path: root/Makefile
2019-06-26rockchip: rk3399: Get bl31.elf via BL31Jagan Teki
Right now rockchip platform need to copy bl31.elf into u-boot source directory to make use of building u-boot.itb. So, add environment variable BL31 like Allwinner SoC so-that the bl31.elf would available via BL31. If the builds are not exporting BL31 env, the make_fit_atf.py explicitly create dummy bl31.elf in u-boot root directory to satisfy travis builds and it will show the warning on console as WARNING: BL31 file bl31.elf NOT found, resulting binary is non-functional WARNING: Please read Building section in doc/README.rockchip Note, that the dummy bl31 files were created during not exporting BL31 case would be removed via clean target in Makefile. Signed-off-by: Jagan Teki <jagan@amarulasolutions.com>
2019-06-26Makefile: clean bl31_*.binJagan Teki
Rockchip platform has its python script that would generate various bl31_*bin for creating u-boot.itb file by taking bl31.elf as input. These bl31_*.bin files are generated in u-boot root directory and have no rule to clean it up. so add support for it by adding in command entry of clean target in Makefile. Signed-off-by: Jagan Teki <jagan@amarulasolutions.com> Reviewed-by: Kever Yang <kever.yang@rock-chips.com>
2019-06-26Makefile: clean image.mapJagan Teki
binman tools for creating single image build will create image.map at the end, which has information about binman image node details. current u-boot, is unable to clean this image.map so add a command entry in clean target in Makefile. Signed-off-by: Jagan Teki <jagan@amarulasolutions.com> Reviewed-by: Kever Yang <kever.yang@rock-chips.com>
2019-06-20doc: Remove duplicated documentation directoryBreno Matheus Lima
Commit ad7061ed742e ("doc: Move device tree bindings documentation to doc/device-tree-bindings") moved all device tree binding documentation to doc/device-tree-bindings directory. The current U-Boot project still have two documentation directories: - doc/ - Documentation/ Move all documentation and sphinx files to doc directory so all content can be in a common place. Signed-off-by: Breno Lima <breno.lima@nxp.com>
2019-06-17Merge branch 'master' of git://git.denx.de/u-boot-spiTom Rini
- Drop zipitz2 board (Tom) - Add DEPRECATED option (Tom) - Mark legacy or non-dm drivers as DEPRECATED (Jagan)
2019-06-13Makefile: Trigger a warning for legcay spi driversJagan Teki
We have a warning text for non dm converted spi drivers, but the plan is to mark all these respective drivers with CONFIG_DEPRECATED. So, trigger a warning saying that these driver configurations and associated code will remove in v2019.07 (earlier plan is to remove it from v2019.04) Signed-off-by: Jagan Teki <jagan@amarulasolutions.com>
2019-06-13Makefile: Trigger a Warning if DEPRECATED is definedJagan Teki
If configured target has deprecated configs enabled, trigger a warning about this. Cc: Heinrich Schuchardt <xypron.glpk@gmx.de> Signed-off-by: Jagan Teki <jagan@amarulasolutions.com> [trini: Change from BROKEN to DEPRECATED] Signed-off-by: Tom Rini <trini@konsulko.com>
2019-06-11Merge tag 'u-boot-imx-20190612' of git://git.denx.de/u-boot-imxTom Rini
u-boot-imx-20190612 -------------------- - Board fixes: - imx6logic - wandboard - mx6sabre boots again - imx8qm_mek - pico-* boards - Toradex apalis / colibri - engicam imx6 (environment) - KP MX53 - opos6ul - Switch to DM: - vining2000 - dh MX6 - Toradex colibri i.MX7 - Novena - Security : fix CSF size for HAB - Other: - imx: fix building for i.mx8 without spl - pcie and switch to DM mx6sabreauto: Enable SPL SDP support
2019-06-11arm, imx, Makefile: fix u-boot-dtb.imx build in CONFIG_MULTI_DTB_FIT caseHeiko Schocher
in case CONFIG_MULTI_DTB_FIT is set and u-boot-dtb.imx image is build, currently u-boot-dtb.bin is used for generating the u-boot-dtb.imx binary, which is wrong, as it contains only a dtb blob not the fit.blob Use instead the u-boot-fit-dtb.bin for generating u-boot-dtb.imx which contains the fit.blob. Signed-off-by: Heiko Schocher <hs@denx.de>
2019-06-10Prepare v2019.07-rc4Tom Rini
2019-06-07spl: add overall SPL size checkSimon Goldschmidt
