With sandbox we want to be able to emulate USB devices so that we can test
the USB stack. Add a uclass to support this. It implements the same
operations as a normal USB device driver, but in this case passes them on
to an emulation driver.
Now that the entire dwc3 driver is adapted to compile with uboot build,
modify the Makefiles so that the dwc3 driver can be built.
Signed-off-by: Kishon Vijay Abraham I <kishon@ti.com>
Reviewed-by: Lukasz Majewski <l.majewski@samsung.com>
Work_92105 from Work Microwave is an LPC3250-
based board with the following features:
- 64MB or 128MB SDR DRAM
- 1 GB SLC NAND, managed through MLC controller.
- Ethernet
- Ethernet + PHY SMSC8710
- I2C:
- EEPROM (24M01-compatible)
- RTC (DS1374-compatible)
- Temperature sensor (DS620)
- DACs (2 x MAX518)
- SPI (through SSP interface)
- Port expander MAX6957
- LCD display (HD44780-compatible), controlled
through the port expander and DACs
This board has SPL support, and uses the LPC32XX boot
image format.
Signed-off-by: Albert ARIBAUD (3ADEV) <albert.aribaud@3adev.fr>
Since the Kconfig conversion, config.mk has been included only when
include/config/auto.conf is newer than the .config file.
It causes build error if both files have the same time-stamps.
It is actually possible because EXT* file systems have a 1s time-stamp
resolution.
The config.mk should be included when include/config/auto.conf is
*not older* than the .config file.
Reported-by: Tom Rini <trini@konsulko.com>
Reported-by: York Sun <yorksun@freescale.com>
Reported-by: Stephen Warren <swarren@nvidia.com>
Reported-by: Matthew Gerlach <mgerlach@opensource.altera.com>
Move the option to Kconfig renaming it to CONFIG_HAVE_GENERIC_BOARD.
Reviewed-by: Alexey Brodkin <abrodkin@synopsys.com>
We have switched to the single .config configuration system,
the same one as used in Linux Kernel.
The necessary glue code is small enough now, so move it to the
top-level Makefile and scripts/kconfig/Makefile, and then delete
scripts/multiconfig.sh.
Commit a93648d197df48fa46dd55f925ff70468bd81c71 introduced linker generated
lists for imagetool which is the base for some host tools (mkimage, dumpimage,
et al.). Unfortunately some host tool chains do not support the used type of
linker scripts. Therefore this commit broke these host-tools for them, namely
FreeBSD and Darwin (OS/X).
This commit tries to fix this. In order to have a clean distinction between host
and embedded code space we need to introduce our own linker generated list
instead of re-using the available linker_lists.h provided functionality. So we
copy the implementation used in linux kernel script/mod/file2alias.c which has
the very same problem (cause it is a host tool). This code also comes with an
abstraction for Mach-O binary format used in Darwin systems.
Cc: Guilherme Maciel Ferreira <guilherme.maciel.ferreira@gmail.com>
This build target now includes the SPL binary as the bin_hdr into the
kwb image. Its used on the AXP port with the mainlined DDR training code.
Reviewed-by: Luka Perkov <luka.perkov@sartura.hr>
Rather than requiring the Makefile to be modified, provide a build option to
enable the ROM to be built.
We cannot do this by default since it requires binary blobs. Without these
the build will fail.
For boards which use multiple I2C devices, or for SOCs which support
multiple boards, we might want to convert these to driver model at different
times. At present this is difficult because we need to either use
CONFIG_DM_I2C for a board or not.
Add a compatibility layer which implements the old API, thus allowing a
board to move to driver model for I2C without requiring that everything it
uses is moved in the same commit.
When build for Atmel related boards which support SPL,
it will generate boot.bin, also clean when it when do
"make clean" operation.
Signed-off-by: Bo Shen <voice.shen@atmel.com>
Acked-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
To avoid having two microcode formats, adjust the build system to support
obtaining the microcode from the device tree, even in the case where it
must be made available before the device tree can be accessed.
Tested-by: Bin Meng <bmeng.cn@gmail.com>
Refactor u-boot.rom build rules by utilizing quiet_cmd_ and cmd_
macros. Also make writing mrc.bin and pci option rom to u-boot.rom
optional and remove mrc.bin from its dependent file list as not
every x86 board port needs mrc binary blob.
In SD boot, the magic number of u-boot image will be checked.
For LS102xA, u-boot.bin doesn't have the magic number. So use
u-boot.img which includes the magic number instead of u-boot.bin
when producing u-boot-with-spl-pbl.bin.
Signed-off-by: Alison Wang <alison.wang@freescale.com>
Reviewed-by: York Sun <yorksun@freescale.com>
For LS102xA, the size of spl/u-boot-spl.bin is variable.
This patch adds the support to deal with the variable
u-boot size in pblimage tool. It will be padded to 64
byte boundary.
Use pblimage_check_params() to add the specific operations
for ARM, such as PBI CRC and END command and the calculation
of pbl_cmd_initaddr.
Introduce a Makefile under arch/$ARCH/ and include it in the
top Makefile (similar to Linux kernel). This allows further
refactoringi like moving architecture-specific code out of global
makefiles, deprecating config variables (CPU, CPUDIR, SOC) or
deprecating arch/$ARCH/config.mk.
In contrary to Linux kernel, U-Boot defines the ARCH variable by
Kconfig, thus the arch Makefile can only included conditionally
after the top config.mk.
