path: root/Makefile
2016-04-10drivers:usb:common:fsl-dt-fixup: Move device-tree fixup framework to common fileSriram Dash
Move usb device-tree fixup framework from ehci-fsl.c to common place so that it can be used by other drivers as well (xhci-fsl.c). Signed-off-by: Ramneek Mehresh <ramneek.mehresh@nxp.com> Signed-off-by: Sriram Dash <sriram.dash@nxp.com> Acked-by: Marek Vasut <marex@denx.de>
2016-03-22cmd: Fix license commandTom Rini
The license command isn't usually built and has a few problems: - The rules to generate license.h haven't worked in a long time, re-write these based on the bmp_logo.h rules. - 'tok' is unused and the license text size has increased - bin2header.c wasn't grabbing unistd.h to know the prototype for read(). Cc: Masahiro Yamada <yamada.masahiro@socionext.com> Signed-off-by: Tom Rini <trini@konsulko.com>
2016-03-17x86: Add support for running Intel reference codeSimon Glass
Intel has invented yet another binary blob which firmware is required to run. This is run after SDRAM is ready. It is linked to load at a particular address, typically 0, but is a relocatable ELF so can be moved if required. Add support for this in the build system. The file should be placed in the board directory, and called refcode.elf. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2016-03-14spl: Add a way to specify a list of device trees to includeSimon Glass
When building a FIT, more than one device tree can be included. The board can select (at run-time) the one that it wants. Add a Kconfig option to allow the list of devices trees (supported by the board) to be specified. When using SPL_LOAD_FIT, build u-boot.img in FIT format instead of the legacy image format. Include all the listed device tree files in this FIT. Signed-off-by: Simon Glass <sjg@chromium.org>
2016-03-14Prepare v2016.03v2016.03Tom Rini
2016-02-29Prepare v2016.03-rc3v2016.03-rc3Tom Rini
2016-02-15Prepare v2016.03-rc2v2016.03-rc2Tom Rini
2016-02-15Makefile: generate symbol list from u-bootStephen Warren
This information may be useful for both debugging, and processes that want to perform simple forms of introspection on the U-Boot binary, such as determining the set of "ut" subtests that are compiled in. Signed-off-by: Stephen Warren <swarren@nvidia.com> Acked-by: Simon Glass <sjg@chromium.org>
2016-02-15Makefile: remove BUILD_TAG from KBUILD_CFLAGSStephen Warren
If BUILD_TAG is part of KBUILD_CFLAGS, then any time the value changes, all files get rebuilt. In a continuous integration environment, the value will change every build. This wastes time, assuming that incremental builds would otherwise occur. To solve this, remove BUILD_TAG from KBUILD_CFLAGS and add it to CFLAGS for just the one file that uses it. This does have the disadvantage that if any other files want to use the flag, we'll need to duplicate this custom CFLAGS setup logic. However, it seems unlikely we'll need this. An alternative would be to add BUILD_TAG to the "local version" and remove the special case code from display_options.c. However, that would affect the format of the U-Boot signon message, which may negatively affect people looking for specific data there. The approach of using file-specific CFLAGS was suggested by Masahiro Yamada. Signed-off-by: Stephen Warren <swarren@nvidia.com> Reviewed-by: Tom Rini <trini@konsulko.com> Reviewed-by: Masahiro Yamada <yamada.masahiro@socionext.com> Acked-by: Simon Glass <sjg@chromium.org>
2016-02-08kbuild: add missing FORCE where $(call if_changed, ) is usedMasahiro Yamada
FORCE is needed for $(call if_changed,...) to be evaluated every time. Otherwise, the command is not executed when the command line has changed but any prerequisite has not been updated. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2016-02-02Prepare v2016.03-rc1v2016.03-rc1Tom Rini
2016-02-01Makefile: Drop unnecessary -dtb suffixesSimon Glass
When OF_CONTROL is enabled, u-boot-dtb.* files are the same as u-boot.* files. So we can use the latter for simplicity. Tested-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Simon Glass <sjg@chromium.org>
2016-02-01Makefile: Make u-boot.img the same as u-boot-dtb.imgSimon Glass
Create u-boot.img even when OF_CONTROL is enabled, so that this file can be used in both cases. Tested-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Simon Glass <sjg@chromium.org>
2016-02-01socfpga: Simplify Makefile filenamesSimon Glass
We don't need the -dtb suffix anymore, so drop it. Tested-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Simon Glass <sjg@chromium.org>
2016-02-01tegra: Always build a boot image with the same filenameSimon Glass
Adjust the Makefile to build u-boot-tegra.bin which contains a device tree if OF_SEPARATE is enabled, and does not if not. This mirrors U-Boot's new approach of using u-boot.bin to handle both cases. Tested-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Simon Glass <sjg@chromium.org>
