U-Boot has imported various source files from other projects,
mostly Linux.
Something like
#ifdef __UBOOT__
[ modification for U-Boot ]
#else
[ original code ]
#endif
is an often used strategy for clarification of adjusted parts,
that is, easier re-sync in future.
Instead of defining __UBOOT__ in each source file,
passing it from the top Makefile would be easier.
Acked-by: Heiko Schocher <hs@denx.de>
Since the host compiler might not be gcc but e.g. clang
default to cc/c++ to invoke it.
cc: Masahiro Yamada <yamada.m@jp.panasonic.com>
cc: Tom Rini <trini@ti.com>
Signed-off-by: Jeroen Hofstee <jeroen@myspectrum.nl>
Copy the Kconfig option from "init/Kconfig" of Linux v3.16 tag
and adjust the help document.
Commit 51148790 added scripts/multiconfig.py written in Python 2
to adjust Kconfig for U-Boot.
It has been hard for Python 3 users because Python 2 and Python 3
are not compatible with each other.
We are not happy about adding a new host tool dependency
(in this case, Python version dependency) for the core build process.
After some discussion, we decided to use only basic tools.
The script may get a bit more unreadable by shell scripting,
but we believe it is worthwhile.
In addition, this commit revives "<board>_config" target that is
equivalent to "<board>_defconfig" for backwards compatibility.
It is annoying to adjust various projects which use U-Boot.
Suggested-by: Igor Grinberg <grinberg@compulab.co.il>
Tested-by: Igor Grinberg <grinberg@compulab.co.il>
Cc: Tom Rini <trini@ti.com>
Cc: Jeroen Hofstee <jeroen@myspectrum.nl>
Cc: Stephen Warren <swarren@nvidia.com>
Signed-off-by: Roger Meier <roger@bufferoverflow.ch>
Reviewed-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
Tested-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
The command generating the "common/system_map.o" file was always shown
during the build making the output messy. Now it is called using the
Kbuild "cmd" macro, so that the full command is shown only when
building in verbose mode.
Signed-off-by: Vasili Galka <vvv444@gmail.com>
"make %_config all" was supported for the first time in U-Boot:
commit 53bca5ab
kbuild: support simultaneous board configuration and "make all"
Surprisingly it had not been working in Linux Kernel for a long time.
So I sent back the patch to the Linux Kbuild community and it was
accepted with a little code improvement, at commit 9319f453.
Now, you can do "make defconfig all" or "make %_defconfig all"
in Linux too.
This commit updates some scripts to fill the code-diff
between Linux and U-Boot.
This commit was imported from Linux Kernel:
commit a86fe353 written by me.
W=... provides extra gcc checks.
Having such code in scripts/Makefile.build results in the same flags
being added to KBUILD_CFLAGS multiple times becuase
scripts/Makefile.build is invoked every time Kbuild descends into
the subdirectories.
Since the top Makefile is already too cluttered, this commit moves
all of extra gcc check stuff to a new file scripts/Makefile.extrawarn,
which is included from the top Makefile.
u-boot.map is generated automatically by the compiler and more
importantly can handle addresses >4GB.
file_size was being calculated using back-ticks but map_size uses
$(shell ...). Update the file_size calculation to use $(shell ...).
The binary_size_check target relies on stat -c %s
to return the size of u-boot.bin. This only works
with GNU stat though. Use wc instead.
Signed-off-by: Chris Packham <judge.packham@gmail.com>
This commit enables Kconfig.
Going forward, we use Kconfig for the board configuration.
mkconfig will never be used. Nor will include/config.mk be generated.
Kconfig must be adjusted for U-Boot because our situation is
a little more complicated than Linux Kernel.
We have to generate multiple boot images (Normal, SPL, TPL)
from one source tree.
Each image needs its own configuration input.
Usage:
Run "make <board>_defconfig" to do the board configuration.
It will create the .config file and additionally spl/.config, tpl/.config
if SPL, TPL is enabled, respectively.
You can use "make config", "make menuconfig" etc. to create
a new .config or modify the existing one.
Use "make spl/config", "make spl/menuconfig" etc. for spl/.config
and do likewise for tpl/.config file.
The generic syntax of configuration targets for SPL, TPL is:
<target_image>/<config_command>
Here, <target_image> is either 'spl' or 'tpl'
<config_command> is 'config', 'menuconfig', 'xconfig', etc.
When the configuration is done, run "make".
(Or "make <board>_defconfig all" will do the configuration and build
in one time.)
For futher information of how Kconfig works in U-Boot,
please read the comment block of scripts/multiconfig.py.
By the way, there is another item worth remarking here:
coexistence of Kconfig and board herder files.
Prior to Kconfig, we used C headers to define a set of configs.
We expect a very long term to migrate from C headers to Kconfig.
Two different infractructure must coexist in the interim.
In our former configuration scheme, include/autoconf.mk was generated
for use in makefiles.
It is still generated under include/, spl/include/, tpl/include/ directory
for the Normal, SPL, TPL image, respectively.
Add support for NAND gpheader image. TI Keystone2 ROM bootloader
expects 8 bytes of trailing zeroes in the nand u-boot image.