This adds a size check for SPL that can dynamically check generated SPL binaries (including devicetree) for a size limit that ensures this image plus global data, heap and stack fit in initial SRAM. Since some of these sizes are not available to make, a new host tool 'spl_size_limit' is added that dumps the resulting maximum size for an SPL binary to stdout. This tool is used in toplevel Makefile to implement the size check on SPL binaries. Signed-off-by: Simon Goldschmidt <simon.k.r.goldschmidt@gmail.com>
2019-06-07configs: define CONFIG_SPL_SIZE_LIMITHeinrich Schuchardt
A new configuration variable CONFIG_SPL_SIZE_LIMIT is introduced to define the board specific maximum size for the SPL file. Use Makefile function size_check() to implement the test. Depending on the size of CONFIG_SPL_SIZE_LIMIT an error like the following is thrown: spl/u-boot-spl.bin exceeds file size limit: limit: 30720 bytes actual: 33426 bytes excess: 2706 bytes make: *** [Makefile:1663: spl/u-boot-spl.bin] Error 1 Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de>
2019-06-07imx: move BOARD_SIZE_CHECK to main MakefileHeinrich Schuchardt
We currently have duplicate definitions for BOARD_SIZE_CHECK in Makefile and arch/arm/mach-imx/Makefile. Move the board size check from arch/arm/mach-imx/Makefile to Makefile. Depending on the value of CONFIG_BOARD_SIZE_LIMIT an error like an error like the following is thrown: u-boot-dtb.imx exceeds file size limit: limit: 503696 bytes actual: 509720 bytes excess: 6024 bytes make: *** [Makefile:1051: u-boot-dtb.imx] Error 1 Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de> Reviewed-by: Fabio Estevam <festevam@gmail.com>
2019-06-07Makefile: reusable function for BOARD_SIZE_CHECKHeinrich Schuchardt
Carve out function size_check from macro BOARD_SIZE_CHECK. This will allow us to reuse the function for other file size checks. Depending on the value of CONFIG_BOARD_SIZE_LIMIT an error like the following is thrown: u-boot-dtb.img exceeds file size limit: limit: 409516 bytes actual: 444346 bytes excess: 34830 bytes make: *** [Makefile:1212: u-boot-dtb.img] Error 1 Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de>
2019-05-27Prepare v2019.07-rc3Tom Rini
2019-05-21ARM: rmobile: Add recovery SPL for R-Car Gen3Marek Vasut
Build an SPL which can be started via SCIF download mode on R-Car Gen3 and allows loading and executing U-Boot uImage with the next stage code. This is also useful for starting e.g. ATF BL2, which inits the hardware and returns to the U-Boot SPL, which can then load e.g. U-Boot proper. The H3, M3-W, M3-N SoCs have plenty of SRAM for storing the U-Boot SPL while the payload, e.g. ATF BL2, executes, so there is no problem here. However, E3 and D3 have much less SRAM, hence the loader uses a trick where it copies itself beyond the area used by BL2 and executes from there. That area is 32kiB large and not enough to hold U-Boot SPL, BSS, stack and malloc area, so the later two are placed at +0x4000 offset from start of SRAM, another area not used by ATF BL2. To make things even more complicated, the SCIF loader cannot load to the upper 32kiB of the SRAM directly, hence the copying approach. Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com> Cc: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2019-05-19Revert "Makefile: Prioritize external dtb if defined"Tom Rini
This is causing unexpected size growth in the normal case and is likely to have been mis-applied by myself. This reverts commit 3eaf6dcd9362b56e3217559401287dd8fa35b5b2. Signed-off-by: Tom Rini <trini@konsulko.com>
2019-05-18Makefile: Prioritize external dtb if definedMichal Simek
Prioritize external dtb if its passed via EXT_DTB than the dtb that was built in the tree. With this patch it appends the specified external dtb to the u-boot image. Signed-off-by: Michal Simek <michal.simek@xilinx.com> Signed-off-by: Siva Durga Prasad Paladugu <siva.durga.paladugu@xilinx.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2019-05-15Prepare v2019.07-rc2Tom Rini
2019-05-09Set time and umask on fit-dtb.blob to ensure reproducibile builds.Vagrant Cascadian
Support for compressed fit-dtb.blob was added in: commit 95f4bbd581cf ("lib: fdt: Allow LZO and GZIP DT compression in U-Boot") When building compressed (lzop, gzip) fit-dtb.blob images, the compression tool may embed the time or umask in the image. Work around this by manually setting the time of the source file using SOURCE_DATE_EPOCH and a hard-coded 0600 umask. With gzip, this could be accomplished by using -n/--no-name, but lzop has no current workaround: https://bugs.debian.org/896520 This is essentially the same fix applied to multi-dtb fit SPL images in: commit 8664ab7debab ("Set time and umask on multi-dtb fit images to ensure reproducibile builds.") Signed-off-by: Vagrant Cascadian <vagrant@reproducible-builds.org>