2016-02-01fdt: Build a U-Boot binary without device treeSimon Glass
At present u-boot.bin holds the plain U-Boot binary without the device tree. This is somewhat annoying since you need either u-boot.bin or u-boot-dtb.bin depending on whether device tree is used. Adjust the build such that u-boot.bin includes a device tree (if enabled), and the plain binary is in u-boot-nodtb.bin. For now u-boot-dtb.bin remains the same. This should be acceptable since: - without OF_CONTROL, u-boot.bin still does not include a device tree - with OF_CONTROL, u-boot-dtb.bin does not change The main impact is build systems which are set up to use u-boot.bin as the output file and then add a device tree. These will have to change to use u-boot-nodtb.bin instead. Adjust tegra rules so it continues to produce the correct files. Tested-by: Stephen Warren <swarren@nvidia.com> Reviewed-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Simon Glass <sjg@chromium.org>
2016-02-01tegra: Clarify generation of -nodtb file with OF_CONTROLSimon Glass
Fix the ALL-y logic in the Makefile so that is clear that we always want the -nodtb file. Tested-by: Stephen Warren <swarren@nvidia.com> Reviewed-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Simon Glass <sjg@chromium.org>
2016-01-25Move all command code into its own directorySimon Glass
There are a lot of unrelated files in common, including all of the commands. Moving them into their own directory makes them easier to find and is more logical. Some commands include non-command code, such as cmd_scsi.c. This should be sorted out at some point so that the function can be enabled with or without the associated command. Unfortunately, with m68k I get this error: m68k: + M5329AFEE +arch/m68k/cpu/mcf532x/start.o: In function `_start': +arch/m68k/cpu/mcf532x/start.S:159:(.text+0x452): relocation truncated to fit: R_68K_PC16 against symbol `board_init_f' defined in .text.board_init_f section in common/built-in.o I hope someone can shed some light on what this means. I hope it isn't depending on the position of code in the image. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Heiko Schocher <hs@denx.de> Acked-by: Stefan Roese <sr@denx.de> Acked-by: Przemyslaw Marczak <p.marczak@samsung.com>
2016-01-20kbuild: drop workaround for old style CONFIG_SYS_TEXT_BASE definesMasahiro Yamada
Now, there is no board defining CONFIG_SYS_TEXT_BASE by its config.mk, so this workaround is no longer needed. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Acked-by: Stefan Roese <sr@denx.de>
2016-01-14arm: mvebu: Add runtime detection of UART (xmodem) boot-modeStefan Roese
This patch adds runtime detection of the Marvell UART boot-mode (xmodem protocol). If this boot-mode is detected, SPL will return to the BootROM to continue the UART booting. With this patch its now possible, to generate a U-Boot image that can be booted either from the strapped boot-device (e.g. SPI NOR, MMC, etc) or via the xmodem protocol from the UART. In the UART case, the kwboot tool will dynamically insert the UART boot-device type into the image. And also patch the load address in the header, so that the mkimage header will be skipped (as its not expected by the Marvell BootROM). This simplifies the development for Armada XP / 38x based boards. As no special images need to be generated by selecting the MVEBU_BOOTROM_UARTBOOT Kconfig option. Since the Kconfig option MVEBU_BOOTROM_UARTBOOT is not needed any more, its now completely removed. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Luka Perkov <luka.perkov@sartura.hr> Cc: Dirk Eibach <dirk.eibach@gdsys.cc> Cc: Phil Sutter <phil@nwl.cc> Cc: Kevin Smith <kevin.smith@elecsyscorp.com>
2016-01-12Prepare v2016.01v2016.01Tom Rini
2016-01-08arm, Makefile: correct compilation flag for u-boot-dtbAneesh Bansal
The compilation of u-boot-dtb.img should be controlled by CONFIG_OF_CONTROL and not CONFIG_DM. CONFIG_DM may be defined even without Device Tree requirement. This was added in commit 947cee1127c5fa97529c8cda4f0b48d141f92560. Signed-off-by: Ruchika Gupta <ruchika.gupta@freescale.com> Signed-off-by: Aneesh Bansal <aneesh.bansal@freescale.com> CC: Alison Wang <alison.wang@freescale.com>
2016-01-04Prepare v2016.01-rc4v2016.01-rc4Tom Rini
2015-12-21Prepare v2016.01-rc3v2016.01-rc3Tom Rini
2015-12-07Prepare v2016.01-rc2v2016.01-rc2Tom Rini
2015-11-19ARM: zynq: Add target for building bootable SPL image for ZynqNathan Rossi