Signed-off-by: Daniel Schwierzeck <daniel.schwierzeck@gmail.com>
Some x86 machines require a binary blob containing 16-bit initialisation
code for their video hardware. Allow this to be built into the x86 ROM so
that it is accessible during boot.
arch/x86/cpu/Makefile
Some CPUs of some architectures have SOC directories.
At present, the build system directly descends into SOC directories
from the top Makefile, but it should generally descend into each
directory from its parent directory.
On x86 machines U-Boot needs to be added to a large ROM image which is
then flashed onto the target board. The ROM has a particular format so it
makes sense for U-Boot to build this image automatically. Unfortunately
it relies on binary blobs so we cannot require this for the default
build as yet.
Create a u-boot.rom output file for this purpose.
Remove BFIN from the CPU macro in Makefile.
Signed-off-by: Sonic Zhang <sonic.zhang@analog.com>
This commit imports some updates in misc scripts from Linux 3.18-rc1.
[1] commit cbb4d3e6510b99522719c5ef0 by Horia Geanta
scripts/kernel-doc: handle object-like macros
[2] commit 164f0d2efaaef83 by Michal Marek
kbuild: Fix handling of backslashes in *.cmd files
[3] commit 270a00963cd367214e by Randy Dunlap
scripts/kernel-doc: recognize __meminit
[4] commit a4954fd7724c0f55361eb5 by Masahiro Yamada
kbuild: remove obj-n and lib-n handling
[5] commit 5b2389b45d1a9c12b9f by Masahiro Yamada
kbuild: simplify build, clean, modbuiltin shorthands
Signed-off-by: Horia Geanta <horia.geanta@freescale.com>
Since Linux 3.15, relative path feature and related fixes,
cleanups have been merged to the top Makefile.
The relative path feature looks stable enough, so let's import it
to U-Boot along with various cleanups.
Commits imported from Linux (some need adjustment) are:
[1] commit 7e1c04779efd by Michal Marek
kbuild: Use relative path for $(objtree)
[2] commit 890676c65d69 by Michal Marek
kbuild: Use relative path when building in the source tree
[3] commit 9da0763bdd82 by Michal Marek
kbuild: Use relative path when building in a subdir of the source tree
[4] commit c2e28dc975ea by Michal Marek
kbuild: Print the name of the build directory
[5] commit 066b7ed95580 by Michal Marek
kbuild: Do not print the build directory with make -s
[6] commit 3f1d9a6cec01 by Michal Marek
kbuild: make -s should be used with kernelrelease/kernelversion/image_name
[7] commit 7ff525712acf by Masahiro Yamada
kbuild: fake the "Entering directory ..." message more simply
[8] commit 745a254322c8 by Masahiro Yamada
kbuild: use $(Q) for sub-make target
[9] commit aa55c8e2f7a3 by Masahiro Yamada
kbuild: handle C=... and M=... after entering into build directory
[10] commit ab7474ea5361 by Borislav Petkov
Kbuild: Ignore GREP_OPTIONS env variable
To use relative path feature, tools/Makefile and scripts/Makefile.autoconf
must be tweaked.
Now we stick to Linux Kernel's build system, so squash
"clobber" to "clean" target.
Commit 0f605c1501f6 (Start the deprecation process for generic board)
added a run-time warning message. Let's be noisier for non-generic
boards to inform the dead line of the conversion.
This commit intentionally outputs a warning message to stdout.
We still have many unconverted boards. If we print the message
to stderr, MAKEALL and buildman will report tons of broken boards
and really important information will be buried.
Cc: Tom Rini <trini@ti.com>
For now we won't want to mess with the existing configurations. Create a
new one which will enable device tree and driver model. Note that this
brings the device tree binary into u-boot-sunxi-with-spl.bin.
Now CONFIG_USE_PRIVATE_LIBGCC is only used as a boolean macro.
Remove CONFIG_USE_PRIVATE_LIBGCC=path/to/libgcc syntax.
Add target to build it automatically upon "make" / MAKEALL. This can/should
be set by board / cpu specific headers if a special U-Boot image is
required for this SoC / board.
E.g. used by Marvell Armada XP to automatically build the u-boot.kwb
target.
Cc: Masahiro Yamada <yamada.m@jp.panasonic.com>
This basic support for the Marvell Armada XP is base on the existing kirkwood
support. Which has been generatized by moving some common files into
common marvell locations.
This is in preparation for the upcoming Armada XP MV78460 support.
Tested-by: Luka Perkov <luka@openwrt.org>
By moving some kirkwood files into a Marvell common directory, those files
can be used by other Marvell platforms as well. The name mvebu is taken
from the Linux kernel source tree. It has been chosen there to represent
the SoC's from the Marvell EBU (Engineering Business Unit). Those SoC's
currently are:
Armada 370/375/XP, Dove, mv78xx0, Kirkwood, Orion5x
This will be used by the upcoming Armada XP (MV78460) platform support.
Acked-by: Prafulla Wadaskar <prafulla@marvell.com>
With the introduction of CONFIG_LOCALVERSION support we cannot build
tools without having a config file (as we won't know our PLAIN_VERSION
until then).
Reported-by: Otavio Salvador <otavio@ossystems.com.br>
[1] Move driver/core/, driver/input/ and drivers/input/ entries
from the top Makefile to drivers/Makefile
[2] Remove the conditional by CONFIG_DM in drivers/core/Makefile
because the whole drivers/core directory is already selected
by CONFIG_DM in the upper level
[3] Likewise for CONFIG_DM_DEMO in drivers/demo/Makefile
[4] Simplify common/Makefile - both CONFIG_DDR_SPD and
CONFIG_SPD_EEPROM are boolean macros so they can directly
select objects