So add zeros at the end of the nand gph image.
Acked-by: Murali Karicheri <m-karicheri2@ti.com>
Signed-off-by: Ivan Khoronzhuk <ivan.khoronzhuk@ti.com>
Replace the TAGS target name by the actual ctags target name.
Also, add etags target documentation.
Cc: Masahiro Yamada <yamada.m@jp.panasonic.com>
Signed-off-by: Igor Grinberg <grinberg@compulab.co.il>
Commit efcf861 (kbuild: use scripts/Makefile.clean)
refactored the cleaning targets and accidentially replaced the actually
generated "ctags" and "etags" files in the file list by "tags" and "TAGS".
"tags" and "TAGS" are not part of the Makefile build targets and
therefore should not be a part of the list for clean targets.
Substitute the actually generated files instead, to fix the clean
targets behavior.
Commit 9e41403 (kbuild: change out-of-tree build)
changed the U-Boot build working directory to the output tree
for the out-of-tree builds.
This broke the {c,e}tags/cscope build targets as TAG_SUBDIRS variable
collected directories based on assumption that the build working
directory is the U-Boot source tree directory.
Fix the {c,e}tags/cscope build targets by adding the $(srctree) prefix.
Also, remove the $(obj) prefix from the etags build target to finish
the $(obj) prefix removal started by the same commit.
Commit 7d89982b stopped creating symbolic link
arch/${arch}/include/asm/proc.
We do not need to delete it by "make mrproper" any more.
Cc: Vasili Galka <vvv444@gmail.com>
We need to subtract two hex numbers. Avoid using strtonum() by doing the
subtraction in bc with a suitable input base.
Reported-by: Vasili Galka <vvv444@gmail.com>
Import the following trivial commits from Linux v3.16-rc1:
bb66fc6 kbuild: trivial - use tabs for code indent where possible
7eb6e34 kbuild: trivial - remove trailing empty lines
3fbb43d kbuild: trivial - fix comment block indent
38385f8 kbuild: trivial - remove trailing spaces
This seems like a better name. This is a patch-up to the earlier commit
63b4b5b, and also removes a redundant Makefile change.
All files under spl/ and tpl/ are generated during the build process
except spl/Makefile.
We can simplify clean-rule and git-ignore by moving spl/Makefile
to somewhere else.
In some cases, an externally-built device tree binary is required to be
attached to U-Boot. An example is when using image signing, since in that
case the .dtb file must include the public keys.
Add a DEV_TREE_BIN option to the Makefile, and update the documentation.
Usage is something like:
make DEV_TREE_BIN=boot/am335x-boneblack-pubkey.dtb
Check that the image size matches the size we get from u-boot.bin. If it
doesn't, that generally means that some extra sections are being added to
u-boot.bin, meaning that it is not possible to access data appended to
the U-Boot binary. This is used for device tree, so needs to work.
This problem was introduced by commit b02bfc4. By adding a test we can
prevent a reccurence.
Building u-boot tools with clang as a host compiler e.g. on
FreeBSD with `gmake HOSTCC=clang CONFIG_USE_PRIVATE_LIBGCC=y tools`
leads to many warnings [1] for every compiler invocation since
commit 598e2d33. Part of mentioned commit imports linux patches:
- kbuild: LLVMLinux: Adapt warnings for compilation with clang
- kbuild: LLVMLinux: Add Kbuild support for building kernel with Clang
No version of clang supports the gcc fno-delete-null-pointer-checks
though, but it is only passed to clang. Gcc does not have the clang
specific Qunused-arguments for the target. Furthermore several
warnings are disabled which aren't encountered in u-boot. Since such
a build has worked for quite some time and works after removing these
changes, just remove the clang specific handling to restore normal
building with clang as hostcc.
[1] Actual warnings
GEN include/autoconf.mk.dep
arm-freebsd-gcc: unrecognized option '-Qunused-arguments'
HOSTCC scripts/basic/fixdep
clang: warning: argument unused during compilation:
'-fno-delete-null-pointer-checks'
Remove the common infrastructure of nand_spl and
clean-up the code inside ifdef(CONFIG_NAND_U_BOOT)..endif.
"checkstack" target uses $(PERL) so PERL must be defined.
RANLIB was added by commit e221174 (more than a decade ago)
but it has been never referenced at all.
Add support for booting from an MMC card.
Signed-off-by: Henrik Nordström <henrik@henriknordstrom.net>
Signed-off-by: Ian Campbell <ijc@hellion.org.uk>
Cc: Tom Cubie <Mr.hipboi@gmail.com>
Reviewed-by: Tom Rini <trini@ti.com>
In case of multilib-enabled toolchains if default architecture differ from
the one examples are being built for linker will fail to link example object
files with libgcc of another (non-compatible) architecture.
Interesting enough for years in main Makefile we used CFLAGS/c_flags for this
but not for examples.
So fixing it now.