2019-05-09Remove fit-dtb.blob* in clean target.Vagrant Cascadian
Support for compressed fit-dtb.blob was added in: commit 95f4bbd581cf ("lib: fdt: Allow LZO and GZIP DT compression in U-Boot") Adjust Makefile to also clean compressed blobs. Signed-off-by: Vagrant Cascadian <vagrant@reproducible-builds.org>
2019-05-09dm: MIGRATION: Add migration plan for WDT (DM watchdog support)Stefan Roese
As much of the watchdog system has been migrated to DM now, formalize a deadline for migration. Please note that the old CONFIG_HW_WATCHDOG macro should be removed completely at some point. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Michal Simek <michal.simek@xilinx.com> Cc: Simon Glass <sjg@chromium.org> Cc: Tom Rini <trini@konsulko.com>
2019-05-08x86: Allow 16-bit init to be in TPLSimon Glass
At present we support having 16-bit init be in SPL or U-Boot proper, but not TPL. Add support for this so that TPL can boot. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2019-05-06ddr: altera: Compile ALTERA SDRAM in SPL onlyLey Foon Tan
Compile ALTERA_SDRAM driver in SPL only. Rename ALTERA_SDRAM to SPL_ALTERA_SDRAM. Signed-off-by: Ley Foon Tan <ley.foon.tan@intel.com>
2019-04-29Prepare v2019.07-rc1Tom Rini
2019-04-22Add target to generate initial environmentStefano Babic
The initial environment is linked to the u-boot binary. Modifying the environment from User Space with the env tools requires that the tools are always built together with the bootloader to be sure that they contain the initial environment in case no environment is stored into persistent storage or when a board boots with just the default environment. This makes difficult for distros to provide a general package to access the environment. A simpler way is if the tools are generic for all boards and a configuration file is given to provide the initial environment. The patch just generates the initial environment by extracting it from the compiled object. This file can then be used for tools in user space to initialize the environment. Signed-off-by: Stefano Babic <sbabic@denx.de>
2019-04-16Makefile: Prioritize external dtb if definedMichal Simek
2019-04-12Makefile: Correct logic for DM_SCSI + unconverted drivers checkStefan Roese
When checking for boards that are enabling a SATA driver that isn't converted to DM yet we need to be sure to not also trip over boards that do set CONFIG_AHCI & CONFIG_BLK by itself, as that is not a bug. This was detected when converting the Armada XP SATA driver sata_mv.c to DM with AHCI & BLK support. This warning is still printed without this patch applied here. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Simon Glass <sjg@chromium.org> Cc: Tom Rini <trini@konsulko.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2019-04-11Merge branch 'master' of git://git.denx.de/u-boot-shTom Rini
- Various rmobile fixes
2019-04-09lib: fdt: Allow LZO and GZIP DT compression in U-BootMarek Vasut
Add required Kconfig symbols, Makefile bits and macro fixes in a few places to support LZO and DT compression in U-Boot. This can save a lot of space with multi-DTB fitImages. Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com> Cc: Nobuhiro Iwamatsu <iwamatsu@nigauri.org> Cc: Simon Glass <sjg@chromium.org> Cc: Tom Rini <trini@konsulko.com> Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com>
2019-04-09Makefile: Add Kconfig option CONFIG_SPL_IMAGE to select the SPL binaryStefan Roese
This patch adds the CONFIG_SPL_IMAGE option to select the SPL image that shall be used to generate the combined SPL + U-Boot image. The default value is the current value "spl/u-boot-spl.bin". This patch also sets CONFIG_SPL_IMAGE to "spl/boot.bin" for AT91 targets which use SPL NAND support (boot from NAND). For these build targets the combined image "u-boot-with-spl.bin" is now automatically generated and can be programmed into NAND as one single image (vs. SPL image and U-Boot as 2 separate images). Signed-off-by: Stefan Roese <sr@denx.de> Cc: Heiko Schocher <hs@denx.de> Cc: Andreas Bießmann <andreas@biessmann.org> Cc: Eugen Hristev <eugen.hristev@microchip.com>
2019-04-08Prepare v2019.04Tom Rini