Add a build target to generate 'boot.bin' which includes SPL. This is used by the platforms BootROM to load SPL directly. This change also conditionally changes what the 'boot.bin' target generates depending on the SoC. Leaving the behaviour unchanged for the AT91 targets. Signed-off-by: Nathan Rossi <nathan@nathanrossi.com> Signed-off-by: Michal Simek <michal.simek@xilinx.com> Cc: Tom Rini <trini@konsulko.com> Cc: Andreas Bießmann <andreas.devel@googlemail.com> Cc: Heiko Schocher <hs@denx.de> Reviewed-by: Tom Rini <trini@konsulko.com>
2015-11-16Prepare v2016.01-rc1v2016.01-rc1Tom Rini
2015-11-10Merge branch 'master' of git://git.denx.de/u-boot-armTom Rini
2015-11-10Various Makefiles: Add SPDX-License-Identifier tagsTom Rini
After consulting with some of the SPDX team, the conclusion is that Makefiles are worth adding SPDX-License-Identifier tags too, and most of ours have one. This adds tags to ones that lack them and converts a few that had full (or in one case, very partial) license blobs into the equivalent tag. Cc: Kate Stewart <kstewart@linuxfoundation.org> Signed-off-by: Tom Rini <trini@konsulko.com>
2015-11-10arm: support Thumb-1 with CONFIG_SYS_THUMB_BUILDAlbert ARIBAUD
When building a Thumb-1-only target with CONFIG_SYS_THUMB_BUILD, some files fail to build, most of the time because they include mcr instructions, which only exist for Thumb-2. This patch introduces a Kconfig option CONFIG_THUMB2 and uses it to select between Thumb-2 and ARM mode for the aforementioned files. Signed-off-by: Albert ARIBAUD <albert.u.boot@aribaud.net>
2015-10-26arm: ls1021a: Add QSPI or IFC support in SD bootAlison Wang
As QSPI and IFC are pin-multiplexed on LS1021A, only IFC is supported in SD boot now. For the customer's demand, QSPI needs to be supported in SD boot too. This patch adds QSPI or IFC support in SD boot according to the corresponding defconfig. For detail, ls1021atwr_sdcard_ifc_defconfig is used to support IFC in SD boot and ls1021atwr_sdcard_qspi_defconfig is used to support QSPI in SD boot. Signed-off-by: Alison Wang <alison.wang@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
2015-10-21Merge git://git.denx.de/u-boot-x86Tom Rini
2015-10-21Makefile: Generate U_BOOT_DMI_DATE for SMBIOSBin Meng
Add U_BOOT_DMI_DATE (format mm/dd/yyyy) generation to be used by SMBIOS tables, as required by SMBIOS spec 3.0 [1]. See chapter 7.1, BIOS information structure offset 08h for details. [1] http://www.dmtf.org/sites/default/files/standards/documents/DSP0134_3.0.0.pdf Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-10-21arm: mvebu: Add DM (driver model) supportStefan Roese
This patch adds driver model support for some Marvell MVEBU SoC's. Including Armada XP and 38x. All 3 currently mainlined boards are converted. DM is now selected automatically for MVEBU platforms. With this DM support now available for MVEBU, hardcoding the base addresses and other information is not necessary any more. Probing should be done by using the values provided via the device tree now instead. For this the driver also need to be converted to DM. Patches for some of the drivers will follow. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Simon Glass <sjg@chromium.org> Cc: Luka Perkov <luka.perkov@sartura.hr>
2015-10-21arm: mvebu: Add option to use UART xmodem protocol via kwbootStefan Roese
This patch enables the use of the kwboot tool, to boot mainline U-Boot on the Marvell Armada XP/38x SoC's. This is done by returning to the SoC's BootROM after SPL has initialized the SDRAM. We need to make sure to not reconfigure the internal register space and MBARs. Otherwise the BootROM will not be able to continue after SPL jumps back to it. To use this feature, please don't forget to change the BOOT_FROM line in your board specfic kwbimage.cfg file this way: BOOT_FROM uart Tested on these Marvell eval boards: DB-MV784MP-GP - Armada XP DB-88F6820-GP - Armada 38x Signed-off-by: Stefan Roese <sr@denx.de> Cc: Dirk Eibach <eibach@gdsys.de> Cc: Kevin Smith <kevin.smith@elecsyscorp.com> Cc: Luka Perkov <luka.perkov@sartura.hr>
2015-10-19Prepare v2015.10v2015.10Tom Rini
2015-10-12Prepare v2015.10-rc5v2015.10-rc5Tom Rini
2015-09-28Prepare v2015.10-rc4v2015.10-rc4Tom Rini
2015-09-07Prepare v2015.10-rc3v2015.10-rc3Tom Rini
2015-08-28Makefile: fix SOURCE_DATE_EPOCH for *BSD hostAndreas Bießmann
The SOURCE_DATE_EPOCH mechanism for reproducible builds require some date(1) with -d switch to print the relevant date and time strings of another point of time. In other words it requires some date(1) that behaves like the GNU date(1) [1]. The BSD date(1) [2] on the other hand has the same switch but with a different meaning. Respect this and check the date(1) abilities before usage, error on non working version. Use the well known pre- and suffixes for the GNU variant of a tool on *BSD hosts to search for a working date(1) version. [1] http://man7.org/linux/man-pages/man1/date.1.html [2] http://www.freebsd.org/cgi/man.cgi?query=date Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com>