Signed-off-by: Alexey Brodkin <abrodkin@synopsys.com>
Cc: Wolfgang Denx <wd@denx.de>
Acked-by: WOlfgang Denk <wd@denx.de>
Acked-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
boards.cfg
Conflicts were trivial once u-boot-arm/master boards.cfg was
reformatted (commit 6130c146) to match u-boot/master's own
reformatting (commit 1b37fa83).
In SPL framework, SPL uses u-boot.img to load u-boot.bin.
Here,
u-boot.img = uImage header + u-boot.bin
To use OF control with a separate devicetree,
u-boot.dtb must be placed right after u-boot.bin.
In this case, u-boot-dtb.bin is generally used.
Here,
u-boot-dtb.bin = u-boot.bin + u-boot.dtb
We need u-boot-dtb.img to use both SPL framework
and separate OF control at the same time.
u-boot-dtb.img = uImage header + u-boot-dtb.bin
For example, Zynq boards already define all of
- CONFIG_SPL
- CONFIG_OF_CONTROL
- CONFIG_OF_SEPARATE
So, the support of u-boot-dtb.img is urgent.
Cc: Michal Simek <michal.simek@xilinx.com>
The commits
commit b7b5f1a16ca66dfdd817e7339f0e263a5b9f2758
Author: Albert ARIBAUD <albert.u.boot@aribaud.net>
da850evm, da850_am18xxevm: convert to CONFIG_SPL_MAX_FOOTPRINT
and
commit e7497891e34efe5cb2b3a3dc7c6c096c012ede28
cam_enc_4xx: convert to CONFIG_SPL_MAX_FOOTPRINT
replaced CONFIG_SPL_MAX_SIZE by CONFIG_SPL_MAX_FOOTPRINT. However,
CONFIG_SPL_MAX_SIZE is used in the Makefile for padding the SPL
when preparing an u-boot.ais image. By removing CONFIG_SPL_MAX_SIZE
said commits broke the ais image of the da850evm and cam_enc_4xx
configurations.
This patch converts the u-boot.ais target to use CONFIG_SPL_PAD_TO
instead of CONFIG_SPL_MAX_SIZE for padding the SPL and adds
a #define CONFIG_SPL_PAD_TO where it is required.
Signed-off-by: Christian Riesch <christian.riesch@omicron.at>
Reported-by: Tom Taylor <ttaylor.tampa@gmail.com>
Cc: Sudhakar Rajashekhara <sudhakar.raj@ti.com>
Cc: Albert ARIBAUD <albert.u.boot@aribaud.net>
Trivial fix.
Using __DATE__, __TIME__ would make the build non-deterministic.
If the code needs to refer to build date/time, use U_BOOT_DATE and
U_BOOT_TIME in include/generated/timestamp_autogenerated.h instead.
This commit has been imported from Linux Kernel,
which should be applied to U-Boot too:
commit fe7c36c7bde12190341722af69358e42171162f3
Author: Josh Triplett <josh@joshtriplett.org>
Date: Mon Dec 23 13:56:06 2013 -0800
Makefile: Build with -Werror=date-time if the compiler supports it
GCC 4.9 and newer have a new warning -Wdate-time, which warns on any use
of __DATE__, __TIME__, or __TIMESTAMP__, which would make the build
non-deterministic. Now that the kernel does not use any of those
macros, turn on -Werror=date-time if available, to keep it that way.
The kernel already (optionally) records this information at build time
in a single place; other kernel code should not duplicate that.
Signed-off-by: Josh Triplett <josh@joshtriplett.org>
drivers/net/Makefile
(trivial merge)
This reverts commit a8b993eb81c142a439c24b871a2317f765fe5397.
Commit a8b993eb claims it fixes u-boot.lds rule by replacing
$(call if_changed) with $(call filechk).
But the problem had already been fixed by commit 395e60cd
a few days before commit a8b993eb was posted.
There is no reason to apply commit a8b993eb. What is worse is
$(call filechk) is too strong to fix the problem and looks weird.
Date of the two patches:
[1] commit 395e60cdc292dc0183c6867d34b43f14a373df55
Author: Masahiro Yamada <yamada.m@jp.panasonic.com>
AuthorDate: Wed Apr 9 20:10:43 2014 +0900
Commit: Tom Rini <trini@ti.com>
CommitDate: Fri Apr 11 10:08:42 2014 -0400
replaces $(call if_changed) -> $(call if_changed_dep)
[2] commit a8b993eb81c142a439c24b871a2317f765fe5397
Author: Jon Loeliger <jon.loeliger@oracle.com>
AuthorDate: Tue Apr 15 16:09:37 2014 -0500
CommitDate: Fri Apr 18 16:14:16 2014 -0400
replaces $(call if_changed) -> $(call filechk)
A conflict must have happened when applying [2], but somehow it was
applied, sadly.
Cc: Jon Loeliger <jon.loeliger@oracle.com>
Cc: Andreas Bießmann <andreas.devel@googlemail.com>
Objective of this target to have concatenate binary having
- SPL binary in PBL command format
- U-boot binary
Signed-off-by: Prabhakar Kushwaha <prabhakar@freescale.com>
Reviewed-by: York Sun <yorksun@freescale.com>