2019-04-03fix compile error on macOS Mojave默默
2019-03-22Makefile: Do not pass -E to mkimage when SPL has full fitImage supportMarek Vasut
When the SPL has full fitImage support, do not generate fitImage with external data. The full fitImage code assumes the entire fitImage is loaded in RAM, and the SPL uses fdt_totalsize() to determine the size of the whole fitImage, which can not work with external data. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Tom Rini <trini@konsulko.com>
2019-03-18Prepare v2019.04-rc4Tom Rini
2019-03-04Prepare v2019.04-rc4Tom Rini
2019-02-18Prepare v2019.04-rc2Tom Rini
2019-02-07Prepare v2019.04-rc1Tom Rini
2019-01-30Makefile: remove generated font filesHeinrich Schuchardt
If `make mrproper` does not delete the generated drivers/video/fonts/*.S files a following `make tests` fails. Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de> Reviewed-by: Anatolij Gustschin <agust@denx.de> Reviewed-by: Simon Glass <sjg@chromium.org>
2019-01-30Merge tag 'u-boot-imx-20190129' of git://git.denx.de/u-boot-imxTom Rini
For 2019.04
2019-01-28imx: build flash.bin for i.MX8Peng Fan
Build flash.bin for i.MX8 when SPL enabled. Signed-off-by: Peng Fan <peng.fan@nxp.com>
2019-01-26Makefile: have "make distclean" remove CHANGELOGRobert P. J. Day
Ensure that "make distclean" deletes an existing CHANGELOG file. Signed-off-by: Robert P. J. Day <rpjday@crashcourse.ca>
2019-01-18mkimage: fixup CONFIG_FIT_EXTERNAL_OFFSETPatrick Wildt
The last parameter is expected to be the imagefile. Since -E is a flag having the output name before -p will make mkimage ignore the external offset option. Signed-off-by: Patrick Wildt <patrick@blueri.se>
2019-01-15Makefile: run CONFIG_BOARD_SIZE_LIMIT against .imgSimon Goldschmidt
With the current Makefile, CONFIG_BOARD_SIZE_LIMIT is used to check the U-Boot binary without devicetree only. This produces wrong results when OF_SEPARATE is used. To fix this, run the CONFIG_BOARD_SIZE_LIMIT check on all .img binaries as well. Signed-off-by: Simon Goldschmidt <simon.k.r.goldschmidt@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2019-01-15kbuild: fix parallel build race caused by u-boot.cfg regenerationMasahiro Yamada
Multiple people have reported intermittent build failure in parallel building. Kever Yang reported this issue some time ago [1], but I could not get enough clue at that time. This time, Richard Purdie provided a full build log [2], which was very helpful for me to root-cause it. The cause of the problem is commit 0d982c585330 ("Makefile: add dependencies to regenerate u-boot.cfg when lost"). That commit added the 'cfg' as the prerequisite of the 'all' target, so the parallel build tries to run it simultaneously, then regenerates a symlink while building objects. When u-boot.cfg is accidentally lost, let's rebuild it before descending into any subdirectories. Also, what is annoying is u-boot.cfg is currently regenerated every time since it depends on FORCE. We can get rid of all the prerequisites of u-boot.cfg because u-boot.cfg is rebuilt anyway as the byproduct of auto.conf when a user updates the .config file. [1] https://lists.denx.de/pipermail/u-boot/2018-June/330341.html [2] https://autobuilder.yoctoproject.org/typhoon/#/builders/65/builds/160/steps/7/logs/step1b Fixes: 0d982c585330 ("Makefile: add dependencies to regenerate u-boot.cfg when lost") Reported-by: Kever Yang <kever.yang@rock-chips.com> Reported-by: Richard Purdie <richard.purdie@linuxfoundation.org> Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2019-01-14Prepare v2019.01Tom Rini
2019-01-11Merge branch 'master' of git://git.denx.de/u-boot-usbTom Rini
2019-01-10usb: Make compiling gadget support optionalJean-Jacques Hiblot
There is no need to compile and include this code if it is not used. CONFIG_USB_GADGET can be used for the purpose. Signed-off-by: Jean-Jacques Hiblot <jjhiblot@ti.com>
2019-01-10Merge tag 'u-boot-imx-20190110' of git://git.denx.de/u-boot-imxTom Rini
Fixes for 2019.01
2019-01-09imx: Add Makefile dependency for mkimage_fit_atf.shChris Spencer
The mkimage_fit_atf.sh SPL FIT generator script requires u-boot-nodtb.bin, but this was not enforced by the Makefile. This could cause the generator script to be executed before u-boot-nodtb.bin has been created. Signed-off-by: Chris Spencer <christopher.spencer@sea.co.uk> Cc: NXP i.MX U-Boot Team <uboot-imx@nxp.com>