2015-08-28ARM: keystone2: move the custom build rules out to keystone specific makefileNishanth Menon
Keystone has build rules introduced by commit ef509b9063fb7 ("k2hk: add support for k2hk SOC and EVM") and commit 0e7f2dbac6ead ("keystone: add support for NAND gpheader image"). These are not reused by other platforms for the build, hence there is no clear benefit is maintaining them in the generic makefile as a build target. move these to the keystone specific make option Original idea of using config.mk by Lokesh Vutla <lokeshvutla@ti.com> Signed-off-by: Nishanth Menon <nm@ti.com> Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com>
2015-08-28Makefile: Use correct timezone for U_BOOT_TZChris Packham
When building with SOURCE_DATE_EPOCH the timezone is in UTC. When building normally the timezone is taken from the build machine's locale setting. Signed-off-by: Chris Packham <judge.packham@gmail.com> Tested-by: Bin Meng <bmeng.cn@gmail.com> Tested-by: Paul Kocialkowski <contact@paulk.fr> Tested-by: Andreas Bießmann <andreas.devel@googlemail.com>
2015-08-26x86: ifdtool: Support collating microcode into one placeSimon Glass
The Intel Firmware Support Package (FSP) requires that microcode be provided very early before the device tree can be scanned. We already support adding a pointer to the microcode data in a place where early init code can access. However this just points into the device tree and can only point to a single lot of microcode. For boards which may have different CPU types we must support multiple microcodes and pass all of them to the FSP in one place. Enhance ifdtool to scan all the microcode, place it together in the ROM and update the microcode pointer to point there. This allows us to pass multiple microcode blocks to the FSP using its existing API. Enable the flag in the Makefile so that this feature is used by default for all boards. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Tested-by: Bin Meng <bmeng.cn@gmail.com>
2015-08-17Prepare v2015.10-rc2v2015.10-rc2Tom Rini
2015-08-08Makefile: Add target for building bootable SPL image for SoCFPGAMarek Vasut
Add build target for generating boot partition images recognised by the SoCFPGA BootROM. The SoCFPGA BootROM expects four copies of the u-boot-spl-dtb.sfp at the beginning of boot partition. Those are u-boot-spl-dtb.bin augmented by a header with which the BootROM can work. The u-boot-dtb.img uImage is appended to this to produce a full boot partition image, the u-boot-with-spl-dtb.sfp . This is the name of the final target. Signed-off-by: Marek Vasut <marex@denx.de>
2015-08-08driver/ddr/altera: Add DDR driver for Altera's SDRAM controllerDinh Nguyen
This patch enables the SDRAM controller that is used on Altera's SoCFPGA family. This patch configures the SDRAM controller based on a configuration file that is generated from the Quartus tool, sdram_config.h. Signed-off-by: Dinh Nguyen <dinguyen@opensource.altera.com>
2015-08-05efi: Add 64-bit payload supportSimon Glass
Most EFI implementations use 64-bit. Add a way to build U-Boot as a 64-bit EFI payload. The payload unpacks a (32-bit) U-Boot and starts it. This can be enabled for x86 boards at present. Signed-off-by: Simon Glass <sjg@chromium.org> Improvements to how the payload is built: Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Tested-by: Bin Meng <bmeng.cn@gmail.com>
2015-08-05efi: Add support for loading U-Boot through an EFI stubSimon Glass
It is useful to be able to load U-Boot onto a board even if is it already running EFI. This can allow access to the U-Boot command interface, flexible booting options and easier development. The easiest way to do this is to build U-Boot as a binary blob and have an EFI stub copy it into RAM. Add support for this feature, targeting 32-bit initially. Also add a way to detect when U-Boot has been loaded via a stub. This goes in common.h since it needs to be widely available so that we avoid redoing initialisation that should be skipped. Signed-off-by: Simon Glass <sjg@chromium.org> Improvements to how the payload is built: Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Tested-by: Bin Meng <bmeng.cn@gmail.com>
2015-08-05efi: Support building a u-boot-app.efi executableSimon Glass
Add support for building U-Boot as an EFI application with a .efi suffix. This can be loaded by EFI provided that EFI has the same bit width (32- or 64-bit) as U-Boot. This unfortunate limitation is imposed by EFI. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2015-08-05Allow objcopy to work without filling gaps with 0xffSimon Glass
This is currently done for all targets, since 0xff is the default erased value for most flash devices. In some cases this is not what we want (e.g. for EFI images) so provide a command to do a vanilla objcopy. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
