc405-generic/xparameters.h This patch is prepared to work with the latest version of EDK (10.1) Signed-off-by: Ricardo Ribalda Delgado <ricardo.ribalda@uam.es> Signed-off-by: Stefan Roese <sr@denx.de>
2008-10-21ppc4xx: Add GDSys neo 405EP board supportDirk Eibach
Signed-off-by: Dirk Eibach <eibach@gdsys.de> Signed-off-by: Stefan Roese <sr@denx.de>
2008-10-21ppc4xx: Add AMCC Arches board support (dual 460GT)Adam Graham
The Arches Evaluation board is based on the AMCC 460GT SoC chip. This board is a dual processor board with each processor providing independent resources for Rapid IO, Gigabit Ethernet, and serial communications. Each 460GT has it's own 512MB DDR2 memory, 32MB NOR FLASH, UART, EEPROM and temperature sensor, along with a shared debug port. The two 460GT's will communicate with each other via shared memory, Gigabit Ethernet and x1 PCI-Express. Signed-off-by: Adam Graham <agraham@amcc.com> Signed-off-by: Victor Gallardo <vgallardo@amcc.com> Signed-off-by: Stefan Roese <sr@denx.de>
2008-10-18Merge 'next' branchWolfgang Denk
Conflicts: board/freescale/mpc8536ds/mpc8536ds.c include/configs/mgcoge.h Signed-off-by: Wolfgang Denk <wd@denx.de>
2008-10-18Add cpu/8xxx to TAGS_SUBDIRSEd Swarthout
Signed-off-by: Ed Swarthout <Ed.Swarthout@freescale.com>
2008-10-18mgsuvd, mgcoge: move this 2 boards in one dir.Heiko Schocher
There are some more extensions, which are for both boards and some more boards from this manufacturer will follow soon. Signed-off-by: Heiko Schocher <hs@denx.de> Signed-off-by: Wolfgang Denk <wd@denx.de>
2008-10-18Prepare v2008.10 release: update CHANGELOG & Makefilev2008.10Wolfgang Denk
2008-10-15Coding Style cleanup, update CHANGELOG, prepare 2008.10-rc3v2008.10-rc3Wolfgang Denk
2008-09-14Prepare v2008.10-rc2v2008.10-rc2Wolfgang Denk
2008-09-13Add support for LZMA uncompression algorithm.Luigi 'Comio' Mantellini
Signed-off-by: Luigi 'Comio' Mantellini <luigi.mantellini@idf-hit.com> Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2008-09-12Merge branch 'Makefile-next' of git://git.denx.de/u-boot-armWolfgang Denk
